9a91646be6446d6746b9362782b88521
4b899e54
4b899e54
doc: module2 exo2 final
572f5934
87 additions
3 deletions
+87
-3
exercice.ipynb
module2/exo2/exercice.ipynb
+87
-3
4b899e54
"cells": [],
"cells": [
"# Savoir faire un calcul simple soi-même"
"## Données d'entrée"
"Les données d'entrée sont les suivantes :"
"execution_count": 1,
"data = [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]"
"## Calculs statistiques"
"Le but est de faire des calculs statistiques sur ces valeurs (moyenne et l'écart-type, le min, la médiane et le max)"
"execution_count": 3,
"Moyenne: 14.113000000000001\n",
"Écart-type: 4.334094455301447\n",
"Min: 2.8\n",
"Médiane: 14.5\n",
"Max: 23.4\n"
"import numpy as np\n",
"mean = np.mean(data)\n",
"std_dev = np.std(data, ddof=1)\n",
"minimum = np.min(data)\n",
"median = np.median(data)\n",
"maximum = np.max(data)\n",
"print(f\"Moyenne: {mean}\")\n",
"print(f\"Écart-type: {std_dev}\")\n",
"print(f\"Min: {minimum}\")\n",
"print(f\"Médiane: {median}\")\n",
"print(f\"Max: {maximum}\")"
"execution_count": null,
"source": []
"kernelspec": {
"display_name": "Python 3",
@@ -16,10 +101,9 @@
"name": "python",
"pygments_lexer": "ipython3",
"version": "3.6.
3
"version": "3.6.
4
"nbformat": 4,
"nbformat_minor": 2
