@@ -34,13 +34,13 @@ Voici un aperçu rapide de la syntaxe Markdown repris d'une
<ahref="https://guides.github.com/features/mastering-markdown/">présentation de Github</a> ainsi que de celles d'<ahref="http://csrgxtu.github.io/2015/03/20/Writing-Mathematic-Fomulars-in-Markdown/">Archer Reilly</a> et de <ahref="http://www.statpower.net/Content/310/R%20Stuff/SampleMarkdown.html">James
We provide here only instructions for debian-based distributions. Feel
free to contribute to this document to provide up-to-date information
@@ -73,9 +73,9 @@ Today, the stable versions of the most common distributions provide
recent enough versions of emacs and org-mode:
</p>
<ulclass="org-ul">
<li>Debian (stretch) ships with <ahref="https://packages.debian.org/stretch/emacs25">emacs 25.1</a> and <ahref="https://packages.debian.org/stretch/org-mode">org-mode 9.0.3</a></li>
<li>Ubuntu (bionic 18.04) ships with <ahref="https://packages.ubuntu.com/bionic/emacs25">emacs 25.2</a> and <ahref="https://packages.ubuntu.com/bionic/org-mode">org-mode 9.1.6</a></li>
<li>Ubuntu (artful 17.04) ships with <ahref="https://packages.ubuntu.com/artful/emacs25">emacs 25.2</a> and <ahref="https://packages.ubuntu.com/artful/org-mode">org-mode 9.0.9</a></li>
<listyle="margin-bottom:0;">Debian (stretch) ships with <ahref="https://packages.debian.org/stretch/emacs25">emacs 25.1</a> and <ahref="https://packages.debian.org/stretch/org-mode">org-mode 9.0.3</a></li>
<listyle="margin-bottom:0;">Ubuntu (bionic 18.04) ships with <ahref="https://packages.ubuntu.com/bionic/emacs25">emacs 25.2</a> and <ahref="https://packages.ubuntu.com/bionic/org-mode">org-mode 9.1.6</a></li>
<listyle="margin-bottom:0;">Ubuntu (artful 17.04) ships with <ahref="https://packages.ubuntu.com/artful/emacs25">emacs 25.2</a> and <ahref="https://packages.ubuntu.com/artful/org-mode">org-mode 9.0.9</a></li>
</ul>
<p>
If your distribution is older than this, well, it may be a good time
<li><ahref="org/journal.html#MissingReference">Common and step-by-step emacs shortcuts for our <i>reproducible research</i> configuration</a></li>
<li><ahref="https://www.gnu.org/software/emacs/refcards/pdf/refcard.pdf">The official GNU emacs refcard</a></li>
<li>Two graphical cheat-sheats by Sacha Hua on <ahref="http://sachachua.com/blog/wp-content/uploads/2013/05/How-to-Learn-Emacs-v2-Large.png">how to learn emacs</a> and on
<listyle="margin-bottom:0;"><ahref="org/journal.html#MissingReference">Common and step-by-step emacs shortcuts for our <i>reproducible research</i> configuration</a></li>
<listyle="margin-bottom:0;"><ahref="https://www.gnu.org/software/emacs/refcards/pdf/refcard.pdf">The official GNU emacs refcard</a></li>
<listyle="margin-bottom:0;">Two graphical cheat-sheats by Sacha Hua on <ahref="http://sachachua.com/blog/wp-content/uploads/2013/05/How-to-Learn-Emacs-v2-Large.png">how to learn emacs</a> and on
<ahref="http://sachachua.com/blog/wp-content/uploads/2013/08/20130830-Emacs-Newbie-How-to-Learn-Emacs-Keyboard-Shortcuts.png">how to learn emacs shortcuts</a>.</li>
<li><ahref="org/journal.html#MissingReference">Common and step-by-step org-mode shortcuts for our <i>reproducible research</i> configuration</a></li>
<li><ahref="https://orgmode.org/worg/orgcard.html">The official org-mode refcard</a></li>
<li><ahref="https://orgmode.org/worg/dev/org-syntax.html">The official description of the org-mode syntax</a> and a <ahref="https://gist.github.com/hoeltgman/3825415">relatively concise description of the org-mode syntax</a>.</li>
<listyle="margin-bottom:0;"><ahref="org/journal.html#MissingReference">Common and step-by-step org-mode shortcuts for our <i>reproducible research</i> configuration</a></li>
<listyle="margin-bottom:0;"><ahref="https://orgmode.org/worg/orgcard.html">The official org-mode refcard</a></li>
<listyle="margin-bottom:0;"><ahref="https://orgmode.org/worg/dev/org-syntax.html">The official description of the org-mode syntax</a> and a <ahref="https://gist.github.com/hoeltgman/3825415">relatively concise description of the org-mode syntax</a>.</li>
<listyle="margin-bottom:0;"><ahref="https://github.com/dfeich/org-babel-examples">Many examples illustrating the use of different languages in org-mode</a></li>
The following <ahref="https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/">webpage</a> lists several Jupyter tricks (in particular, it
illustrates many <code>Ipython magic</code> commands) that should improve your
@@ -45,9 +45,9 @@ Today, the stable versions of the most common distributions provide
</p>
<ulclass="org-ul">
<li>Debian (stretch) ships with <ahref="https://packages.debian.org/stretch/r-base">R 3.3.3-1</a>, <ahref="https://packages.debian.org/stretch/r-cran-knitr">knitr 1.15.1</a>, and <ahref="https://packages.debian.org/stretch/r-cran-ggplot2">ggplot 2.2.1</a></li>
<li>Ubuntu (bionic 18.04) ships with <ahref="https://packages.ubuntu.com/bionic/r-base">R 3.4.4</a>, and <ahref="https://packages.ubuntu.com/bionic/r-cran-knitr">knitr 1.17</a>, and <ahref="https://packages.ubuntu.com/bionic/r-cran-ggplot2">ggplot 2.2.1</a></li>
<li>Ubuntu (artful 17.04) ships with <ahref="https://packages.ubuntu.com/artful/r-base">R 3.4.2</a>, and <ahref="https://packages.ubuntu.com/artful/r-cran-knitr">knitr 1.15</a>, and <ahref="https://packages.ubuntu.com/artful/r-cran-ggplot2">ggplot 2.2.1</a></li>
<listyle="margin-bottom:0;">Debian (stretch) ships with <ahref="https://packages.debian.org/stretch/r-base">R 3.3.3-1</a>, <ahref="https://packages.debian.org/stretch/r-cran-knitr">knitr 1.15.1</a>, and <ahref="https://packages.debian.org/stretch/r-cran-ggplot2">ggplot 2.2.1</a></li>
<listyle="margin-bottom:0;">Ubuntu (bionic 18.04) ships with <ahref="https://packages.ubuntu.com/bionic/r-base">R 3.4.4</a>, and <ahref="https://packages.ubuntu.com/bionic/r-cran-knitr">knitr 1.17</a>, and <ahref="https://packages.ubuntu.com/bionic/r-cran-ggplot2">ggplot 2.2.1</a></li>
<listyle="margin-bottom:0;">Ubuntu (artful 17.04) ships with <ahref="https://packages.ubuntu.com/artful/r-base">R 3.4.2</a>, and <ahref="https://packages.ubuntu.com/artful/r-cran-knitr">knitr 1.15</a>, and <ahref="https://packages.ubuntu.com/artful/r-cran-ggplot2">ggplot 2.2.1</a></li>
</ul>
<p>
<h2id="orgabc8626">Rstudio and git/github/gitlab</h2>
<divclass="outline-text-2"id="text-orgabc8626">
<blockquote>
<p>
We may want to redo a screencast in French for this
</p>
</blockquote>
<ulclass="org-ul">
<li><ahref="https://www.rstudio.com/resources/webinars/rstudio-essentials-webinar-series-managing-part-2/">This video on using git/githugb/gitlab from Rstudio</a> (starting at time 9:09)</li>
<listyle="margin-bottom:0;"><ahref="https://www.rstudio.com/resources/webinars/rstudio-essentials-webinar-series-managing-part-2/">This video on using git/githugb/gitlab from Rstudio</a> (starting at time 9:09)</li>
</ul>
<p>
@@ -197,26 +197,26 @@ Alternatively, we can point to:
<listyle="margin-bottom:0;"><ahref="https://github.com/rstudio/cheatsheets/raw/master/data-visualization-2.1.pdf">data visualization with ggplot2</a>,</li>
<listyle="margin-bottom:0;"><ahref="https://github.com/rstudio/cheatsheets/raw/master/data-transformation.pdf">data transformation with dplyr</a></li>
</ul>
<p>
@@ -224,10 +224,10 @@ In case it helps, here are some (sometimes outdated) French versions
<li><ahref="https://github.com/rstudio/cheatsheets/raw/master/translations/french/ggplot2-french-cheatsheet.pdf">Visualisation de données avec ggplot2</a></li>
<li><ahref="https://github.com/rstudio/cheatsheets/raw/master/translations/french/data-wrangling-french.pdf">Transformation de données avec dplyr</a></li>
<li><ahref="https://www.fun-mooc.fr/c4x/UPSUD/42001S02/asset/RMarkdown.pdf">Un court document sur R Markdown</a></li>
<listyle="margin-bottom:0;"><ahref="https://github.com/rstudio/cheatsheets/raw/master/translations/french/ggplot2-french-cheatsheet.pdf">Visualisation de données avec ggplot2</a></li>
<listyle="margin-bottom:0;"><ahref="https://github.com/rstudio/cheatsheets/raw/master/translations/french/data-wrangling-french.pdf">Transformation de données avec dplyr</a></li>
<listyle="margin-bottom:0;"><ahref="https://www.fun-mooc.fr/c4x/UPSUD/42001S02/asset/RMarkdown.pdf">Un court document sur R Markdown</a></li>
