Commit 22674941 authored by Laurence Farhi's avatar Laurence Farhi
parents 6f231493 17ba538f
......@@ -50,6 +50,10 @@
;; (setenv "JVM_OPTS" (concat "-Dhttp.proxyHost=" proxy-name
;; " -Dhttp.proxyPort=" proxy-port)))
(package-initialize)
(add-to-list 'package-archives
'("melpa-stable" . "http://stable.melpa.org/packages/"))
(require 'org)
(require 'ess-site)
......@@ -74,6 +74,13 @@ document, simply =M-x org-babel-tangle=.
* Package sources
** Use melpa-stable
#+BEGIN_SRC emacs-lisp :tangle init.el
#+END_SRC
* Loading files:
** Loading babel: :ARNAUD:
#+begin_src emacs-lisp :tangle init.el
# -*- coding: utf-8 -*-
# -*- mode: org -*-
#+TITLE: Org document examples
#+STARTUP: overview indent inlineimages logdrawer
#+LANGUAGE: en
In the MOOC video, I quickly demo how org-mode can be used in various
contexts. Here are the (sometimes trimmed) corresponding
org-files. These documents depend on many other external data files
and are not meant to lead to reproducible documents but it will give
you an idea of how it can be organized:
1. [[file:journal.org][journal.org]]: an excerpt (I've only left a few code samples and links
to some resources on R, Stats, ...) from my own journal. This is a
personal document where everything (meeting notes, hacking, random
thoughts, ...) goes by default. Entries are created with the =C-c c=
shortcut.
2. [[file:labbook_single.org][labbook_single.org]]: this is an excerpt from the laboratory notebook
[[https://cornebize.net/][Tom Cornebize]] wrote during his Master thesis internship under my
supervision. This a personal labbook. I consider this notebook to be
excellent and was the ideal level of details for us to communicate
without any ambiguity and for him to move forward with confidence.
3. [[file:paper.org][paper.org]]: this is an ongoing paper based on the previous labbook of
Tom Cornebize. As such it is not reproducible as there are hardcoded
paths and uncleaned dependencies but writing it from the labbook was
super easy as we just had to cut and paste the parts we
needed. What may be interesting is the organization and the org
tricks to export to the right LaTeX style. As you may notice, in
the end of the document, there is a commented section with emacs
commands that are automatically executed when opening the file. It
is an effective way to depend less on the =.emacs/init.el= which is
generally customized by everyone.
4. [[file:labbook_several.org][labbook_several.org]]: this is a labbook for a specific project shared
by several persons. As a consequence it starts with information
about installation, common scripts, has section with notes about all
our meetings, a section with information about experiments and an
other one about analysis. Entries could have been labeled by who
wrote them but there were only a few of us and this information was
available in git so we did not bother. In such labbook, it is common
to find annotations indicating that such experiment was =:FLAWED:= as
it had some issues.
5. [[file:technical_report.org][technical_report.org]]: this is a short technical document I wrote
after a colleague sent me a PDF describing an experiment he was
conducting and asked me about how reproducible I felt it was. It
turned out I had to cut and paste the C code from the PDF, then
remove all the line numbers and fix syntax, etc. Obviously I got
quite different performance results but writing everything in
org-mode made it very easy to generate both HTML and PDF and to
explicitly explain how the measurements were done.
This diff is collapsed.
