The proxyPassword will be stored unencrypted in your ~.gitconfig~ file,
which you may not want. In that case, remove it from the URL and you
will be prompted for it every time it is needed.
** Configuring your password on GitLab
** Changing the default password on GitLab
1. Access [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/xblock/block-v1:inria+41016+session01bis+type@lti+block@05a0ce425f1741e5bee5049040f70529/handler/preview_handler][GitLab]]. /Note: You have to access Gitlab from the FUN
*Warning (Jupyter users) :* changing your default Gitlab password will prevent you from commiting in Jupyter. You will have to do the extra step of changing your Jupyter =~/.git-credentials=
1. Get your default password using the [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/jump_to_id/7508aece244548349424dfd61ee3ba85][Gitlab credentials retrieval tool]
2. Access [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/xblock/block-v1:inria+41016+session01bis+type@lti+block@05a0ce425f1741e5bee5049040f70529/handler/preview_handler][GitLab]]. /Note: You have to access Gitlab from the FUN
platform otherwise you may get a 405 error/ /when trying to direcly
open https://app-learninglab.inria.fr/gitlab/users/sign_in/.
#+BEGIN_CENTER
#+BEGIN_CENTER
[[file:gitlab_images/erreur405.png]]
#+END_CENTER
#+END_CENTER
2. Click on =Sign in:=
3. Click on =Sign in:= or using your default credentials
#+BEGIN_CENTER
#+BEGIN_CENTER
[[file:gitlab_images/projects.png]]
[[file:gitlab_images/signin.png]]
#+END_CENTER
#+END_CENTER
The long and uggly character sequence, which is here replaced by =xxx=
is your GitLab login/id. You'll need to use it when trying to
propagate some modifications from your computer to GitLab.
3. To defind your password, you should go in =settings=:
4. Go to =Account > Settings > Password= and define your password using your default password :
#+BEGIN_CENTER
#+BEGIN_CENTER
[[file:gitlab_images/settings.png]]
#+END_CENTER
4. Then, go to the =profile= tab to define a valid email address:
#+BEGIN_CENTER
[[file:gitlab_images/profile.png]]
#+END_CENTER
You will then receive a email with a link to open to confirm your
email address is correct. Just open it.
5. Once your email address is validated, it will appear as =verified= and
as your =main address= in the =Emails= tab:
#+BEGIN_CENTER
[[file:gitlab_images/mail.png]]
#+END_CENTER
6. You will then finally be able to click on the =I forgot my password=
button from the =password= tab:
[[file:gitlab_images/password.png]]
#+END_CENTER
You will then receive an email allowing you to reset your GitLab
password.
** Remembering your password locally
If you clone your repos by simply pasting the GitLab URL, you will be
prompted for your login and your password every time you want to
