7fd3cd06
7fd3cd06
Cosmetics
5e828909
12 additions
11 deletions
+12
-11
emacs_newbie.org
module2/ressources/emacs_newbie.org
+12
-11
7fd3cd06
@@ -11,7 +11,7 @@ the screenshots in this demo are done under the Windows operating
system but similar results should be obtained on any OS.
* First steps with Emacs as a computationnal environment
Run Emacs
A first org-mode document
- Launch emacs
- Launch emacs
#+BEGIN_CENTER
#+BEGIN_CENTER
[[file:emacs_orgmode_images/emacs.png]]
@@ -59,13 +59,13 @@ system but similar results should be obtained on any OS.
If you do not like this behavior, you can edit the =init.el= file and
replace =(org-babel-temp-file \"figure\" \".png\")= by
=\"D:/temp/figure.png\"= or whichever location/name you prefer (both
for =<R=
et
=<PP=).
for =<R=
=<PP=).
** Running
p
ython code
** Running
P
ython code
- You may want to read the [[https://orgmode.org/worg/org-contrib/babel/languages/ob-doc-python.html][Python Source Code Blocks in Org Mode]]
webpage for more examples
- The =<p= + =tab= will insert a
p
ython block in a /non-session/ mode. This
P
means that a new
p
ython shell will be started for this block and
means that a new
P
that variables will not be shared between blocks. Again, the code
is executed with the =C-c C-c= shortcut.
#+BEGIN_CENTER
#+BEGIN_CENTER
@@ -80,20 +80,20 @@ system but similar results should be obtained on any OS.
# [[file:emacs_orgmode_images/python3.png]]
# #+END_CENTER
# #+END_CENTER
# Then try to follow the steps in the installation section.
- The =<P= + =tab= will insert a
p
ython block in /session/ mode. This
P
allows to keep variables alive from a block to an other. Internally,
emacs will have a buffer with a
p
ython session running. Again, the
P
code is executed with the =C-c C-c= shortcut.
#+BEGIN_CENTER
#+BEGIN_CENTER
[[file:emacs_orgmode_images/python2.png]]
#+END_CENTER
#+END_CENTER
- The =<PP= + =tab= will insert a
p
ython block in /session/ mode and ready
P
to generate graphics.
#+BEGIN_CENTER
#+BEGIN_CENTER
[[file:emacs_orgmode_images/python4.png]]
#+END_CENTER
#+END_CENTER
If this fails, try to update the
p
ython =numpy= library, for exemple
P
like this in a dos/shell command:
python -m pip install -U numpy
@@ -119,12 +119,13 @@ system but similar results should be obtained on any OS.
#+BEGIN_CENTER
#+BEGIN_CENTER
[[file:emacs_orgmode_images/org_mode.png]]
#+END_CENTER
#+END_CENTER
When you are done
s
, simply hit =C-c C-c= to save your modifications
When you are done, simply hit =C-c C-c= to save your modifications
and close the mini-buffer.
** Fast editing of an org document
- It is common when taking notes in a brainstorming session to have to
clean and reorganize them. The =Alt= + =\leftarrow= or =Alt= +
=\rightarrow= will allow you to shift items to the left or to the right.
right. Likewise, entries can be moved up or down.
- Org-mode shortcuts are actually much more intuitive than prehistoric
emacs shortcuts. You'll quickly get use to it. Again, have a look to
the first entry of the =journal.org= file we gave you and which
