f6462162
f6462162
version anglaise de l'exercice 5 en Python
d89e2b92
222 additions
+222
+222
f6462162
#+TITLE: Analyse du risque de défaillance des joints toriques de la navette Challenger
held a three-hour teleconference between the
Morton Thiokol (manufacturer of one of the engines) and NASA. The
0°C) on the success of the flight and in particular on the performance of the
O-rings used in motors. Indeed, no test
The following study therefore takes up some of the analyses carried out in this study
night and whose objective was to assess the potential influence of
the temperature and pressure to which the seals are subjected
torics on their probability of malfunction. To do this, we
have the results of the experiments carried out by the engineers
of NASA during the 6 years preceding the launch of the shuttle
* Chargement des données
So we start by loading this data:
The data set shows us the date of the test, the number of joints
number of identified dysfunctions.
* Graphical data inspection
Flights where no incidents are found that do not provide any information
on the influence of temperature or pressure on the
dysfunctions, we focus on experiences where in the
at least one seal was defective.
All right, we have a high temperature variability but
At first sight, it's not obvious but good, let's try it anyway
to estimate the impact of temperature $t$ on the probability of
malfunctions of a seal.
Suppose that each of the 6 toroidal seals is damaged with the same
probability and independently of the others and that this probability does not
depends only on the temperature. If we note $p(t)$ this probability, the
number of joints $D$ malfunctioning when the flight is performed at
temperature $t$ follows a binomial law of parameter $n=6$ and
* Estimation of the probability of malfunctioning toric seals
The expected temperature on take-off day is 31°F. Let's try to
estimate the probability of malfunctioning toric seals at
toric seals. It will be about 0.2, as in the tests
where we had a failure of at least one joint. Let's get back to the subject
to the set of initial data to estimate the probability of
failure of a seal:
This probability is therefore about $p=0.065$, knowing that there is
a primary seal a secondary seal on each of the three parts of the
launcher, the probability of failure of the two joints of a launcher
is $p^2 \approx 0.00425$. The probability of failure of one of the
so the thrower is $1-(1-p^2)^3 \approximately 1.2%$. It would really be
no luck.... Everything is under control, so the takeoff can have
Only the next day, the Challenger shuttle will explode and take away
with her seven crew members. Public opinion is
affected and in the subsequent investigation, the reliability of the
toric seals will be directly implicated. Beyond the problems
of internal communication at NASA, which have a lot to do with this
fiasco, the previous analysis includes (at least) a small
problem.... Can you find it? You are free to modify this
analysis and to look at this dataset from all angles in order to
to explain what's wrong.
