no commit message
parent c5dae633
"cells": [
"execution_count": null,
"# On the computation of $\\pi$"
"## Asking the maths library\n",
"execution_count": 2,
......@@ -18,6 +37,16 @@
"print(pi)"
"## Buffon's needle\n",
"Applying the method of [Buffon's needle](https://en.wikipedia.org/wiki/Buffon%27s_needle_problem), we get the __approximation__"
"execution_count": 4,
......@@ -43,6 +72,16 @@
"A method that is easier to understand and does not make use of the $\\sin$ function is based on the fact that if $X\\sim U(0,1)$ and $Y\\sim U(0,1)$, then $P[X^2+Y^2\\leq 1] = \\pi/4$ (see [\"Monte Carlo method\" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:"
"execution_count": 5,
......@@ -79,6 +118,24 @@
"ax.set_aspect('equal')"
"execution_count": 7,
"ename": "SyntaxError",
"evalue": "invalid syntax (<ipython-input-7-46b60a496a9b>, line 1)",
"output_type": "error",
"traceback": [
"\u001b[0;36m File \u001b[0;32m\"<ipython-input-7-46b60a496a9b>\"\u001b[0;36m, line \u001b[0;32m1\u001b[0m\n\u001b[0;31m It is then straightforward to obtain a (not really good) approximation to $\\pi$ by counting how many times, on average, $X^2 + Y^2$ is smaller than 1:\u001b[0m\n\u001b[0m ^\u001b[0m\n\u001b[0;31mSyntaxError\u001b[0m\u001b[0;31m:\u001b[0m invalid syntax\n"
"It is then straightforward to obtain a (not really good) approximation to $\\pi$ by counting how many times, on average, $X^2 + Y^2$ is smaller than 1:"
"execution_count": 6,
......@@ -98,13 +155,6 @@
"4*np.mean(accept)"
"source": []
