data <- unlist(read_clip_tbl(header = FALSE,sep=","))
```{r setup, include=FALSE}
mean(data)
min(data)
max(data)
median(data)
## Quelques explications
sd(data)
plot(data, col="blue", type = "l")
grid(nx = NULL, ny = NULL,
lty = 2, # Grid line type
col = "gray", # Grid line color
lwd = 2) # Grid line width
hist(data)
\ No newline at end of file
```{r pressure, echo=FALSE}
plot(pressure)
