Update exercice_fr.Rmd
parent b4778907
......@@ -10,24 +10,8 @@ output: html_document
## Quelques explications
hist(mesdonnees, xlim=c(0,25), ylim=c(0,25),col="blue", plot=TRUE)
```{r pressure, echo=FALSE}
plot(pressure)
plot(mesdonnees, type="l", col="blue", xlim=0,25, ylim=0,25)
