Jupyter test. Help.
parent bc064b91
"cells": [
"execution_count": null,
"%load_ext rpy2.ipython"
"kernelspec": {
"display_name": "Python 3",
"language": "python",
"name": "python3"
"language_info": {
"codemirror_mode": {
"name": "ipython",
"version": 3
"file_extension": ".py",
"mimetype": "text/x-python",
"name": "python",
"pygments_lexer": "ipython3",
"version": "3.6.4"
"nbformat": 4,
"nbformat_minor": 4
"cells": [
"Mon ordinateur m’indique que $\\pi$ vaut *approximativement* "
"execution_count": 1,
"3.141592653589793\n"
"from math import *\n",
"print (pi)"
"## En utilisant la méthode des aiguilles de Buffon \n",
"Mais calculé avec la **méthode** des [https://fr.wikipedia.org/wiki/Aiguille_de_Buffon], on obtiendrait comme **approximation** :"
"execution_count": 2,
"3.128911138923655"
"import numpy as np\n",
"np.random.seed(seed=42)\n",
"N = 10000\n",
"x = np.random.uniform(size=N, low=0, high=1) \n",
"Sinon, une méthode plus simple à comprendre et ne faisant pas intervenir d’appel à la fonction sinus se base sur le fait que si $X\\sim U(0,1)$ et $Y\\sim U(0,1)$ alors $P[X^2+Y^2\\leq1]=\\pi/4$ (voir [https://fr.wikipedia.org/wiki/M%C3%A9thode_de_Monte-Carlo#D%C3%A9termination_de_la_valeur_de_%CF%80]). Le code suivant illustre ce fait :"
"execution_count": 4,
"ename": "SyntaxError",
"evalue": "EOL while scanning string literal (<ipython-input-4-c8a26f7cb22f>, line 13)",
"output_type": "error",
"traceback": [
"\u001b[0;36m File \u001b[0;32m\"<ipython-input-4-c8a26f7cb22f>\"\u001b[0;36m, line \u001b[0;32m13\u001b[0m\n\u001b[0;31m ax.scatter(x[reject],y[reject], c='r’, alpha=0.2, edgecolor=None)\u001b[0m\n\u001b[0m ^\u001b[0m\n\u001b[0;31mSyntaxError\u001b[0m\u001b[0;31m:\u001b[0m EOL while scanning string literal\n"
"%matplotlib inline\n",
"N = 1000\n",
"accept=(x*x+y*y)<=1 \n",
"fig, ax=plt.subplots(1) \n",
"ax.scatter(x[reject],y[reject], c='r’, alpha=0.2, edgecolor=None) \n",
"ax.set_aspect('equal')"
"Il est alor saisé d’obtenir une approximation (pas terrible) de $\\pi$ en comptant combien de fois, en moyenne, $X^2 + Y^2$ est inferoeir à 1 :"
"execution_count": 7,
"evalue": "invalid syntax (<ipython-input-7-e627d624d667>, line 1)",
"traceback": [
"\u001b[0;36m File \u001b[0;32m\"<ipython-input-7-e627d624d667>\"\u001b[0;36m, line \u001b[0;32m1\u001b[0m\n\u001b[0;31m 4.np.mean(accept)\u001b[0m\n\u001b[0m ^\u001b[0m\n\u001b[0;31mSyntaxError\u001b[0m\u001b[0;31m:\u001b[0m invalid syntax\n"
"4.np.mean(accept)"
"source": []
"kernelspec": {
"name": "python3"
"language_info": {
"name": "ipython",
"version": 3
"name": "python",
"version": "3.6.4"
"nbformat": 4,
"nbformat_minor": 4
"cells": [],
"cells": [
"execution_count": 6,
"print(pi)"
"source": []
"kernelspec": {
......@@ -16,10 +59,9 @@
"name": "python",
"version": "3.6.3"
"version": "3.6.4"
"nbformat": 4,
"nbformat_minor": 2
