ae481a6e46ed717c92c698cb41c89458
a4884fd4
a4884fd4
Upload New File
85364c04
813 additions
+813
monthly_in_situ_co2_mlo.csv
module3/exo3/monthly_in_situ_co2_mlo.csv
+813
a4884fd4
" Atmospheric CO2 concentrations (ppm) derived from in situ air measurements "
" at Mauna Loa, Observatory, Hawaii: Latitude 19.5°N Longitude 155.6°W Elevation 3397m "
" Source: R. F. Keeling, S. J. Walker, S. C. Piper and A. F. Bollenbacher "
" Scripps CO2 Program ( http://scrippsco2.ucsd.edu ) "
" Scripps Institution of Oceanography (SIO) "
" University of California "
" La Jolla, California USA 92093-0244 "
" Status of data and correspondence: "
" These data are subject to revision based on recalibration of standard gases. Questions "
" about the data should be directed to Dr. Ralph Keeling (rkeeling@ucsd.edu), Stephen Walker"
" (sjwalker@ucsd.edu) and Stephen Piper (scpiper@ucsd.edu), Scripps CO2 Program. "
" Baseline data in this file through 06-Feb-2020 from archive dated 06-Feb-2020 08:55:31 "
" Please cite as: "
" C. D. Keeling, S. C. Piper, R. B. Bacastow, M. Wahlen, T. P. Whorf, M. Heimann, and "
" H. A. Meijer, Exchanges of atmospheric CO2 and 13CO2 with the terrestrial biosphere and "
" oceans from 1978 to 2000. I. Global aspects, SIO Reference Series, No. 01-06, Scripps "
" Institution of Oceanography, San Diego, 88 pages, 2001. "
" If it is necessary to cite a peer-reviewed article, please cite as: "
" H. A. Meijer, Atmospheric CO2 and 13CO2 exchange with the terrestrial biosphere and "
" oceans from 1978 to 2000: observations and carbon cycle implications, pages 83-113, "
" in "A History of Atmospheric CO2 and its effects on Plants, Animals, and Ecosystems", "
" editors, Ehleringer, J.R., T. E. Cerling, M. D. Dearing, Springer Verlag, "
" New York, 2005. "
" The data file below contains 10 columns. Columns 1-4 give the dates in several redundant "
" formats. Column 5 below gives monthly Mauna Loa CO2 concentrations in micro-mol CO2 per "
" mole (ppm), reported on the 2008A SIO manometric mole fraction scale. This is the "
" standard version of the data most often sought. The monthly values have been adjusted "
" to 24:00 hours on the 15th of each month. Column 6 gives the same data after a seasonal "
" adjustment to remove the quasi-regular seasonal cycle. The adjustment involves "
" subtracting from the data a 4-harmonic fit with a linear gain factor. Column 7 is a "
" smoothed version of the data generated from a stiff cubic spline function plus 4-harmonic "
" functions with linear gain. Column 8 is the same smoothed version with the seasonal "
" cycle removed. Column 9 is identical to Column 5 except that the missing values from "
" Column 5 have been filled with values from Column 7. Column 10 is identical to Column 6 "
" except missing values have been filled with values from Column 8. Missing values are "
" denoted by -99.99 "
" CO2 concentrations are measured on the '08A' calibration scale "
Yr, Mn, Date, Date, CO2,seasonally, fit, seasonally, CO2, seasonally
, , , , , adjusted, ,adjusted fit, filled,adjusted filled
, , Excel, , [ppm], [ppm] , [ppm], [ppm], [ppm], [ppm]
1958, 01, 21200, 1958.0411, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99
1958, 02, 21231, 1958.1260, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99
1958, 03, 21259, 1958.2027, 315.70, 314.44, 316.19, 314.91, 315.70, 314.44
1958, 04, 21290, 1958.2877, 317.45, 315.16, 317.30, 314.99, 317.45, 315.16
1958, 05, 21320, 1958.3699, 317.51, 314.71, 317.86, 315.06, 317.51, 314.71
1958, 06, 21351, 1958.4548, -99.99, -99.99, 317.24, 315.14, 317.24, 315.14
1958, 07, 21381, 1958.5370, 315.86, 315.19, 315.86, 315.22, 315.86, 315.19
1958, 08, 21412, 1958.6219, 314.93, 316.19, 314.00, 315.29, 314.93, 316.19
1958, 09, 21443, 1958.7068, 313.21, 316.08, 312.46, 315.35, 313.21, 316.08
1958, 10, 21473, 1958.7890, -99.99, -99.99, 312.44, 315.40, 312.44, 315.40
1958, 11, 21504, 1958.8740, 313.33, 315.20, 313.62, 315.46, 313.33, 315.20
1958, 12, 21534, 1958.9562, 314.67, 315.43, 314.77, 315.51, 314.67, 315.43
1959, 01, 21565, 1959.0411, 315.58, 315.54, 315.62, 315.57, 315.58, 315.54
1959, 02, 21596, 1959.1260, 316.49, 315.86, 316.27, 315.63, 316.49, 315.86
1959, 03, 21624, 1959.2027, 316.65, 315.38, 316.98, 315.69, 316.65, 315.38
1959, 04, 21655, 1959.2877, 317.72, 315.42, 318.09, 315.77, 317.72, 315.42
1959, 05, 21685, 1959.3699, 318.29, 315.49, 318.65, 315.85, 318.29, 315.49
1959, 06, 21716, 1959.4548, 318.15, 316.03, 318.04, 315.94, 318.15, 316.03
1959, 07, 21746, 1959.5370, 316.54, 315.86, 316.67, 316.03, 316.54, 315.86
1959, 08, 21777, 1959.6219, 314.80, 316.06, 314.83, 316.12, 314.80, 316.06
1959, 09, 21808, 1959.7068, 313.84, 316.72, 313.32, 316.22, 313.84, 316.72
1959, 10, 21838, 1959.7890, 313.33, 316.32, 313.33, 316.30, 313.33, 316.32
1959, 11, 21869, 1959.8740, 314.81, 316.68, 314.54, 316.39, 314.81, 316.68
1959, 12, 21899, 1959.9562, 315.58, 316.35, 315.72, 316.47, 315.58, 316.35
1960, 01, 21930, 1960.0410, 316.43, 316.39, 316.61, 316.56, 316.43, 316.39
1960, 02, 21961, 1960.1257, 316.98, 316.35, 317.27, 316.64, 316.98, 316.35
1960, 03, 21990, 1960.2049, 317.58, 316.28, 318.03, 316.71, 317.58, 316.28
1960, 04, 22021, 1960.2896, 319.03, 316.70, 319.14, 316.79, 319.03, 316.70
1960, 05, 22051, 1960.3716, 320.04, 317.22, 319.67, 316.86, 320.04, 317.22
1960, 06, 22082, 1960.4563, 319.59, 317.48, 319.01, 316.93, 319.59, 317.48
1960, 07, 22112, 1960.5383, 318.18, 317.53, 317.60, 316.98, 318.18, 317.53
1960, 08, 22143, 1960.6230, 315.90, 317.20, 315.69, 317.01, 315.90, 317.20
1960, 09, 22174, 1960.7077, 314.17, 317.07, 314.12, 317.04, 314.17, 317.07
1960, 10, 22204, 1960.7896, 313.83, 316.83, 314.09, 317.07, 313.83, 316.83
1960, 11, 22235, 1960.8743, 315.00, 316.87, 315.25, 317.11, 315.00, 316.87
1960, 12, 22265, 1960.9563, 316.19, 316.96, 316.40, 317.15, 316.19, 316.96
1961, 01, 22296, 1961.0411, 316.89, 316.86, 317.25, 317.20, 316.89, 316.86
1961, 02, 22327, 1961.1260, 317.70, 317.07, 317.90, 317.26, 317.70, 317.07
1961, 03, 22355, 1961.2027, 318.54, 317.26, 318.63, 317.33, 318.54, 317.26
1961, 04, 22386, 1961.2877, 319.48, 317.16, 319.75, 317.41, 319.48, 317.16
1961, 05, 22416, 1961.3699, 320.58, 317.76, 320.32, 317.50, 320.58, 317.76
1961, 06, 22447, 1961.4548, 319.77, 317.63, 319.71, 317.59, 319.77, 317.63
1961, 07, 22477, 1961.5370, 318.57, 317.89, 318.33, 317.68, 318.57, 317.89
1961, 08, 22508, 1961.6219, 316.79, 318.06, 316.46, 317.76, 316.79, 318.06
1961, 09, 22539, 1961.7068, 314.99, 317.89, 314.92, 317.85, 314.99, 317.89
1961, 10, 22569, 1961.7890, 315.31, 318.32, 314.92, 317.92, 315.31, 318.32
1961, 11, 22600, 1961.8740, 316.10, 317.99, 316.13, 317.99, 316.10, 317.99
1961, 12, 22630, 1961.9562, 317.01, 317.78, 317.30, 318.06, 317.01, 317.78
1962, 01, 22661, 1962.0411, 317.94, 317.90, 318.18, 318.13, 317.94, 317.90
1962, 02, 22692, 1962.1260, 318.55, 317.92, 318.83, 318.19, 318.55, 317.92
1962, 03, 22720, 1962.2027, 319.68, 318.39, 319.56, 318.26, 319.68, 318.39
1962, 04, 22751, 1962.2877, 320.57, 318.24, 320.67, 318.32, 320.57, 318.24
1962, 05, 22781, 1962.3699, 321.02, 318.18, 321.22, 318.39, 321.02, 318.18
1962, 06, 22812, 1962.4548, 320.62, 318.48, 320.57, 318.45, 320.62, 318.48
1962, 07, 22842, 1962.5370, 319.61, 318.93, 319.16, 318.51, 319.61, 318.93
1962, 08, 22873, 1962.6219, 317.40, 318.68, 317.25, 318.56, 317.40, 318.68
1962, 09, 22904, 1962.7068, 316.25, 319.16, 315.67, 318.60, 316.25, 319.16
1962, 10, 22934, 1962.7890, 315.42, 318.44, 315.63, 318.64, 315.42, 318.44
1962, 11, 22965, 1962.8740, 316.69, 318.58, 316.81, 318.68, 316.69, 318.58
1962, 12, 22995, 1962.9562, 317.70, 318.47, 317.96, 318.72, 317.70, 318.47
1963, 01, 23026, 1963.0411, 318.74, 318.70, 318.81, 318.76, 318.74, 318.70
1963, 02, 23057, 1963.1260, 319.07, 318.44, 319.45, 318.81, 319.07, 318.44
1963, 03, 23085, 1963.2027, 319.86, 318.57, 320.16, 318.86, 319.86, 318.57
1963, 04, 23116, 1963.2877, 321.38, 319.05, 321.26, 318.91, 321.38, 319.05
1963, 05, 23146, 1963.3699, 322.25, 319.40, 321.80, 318.96, 322.25, 319.40
1963, 06, 23177, 1963.4548, 321.48, 319.33, 321.14, 319.01, 321.48, 319.33
1963, 07, 23207, 1963.5370, 319.74, 319.06, 319.71, 319.06, 319.74, 319.06
1963, 08, 23238, 1963.6219, 317.77, 319.05, 317.78, 319.10, 317.77, 319.05
1963, 09, 23269, 1963.7068, 316.21, 319.14, 316.20, 319.14, 316.21, 319.14
1963, 10, 23299, 1963.7890, 315.99, 319.02, 316.16, 319.18, 315.99, 319.02
1963, 11, 23330, 1963.8740, 317.07, 318.96, 317.35, 319.23, 317.07, 318.96
1963, 12, 23360, 1963.9562, 318.35, 319.13, 318.51, 319.27, 318.35, 319.13
1964, 01, 23391, 1964.0410, 319.57, 319.53, 319.37, 319.32, 319.57, 319.53
1964, 02, 23422, 1964.1257, -99.99, -99.99, 320.01, 319.36, 320.01, 319.36
1964, 03, 23451, 1964.2049, -99.99, -99.99, 320.74, 319.41, 320.74, 319.41
1964, 04, 23482, 1964.2896, -99.99, -99.99, 321.83, 319.45, 321.83, 319.45
1964, 05, 23512, 1964.3716, 322.26, 319.40, 322.34, 319.49, 322.26, 319.40
1964, 06, 23543, 1964.4563, 321.89, 319.75, 321.64, 319.52, 321.89, 319.75
1964, 07, 23573, 1964.5383, 320.44, 319.78, 320.19, 319.55, 320.44, 319.78
1964, 08, 23604, 1964.6230, 318.69, 320.00, 318.24, 319.58, 318.69, 320.00
1964, 09, 23635, 1964.7077, 316.71, 319.65, 316.64, 319.60, 316.71, 319.65
1964, 10, 23665, 1964.7896, 316.87, 319.91, 316.59, 319.62, 316.87, 319.91
1964, 11, 23696, 1964.8743, 317.68, 319.58, 317.76, 319.64, 317.68, 319.58
1964, 12, 23726, 1964.9563, 318.71, 319.49, 318.89, 319.66, 318.71, 319.49
1965, 01, 23757, 1965.0411, 319.44, 319.40, 319.73, 319.68, 319.44, 319.40
1965, 02, 23788, 1965.1260, 320.44, 319.81, 320.37, 319.72, 320.44, 319.81
1965, 03, 23816, 1965.2027, 320.89, 319.59, 321.08, 319.77, 320.89, 319.59
1965, 04, 23847, 1965.2877, 322.14, 319.78, 322.20, 319.83, 322.14, 319.78
1965, 05, 23877, 1965.3699, 322.17, 319.30, 322.77, 319.91, 322.17, 319.30
1965, 06, 23908, 1965.4548, 321.87, 319.71, 322.15, 320.00, 321.87, 319.71
1965, 07, 23938, 1965.5370, 321.21, 320.52, 320.76, 320.10, 321.21, 320.52
1965, 08, 23969, 1965.6219, 318.87, 320.16, 318.88, 320.21, 318.87, 320.16
1965, 09, 24000, 1965.7068, 317.82, 320.76, 317.36, 320.32, 317.82, 320.76
1965, 10, 24030, 1965.7890, 317.30, 320.36, 317.39, 320.43, 317.30, 320.36
1965, 11, 24061, 1965.8740, 318.87, 320.78, 318.66, 320.55, 318.87, 320.78
1965, 12, 24091, 1965.9562, 319.42, 320.20, 319.90, 320.66, 319.42, 320.20
1966, 01, 24122, 1966.0411, 320.62, 320.58, 320.83, 320.78, 320.62, 320.58
1966, 02, 24153, 1966.1260, 321.60, 320.96, 321.55, 320.90, 321.60, 320.96
1966, 03, 24181, 1966.2027, 322.39, 321.08, 322.33, 321.01, 322.39, 321.08
1966, 04, 24212, 1966.2877, 323.70, 321.34, 323.50, 321.12, 323.70, 321.34
1966, 05, 24242, 1966.3699, 324.08, 321.20, 324.10, 321.22, 324.08, 321.20
1966, 06, 24273, 1966.4548, 323.75, 321.58, 323.47, 321.32, 323.75, 321.58
1966, 07, 24303, 1966.5370, 322.38, 321.69, 322.07, 321.40, 322.38, 321.69
1966, 08, 24334, 1966.6219, 320.36, 321.66, 320.15, 321.48, 320.36, 321.66
1966, 09, 24365, 1966.7068, 318.64, 321.60, 318.58, 321.55, 318.64, 321.60
1966, 10, 24395, 1966.7890, 318.10, 321.17, 318.56, 321.62, 318.10, 321.17
1966, 11, 24426, 1966.8740, 319.78, 321.70, 319.78, 321.68, 319.78, 321.70
1966, 12, 24456, 1966.9562, 321.03, 321.81, 320.97, 321.74, 321.03, 321.81
1967, 01, 24487, 1967.0411, 322.33, 322.29, 321.85, 321.80, 322.33, 322.29
1967, 02, 24518, 1967.1260, 322.50, 321.86, 322.51, 321.86, 322.50, 321.86
1967, 03, 24546, 1967.2027, 323.04, 321.73, 323.23, 321.90, 323.04, 321.73
1967, 04, 24577, 1967.2877, 324.42, 322.05, 324.35, 321.96, 324.42, 322.05
1967, 05, 24607, 1967.3699, 325.00, 322.12, 324.90, 322.01, 325.00, 322.12
1967, 06, 24638, 1967.4548, 324.09, 321.91, 324.24, 322.07, 324.09, 321.91
1967, 07, 24668, 1967.5370, 322.54, 321.85, 322.80, 322.13, 322.54, 321.85
1967, 08, 24699, 1967.6219, 320.92, 322.22, 320.87, 322.20, 320.92, 322.22
1967, 09, 24730, 1967.7068, 319.25, 322.22, 319.29, 322.27, 319.25, 322.22
1967, 10, 24760, 1967.7890, 319.39, 322.47, 319.28, 322.35, 319.39, 322.47
1967, 11, 24791, 1967.8740, 320.73, 322.65, 320.52, 322.42, 320.73, 322.65
1967, 12, 24821, 1967.9562, 321.96, 322.74, 321.72, 322.49, 321.96, 322.74
1968, 01, 24852, 1968.0410, 322.57, 322.53, 322.62, 322.57, 322.57, 322.53
1968, 02, 24883, 1968.1257, 323.15, 322.50, 323.30, 322.65, 323.15, 322.50
1968, 03, 24912, 1968.2049, 323.89, 322.55, 324.09, 322.73, 323.89, 322.55
1968, 04, 24943, 1968.2896, 325.02, 322.62, 325.24, 322.83, 325.02, 322.62
1968, 05, 24973, 1968.3716, 325.57, 322.68, 325.82, 322.92, 325.57, 322.68
1968, 06, 25004, 1968.4563, 325.36, 323.19, 325.18, 323.03, 325.36, 323.19
1968, 07, 25034, 1968.5383, 324.14, 323.47, 323.78, 323.14, 324.14, 323.47
1968, 08, 25065, 1968.6230, 322.11, 323.44, 321.89, 323.25, 322.11, 323.44
1968, 09, 25096, 1968.7077, 320.33, 323.32, 320.36, 323.37, 320.33, 323.32
1968, 10, 25126, 1968.7896, 320.25, 323.33, 320.42, 323.49, 320.25, 323.33
1968, 11, 25157, 1968.8743, 321.32, 323.25, 321.71, 323.61, 321.32, 323.25
1968, 12, 25187, 1968.9563, 322.89, 323.68, 322.97, 323.75, 322.89, 323.68
1969, 01, 25218, 1969.0411, 324.00, 323.96, 323.94, 323.89, 324.00, 323.96
1969, 02, 25249, 1969.1260, 324.42, 323.77, 324.69, 324.03, 324.42, 323.77
1969, 03, 25277, 1969.2027, 325.63, 324.31, 325.50, 324.16, 325.63, 324.31
1969, 04, 25308, 1969.2877, 326.66, 324.28, 326.71, 324.30, 326.66, 324.28
1969, 05, 25338, 1969.3699, 327.38, 324.48, 327.34, 324.44, 327.38, 324.48
1969, 06, 25369, 1969.4548, 326.71, 324.51, 326.75, 324.57, 326.71, 324.51
1969, 07, 25399, 1969.5370, 325.88, 325.18, 325.36, 324.69, 325.88, 325.18
1969, 08, 25430, 1969.6219, 323.66, 324.97, 323.46, 324.80, 323.66, 324.97
1969, 09, 25461, 1969.7068, 322.38, 325.37, 321.90, 324.90, 322.38, 325.37
1969, 10, 25491, 1969.7890, 321.78, 324.88, 321.91, 324.99, 321.78, 324.88
1969, 11, 25522, 1969.8740, 322.85, 324.79, 323.16, 325.08, 322.85, 324.79
1969, 12, 25552, 1969.9562, 324.12, 324.91, 324.38, 325.16, 324.12, 324.91
1970, 01, 25583, 1970.0411, 325.06, 325.02, 325.29, 325.24, 325.06, 325.02
1970, 02, 25614, 1970.1260, 325.98, 325.33, 325.98, 325.32, 325.98, 325.33
1970, 03, 25642, 1970.2027, 326.93, 325.61, 326.74, 325.40, 326.93, 325.61
1970, 04, 25673, 1970.2877, 328.13, 325.74, 327.89, 325.48, 328.13, 325.74
1970, 05, 25703, 1970.3699, 328.08, 325.16, 328.47, 325.55, 328.08, 325.16
1970, 06, 25734, 1970.4548, 327.67, 325.46, 327.81, 325.63, 327.67, 325.46
1970, 07, 25764, 1970.5370, 326.34, 325.64, 326.37, 325.70, 326.34, 325.64
1970, 08, 25795, 1970.6219, 324.69, 326.00, 324.42, 325.77, 324.69, 326.00
1970, 09, 25826, 1970.7068, 323.10, 326.10, 322.82, 325.83, 323.10, 326.10
1970, 10, 25856, 1970.7890, 323.06, 326.17, 322.79, 325.88, 323.06, 326.17
1970, 11, 25887, 1970.8740, 324.01, 325.95, 324.01, 325.93, 324.01, 325.95
1970, 12, 25917, 1970.9562, 325.13, 325.93, 325.19, 325.97, 325.13, 325.93
1971, 01, 25948, 1971.0411, 326.17, 326.13, 326.06, 326.01, 326.17, 326.13
1971, 02, 25979, 1971.1260, 326.68, 326.03, 326.71, 326.05, 326.68, 326.03
1971, 03, 26007, 1971.2027, 327.18, 325.85, 327.43, 326.09, 327.18, 325.85
1971, 04, 26038, 1971.2877, 327.79, 325.38, 328.56, 326.14, 327.79, 325.38
1971, 05, 26068, 1971.3699, 328.93, 326.00, 329.12, 326.19, 328.93, 326.00
1971, 06, 26099, 1971.4548, 328.57, 326.36, 328.45, 326.26, 328.57, 326.36
1971, 07, 26129, 1971.5370, 327.36, 326.66, 327.00, 326.33, 327.36, 326.66
1971, 08, 26160, 1971.6219, 325.43, 326.75, 325.05, 326.40, 325.43, 326.75
1971, 09, 26191, 1971.7068, 323.36, 326.37, 323.45, 326.47, 323.36, 326.37
1971, 10, 26221, 1971.7890, 323.56, 326.68, 323.44, 326.54, 323.56, 326.68
1971, 11, 26252, 1971.8740, 324.80, 326.75, 324.69, 326.62, 324.80, 326.75
1971, 12, 26282, 1971.9562, 326.01, 326.81, 325.92, 326.70, 326.01, 326.81
1972, 01, 26313, 1972.0410, 326.77, 326.73, 326.83, 326.78, 326.77, 326.73
1972, 02, 26344, 1972.1257, 327.63, 326.98, 327.54, 326.88, 327.63, 326.98
1972, 03, 26373, 1972.2049, 327.75, 326.39, 328.35, 326.98, 327.75, 326.39
1972, 04, 26404, 1972.2896, 329.72, 327.29, 329.55, 327.10, 329.72, 327.29
1972, 05, 26434, 1972.3716, 330.07, 327.14, 330.16, 327.23, 330.07, 327.14
1972, 06, 26465, 1972.4563, 329.09, 326.89, 329.55, 327.38, 329.09, 326.89
1972, 07, 26495, 1972.5383, 328.04, 327.36, 328.19, 327.54, 328.04, 327.36
1972, 08, 26526, 1972.6230, 326.32, 327.67, 326.34, 327.72, 326.32, 327.67
1972, 09, 26557, 1972.7077, 324.84, 327.87, 324.86, 327.91, 324.84, 327.87
1972, 10, 26587, 1972.7896, 325.20, 328.33, 324.99, 328.10, 325.20, 328.33
1972, 11, 26618, 1972.8743, 326.50, 328.45, 326.37, 328.31, 326.50, 328.45
1972, 12, 26648, 1972.9563, 327.55, 328.35, 327.72, 328.51, 327.55, 328.35
1973, 01, 26679, 1973.0411, 328.55, 328.51, 328.77, 328.72, 328.55, 328.51
1973, 02, 26710, 1973.1260, 329.56, 328.90, 329.59, 328.92, 329.56, 328.90
1973, 03, 26738, 1973.2027, 330.30, 328.96, 330.46, 329.11, 330.30, 328.96
1973, 04, 26769, 1973.2877, 331.50, 329.08, 331.74, 329.30, 331.50, 329.08
1973, 05, 26799, 1973.3699, 332.48, 329.54, 332.42, 329.48, 332.48, 329.54
1973, 06, 26830, 1973.4548, 332.07, 329.84, 331.85, 329.64, 332.07, 329.84
1973, 07, 26860, 1973.5370, 330.87, 330.16, 330.45, 329.77, 330.87, 330.16
1973, 08, 26891, 1973.6219, 329.31, 330.64, 328.52, 329.88, 329.31, 330.64
1973, 09, 26922, 1973.7068, 327.51, 330.54, 326.91, 329.96, 327.51, 330.54
1973, 10, 26952, 1973.7890, 327.18, 330.32, 326.88, 330.01, 327.18, 330.32
1973, 11, 26983, 1973.8740, 328.16, 330.13, 328.10, 330.04, 328.16, 330.13
1973, 12, 27013, 1973.9562, 328.64, 329.44, 329.28, 330.07, 328.64, 329.44
1974, 01, 27044, 1974.0411, 329.35, 329.31, 330.14, 330.09, 329.35, 329.31
1974, 02, 27075, 1974.1260, 330.71, 330.05, 330.78, 330.12, 330.71, 330.05
1974, 03, 27103, 1974.2027, 331.48, 330.14, 331.50, 330.14, 331.48, 330.14
1974, 04, 27134, 1974.2877, 332.65, 330.22, 332.62, 330.18, 332.65, 330.22
1974, 05, 27164, 1974.3699, 333.09, 330.13, 333.17, 330.22, 333.09, 330.13
1974, 06, 27195, 1974.4548, 332.25, 330.01, 332.48, 330.26, 332.25, 330.01
1974, 07, 27225, 1974.5370, 331.18, 330.46, 330.99, 330.31, 331.18, 330.46
1974, 08, 27256, 1974.6219, 329.39, 330.73, 328.99, 330.36, 329.39, 330.73
1974, 09, 27287, 1974.7068, 327.43, 330.47, 327.35, 330.41, 327.43, 330.47
1974, 10, 27317, 1974.7890, 327.37, 330.52, 327.32, 330.46, 327.37, 330.52
1974, 11, 27348, 1974.8740, 328.46, 330.43, 328.57, 330.52, 328.46, 330.43
1974, 12, 27378, 1974.9562, 329.57, 330.38, 329.79, 330.58, 329.57, 330.38
1975, 01, 27409, 1975.0411, 330.40, 330.36, 330.71, 330.65, 330.40, 330.36
1975, 02, 27440, 1975.1260, 331.40, 330.74, 331.41, 330.74, 331.40, 330.74
1975, 03, 27468, 1975.2027, 332.04, 330.69, 332.18, 330.82, 332.04, 330.69
1975, 04, 27499, 1975.2877, 333.31, 330.87, 333.36, 330.91, 333.31, 330.87
1975, 05, 27529, 1975.3699, 333.97, 331.00, 333.97, 331.00, 333.97, 331.00
1975, 06, 27560, 1975.4548, 333.60, 331.36, 333.33, 331.10, 333.60, 331.36
1975, 07, 27590, 1975.5370, 331.90, 331.19, 331.88, 331.20, 331.90, 331.19
1975, 08, 27621, 1975.6219, 330.06, 331.39, 329.92, 331.29, 330.06, 331.39
1975, 09, 27652, 1975.7068, 328.56, 331.61, 328.32, 331.39, 328.56, 331.61
1975, 10, 27682, 1975.7890, 328.34, 331.50, 328.32, 331.47, 328.34, 331.50
1975, 11, 27713, 1975.8740, 329.49, 331.47, 329.60, 331.56, 329.49, 331.47
1975, 12, 27743, 1975.9562, 330.76, 331.57, 330.84, 331.64, 330.76, 331.57
1976, 01, 27774, 1976.0410, 331.75, 331.71, 331.77, 331.72, 331.75, 331.71
1976, 02, 27805, 1976.1257, 332.56, 331.91, 332.47, 331.80, 332.56, 331.91
1976, 03, 27834, 1976.2049, 333.50, 332.12, 333.26, 331.87, 333.50, 332.12
1976, 04, 27865, 1976.2896, 334.58, 332.12, 334.43, 331.95, 334.58, 332.12
1976, 05, 27895, 1976.3716, 334.88, 331.90, 335.00, 332.03, 334.88, 331.90
1976, 06, 27926, 1976.4563, 334.33, 332.10, 334.32, 332.11, 334.33, 332.10
1976, 07, 27956, 1976.5383, 333.05, 332.36, 332.85, 332.19, 333.05, 332.36
1976, 08, 27987, 1976.6230, 330.94, 332.31, 330.89, 332.29, 330.94, 332.31
1976, 09, 28018, 1976.7077, 329.30, 332.38, 329.30, 332.39, 329.30, 332.38
1976, 10, 28048, 1976.7896, 328.94, 332.11, 329.35, 332.50, 328.94, 332.11
1976, 11, 28079, 1976.8743, 330.31, 332.29, 330.67, 332.63, 330.31, 332.29
1976, 12, 28109, 1976.9563, 331.68, 332.49, 331.98, 332.77, 331.68, 332.49
1977, 01, 28140, 1977.0411, 332.93, 332.88, 332.98, 332.93, 332.93, 332.88
1977, 02, 28171, 1977.1260, 333.42, 332.75, 333.78, 333.11, 333.42, 332.75
1977, 03, 28199, 1977.2027, 334.70, 333.35, 334.64, 333.27, 334.70, 333.35
1977, 04, 28230, 1977.2877, 336.07, 333.62, 335.93, 333.46, 336.07, 333.62
1977, 05, 28260, 1977.3699, 336.75, 333.76, 336.62, 333.64, 336.75, 333.76
1977, 06, 28291, 1977.4548, 336.27, 334.01, 336.06, 333.82, 336.27, 334.01
1977, 07, 28321, 1977.5370, 334.92, 334.20, 334.67, 333.99, 334.92, 334.20
1977, 08, 28352, 1977.6219, 332.75, 334.10, 332.77, 334.15, 332.75, 334.10
1977, 09, 28383, 1977.7068, 331.59, 334.66, 331.22, 334.31, 331.59, 334.66
1977, 10, 28413, 1977.7890, 331.16, 334.35, 331.28, 334.46, 331.16, 334.35
1977, 11, 28444, 1977.8740, 332.40, 334.40, 332.63, 334.60, 332.40, 334.40
1977, 12, 28474, 1977.9562, 333.85, 334.66, 333.94, 334.74, 333.85, 334.66
1978, 01, 28505, 1978.0411, 334.97, 334.93, 334.93, 334.88, 334.97, 334.93
1978, 02, 28536, 1978.1260, 335.38, 334.72, 335.69, 335.01, 335.38, 334.72
1978, 03, 28564, 1978.2027, 336.64, 335.28, 336.50, 335.13, 336.64, 335.28
1978, 04, 28595, 1978.2877, 337.76, 335.30, 337.73, 335.25, 337.76, 335.30
1978, 05, 28625, 1978.3699, 338.01, 335.02, 338.37, 335.37, 338.01, 335.02
1978, 06, 28656, 1978.4548, 337.90, 335.63, 337.73, 335.49, 337.90, 335.63
1978, 07, 28686, 1978.5370, 336.54, 335.82, 336.29, 335.60, 336.54, 335.82
1978, 08, 28717, 1978.6219, 334.68, 336.03, 334.31, 335.70, 334.68, 336.03
1978, 09, 28748, 1978.7068, 332.76, 335.84, 332.70, 335.80, 332.76, 335.84
1978, 10, 28778, 1978.7890, 332.55, 335.74, 332.71, 335.89, 332.55, 335.74
1978, 11, 28809, 1978.8740, 333.92, 335.92, 334.01, 335.99, 333.92, 335.92
1978, 12, 28839, 1978.9562, 334.95, 335.77, 335.28, 336.08, 334.95, 335.77
1979, 01, 28870, 1979.0411, 336.23, 336.19, 336.24, 336.19, 336.23, 336.19
1979, 02, 28901, 1979.1260, 336.76, 336.09, 336.98, 336.30, 336.76, 336.09
1979, 03, 28929, 1979.2027, 337.96, 336.60, 337.79, 336.41, 337.96, 336.60
1979, 04, 28960, 1979.2877, 338.88, 336.41, 339.03, 336.54, 338.88, 336.41
1979, 05, 28990, 1979.3699, 339.47, 336.47, 339.67, 336.67, 339.47, 336.47
1979, 06, 29021, 1979.4548, 339.29, 337.01, 339.06, 336.80, 339.29, 337.01
1979, 07, 29051, 1979.5370, 337.73, 337.01, 337.63, 336.94, 337.73, 337.01
1979, 08, 29082, 1979.6219, 336.09, 337.44, 335.69, 337.08, 336.09, 337.44
1979, 09, 29113, 1979.7068, 333.92, 337.01, 334.11, 337.22, 333.92, 337.01
1979, 10, 29143, 1979.7890, 333.86, 337.07, 334.17, 337.37, 333.86, 337.07
1979, 11, 29174, 1979.8740, 335.29, 337.30, 335.54, 337.52, 335.29, 337.30
1979, 12, 29204, 1979.9562, 336.73, 337.55, 336.88, 337.68, 336.73, 337.55
1980, 01, 29235, 1980.0410, 338.01, 337.97, 337.90, 337.85, 338.01, 337.97
1980, 02, 29266, 1980.1257, 338.36, 337.69, 338.70, 338.02, 338.36, 337.69
1980, 03, 29295, 1980.2049, 340.07, 338.68, 339.58, 338.17, 340.07, 338.68
1980, 04, 29326, 1980.2896, 340.76, 338.26, 340.85, 338.33, 340.76, 338.26
1980, 05, 29356, 1980.3716, 341.47, 338.45, 341.50, 338.48, 341.47, 338.45
1980, 06, 29387, 1980.4563, 341.17, 338.91, 340.87, 338.63, 341.17, 338.91
1980, 07, 29417, 1980.5383, 339.56, 338.86, 339.43, 338.77, 339.56, 338.86
1980, 08, 29448, 1980.6230, 337.60, 338.99, 337.48, 338.90, 337.60, 338.99
1980, 09, 29479, 1980.7077, 335.88, 338.99, 335.89, 339.02, 335.88, 338.99
1980, 10, 29509, 1980.7896, 336.02, 339.23, 335.93, 339.13, 336.02, 339.23
1980, 11, 29540, 1980.8743, 337.10, 339.11, 337.25, 339.24, 337.10, 339.11
1980, 12, 29570, 1980.9563, 338.21, 339.04, 338.54, 339.34, 338.21, 339.04
1981, 01, 29601, 1981.0411, 339.24, 339.19, 339.50, 339.44, 339.24, 339.19
1981, 02, 29632, 1981.1260, 340.48, 339.81, 340.23, 339.55, 340.48, 339.81
1981, 03, 29660, 1981.2027, 341.38, 340.01, 341.02, 339.63, 341.38, 340.01
1981, 04, 29691, 1981.2877, 342.50, 340.02, 342.23, 339.72, 342.50, 340.02
1981, 05, 29721, 1981.3699, 342.91, 339.89, 342.83, 339.81, 342.91, 339.89
1981, 06, 29752, 1981.4548, 342.25, 339.96, 342.16, 339.89, 342.25, 339.96
1981, 07, 29782, 1981.5370, 340.49, 339.76, 340.67, 339.98, 340.49, 339.76
1981, 08, 29813, 1981.6219, 338.43, 339.80, 338.67, 340.07, 338.43, 339.80
1981, 09, 29844, 1981.7068, 336.69, 339.81, 337.03, 340.16, 336.69, 339.81
1981, 10, 29874, 1981.7890, 336.86, 340.08, 337.05, 340.26, 336.86, 340.08
1981, 11, 29905, 1981.8740, 338.36, 340.38, 338.38, 340.37, 338.36, 340.38
1981, 12, 29935, 1981.9562, 339.61, 340.44, 339.67, 340.48, 339.61, 340.44
1982, 01, 29966, 1982.0411, 340.75, 340.71, 340.65, 340.59, 340.75, 340.71
1982, 02, 29997, 1982.1260, 341.61, 340.94, 341.38, 340.70, 341.61, 340.94
1982, 03, 30025, 1982.2027, 342.70, 341.32, 342.18, 340.79, 342.70, 341.32
1982, 04, 30056, 1982.2877, 343.57, 341.07, 343.39, 340.88, 343.57, 341.07
1982, 05, 30086, 1982.3699, 344.14, 341.10, 344.00, 340.96, 344.14, 341.10
1982, 06, 30117, 1982.4548, 343.35, 341.05, 343.32, 341.04, 343.35, 341.05
1982, 07, 30147, 1982.5370, 342.06, 341.32, 341.82, 341.12, 342.06, 341.32
1982, 08, 30178, 1982.6219, 339.81, 341.18, 339.79, 341.20, 339.81, 341.18
1982, 09, 30209, 1982.7068, 337.98, 341.10, 338.14, 341.28, 337.98, 341.10
1982, 10, 30239, 1982.7890, 337.86, 341.10, 338.15, 341.38, 337.86, 341.10
1982, 11, 30270, 1982.8740, 339.26, 341.29, 339.49, 341.49, 339.26, 341.29
1982, 12, 30300, 1982.9562, 340.49, 341.32, 340.81, 341.62, 340.49, 341.32
1983, 01, 30331, 1983.0411, 341.38, 341.33, 341.83, 341.78, 341.38, 341.33
1983, 02, 30362, 1983.1260, 342.52, 341.84, 342.64, 341.95, 342.52, 341.84
1983, 03, 30390, 1983.2027, 343.10, 341.71, 343.51, 342.11, 343.10, 341.71
1983, 04, 30421, 1983.2877, 344.94, 342.44, 344.83, 342.31, 344.94, 342.44
1983, 05, 30451, 1983.3699, 345.76, 342.71, 345.54, 342.50, 345.76, 342.71
1983, 06, 30482, 1983.4548, 345.32, 343.01, 344.97, 342.69, 345.32, 343.01
1983, 07, 30512, 1983.5370, 343.98, 343.25, 343.56, 342.86, 343.98, 343.25
1983, 08, 30543, 1983.6219, 342.38, 343.75, 341.62, 343.03, 342.38, 343.75
1983, 09, 30574, 1983.7068, 339.87, 343.00, 340.04, 343.19, 339.87, 343.00
1983, 10, 30604, 1983.7890, 339.99, 343.24, 340.10, 343.34, 339.99, 343.24
1983, 11, 30635, 1983.8740, 341.15, 343.19, 341.47, 343.48, 341.15, 343.19
1983, 12, 30665, 1983.9562, 342.99, 343.82, 342.81, 343.62, 342.99, 343.82
1984, 01, 30696, 1984.0410, 343.70, 343.66, 343.81, 343.76, 343.70, 343.66
1984, 02, 30727, 1984.1257, 344.50, 343.83, 344.58, 343.89, 344.50, 343.83
1984, 03, 30756, 1984.2049, 345.28, 343.87, 345.44, 344.01, 345.28, 343.87
1984, 04, 30787, 1984.2896, 347.05, 344.52, 346.70, 344.14, 347.05, 344.52
1984, 05, 30817, 1984.3716, 347.43, 344.38, 347.32, 344.26, 347.43, 344.38
1984, 06, 30848, 1984.4563, 346.80, 344.51, 346.65, 344.39, 346.80, 344.51
1984, 07, 30878, 1984.5383, 345.39, 344.69, 345.18, 344.50, 345.39, 344.69
1984, 08, 30909, 1984.6230, 343.28, 344.68, 343.18, 344.62, 343.28, 344.68
1984, 09, 30940, 1984.7077, 341.07, 344.23, 341.57, 344.74, 341.07, 344.23
1984, 10, 30970, 1984.7896, 341.35, 344.60, 341.62, 344.86, 341.35, 344.60
1984, 11, 31001, 1984.8743, 342.98, 345.01, 342.98, 344.99, 342.98, 345.01
1984, 12, 31031, 1984.9563, 344.22, 345.05, 344.30, 345.12, 344.22, 345.05
1985, 01, 31062, 1985.0411, 344.97, 344.93, 345.31, 345.25, 344.97, 344.93
1985, 02, 31093, 1985.1260, 345.99, 345.31, 346.08, 345.39, 345.99, 345.31
1985, 03, 31121, 1985.2027, 347.42, 346.03, 346.91, 345.50, 347.42, 346.03
1985, 04, 31152, 1985.2877, 348.35, 345.83, 348.16, 345.62, 348.35, 345.83
1985, 05, 31182, 1985.3699, 348.93, 345.86, 348.80, 345.73, 348.93, 345.86
1985, 06, 31213, 1985.4548, 348.25, 345.93, 348.13, 345.83, 348.25, 345.93
1985, 07, 31243, 1985.5370, 346.56, 345.82, 346.63, 345.93, 346.56, 345.82
1985, 08, 31274, 1985.6219, 344.67, 346.06, 344.60, 346.02, 344.67, 346.06
1985, 09, 31305, 1985.7068, 343.09, 346.24, 342.93, 346.10, 343.09, 346.24
1985, 10, 31335, 1985.7890, 342.80, 346.07, 342.93, 346.19, 342.80, 346.07
1985, 11, 31366, 1985.8740, 344.24, 346.29, 344.26, 346.28, 344.24, 346.29
1985, 12, 31396, 1985.9562, 345.56, 346.39, 345.55, 346.37, 345.56, 346.39
1986, 01, 31427, 1986.0411, 346.30, 346.25, 346.53, 346.47, 346.30, 346.25
1986, 02, 31458, 1986.1260, 346.95, 346.27, 347.28, 346.58, 346.95, 346.27
1986, 03, 31486, 1986.2027, 347.85, 346.46, 348.10, 346.69, 347.85, 346.46
1986, 04, 31517, 1986.2877, 349.55, 347.02, 349.36, 346.81, 349.55, 347.02
1986, 05, 31547, 1986.3699, 350.22, 347.14, 350.01, 346.93, 350.22, 347.14
1986, 06, 31578, 1986.4548, 349.55, 347.23, 349.37, 347.06, 349.55, 347.23
1986, 07, 31608, 1986.5370, 347.94, 347.20, 347.89, 347.18, 347.94, 347.20
1986, 08, 31639, 1986.6219, 345.90, 347.29, 345.89, 347.31, 345.90, 347.29
1986, 09, 31670, 1986.7068, 344.85, 348.02, 344.26, 347.44, 344.85, 348.02
1986, 10, 31700, 1986.7890, 344.17, 347.45, 344.30, 347.56, 344.17, 347.45
1986, 11, 31731, 1986.8740, 345.66, 347.71, 345.66, 347.70, 345.66, 347.71
1986, 12, 31761, 1986.9562, 346.90, 347.74, 347.01, 347.83, 346.90, 347.74
1987, 01, 31792, 1987.0411, 348.02, 347.98, 348.03, 347.97, 348.02, 347.98
1987, 02, 31823, 1987.1260, 348.48, 347.79, 348.83, 348.13, 348.48, 347.79
1987, 03, 31851, 1987.2027, 349.42, 348.01, 349.70, 348.29, 349.42, 348.01
1987, 04, 31882, 1987.2877, 350.98, 348.45, 351.02, 348.47, 350.98, 348.45
1987, 05, 31912, 1987.3699, 351.85, 348.76, 351.74, 348.66, 351.85, 348.76
1987, 06, 31943, 1987.4548, 351.26, 348.92, 351.17, 348.86, 351.26, 348.92
1987, 07, 31973, 1987.5370, 349.51, 348.77, 349.77, 349.06, 349.51, 348.77
1987, 08, 32004, 1987.6219, 348.10, 349.49, 347.85, 349.28, 348.10, 349.49
1987, 09, 32035, 1987.7068, 346.45, 349.62, 346.31, 349.50, 346.45, 349.62
1987, 10, 32065, 1987.7890, 346.36, 349.65, 346.44, 349.72, 346.36, 349.65
1987, 11, 32096, 1987.8740, 347.81, 349.87, 347.90, 349.94, 347.81, 349.87
1987, 12, 32126, 1987.9562, 348.96, 349.81, 349.34, 350.16, 348.96, 349.81
1988, 01, 32157, 1988.0410, 350.43, 350.39, 350.44, 350.39, 350.43, 350.39
1988, 02, 32188, 1988.1257, 351.73, 351.04, 351.31, 350.61, 351.73, 351.04
1988, 03, 32217, 1988.2049, 352.22, 350.79, 352.26, 350.81, 352.22, 350.79
1988, 04, 32248, 1988.2896, 353.59, 351.02, 353.61, 351.02, 353.59, 351.02
1988, 05, 32278, 1988.3716, 354.22, 351.12, 354.31, 351.21, 354.22, 351.12
1988, 06, 32309, 1988.4563, 353.80, 351.48, 353.70, 351.40, 353.80, 351.48
1988, 07, 32339, 1988.5383, 352.38, 351.66, 352.26, 351.57, 352.38, 351.66
1988, 08, 32370, 1988.6230, 350.43, 351.85, 350.28, 351.74, 350.43, 351.85
1988, 09, 32401, 1988.7077, 348.73, 351.92, 348.68, 351.89, 348.73, 351.92
1988, 10, 32431, 1988.7896, 348.88, 352.18, 348.74, 352.03, 348.88, 352.18
1988, 11, 32462, 1988.8743, 350.07, 352.13, 350.12, 352.16, 350.07, 352.13
1988, 12, 32492, 1988.9563, 351.34, 352.19, 351.45, 352.28, 351.34, 352.19
1989, 01, 32523, 1989.0411, 352.76, 352.72, 352.44, 352.39, 352.76, 352.72
1989, 02, 32554, 1989.1260, 353.07, 352.38, 353.20, 352.50, 353.07, 352.38
1989, 03, 32582, 1989.2027, 353.68, 352.27, 354.02, 352.59, 353.68, 352.27
1989, 04, 32613, 1989.2877, 355.42, 352.86, 355.26, 352.69, 355.42, 352.86
1989, 05, 32643, 1989.3699, 355.67, 352.56, 355.90, 352.79, 355.67, 352.56
1989, 06, 32674, 1989.4548, 355.12, 352.77, 355.22, 352.89, 355.12, 352.77
1989, 07, 32704, 1989.5370, 353.90, 353.15, 353.70, 352.99, 353.90, 353.15
1989, 08, 32735, 1989.6219, 351.67, 353.07, 351.65, 353.08, 351.67, 353.07
1989, 09, 32766, 1989.7068, 349.81, 353.00, 349.97, 353.18, 349.81, 353.00
1989, 10, 32796, 1989.7890, 349.99, 353.30, 349.98, 353.28, 349.99, 353.30
1989, 11, 32827, 1989.8740, 351.30, 353.37, 351.33, 353.38, 351.30, 353.37
1989, 12, 32857, 1989.9562, 352.52, 353.37, 352.64, 353.48, 352.52, 353.37
1990, 01, 32888, 1990.0411, 353.66, 353.62, 353.63, 353.58, 353.66, 353.62
1990, 02, 32919, 1990.1260, 354.70, 354.01, 354.38, 353.68, 354.70, 354.01
1990, 03, 32947, 1990.2027, 355.38, 353.97, 355.20, 353.77, 355.38, 353.97
1990, 04, 32978, 1990.2877, 356.20, 353.64, 356.45, 353.88, 356.20, 353.64
1990, 05, 33008, 1990.3699, 357.16, 354.04, 357.10, 353.98, 357.16, 354.04
1990, 06, 33039, 1990.4548, 356.23, 353.87, 356.43, 354.09, 356.23, 353.87
1990, 07, 33069, 1990.5370, 354.81, 354.06, 354.93, 354.21, 354.81, 354.06
1990, 08, 33100, 1990.6219, 352.91, 354.31, 352.90, 354.35, 352.91, 354.31
1990, 09, 33131, 1990.7068, 350.96, 354.17, 351.26, 354.49, 350.96, 354.17
1990, 10, 33161, 1990.7890, 351.18, 354.50, 351.32, 354.63, 351.18, 354.50
1990, 11, 33192, 1990.8740, 352.83, 354.91, 352.72, 354.78, 352.83, 354.91
1990, 12, 33222, 1990.9562, 354.21, 355.06, 354.09, 354.93, 354.21, 355.06
1991, 01, 33253, 1991.0411, 354.72, 354.68, 355.13, 355.07, 354.72, 354.68
1991, 02, 33284, 1991.1260, 355.75, 355.05, 355.92, 355.21, 355.75, 355.05
1991, 03, 33312, 1991.2027, 357.16, 355.74, 356.77, 355.33, 357.16, 355.74
1991, 04, 33343, 1991.2877, 358.60, 356.03, 358.03, 355.45, 358.60, 356.03
1991, 05, 33373, 1991.3699, 359.34, 356.21, 358.67, 355.54, 359.34, 356.21
1991, 06, 33404, 1991.4548, 358.24, 355.87, 357.96, 355.62, 358.24, 355.87
1991, 07, 33434, 1991.5370, 356.17, 355.42, 356.40, 355.68, 356.17, 355.42
1991, 08, 33465, 1991.6219, 354.01, 355.42, 354.30, 355.74, 354.01, 355.42
1991, 09, 33496, 1991.7068, 352.15, 355.37, 352.56, 355.80, 352.15, 355.37
1991, 10, 33526, 1991.7890, 352.21, 355.55, 352.54, 355.86, 352.21, 355.55
1991, 11, 33557, 1991.8740, 353.75, 355.83, 353.86, 355.92, 353.75, 355.83
1991, 12, 33587, 1991.9562, 354.99, 355.85, 355.15, 355.99, 354.99, 355.85
1992, 01, 33618, 1992.0410, 355.99, 355.94, 356.12, 356.06, 355.99, 355.94
1992, 02, 33649, 1992.1257, 356.72, 356.03, 356.84, 356.13, 356.72, 356.03
1992, 03, 33678, 1992.2049, 357.81, 356.36, 357.66, 356.20, 357.81, 356.36
1992, 04, 33709, 1992.2896, 359.15, 356.55, 358.88, 356.26, 359.15, 356.55
1992, 05, 33739, 1992.3716, 359.66, 356.53, 359.45, 356.31, 359.66, 356.53
1992, 06, 33770, 1992.4563, 359.25, 356.90, 358.69, 356.36, 359.25, 356.90
1992, 07, 33800, 1992.5383, 357.02, 356.30, 357.09, 356.39, 357.02, 356.30
1992, 08, 33831, 1992.6230, 355.00, 356.44, 354.95, 356.43, 355.00, 356.44
1992, 09, 33862, 1992.7077, 353.01, 356.25, 353.20, 356.46, 353.01, 356.25
1992, 10, 33892, 1992.7896, 353.31, 356.65, 353.16, 356.49, 353.31, 356.65
1992, 11, 33923, 1992.8743, 354.16, 356.25, 354.46, 356.53, 354.16, 356.25
1992, 12, 33953, 1992.9563, 355.40, 356.25, 355.73, 356.57, 355.40, 356.25
1993, 01, 33984, 1993.0411, 356.70, 356.66, 356.68, 356.62, 356.70, 356.66
1993, 02, 34015, 1993.1260, 357.17, 356.46, 357.39, 356.68, 357.17, 356.46
1993, 03, 34043, 1993.2027, 358.38, 356.95, 358.19, 356.74, 358.38, 356.95
1993, 04, 34074, 1993.2877, 359.46, 356.88, 359.42, 356.82, 359.46, 356.88
1993, 05, 34104, 1993.3699, 360.28, 357.13, 360.05, 356.90, 360.28, 357.13
1993, 06, 34135, 1993.4548, 359.60, 357.21, 359.35, 356.99, 359.60, 357.21
1993, 07, 34165, 1993.5370, 357.57, 356.81, 357.81, 357.09, 357.57, 356.81
1993, 08, 34196, 1993.6219, 355.52, 356.94, 355.75, 357.20, 355.52, 356.94
1993, 09, 34227, 1993.7068, 353.69, 356.93, 354.07, 357.33, 353.69, 356.93
1993, 10, 34257, 1993.7890, 353.99, 357.34, 354.12, 357.46, 353.99, 357.34
1993, 11, 34288, 1993.8740, 355.34, 357.44, 355.54, 357.62, 355.34, 357.44
1993, 12, 34318, 1993.9562, 356.80, 357.66, 356.93, 357.77, 356.80, 357.66
1994, 01, 34349, 1994.0411, 358.37, 358.32, 358.00, 357.94, 358.37, 358.32
1994, 02, 34380, 1994.1260, 358.91, 358.21, 358.82, 358.11, 358.91, 358.21
1994, 03, 34408, 1994.2027, 359.97, 358.53, 359.71, 358.26, 359.97, 358.53
1994, 04, 34439, 1994.2877, 361.26, 358.67, 361.04, 358.43, 361.26, 358.67
1994, 05, 34469, 1994.3699, 361.69, 358.53, 361.75, 358.59, 361.69, 358.53
1994, 06, 34500, 1994.4548, 360.94, 358.56, 361.12, 358.76, 360.94, 358.56
1994, 07, 34530, 1994.5370, 359.55, 358.79, 359.65, 358.92, 359.55, 358.79
1994, 08, 34561, 1994.6219, 357.48, 358.90, 357.63, 359.09, 357.48, 358.90
1994, 09, 34592, 1994.7068, 355.84, 359.09, 356.00, 359.27, 355.84, 359.09
1994, 10, 34622, 1994.7890, 356.00, 359.36, 356.09, 359.44, 356.00, 359.36
1994, 11, 34653, 1994.8740, 357.58, 359.69, 357.54, 359.63, 357.58, 359.69
1994, 12, 34683, 1994.9562, 359.04, 359.90, 358.96, 359.81, 359.04, 359.90
1995, 01, 34714, 1995.0411, 359.97, 359.93, 360.05, 359.99, 359.97, 359.93
1995, 02, 34745, 1995.1260, 361.00, 360.30, 360.89, 360.17, 361.00, 360.30
1995, 03, 34773, 1995.2027, 361.63, 360.20, 361.78, 360.33, 361.63, 360.20
1995, 04, 34804, 1995.2877, 363.45, 360.85, 363.12, 360.50, 363.45, 360.85
1995, 05, 34834, 1995.3699, 363.80, 360.63, 363.83, 360.67, 363.80, 360.63
1995, 06, 34865, 1995.4548, 363.26, 360.87, 363.21, 360.83, 363.26, 360.87
1995, 07, 34895, 1995.5370, 361.89, 361.13, 361.72, 360.99, 361.89, 361.13
1995, 08, 34926, 1995.6219, 359.45, 360.88, 359.69, 361.15, 359.45, 360.88
1995, 09, 34957, 1995.7068, 358.05, 361.31, 358.03, 361.31, 358.05, 361.31
1995, 10, 34987, 1995.7890, 357.75, 361.13, 358.10, 361.47, 357.75, 361.13
1995, 11, 35018, 1995.8740, 359.56, 361.68, 359.54, 361.63, 359.56, 361.68
1995, 12, 35048, 1995.9562, 360.70, 361.56, 360.93, 361.78, 360.70, 361.56
1996, 01, 35079, 1996.0410, 362.05, 362.01, 361.99, 361.94, 362.05, 362.01
1996, 02, 35110, 1996.1257, 363.24, 362.54, 362.80, 362.08, 363.24, 362.54
1996, 03, 35139, 1996.2049, 364.02, 362.55, 363.69, 362.21, 364.02, 362.55
1996, 04, 35170, 1996.2896, 364.71, 362.08, 364.99, 362.33, 364.71, 362.08
1996, 05, 35200, 1996.3716, 365.42, 362.24, 365.62, 362.45, 365.42, 362.24
1996, 06, 35231, 1996.4563, 364.97, 362.59, 364.92, 362.56, 364.97, 362.59
1996, 07, 35261, 1996.5383, 363.65, 362.92, 363.36, 362.65, 363.65, 362.92
1996, 08, 35292, 1996.6230, 361.48, 362.94, 361.25, 362.75, 361.48, 362.94
1996, 09, 35323, 1996.7077, 359.45, 362.73, 359.53, 362.83, 359.45, 362.73
1996, 10, 35353, 1996.7896, 359.61, 362.99, 359.54, 362.91, 359.61, 362.99
1996, 11, 35384, 1996.8743, 360.76, 362.87, 360.90, 362.99, 360.76, 362.87
1996, 12, 35414, 1996.9563, 362.33, 363.19, 362.22, 363.07, 362.33, 363.19
1997, 01, 35445, 1997.0411, 363.18, 363.14, 363.20, 363.15, 363.18, 363.14
1997, 02, 35476, 1997.1260, 363.99, 363.28, 363.95, 363.23, 363.99, 363.28
1997, 03, 35504, 1997.2027, 364.56, 363.12, 364.78, 363.32, 364.56, 363.12
1997, 04, 35535, 1997.2877, 366.36, 363.74, 366.06, 363.42, 366.36, 363.74
1997, 05, 35565, 1997.3699, 366.80, 363.61, 366.73, 363.54, 366.80, 363.61
1997, 06, 35596, 1997.4548, 365.63, 363.22, 366.06, 363.67, 365.63, 363.22
1997, 07, 35626, 1997.5370, 364.47, 363.70, 364.56, 363.82, 364.47, 363.70
1997, 08, 35657, 1997.6219, 362.50, 363.94, 362.53, 364.00, 362.50, 363.94
1997, 09, 35688, 1997.7068, 360.19, 363.47, 360.90, 364.20, 360.19, 363.47
1997, 10, 35718, 1997.7890, 360.77, 364.17, 361.03, 364.42, 360.77, 364.17
1997, 11, 35749, 1997.8740, 362.43, 364.56, 362.56, 364.66, 362.43, 364.56
1997, 12, 35779, 1997.9562, 364.28, 365.15, 364.06, 364.91, 364.28, 365.15
1998, 01, 35810, 1998.0411, 365.33, 365.29, 365.24, 365.18, 365.33, 365.29
1998, 02, 35841, 1998.1260, 366.15, 365.44, 366.18, 365.46, 366.15, 365.44
1998, 03, 35869, 1998.2027, 367.31, 365.86, 367.17, 365.71, 367.31, 365.86
1998, 04, 35900, 1998.2877, 368.61, 365.99, 368.63, 365.98, 368.61, 365.99
1998, 05, 35930, 1998.3699, 369.30, 366.10, 369.44, 366.24, 369.30, 366.10
1998, 06, 35961, 1998.4548, 368.88, 366.46, 368.90, 366.51, 368.88, 366.46
1998, 07, 35991, 1998.5370, 367.64, 366.87, 367.48, 366.75, 367.64, 366.87
1998, 08, 36022, 1998.6219, 365.78, 367.22, 365.51, 366.98, 365.78, 367.22
1998, 09, 36053, 1998.7068, 363.90, 367.19, 363.89, 367.20, 363.90, 367.19
1998, 10, 36083, 1998.7890, 364.23, 367.64, 364.00, 367.39, 364.23, 367.64
1998, 11, 36114, 1998.8740, 365.46, 367.59, 365.46, 367.57, 365.46, 367.59
1998, 12, 36144, 1998.9562, 366.97, 367.84, 366.86, 367.72, 366.97, 367.84
1999, 01, 36175, 1999.0411, 368.15, 368.11, 367.91, 367.85, 368.15, 368.11
1999, 02, 36206, 1999.1260, 368.87, 368.16, 368.69, 367.96, 368.87, 368.16
1999, 03, 36234, 1999.2027, 369.59, 368.13, 369.52, 368.05, 369.59, 368.13
1999, 04, 36265, 1999.2877, 371.14, 368.50, 370.78, 368.13, 371.14, 368.50
1999, 05, 36295, 1999.3699, 371.00, 367.79, 371.41, 368.20, 371.00, 367.79
1999, 06, 36326, 1999.4548, 370.35, 367.93, 370.67, 368.27, 370.35, 367.93
1999, 07, 36356, 1999.5370, 369.27, 368.49, 369.07, 368.33, 369.27, 368.49
1999, 08, 36387, 1999.6219, 366.93, 368.37, 366.92, 368.40, 366.93, 368.37
1999, 09, 36418, 1999.7068, 364.64, 367.94, 365.16, 368.48, 364.64, 367.94
1999, 10, 36448, 1999.7890, 365.13, 368.55, 365.15, 368.56, 365.13, 368.55
1999, 11, 36479, 1999.8740, 366.68, 368.82, 366.53, 368.64, 366.68, 368.82
1999, 12, 36509, 1999.9562, 368.00, 368.88, 367.87, 368.73, 368.00, 368.88
2000, 01, 36540, 2000.0410, 369.14, 369.09, 368.88, 368.82, 369.14, 369.09
2000, 02, 36571, 2000.1257, 369.46, 368.75, 369.64, 368.91, 369.46, 368.75
2000, 03, 36600, 2000.2049, 370.51, 369.02, 370.51, 369.01, 370.51, 369.02
2000, 04, 36631, 2000.2896, 371.66, 368.99, 371.81, 369.12, 371.66, 368.99
2000, 05, 36661, 2000.3716, 371.83, 368.61, 372.45, 369.23, 371.83, 368.61
2000, 06, 36692, 2000.4563, 371.69, 369.28, 371.75, 369.36, 371.69, 369.28
2000, 07, 36722, 2000.5383, 370.12, 369.37, 370.21, 369.50, 370.12, 369.37
2000, 08, 36753, 2000.6230, 368.12, 369.60, 368.13, 369.64, 368.12, 369.60
2000, 09, 36784, 2000.7077, 366.62, 369.94, 366.45, 369.79, 366.62, 369.94
2000, 10, 36814, 2000.7896, 366.73, 370.15, 366.52, 369.93, 366.73, 370.15
2000, 11, 36845, 2000.8743, 368.29, 370.43, 367.95, 370.07, 368.29, 370.43
2000, 12, 36875, 2000.9563, 369.53, 370.40, 369.34, 370.20, 369.53, 370.40
2001, 01, 36906, 2001.0411, 370.28, 370.24, 370.38, 370.33, 370.28, 370.24
2001, 02, 36937, 2001.1260, 371.50, 370.78, 371.18, 370.45, 371.50, 370.78
2001, 03, 36965, 2001.2027, 372.12, 370.65, 372.04, 370.56, 372.12, 370.65
2001, 04, 36996, 2001.2877, 372.86, 370.21, 373.34, 370.67, 372.86, 370.21
2001, 05, 37026, 2001.3699, 374.02, 370.79, 374.02, 370.79, 374.02, 370.79
2001, 06, 37057, 2001.4548, 373.31, 370.87, 373.34, 370.92, 373.31, 370.87
2001, 07, 37087, 2001.5370, 371.62, 370.84, 371.80, 371.06, 371.62, 370.84
2001, 08, 37118, 2001.6219, 369.55, 371.00, 369.71, 371.20, 369.55, 371.00
2001, 09, 37149, 2001.7068, 367.96, 371.28, 368.01, 371.35, 367.96, 371.28
2001, 10, 37179, 2001.7890, 368.09, 371.54, 368.08, 371.51, 368.09, 371.54
2001, 11, 37210, 2001.8740, 369.68, 371.84, 369.54, 371.67, 369.68, 371.84
2001, 12, 37240, 2001.9562, 371.24, 372.12, 370.97, 371.83, 371.24, 372.12
2002, 01, 37271, 2002.0411, 372.44, 372.39, 372.06, 372.00, 372.44, 372.39
2002, 02, 37302, 2002.1260, 373.08, 372.36, 372.91, 372.17, 373.08, 372.36
2002, 03, 37330, 2002.2027, 373.52, 372.05, 373.82, 372.34, 373.52, 372.05
2002, 04, 37361, 2002.2877, 374.85, 372.19, 375.20, 372.52, 374.85, 372.19
2002, 05, 37391, 2002.3699, 375.55, 372.31, 375.95, 372.71, 375.55, 372.31
2002, 06, 37422, 2002.4548, 375.40, 372.95, 375.35, 372.92, 375.40, 372.95
2002, 07, 37452, 2002.5370, 374.02, 373.24, 373.88, 373.14, 374.02, 373.24
2002, 08, 37483, 2002.6219, 371.48, 372.94, 371.87, 373.36, 371.48, 372.94
2002, 09, 37514, 2002.7068, 370.70, 374.03, 370.25, 373.60, 370.70, 374.03
2002, 10, 37544, 2002.7890, 370.25, 373.70, 370.39, 373.83, 370.25, 373.70
2002, 11, 37575, 2002.8740, 372.08, 374.24, 371.92, 374.06, 372.08, 374.24
2002, 12, 37605, 2002.9562, 373.78, 374.67, 373.42, 374.28, 373.78, 374.67
2003, 01, 37636, 2003.0411, 374.68, 374.64, 374.56, 374.51, 374.68, 374.64
2003, 02, 37667, 2003.1260, 375.62, 374.90, 375.46, 374.72, 375.62, 374.90
2003, 03, 37695, 2003.2027, 376.11, 374.63, 376.41, 374.92, 376.11, 374.63
2003, 04, 37726, 2003.2877, 377.65, 374.98, 377.82, 375.13, 377.65, 374.98
2003, 05, 37756, 2003.3699, 378.35, 375.11, 378.58, 375.33, 378.35, 375.11
2003, 06, 37787, 2003.4548, 378.13, 375.67, 377.97, 375.53, 378.13, 375.67
2003, 07, 37817, 2003.5370, 376.60, 375.82, 376.48, 375.73, 376.60, 375.82
2003, 08, 37848, 2003.6219, 374.48, 375.95, 374.42, 375.92, 374.48, 375.95
2003, 09, 37879, 2003.7068, 372.98, 376.32, 372.74, 376.10, 372.98, 376.32
2003, 10, 37909, 2003.7890, 373.00, 376.46, 372.81, 376.26, 373.00, 376.46
2003, 11, 37940, 2003.8740, 374.35, 376.51, 374.28, 376.42, 374.35, 376.51
2003, 12, 37970, 2003.9562, 375.69, 376.57, 375.70, 376.57, 375.69, 376.57
2004, 01, 38001, 2004.0410, 376.79, 376.74, 376.77, 376.71, 376.79, 376.74
2004, 02, 38032, 2004.1257, 377.37, 376.64, 377.57, 376.84, 377.37, 376.64
2004, 03, 38061, 2004.2049, 378.39, 376.89, 378.48, 376.96, 378.39, 376.89
2004, 04, 38092, 2004.2896, 380.50, 377.80, 379.80, 377.08, 380.50, 377.80
2004, 05, 38122, 2004.3716, 380.62, 377.36, 380.45, 377.19, 380.62, 377.36
2004, 06, 38153, 2004.4563, 379.55, 377.11, 379.73, 377.31, 379.55, 377.11
2004, 07, 38183, 2004.5383, 377.76, 377.01, 378.15, 377.43, 377.76, 377.01
2004, 08, 38214, 2004.6230, 375.83, 377.33, 376.03, 377.56, 375.83, 377.33
2004, 09, 38245, 2004.7077, 374.05, 377.41, 374.33, 377.72, 374.05, 377.41
2004, 10, 38275, 2004.7896, 374.22, 377.69, 374.42, 377.88, 374.22, 377.69
2004, 11, 38306, 2004.8743, 375.84, 378.01, 375.91, 378.06, 375.84, 378.01
2004, 12, 38336, 2004.9563, 377.44, 378.33, 377.37, 378.24, 377.44, 378.33
2005, 01, 38367, 2005.0411, 378.34, 378.29, 378.51, 378.45, 378.34, 378.29
2005, 02, 38398, 2005.1260, 379.61, 378.88, 379.40, 378.66, 379.61, 378.88
2005, 03, 38426, 2005.2027, 380.08, 378.60, 380.36, 378.86, 380.08, 378.60
2005, 04, 38457, 2005.2877, 382.05, 379.36, 381.78, 379.08, 382.05, 379.36
2005, 05, 38487, 2005.3699, 382.24, 378.97, 382.56, 379.29, 382.24, 378.97
2005, 06, 38518, 2005.4548, 382.08, 379.61, 381.96, 379.51, 382.08, 379.61
2005, 07, 38548, 2005.5370, 380.66, 379.88, 380.47, 379.72, 380.66, 379.88
2005, 08, 38579, 2005.6219, 378.67, 380.14, 378.43, 379.94, 378.67, 380.14
2005, 09, 38610, 2005.7068, 376.42, 379.78, 376.76, 380.15, 376.42, 379.78
2005, 10, 38640, 2005.7890, 376.80, 380.29, 376.87, 380.34, 376.80, 380.29
2005, 11, 38671, 2005.8740, 378.31, 380.49, 378.39, 380.54, 378.31, 380.49
2005, 12, 38701, 2005.9562, 379.96, 380.85, 379.86, 380.73, 379.96, 380.85
2006, 01, 38732, 2006.0411, 381.37, 381.32, 380.97, 380.91, 381.37, 381.32
2006, 02, 38763, 2006.1260, 382.02, 381.29, 381.82, 381.08, 382.02, 381.29
2006, 03, 38791, 2006.2027, 382.56, 381.07, 382.74, 381.23, 382.56, 381.07
2006, 04, 38822, 2006.2877, 384.36, 381.67, 384.10, 381.39, 384.36, 381.67
2006, 05, 38852, 2006.3699, 384.92, 381.64, 384.81, 381.53, 384.92, 381.64
2006, 06, 38883, 2006.4548, 384.03, 381.55, 384.14, 381.68, 384.03, 381.55
2006, 07, 38913, 2006.5370, 382.28, 381.49, 382.58, 381.82, 382.28, 381.49
2006, 08, 38944, 2006.6219, 380.48, 381.95, 380.46, 381.97, 380.48, 381.95
2006, 09, 38975, 2006.7068, 378.81, 382.18, 378.73, 382.12, 378.81, 382.18
2006, 10, 39005, 2006.7890, 379.06, 382.55, 378.78, 382.27, 379.06, 382.55
2006, 11, 39036, 2006.8740, 380.14, 382.33, 380.25, 382.42, 380.14, 382.33
2006, 12, 39066, 2006.9562, 381.66, 382.55, 381.69, 382.56, 381.66, 382.55
2007, 01, 39097, 2007.0411, 382.58, 382.54, 382.77, 382.71, 382.58, 382.54
2007, 02, 39128, 2007.1260, 383.71, 382.98, 383.61, 382.87, 383.71, 382.98
2007, 03, 39156, 2007.2027, 384.34, 382.84, 384.52, 383.01, 384.34, 382.84
2007, 04, 39187, 2007.2877, 386.23, 383.52, 385.89, 383.17, 386.23, 383.52
2007, 05, 39217, 2007.3699, 386.41, 383.12, 386.61, 383.33, 386.41, 383.12
2007, 06, 39248, 2007.4548, 385.87, 383.38, 385.95, 383.49, 385.87, 383.38
2007, 07, 39278, 2007.5370, 384.44, 383.65, 384.40, 383.65, 384.44, 383.65
2007, 08, 39309, 2007.6219, 381.84, 383.33, 382.29, 383.81, 381.84, 383.33
2007, 09, 39340, 2007.7068, 380.86, 384.25, 380.57, 383.98, 380.86, 384.25
2007, 10, 39370, 2007.7890, 380.86, 384.37, 380.64, 384.13, 380.86, 384.37
2007, 11, 39401, 2007.8740, 382.36, 384.55, 382.12, 384.29, 382.36, 384.55
2007, 12, 39431, 2007.9562, 383.61, 384.51, 383.56, 384.44, 383.61, 384.51
2008, 01, 39462, 2008.0410, 385.07, 385.02, 384.64, 384.58, 385.07, 385.02
2008, 02, 39493, 2008.1257, 385.84, 385.11, 385.47, 384.73, 385.84, 385.11
2008, 03, 39522, 2008.2049, 385.83, 384.31, 386.41, 384.86, 385.83, 384.31
2008, 04, 39553, 2008.2896, 386.77, 384.03, 387.77, 385.02, 386.77, 384.03
2008, 05, 39583, 2008.3716, 388.51, 385.21, 388.47, 385.18, 388.51, 385.21
2008, 06, 39614, 2008.4563, 388.05, 385.58, 387.79, 385.34, 388.05, 385.58
2008, 07, 39644, 2008.5383, 386.25, 385.49, 386.24, 385.51, 386.25, 385.49
2008, 08, 39675, 2008.6230, 384.08, 385.60, 384.13, 385.68, 384.08, 385.60
2008, 09, 39706, 2008.7077, 383.09, 386.49, 382.42, 385.85, 383.09, 386.49
2008, 10, 39736, 2008.7896, 382.78, 386.29, 382.51, 386.00, 382.78, 386.29
2008, 11, 39767, 2008.8743, 384.01, 386.21, 383.99, 386.16, 384.01, 386.21
2008, 12, 39797, 2008.9563, 385.11, 386.01, 385.43, 386.31, 385.11, 386.01
2009, 01, 39828, 2009.0411, 386.65, 386.61, 386.52, 386.47, 386.65, 386.61
2009, 02, 39859, 2009.1260, 387.12, 386.39, 387.37, 386.62, 387.12, 386.39
2009, 03, 39887, 2009.2027, 388.52, 387.02, 388.29, 386.77, 388.52, 387.02
2009, 04, 39918, 2009.2877, 389.57, 386.85, 389.67, 386.93, 389.57, 386.85
2009, 05, 39948, 2009.3699, 390.17, 386.86, 390.41, 387.10, 390.17, 386.86
2009, 06, 39979, 2009.4548, 389.62, 387.12, 389.76, 387.28, 389.62, 387.12
2009, 07, 40009, 2009.5370, 388.07, 387.27, 388.23, 387.47, 388.07, 387.27
2009, 08, 40040, 2009.6219, 386.08, 387.57, 386.14, 387.67, 386.08, 387.57
2009, 09, 40071, 2009.7068, 384.65, 388.06, 384.46, 387.88, 384.65, 388.06
2009, 10, 40101, 2009.7890, 384.33, 387.86, 384.58, 388.09, 384.33, 387.86
2009, 11, 40132, 2009.8740, 386.05, 388.26, 386.13, 388.31, 386.05, 388.26
2009, 12, 40162, 2009.9562, 387.49, 388.39, 387.65, 388.53, 387.49, 388.39
2010, 01, 40193, 2010.0411, 388.55, 388.51, 388.82, 388.76, 388.55, 388.51
2010, 02, 40224, 2010.1260, 390.07, 389.34, 389.73, 388.99, 390.07, 389.34
2010, 03, 40252, 2010.2027, 391.01, 389.51, 390.71, 389.18, 391.01, 389.51
2010, 04, 40283, 2010.2877, 392.38, 389.65, 392.13, 389.39, 392.38, 389.65
2010, 05, 40313, 2010.3699, 393.22, 389.90, 392.90, 389.58, 393.22, 389.90
2010, 06, 40344, 2010.4548, 392.24, 389.73, 392.25, 389.76, 392.24, 389.73
2010, 07, 40374, 2010.5370, 390.33, 389.53, 390.70, 389.94, 390.33, 389.53
2010, 08, 40405, 2010.6219, 388.52, 390.02, 388.57, 390.11, 388.52, 390.02
2010, 09, 40436, 2010.7068, 386.84, 390.25, 386.84, 390.27, 386.84, 390.25
2010, 10, 40466, 2010.7890, 387.16, 390.70, 386.90, 390.43, 387.16, 390.70
2010, 11, 40497, 2010.8740, 388.67, 390.88, 388.39, 390.58, 388.67, 390.88
2010, 12, 40527, 2010.9562, 389.81, 390.71, 389.82, 390.71, 389.81, 390.71
2011, 01, 40558, 2011.0411, 391.30, 391.25, 390.90, 390.84, 391.30, 391.25
2011, 02, 40589, 2011.1260, 391.92, 391.18, 391.73, 390.97, 391.92, 391.18
2011, 03, 40617, 2011.2027, 392.45, 390.94, 392.62, 391.09, 392.45, 390.94
2011, 04, 40648, 2011.2877, 393.37, 390.63, 393.98, 391.23, 393.37, 390.63
2011, 05, 40678, 2011.3699, 394.28, 390.95, 394.70, 391.37, 394.28, 390.95
2011, 06, 40709, 2011.4548, 393.69, 391.18, 394.02, 391.53, 393.69, 391.18
2011, 07, 40739, 2011.5370, 392.59, 391.79, 392.46, 391.69, 392.59, 391.79
2011, 08, 40770, 2011.6219, 390.21, 391.71, 390.33, 391.87, 390.21, 391.71
2011, 09, 40801, 2011.7068, 389.00, 392.43, 388.60, 392.05, 389.00, 392.43
2011, 10, 40831, 2011.7890, 388.93, 392.48, 388.69, 392.22, 388.93, 392.48
2011, 11, 40862, 2011.8740, 390.24, 392.46, 390.21, 392.41, 390.24, 392.46
2011, 12, 40892, 2011.9562, 391.80, 392.71, 391.69, 392.58, 391.80, 392.71
2012, 01, 40923, 2012.0410, 393.07, 393.03, 392.83, 392.77, 393.07, 393.03
2012, 02, 40954, 2012.1257, 393.35, 392.61, 393.71, 392.96, 393.35, 392.61
2012, 03, 40983, 2012.2049, 394.36, 392.81, 394.70, 393.14, 394.36, 392.81
2012, 04, 41014, 2012.2896, 396.43, 393.66, 396.13, 393.34, 396.43, 393.66
2012, 05, 41044, 2012.3716, 396.87, 393.53, 396.88, 393.54, 396.87, 393.53
2012, 06, 41075, 2012.4563, 395.88, 393.38, 396.24, 393.76, 395.88, 393.38
2012, 07, 41105, 2012.5383, 394.52, 393.75, 394.72, 393.98, 394.52, 393.75
2012, 08, 41136, 2012.6230, 392.54, 394.07, 392.64, 394.21, 392.54, 394.07
2012, 09, 41167, 2012.7077, 391.13, 394.57, 390.99, 394.45, 391.13, 394.57
2012, 10, 41197, 2012.7896, 391.01, 394.56, 391.15, 394.69, 391.01, 394.56
2012, 11, 41228, 2012.8743, 392.95, 395.17, 392.74, 394.93, 392.95, 395.17
2012, 12, 41258, 2012.9563, 394.33, 395.25, 394.27, 395.16, 394.33, 395.25
2013, 01, 41289, 2013.0411, 395.61, 395.56, 395.46, 395.40, 395.61, 395.56
2013, 02, 41320, 2013.1260, 396.85, 396.10, 396.38, 395.62, 396.85, 396.10
2013, 03, 41348, 2013.2027, 397.26, 395.74, 397.36, 395.82, 397.26, 395.74
2013, 04, 41379, 2013.2877, 398.35, 395.60, 398.81, 396.04, 398.35, 395.60
2013, 05, 41409, 2013.3699, 399.98, 396.63, 399.59, 396.24, 399.98, 396.63
2013, 06, 41440, 2013.4548, 398.87, 396.34, 398.95, 396.44, 398.87, 396.34
2013, 07, 41470, 2013.5370, 397.37, 396.56, 397.40, 396.63, 397.37, 396.56
2013, 08, 41501, 2013.6219, 395.41, 396.92, 395.28, 396.83, 395.41, 396.92
2013, 09, 41532, 2013.7068, 393.39, 396.84, 393.55, 397.01, 393.39, 396.84
2013, 10, 41562, 2013.7890, 393.70, 397.27, 393.64, 397.19, 393.70, 397.27
2013, 11, 41593, 2013.8740, 395.19, 397.43, 395.16, 397.37, 395.19, 397.43
2013, 12, 41623, 2013.9562, 396.82, 397.74, 396.65, 397.54, 396.82, 397.74
2014, 01, 41654, 2014.0411, 397.93, 397.88, 397.77, 397.71, 397.93, 397.88
2014, 02, 41685, 2014.1260, 398.10, 397.35, 398.64, 397.88, 398.10, 397.35
2014, 03, 41713, 2014.2027, 399.47, 397.94, 399.58, 398.03, 399.47, 397.94
2014, 04, 41744, 2014.2877, 401.33, 398.57, 400.98, 398.20, 401.33, 398.57
2014, 05, 41774, 2014.3699, 401.88, 398.52, 401.71, 398.36, 401.88, 398.52
2014, 06, 41805, 2014.4548, 401.31, 398.76, 401.04, 398.52, 401.31, 398.76
2014, 07, 41835, 2014.5370, 399.07, 398.26, 399.45, 398.67, 399.07, 398.26
2014, 08, 41866, 2014.6219, 397.21, 398.72, 397.28, 398.84, 397.21, 398.72
2014, 09, 41897, 2014.7068, 395.40, 398.86, 395.53, 399.00, 395.40, 398.86
2014, 10, 41927, 2014.7890, 395.65, 399.23, 395.60, 399.17, 395.65, 399.23
2014, 11, 41958, 2014.8740, 397.23, 399.47, 397.13, 399.35, 397.23, 399.47
2014, 12, 41988, 2014.9562, 398.79, 399.70, 398.62, 399.52, 398.79, 399.70
2015, 01, 42019, 2015.0411, 399.85, 399.81, 399.76, 399.70, 399.85, 399.81
2015, 02, 42050, 2015.1260, 400.31, 399.56, 400.65, 399.89, 400.31, 399.56
2015, 03, 42078, 2015.2027, 401.51, 399.98, 401.62, 400.07, 401.51, 399.98
2015, 04, 42109, 2015.2877, 403.45, 400.68, 403.07, 400.28, 403.45, 400.68
2015, 05, 42139, 2015.3699, 404.10, 400.73, 403.86, 400.49, 404.10, 400.73
2015, 06, 42170, 2015.4548, 402.88, 400.33, 403.25, 400.73, 402.88, 400.33
2015, 07, 42200, 2015.5370, 401.61, 400.80, 401.75, 400.97, 401.61, 400.80
2015, 08, 42231, 2015.6219, 399.00, 400.52, 399.69, 401.25, 399.00, 400.52
2015, 09, 42262, 2015.7068, 397.50, 400.96, 398.06, 401.55, 397.50, 400.96
2015, 10, 42292, 2015.7890, 398.28, 401.88, 398.27, 401.85, 398.28, 401.88
2015, 11, 42323, 2015.8740, 400.24, 402.49, 399.95, 402.17, 400.24, 402.49
2015, 12, 42353, 2015.9562, 401.89, 402.81, 401.58, 402.48, 401.89, 402.81
2016, 01, 42384, 2016.0410, 402.65, 402.60, 402.86, 402.80, 402.65, 402.60
2016, 02, 42415, 2016.1257, 404.16, 403.41, 403.87, 403.11, 404.16, 403.41
2016, 03, 42444, 2016.2049, 404.85, 403.29, 404.97, 403.39, 404.85, 403.29
2016, 04, 42475, 2016.2896, 407.57, 404.76, 406.49, 403.67, 407.57, 404.76
2016, 05, 42505, 2016.3716, 407.66, 404.28, 407.30, 403.92, 407.66, 404.28
2016, 06, 42536, 2016.4563, 407.00, 404.47, 406.67, 404.16, 407.00, 404.47
2016, 07, 42566, 2016.5383, 404.50, 403.72, 405.13, 404.38, 404.50, 403.72
2016, 08, 42597, 2016.6230, 402.24, 403.79, 403.01, 404.60, 402.24, 403.79
2016, 09, 42628, 2016.7077, 401.01, 404.50, 401.32, 404.83, 401.01, 404.50
2016, 10, 42658, 2016.7896, 401.50, 405.10, 401.45, 405.04, 401.50, 405.10
2016, 11, 42689, 2016.8743, 403.64, 405.89, 403.02, 405.25, 403.64, 405.89
2016, 12, 42719, 2016.9563, 404.55, 405.47, 404.54, 405.44, 404.55, 405.47
2017, 01, 42750, 2017.0411, 406.07, 406.03, 405.69, 405.63, 406.07, 406.03
2017, 02, 42781, 2017.1260, 406.64, 405.89, 406.58, 405.81, 406.64, 405.89
2017, 03, 42809, 2017.2027, 407.06, 405.52, 407.52, 405.97, 407.06, 405.52
2017, 04, 42840, 2017.2877, 408.95, 406.16, 408.94, 406.13, 408.95, 406.16
2017, 05, 42870, 2017.3699, 409.91, 406.52, 409.68, 406.29, 409.91, 406.52
2017, 06, 42901, 2017.4548, 409.12, 406.55, 408.99, 406.45, 409.12, 406.55
2017, 07, 42931, 2017.5370, 407.20, 406.38, 407.39, 406.61, 407.20, 406.38
2017, 08, 42962, 2017.6219, 405.24, 406.77, 405.20, 406.76, 405.24, 406.77
2017, 09, 42993, 2017.7068, 403.27, 406.76, 403.41, 406.92, 403.27, 406.76
2017, 10, 43023, 2017.7890, 403.64, 407.25, 403.47, 407.07, 403.64, 407.25
2017, 11, 43054, 2017.8740, 405.17, 407.43, 404.98, 407.22, 405.17, 407.43
2017, 12, 43084, 2017.9562, 406.75, 407.68, 406.46, 407.37, 406.75, 407.68
2018, 01, 43115, 2018.0411, 408.05, 408.00, 407.58, 407.52, 408.05, 408.00
2018, 02, 43146, 2018.1260, 408.34, 407.59, 408.44, 407.68, 408.34, 407.59
2018, 03, 43174, 2018.2027, 409.25, 407.71, 409.39, 407.82, 409.25, 407.71
2018, 04, 43205, 2018.2877, 410.30, 407.51, 410.82, 408.00, 410.30, 407.51
2018, 05, 43235, 2018.3699, 411.30, 407.90, 411.60, 408.20, 411.30, 407.90
2018, 06, 43266, 2018.4548, 410.88, 408.30, 410.97, 408.42, 410.88, 408.30
2018, 07, 43296, 2018.5370, 408.90, 408.08, 409.43, 408.65, 408.90, 408.08
2018, 08, 43327, 2018.6219, 407.10, 408.63, 407.33, 408.91, 407.10, 408.63
2018, 09, 43358, 2018.7068, 405.59, 409.09, 405.66, 409.18, 405.59, 409.09
2018, 10, 43388, 2018.7890, 405.99, 409.62, 405.83, 409.44, 405.99, 409.62
2018, 11, 43419, 2018.8740, 408.12, 410.39, 407.47, 409.72, 408.12, 410.39
2018, 12, 43449, 2018.9562, 409.23, 410.16, 409.07, 409.97, 409.23, 410.16
2019, 01, 43480, 2019.0411, 410.92, 410.87, 410.29, 410.23, 410.92, 410.87
2019, 02, 43511, 2019.1260, 411.66, 410.90, 411.24, 410.47, 411.66, 410.90
2019, 03, 43539, 2019.2027, 412.00, 410.45, 412.25, 410.68, 412.00, 410.45
2019, 04, 43570, 2019.2877, 413.52, 410.72, 413.73, 410.91, 413.52, 410.72
2019, 05, 43600, 2019.3699, 414.83, 411.42, 414.54, 411.13, 414.83, 411.42
2019, 06, 43631, 2019.4548, 413.96, 411.38, 413.91, 411.35, 413.96, 411.38
2019, 07, 43661, 2019.5370, 411.85, 411.03, 412.36, 411.57, 411.85, 411.03
2019, 08, 43692, 2019.6219, 410.08, 411.62, 410.23, 411.81, 410.08, 411.62
2019, 09, 43723, 2019.7068, 408.55, 412.06, 408.52, 412.05, 408.55, 412.06
2019, 10, 43753, 2019.7890, 408.43, 412.07, 408.67, 412.29, 408.43, 412.07
2019, 11, 43784, 2019.8740, 410.28, 412.56, 410.29, 412.54, 410.28, 412.56
2019, 12, 43814, 2019.9562, 411.85, 412.78, 411.88, 412.79, 411.85, 412.78
2020, 01, 43845, 2020.0410, 413.37, 413.33, 413.11, 413.05, 413.37, 413.33
2020, 02, 43876, 2020.1257, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99
2020, 03, 43905, 2020.2049, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99
2020, 04, 43936, 2020.2896, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99
2020, 05, 43966, 2020.3716, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99
2020, 06, 43997, 2020.4563, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99
2020, 07, 44027, 2020.5383, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99
2020, 08, 44058, 2020.6230, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99
2020, 09, 44089, 2020.7077, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99
2020, 10, 44119, 2020.7896, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99
2020, 11, 44150, 2020.8743, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99
2020, 12, 44180, 2020.9563, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99
