Update toy_document_orgmode_R_en.org
parent ad6da5f0
...@@ -20,8 +20,10 @@ pi ...@@ -20,8 +20,10 @@ pi
#+RESULTS: #+RESULTS:
: [1] 3.141593 : [1] 3.141593
* Buffon's needle * Buffon's needle
Applying the method of [[https://en.wikipedia.org/wiki/Buffon%2527s_needle_problem][Buffon's needle]], we get the *approximation* Applying the method of [[https://en.wikipedia.org/wiki/Buffon%2527s_needle_problem][Buffon's needle]], we get the *approximation*
#+begin_src R :results output :session *R* :exports both #+begin_src R :results output :session *R* :exports both
set.seed(42) set.seed(42)
N = 100000 N = 100000
...@@ -29,10 +31,13 @@ x = runif(N) ...@@ -29,10 +31,13 @@ x = runif(N)
theta = pi/2*runif(N) theta = pi/2*runif(N)
2/(mean(x+sin(theta)>1)) 2/(mean(x+sin(theta)>1))
#+end_src #+end_src
: [1] 3.14327 : [1] 3.14327
* Using a surface fraction argument * Using a surface fraction argument
A method that is easier to understand and does not make use of the $\sin$ function is based on the fact that if $X\sim U(0,1)$ and $Y\sim U(0,1)$, then $P[X^2+Y^2\leq 1] = \pi/4$ (see [[https://en.wikipedia.org/wiki/Monte_Carlo_method]["Monte Carlo method" on Wikipedia]]). The following code uses this approach: A method that is easier to understand and does not make use of the $\sin$ function is based on the fact that if $X\sim U(0,1)$ and $Y\sim U(0,1)$, then $P[X^2+Y^2\leq 1] = \pi/4$ (see [[https://en.wikipedia.org/wiki/Monte_Carlo_method]["Monte Carlo method" on Wikipedia]]). The following code uses this approach:
#+begin_src R :results output graphics :file figure_pi_mc1.png :exports both :width 600 :height 400 :session *R* #+begin_src R :results output graphics :file figure_pi_mc1.png :exports both :width 600 :height 400 :session *R*
N = 1000 N = 1000
...@@ -41,11 +46,15 @@ df$Accept = (df$X**2 + df$Y**2 <=1) ...@@ -41,11 +46,15 @@ df$Accept = (df$X**2 + df$Y**2 <=1)
library(ggplot2) library(ggplot2)
ggplot(df, aes(x=X,y=Y,color=Accept)) + geom_point(alpha=.2) + coord_fixed() + theme_bw() ggplot(df, aes(x=X,y=Y,color=Accept)) + geom_point(alpha=.2) + coord_fixed() + theme_bw()
#+end_src #+end_src
[[file:figure_pi_mc1.png]] [[file:figure_pi_mc1.png]]
It is then straightforward to obtain a (not really good) approximation to $\pi$ by counting how many times, on average, $X^2 + Y^2$ is smaller than 1: It is then straightforward to obtain a (not really good) approximation to $\pi$ by counting how many times, on average, $X^2 + Y^2$ is smaller than 1:
4*mean(df$Accept) 4*mean(df$Accept)
#+end_src #+end_src
: [1] 3.156 : [1] 3.156
