Commit 65641621 authored by landri01's avatar landri01
Update exercice_fr.Rmd
parent 5dd5bb7b
...@@ -6,28 +6,16 @@ output: html_document ...@@ -6,28 +6,16 @@ output: html_document
```{r setup, include=FALSE} ## Module 2 exo 3
## Quelques explications
```{r cars} ```{r}
summary(cars) plot(x, type = "l", col = "blue", lwd = 2,grid = TRUE, ylim = c(0, 25),xaxs = "i")
abline(h = seq(0, 25, by = 5), col = "gray", lty = 2) # lignes horizontales
abline(v = seq(1, length(x), by = 10), col = "gray", lty = 2) # lignes verticales
Et on peut aussi aisément inclure des figures. Par exemple: ```{r}
hist(x,col = "blue",ylim=c(0,25))
```{r pressure, echo=FALSE} abline(h = seq(0, 25, by = 5), col = "gray", lty = 2) # lignes horizontales
plot(pressure) abline(v = seq(1, length(x), by = 5), col = "gray", lty = 2) # lignes verticales
\ No newline at end of file
