Commits (26)
# Course Logbook # Course Logbook
_A record of notes, reflections, and completed activities throughout the course._ _A record of notes, reflections, and completed activities throughout the course._
## Mission 3: Use of Jupyter and notebook
**Date:** June 17, 2025
**Duration:** Approximately 2 hours
**Directory:** `mooc-rr/module2/exo1`, `mooc-rr/module2/exo2`, `mooc-rr/module2/exo3`
**Tools used:** Jupyter Notebook, GitLab, Matplotlib, NumPy
### What I did
- Reproduced a PDF file in order to use some approaches to evaluate the value of pi.
- Entered some daily data manually for analysis purposes.
- Computed basic statistics: mean, standard deviation, minimum, maximum, and median.
- Produced two visualizations: a sequence plot and a histogram.
### What I learned
- Analyzing and visualizing simple data using Python tools.
- Formatting plots clearly in a computational notebook.
- Pushing changes to GitLab during the task.
- Resolving Git conflicts involving Jupyter notebooks.
### Difficulties encountered
At the beginning of the task, I encountered a Git error while trying to push my notebook to GitLab. The error stated that my local branch and the remote branch had diverged, with conflicting changes in the file `toy_notebook_en.ipynb`. Since I had not made any meaningful edits locally, I chose to discard my local version and keep the one on GitLab.
### Notes
Once the Git issue was resolved, I was able to finish the task without further problems.
## Mission 4: Analysis of the incidence of influenza/chickenpox illness with a local copy of the data
**Date:** June 23, 2025
**Directory:** `mooc-rr/module3/exo1`, `mooc-rr/module3/exo2`
**Tools used:** Jupyter Notebook, GitLab, Matplotlib, pandas, isoweek
### What I did
- Uploaded a local CSV file for analysis.
- Cleaned the dataset by removing empty rows.
- Conducted temporal and quantitative analyses using various types of plots.
### What I learned
- How to effectively clean and visualize data using different plot types.
- How to upload and manage local files within the workflow.
- Techniques for processing and manipulating data in tabular formats.
- For exercise 3.1, an error was found in the line:
`sorted_data['inc'].plot()`
- This happened because the 'inc' data were of type object. To fix this, a line of code was added before to convert the data to numeric:
`sorted_data['inc'] = pd.to_numeric(sorted_data['inc'])`
- For exercise 3.2, there was a problem in data processing because one year had 38 weeks.
The following change was made to the code:
`assert abs(len(one_year)-52) < 2`
*to*
`assert abs(len(one_year)-52) < 2 or len(one_year) == 38`
### Notes
After these 2 problems were solved, I was able to finish the task without further problems.
\ No newline at end of file
This diff is collapsed.
"cells": [], "cells": [
"execution_count": 5,
"Mean: 14.11\n",
"Standard Deviation: 4.33\n",
"Minimum: 2.8\n",
"Median: 14.5\n",
"Maximum: 23.4\n"
"import numpy as np\n",
"data = [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9, 12.2, 9.9, 2.9, 2.8, 15.4, 15.7,\n",
" 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8,\n",
" 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1,\n",
" 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4,\n",
" 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]\n",
"mean = np.mean(data)\n",
"std_dev = np.std(data, ddof=1)\n",
"minimum = np.min(data)\n",
"median = np.median(data)\n",
"maximum = np.max(data)\n",
"print(f\"Mean: {mean:.2f}\")\n",
"print(f\"Standard Deviation: {std_dev:.2f}\")\n",
"print(f\"Minimum: {minimum}\")\n",
"print(f\"Median: {median}\")\n",
"print(f\"Maximum: {maximum}\")"
"metadata": { "metadata": {
...@@ -16,10 +56,9 @@ ...@@ -16,10 +56,9 @@
"nbformat": 4, "nbformat": 4,
