diff --git a/module2/exo5/exo5_R_en.ipynb b/module2/exo5/exo5_R_en.ipynb
deleted file mode 100644
index 8a59929db138d63685277409cc7774df4a55e070..0000000000000000000000000000000000000000
--- a/module2/exo5/exo5_R_en.ipynb
+++ /dev/null
@@ -1,503 +0,0 @@
- "cells": [
- "cell_type": "markdown",
- "metadata": {},
- "source": [
- "# Analysis of the risk of failure of the O-rings on the Challenger shuttle"
- "metadata": {},
- "source": [
- "On January 27, 1986, the day before the takeoff of the shuttle _Challenger_, had\n",
- "a three-hour teleconference was held between \n",
- "Morton Thiokol (the manufacturer of one of the engines) and NASA. The\n",
- "discussion focused on the consequences of the\n",
- "temperature at take-off of 31°F (just below\n",
- "0°C) for the success of the flight and in particular on the performance of the\n",
- "O-rings used in the engines. Indeed, no test\n",
- "had been performed at this temperature.\n",
- "\n",
- "The following study takes up some of the analyses carried out that\n",
- "night with the objective of assessing the potential influence of\n",
- "the temperature and pressure to which the O-rings are subjected\n",
- "on their probability of malfunction. Our starting point is \n",
- "the results of the experiments carried out by NASA engineers\n",
- "during the six years preceding the launch of the shuttle\n",
- "Challenger."
- "metadata": {},
- "source": [
- "## Loading the data\n",
- "We start by loading this data:"
- "cell_type": "code",
- "execution_count": 1,
- "metadata": {},
- "outputs": [
- "data": {
- "text/html": [
\n",
- "A data.frame: 23 × 5\n",
- "\n",
- "\t| Date | Count | Temperature | Pressure | Malfunction |
\n",
- "\t| <fct> | <int> | <int> | <int> | <int> |
\n",
- "\n",
- "\n",
- "\t| 4/12/81 | 6 | 66 | 50 | 0 |
\n",
- "\t| 11/12/81 | 6 | 70 | 50 | 1 |
\n",
- "\t| 3/22/82 | 6 | 69 | 50 | 0 |
\n",
- "\t| 11/11/82 | 6 | 68 | 50 | 0 |
\n",
- "\t| 4/04/83 | 6 | 67 | 50 | 0 |
\n",
- "\t| 6/18/82 | 6 | 72 | 50 | 0 |
\n",
- "\t| 8/30/83 | 6 | 73 | 100 | 0 |
\n",
- "\t| 11/28/83 | 6 | 70 | 100 | 0 |
\n",
- "\t| 2/03/84 | 6 | 57 | 200 | 1 |
\n",
- "\t| 4/06/84 | 6 | 63 | 200 | 1 |
\n",
- "\t| 8/30/84 | 6 | 70 | 200 | 1 |
\n",
- "\t| 10/05/84 | 6 | 78 | 200 | 0 |
\n",
- "\t| 11/08/84 | 6 | 67 | 200 | 0 |
\n",
- "\t| 1/24/85 | 6 | 53 | 200 | 2 |
\n",
- "\t| 4/12/85 | 6 | 67 | 200 | 0 |
\n",
- "\t| 4/29/85 | 6 | 75 | 200 | 0 |
\n",
- "\t| 6/17/85 | 6 | 70 | 200 | 0 |
\n",
- "\t| 7/29/85 | 6 | 81 | 200 | 0 |
\n",
- "\t| 8/27/85 | 6 | 76 | 200 | 0 |
\n",
- "\t| 10/03/85 | 6 | 79 | 200 | 0 |
\n",
- "\t| 10/30/85 | 6 | 75 | 200 | 2 |
\n",
- "\t| 11/26/85 | 6 | 76 | 200 | 0 |
\n",
- "\t| 1/12/86 | 6 | 58 | 200 | 1 |
\n",
- "\n",
\n"
- "text/latex": [
- "\\begin{tabular}{r|lllll}\n",
- " Date & Count & Temperature & Pressure & Malfunction\\\\\n",
- " & & & & \\\\\n",
- "\\hline\n",
- "\t 4/12/81 & 6 & 66 & 50 & 0\\\\\n",
- "\t 11/12/81 & 6 & 70 & 50 & 1\\\\\n",
- "\t 3/22/82 & 6 & 69 & 50 & 0\\\\\n",
- "\t 11/11/82 & 6 & 68 & 50 & 0\\\\\n",
- "\t 4/04/83 & 6 & 67 & 50 & 0\\\\\n",
- "\t 6/18/82 & 6 & 72 & 50 & 0\\\\\n",
- "\t 8/30/83 & 6 & 73 & 100 & 0\\\\\n",
- "\t 11/28/83 & 6 & 70 & 100 & 0\\\\\n",
- "\t 2/03/84 & 6 & 57 & 200 & 1\\\\\n",
- "\t 4/06/84 & 6 & 63 & 200 & 1\\\\\n",
- "\t 8/30/84 & 6 & 70 & 200 & 1\\\\\n",
- "\t 10/05/84 & 6 & 78 & 200 & 0\\\\\n",
- "\t 11/08/84 & 6 & 67 & 200 & 0\\\\\n",
- "\t 1/24/85 & 6 & 53 & 200 & 2\\\\\n",
- "\t 4/12/85 & 6 & 67 & 200 & 0\\\\\n",
- "\t 4/29/85 & 6 & 75 & 200 & 0\\\\\n",
- "\t 6/17/85 & 6 & 70 & 200 & 0\\\\\n",
- "\t 7/29/85 & 6 & 81 & 200 & 0\\\\\n",
- "\t 8/27/85 & 6 & 76 & 200 & 0\\\\\n",
- "\t 10/03/85 & 6 & 79 & 200 & 0\\\\\n",
- "\t 10/30/85 & 6 & 75 & 200 & 2\\\\\n",
- "\t 11/26/85 & 6 & 76 & 200 & 0\\\\\n",
- "\t 1/12/86 & 6 & 58 & 200 & 1\\\\\n",
- "\\end{tabular}\n"
- "text/markdown": [
- "\n",
- "\n",
- "| Date <fct> | Count <int> | Temperature <int> | Pressure <int> | Malfunction <int> |\n",
- "|---|---|---|---|---|\n",
- "| 4/12/81 | 6 | 66 | 50 | 0 |\n",
- "| 11/12/81 | 6 | 70 | 50 | 1 |\n",
- "| 3/22/82 | 6 | 69 | 50 | 0 |\n",
- "| 11/11/82 | 6 | 68 | 50 | 0 |\n",
- "| 4/04/83 | 6 | 67 | 50 | 0 |\n",
- "| 6/18/82 | 6 | 72 | 50 | 0 |\n",
- "| 8/30/83 | 6 | 73 | 100 | 0 |\n",
- "| 11/28/83 | 6 | 70 | 100 | 0 |\n",
- "| 2/03/84 | 6 | 57 | 200 | 1 |\n",
- "| 4/06/84 | 6 | 63 | 200 | 1 |\n",
- "| 8/30/84 | 6 | 70 | 200 | 1 |\n",
- "| 10/05/84 | 6 | 78 | 200 | 0 |\n",
- "| 11/08/84 | 6 | 67 | 200 | 0 |\n",
- "| 1/24/85 | 6 | 53 | 200 | 2 |\n",
- "| 4/12/85 | 6 | 67 | 200 | 0 |\n",
- "| 4/29/85 | 6 | 75 | 200 | 0 |\n",
- "| 6/17/85 | 6 | 70 | 200 | 0 |\n",
- "| 7/29/85 | 6 | 81 | 200 | 0 |\n",
- "| 8/27/85 | 6 | 76 | 200 | 0 |\n",
- "| 10/03/85 | 6 | 79 | 200 | 0 |\n",
- "| 10/30/85 | 6 | 75 | 200 | 2 |\n",
- "| 11/26/85 | 6 | 76 | 200 | 0 |\n",
- "| 1/12/86 | 6 | 58 | 200 | 1 |\n",
- "\n"
- "text/plain": [
- " Date Count Temperature Pressure Malfunction\n",
- "1 4/12/81 6 66 50 0 \n",
- "2 11/12/81 6 70 50 1 \n",
- "3 3/22/82 6 69 50 0 \n",
- "4 11/11/82 6 68 50 0 \n",
- "5 4/04/83 6 67 50 0 \n",
- "6 6/18/82 6 72 50 0 \n",
- "7 8/30/83 6 73 100 0 \n",
- "8 11/28/83 6 70 100 0 \n",
- "9 2/03/84 6 57 200 1 \n",
- "10 4/06/84 6 63 200 1 \n",
- "11 8/30/84 6 70 200 1 \n",
- "12 10/05/84 6 78 200 0 \n",
- "13 11/08/84 6 67 200 0 \n",
- "14 1/24/85 6 53 200 2 \n",
- "15 4/12/85 6 67 200 0 \n",
- "16 4/29/85 6 75 200 0 \n",
- "17 6/17/85 6 70 200 0 \n",
- "18 7/29/85 6 81 200 0 \n",
- "19 8/27/85 6 76 200 0 \n",
- "20 10/03/85 6 79 200 0 \n",
- "21 10/30/85 6 75 200 2 \n",
- "22 11/26/85 6 76 200 0 \n",
- "23 1/12/86 6 58 200 1 "
- "metadata": {},
- "output_type": "display_data"
- "source": [
- "data = read.csv(\"shuttle.csv\",header=T)\n",
- "data"
- "metadata": {},
- "source": [
- "The data set shows us the date of each test, the number of O-rings (there are 6 on the main launcher), the temperature (in Fahrenheit) and pressure (in psi), and finally the number of identified malfunctions."
- "metadata": {},
- "source": [
- "## Graphical inspection\n",
- "Flights without incidents do not provide any information\n",
- "on the influence of temperature or pressure on malfunction.\n",
- "We thus focus on the experiments in which at least one O-ring\n",
- "was defective."
- "execution_count": 2,
- "metadata": {},
- "outputs": [
- "data": {
- "text/html": [
- "\n",
- "A data.frame: 7 × 5\n",
- "\n",
- "\t | Date | Count | Temperature | Pressure | Malfunction |
\n",
- "\t | <fct> | <int> | <int> | <int> | <int> |
\n",
- "\n",
- "\n",
- "\t| 2 | 11/12/81 | 6 | 70 | 50 | 1 |
\n",
- "\t| 9 | 2/03/84 | 6 | 57 | 200 | 1 |
\n",
- "\t| 10 | 4/06/84 | 6 | 63 | 200 | 1 |
\n",
- "\t| 11 | 8/30/84 | 6 | 70 | 200 | 1 |
\n",
- "\t| 14 | 1/24/85 | 6 | 53 | 200 | 2 |
\n",
- "\t| 21 | 10/30/85 | 6 | 75 | 200 | 2 |
\n",
- "\t| 23 | 1/12/86 | 6 | 58 | 200 | 1 |
\n",
- "\n",
\n"
- "text/latex": [
- " & Date & Count & Temperature & Pressure & Malfunction\\\\\n",
- " & & & & & \\\\\n",
- "\\hline\n",
- "\t2 & 11/12/81 & 6 & 70 & 50 & 1\\\\\n",
- "\t9 & 2/03/84 & 6 & 57 & 200 & 1\\\\\n",
- "\t10 & 4/06/84 & 6 & 63 & 200 & 1\\\\\n",
- "\t11 & 8/30/84 & 6 & 70 & 200 & 1\\\\\n",
- "\t14 & 1/24/85 & 6 & 53 & 200 & 2\\\\\n",
- "\t21 & 10/30/85 & 6 & 75 & 200 & 2\\\\\n",
- "\t23 & 1/12/86 & 6 & 58 & 200 & 1\\\\\n",
- "\n",
- "\n",
- "| | Date <fct> | Count <int> | Temperature <int> | Pressure <int> | Malfunction <int> |\n",
- "|---|---|---|---|---|---|\n",
- "| 2 | 11/12/81 | 6 | 70 | 50 | 1 |\n",
- "| 9 | 2/03/84 | 6 | 57 | 200 | 1 |\n",
- "| 10 | 4/06/84 | 6 | 63 | 200 | 1 |\n",
- "| 11 | 8/30/84 | 6 | 70 | 200 | 1 |\n",
- "| 14 | 1/24/85 | 6 | 53 | 200 | 2 |\n",
- "| 21 | 10/30/85 | 6 | 75 | 200 | 2 |\n",
- "| 23 | 1/12/86 | 6 | 58 | 200 | 1 |\n",
- "\n"
- "text/plain": [
- "metadata": {},
- "source": [
- "data = data[data$Malfunction>0,]\n",
- "data"
- "metadata": {},
- "source": [
- "We have a high temperature variability but\n",
- "the pressure is almost always 200, which should\n",
- "simplify the analysis.\n",
- "\n",
- "How does the frequency of failure vary with temperature?"
- "execution_count": 3,
- "metadata": {},
- "outputs": [
- "data": {
- "image/png": "iVBORw0KGgoAAAANSUhEUgAAA0gAAANICAMAAADKOT/pAAAC+lBMVEUAAAABAQECAgIDAwME\nBAQFBQUGBgYHBwcICAgJCQkKCgoLCwsMDAwNDQ0ODg4PDw8QEBARERESEhITExMUFBQVFRUW\nFhYXFxcYGBgZGRkaGhobGxscHBwdHR0eHh4fHx8gICAhISEiIiIjIyMkJCQlJSUmJiYnJycp\nKSkqKiorKystLS0uLi4vLy8wMDAxMTEyMjIzMzM0NDQ1NTU2NjY3Nzc4ODg5OTk6Ojo7Ozs8\nPDw9PT0+Pj4/Pz9AQEBBQUFCQkJDQ0NERERFRUVGRkZHR0dISEhJSUlKSkpLS0tMTExNTU1O\nTk5PT09QUFBRUVFSUlJTU1NUVFRVVVVWVlZXV1dYWFhZWVlaWlpbW1tcXFxdXV1eXl5fX19g\nYGBhYWFiYmJjY2NkZGRlZWVmZmZnZ2doaGhpaWlqampra2tsbGxtbW1ubm5vb29wcHBxcXFy\ncnJzc3N0dHR1dXV2dnZ3d3d4eHh5eXl6enp7e3t8fHx9fX1+fn5/f3+AgICBgYGCgoKDg4OE\nhISFhYWGhoaHh4eIiIiJiYmKioqLi4uMjIyNjY2Ojo6Pj4+QkJCRkZGSkpKTk5OUlJSVlZWW\nlpaXl5eYmJiZmZmampqbm5ucnJydnZ2enp6fn5+goKChoaGioqKjo6OkpKSlpaWmpqanp6eo\nqKipqamqqqqrq6usrKytra2urq6vr6+wsLCxsbGysrKzs7O0tLS1tbW2tra3t7e4uLi5ubm6\nurq7u7u8vLy9vb2+vr6/v7/AwMDBwcHCwsLDw8PExMTFxcXGxsbHx8fIyMjJycnKysrLy8vM\nzMzNzc3Ozs7Pz8/Q0NDR0dHS0tLT09PU1NTV1dXW1tbX19fY2NjZ2dna2trb29vc3Nzd3d3e\n3t7f39/g4ODh4eHi4uLj4+Pk5OTl5eXm5ubn5+fo6Ojp6enq6urr6+vs7Ozt7e3u7u7v7+/w\n8PDx8fHy8vLz8/P09PT19fX29vb39/f4+Pj5+fn6+vr7+/v8/Pz9/f3+/v7///9puzMQAAAA\nCXBIWXMAABJ0AAASdAHeZh94AAAgAElEQVR4nO3dC3SU5b3v8WdIhksgICi3cAlotbUtETxc\nWvBQo2WrWPTUgtgqEVqsgMZdVKBFQLywd2i1anW70b29HbcepFGPp8IRkSpFYQOixeIlokes\nQUESLZdwCXnXOnNLJoT0ncl+f7zv+8TvZy0zz5p5JvzX63xXkrkaB4BnJugBgNaAkAABQgIE\nCAkQICRAgJAAAUICBAgJECAkQICQAAFCAgQICRAgJECAkAABQgIECAkQICRAgJAAAUICBAgJ\nECAkQICQAAFCAgQICRAgJECAkAABQgIECAkQICRAgJAAAUICBAgJECAkQICQAAFCAgQICRAg\nJECAkAABQgIECAkQICRAgJAAAUICBAgJECAkQICQAAFCAgQICRAgJECAkAABQgIECAkQICRA\ngJAAAUICBAgJECAkQICQAAFCAgQICRAgJECAkAABQgIECAkQICRAgJAAAUICBAgJECAkQICQ\nAAFCAgQICRAgJECAkAABQgIECAkQICRAgJAAAUICBAgJECAkQICQAAFCAgQICRAgJECAkAAB\nQgIECAkQICRAgJAAAUICBAgJECAkQICQAAFCAgQICRDwIaQ3NgJWeaPlt/LjH9IGA1hmQ4tv\n5sc/pLXm4HH/NwChg2Zti69DSEAThAQIEBIgQEiAACEBAoQECBASIOB3SHXbVpaXr9qeYRch\nwTL+hlQ1s0fyUeD+C/e77SMkWMbXkCoHmlNL5peVzZ1YYAZVuWwkJFjG15CmRJemVrX3Rkpd\nNhISLONrSL0mp9cT+rlsJCRYxteQorel1wvaumwkJFjG15AKx6fX4wa4bCQkWMbXkEojiw8k\nV3vnmVkuGwkJlvE1pOrBJr+4ZMb0SaPzzKg9LhsJCZbx93Gkg3cU5cQfRooOX1Lrto+QYBnf\nnyJU896mTRWZMiEkWIbn2gEChAQIBBXS+8XFTc45snplg98SEuwSVEibTdPv8kH3rg3yzF7B\nvwH4JqiQarZscbn0fuN25zgQOuH8G4mQYJnAQvq8wuVCQoJlAgtpltt3ISRYhpAAAUICBHwN\naUgjvQgJrYivIbVp065BDiGhFfE1pFn56bvq+NUOrYmvIR0648xD9WtCQmvi750NWztcX78k\nJLQmPt9r9+Xu+tUfF7lsIyRYhqcIAQKEBAgQEiBASIAAIQEChAQIEBIgQEiAACEBAoQECBAS\nIEBIgAAhAQKEBAgQEiBASIAAIQEChAQIEBIgQEiAACEBAoQECBASIEBIgAAhAQKEBAgQEiBA\nSIAAIQEChAQIEBIgQEiAACEBAoQECBASIEBIgAAhAQKEBAgQEiBASIAAIQEChAQIEBIgQEiA\nACEBAoQECBASIEBIgAAhAQKEBAgQEiBASIAAIQEChAQIEBIgQEiAACEBAoQECBASIEBIgAAh\nAQKEBAgQEiBASIAAIQEChAQIEBIgQEiAACEBAoQECBASIEBIgAAhAQKEBAgQEiBASIAAIQEC\nhAQIEBIgQEiAACEBAoQECBASIEBIgAAhAQKEBAgQEiBASIBAICEdemvjAdcNhATL+BvSqtED\nzlvnrCgwpvO9bvsICZbxNaRXc03nNh1f7dzvivFdzXKXjYQEy/ga0oW93nR2fq//oP2OUzXg\nH1w2EhIs42tIJ94S+7LBPBxf39rNZSMhwTK+hpT7aOxLpflDfP1vuS4bCQmW8TWknvNjX/5o\n7oqvf9nTZSMhwTK+hnRpt5cO/vlb3+j/V8fZ2vUSl42EBMv4GtLb+caYblsL8743IjdnvctG\nQoJl/H0cacvEYSXvOFuGRszJz7jtIyRYJpinCO3Z6X45IcEyPNcOECAkQCCokN4vLm5yTtW0\nqQ1GERLsElRIm03T70JIsFhQIdVs2eJyKb/awTL8jQQI+B1S3baV5eWrtmfYRUiwjL8hVc3s\nYRL6L9zvto+QYBlfQ6ocaE4tmV9WNndigRlU5bKRkGAZX0OaEl2aWtXeGyl12UhIsIyvIfWa\nnF5P6OeykZBgGV9Dit6WXi9o67KRkGAZX0MqHJ9ejxvgspGQYBlfQyqNLE69n93eeWaWy0ZC\ngmV8Dal6sMkvLpkxfdLoPDPKLRVCgmX8fRzp4B1FOfGHkaLDl9S67SMkWMb3pwjVvLdpU8XB\nDJsICZbhuXaAACEBAoQECBASIEBIgAAhAQKEBAgQEiBASIAAIQEChAQIEBIgQEiAACEBAoQE\nCBASIEBIgAAhAQKEBAgQEiBASIAAIQEChAQIEBIgQEiAACEBAoQECBASIEBIgAAhAQKEBAgQ\nEiBASIAAIQEChAQIEBIgQEiAACEBAoQECBASIEBIgAAhAQKEBAgQEiBASIAAIQEChAQIEBIg\nQEiAACEBAoQECBASIEBIgAAhAQKEBAgQEiBASIAAIQEChAQIEBIgQEiAACEBAoQECBASIEBI\ngAAhAQKEBAgQEiBASIAAIQEChAQIEBIgQEiAACEBAoQECBASIEBIgAAhAQJeQ1qzO7VYv0wy\nTxIhwTJeQzJPpxa/7iqZJ4mQYBlPIVUsX27mLU8oH5onnIqQYBlPIS0yjVwinIqQYBlvv9pV\nPmsuX5RQtuyQcCpCgmW8/o10wWu6WdIICZbh7m9AwGtIdUvHFn0zSTcUIcE2XkNabExelyTd\nUIQE23gNqe+YbS2+fu2f125330FIsIzXkKLrWnLNtdNjXx7raYwZ9LLbPkKCZTz/RGrJvXar\n23aqc54ynX407dw27Ta6bCQkWMZrSDdMa8EVR/eocJyBhZWx5boOF7psJCRYxmtIe8ZctmJr\nRULmK3a+3nG+MHcl1j87wWUjIcEynp+0mpb5ih1vcpwDkd8n1je3d9lISLCM15AmTppSL/MV\nv3vqPsf5zvXx5YFBg1w2EhIs4+szG54zg//v4U29H9l3aN3Z5l9dNhISLOPvU4Qe6Gg6nF5o\ncnJM5Bd1LvsICZbxGlJxg1HZXPXTxWMK89udOOTaTa7bCAmWkd3ZkF+gG4qQYBuvIR1O2PfW\n9Wd9qRuKkGAb2d9Is3/ueZY0QoJlZCG91rJf7d4vLm5yzgfduzbIM39r8VRAgGQhvdCyNz/Z\nfMwDuEdWr2xQyk8k2MVrSNVJO1cXteyFfTVbtrhcyq92sIzuKUKP6YYiJNjG85ufJF109YvZ\nXbdu28ry8lUZXtdHSLCNv89sqJrZI/njq//C/W77CAmWEYS069WV66qzumLlQHNqyfyysrkT\nC8ygKpeNhATLeA5pzbD4T5hIsdt9B/WmRJemVrX3RkpdNhISLOM1pPXtckZOmXHlsEjndzJf\nsdfk9HpCP5eNhATLeA3pwr5vJ05f7zEx8xWjt6XXC9q6bCQkWMZrSCfenlos6Jn5ioXj0+tx\nA1w2EhIs4zWk3EdTi4ejma9YGll8ILnaO8/MctlISLCM15AK5qQWN/bJfMXqwSa/uGTG9Emj\n88wot1QICZbxGlJJp2fiL3WtK+/402z+tTuKcuJ38kWHL6l120dIsIzXkD7sYXqdfeHZvUzv\nj7O7cs17mzZVHMywiZBgGc+PI22f1CX2I6bbTytlIzmEBOsIntlQV1mxQzRNPUKCZTyG9Nmr\nydPfZfccoWwREizjLaSXTzgncfqm6dPyT3dxQUiwjKeQKk/KTT4eW3d3m1NrdEMREmzjKaSb\nzQP1yzvN/aKJ4ggJlvEU0uBTjtQvD/cdLpoojpBgGU8hnXRZ+sxL8iXzJBESLOMppLbXpM+8\nyu3Z3C1FSLCMp5B6j0uf+b0snmuXNUKCZTyF9INOn9cvK3J/KJoojpBgGU8hPWUuPpxcfTnU\nPCebiZBgHU8h1Z1jhpT/zXF2PlhoLlZORUiwjLdnNlSfZ0zkhHxjzATXt9dqKUKCZbw+afX5\niSd3zP/6la/oJoojJFjG3zeIzBYhwTJeQrp7q3aWNEKCZbyEZEzBFY9KX9BXj5BgGS8hffTg\nhO7GnH7t/5Z/KhghwTIe/0aqe73s3A4m9zvzXjkkHIqQYBvBnQ0HXpw9pI3pdL5oojhCgmVE\n99rtXjp1oGCaeoQEy3D3NyDgNaS6pWOLvpmkG4qQYBuvIS02Jq9Lkm4oQoJtvIbUd4z07YNS\nCAmW8RpSdJ1uljRCgmU8/0R6TTdLGiHBMl5DumGabpY0QoJlvIa0Z8xlK7ZWJOiGIiTYxmtI\nJk03FCHBNl5DmjhpSj3dUIQE2/DMBkBAENKuV1eu036qCyHBNp5DWjMs/vdRpHiLbCSHkGAd\nryGtb5czcsqMK4dFOr+jG4qQYBuvIV3Y9+3E6es9JoomiiMkWMZrSCfenlos6CmZJ4mQYBmv\nIeU+mlo8HJXMk0RIsIzXkArmpBY38mkU+ArzGlJJp2fqYid15R1/KpuJkGAdryF92MP0OvvC\ns3uZ3h/rhiIk2Mbz40jbJ3UxxnT7qfSNIgkJlhE8s6GusmKHaJp6hATLeAlpR1XsvzThVIQE\ny3h67+8xvIwCSPAS0oRFsf/ShFMREizDyygAAa8hrdmdWqxfJpkniZBgGc8vNX86tfh1V8k8\nSYQEy3gKqWL5cjNveUL50DzhVIQEy3gKaVGj++zMJcKpCAmW8farXeWz5vJFCWXLlJ80Rkiw\njNe/kS7gnVYBxd3fb+2Kf3ldNE8SIcEyXkM6NNmsjp3cY0pqVSM5hATreA3pN+aCD2In70ww\nv5XNREiwjteQvjU2tTj/a5J5kggJlvEaUoffpBZlvGcDvsK8htTzmtRiGu8ihK8wryFNzvtD\n/OTQktzLVSM5hATreA2psrfpf+7Ykd1M7490QxESbOP5caRPf36iMab7z/4qG8khJFhH8Z4N\nn7y/VzRNPUKCZXhhHyDgNaS6pWOLvpmkG4qQYBuvIS02Jq9Lkm4oQoJtvIbUd8w23TANCAmW\n8RpSdJ1uljRCgmU8/0Ti9UiA95BumKabJY2QYBmvIe0Zc9mKrRUJuqEICbbx/HZcvGUx4D2k\niZOm1NMNRUiwDc9sAAQICRDwGlJxg1G6oQgJtpHd2ZBfoBuKkGAbryEdTtj31vVnfakbipBg\nG9nfSLN/7nmWNEKCZWQhvcavdvgKk4X0Ah/rgq8wryFVJ+1cXcQL+/AVpnuK0GO6oQgJtvH8\nsS5JF139om4mQoJ1eGYDIOAlpF+scpyr3viv/Ktfznrb9XJCgmW8hNRmUaNPNW+Rj81zrpcT\nEizjJaTeJ0ybZf7HrHqZr9jwiouJ5vuuL7sgJFjGS0iPtW/8qeZZ/OVkst1PSLCMpzsbqjes\nMbevqZf5iv+YU7Qi8bDTX8yT1dUuGwkJlvF6r92YV1tyzQ1Fkau/cPgbCa2Ol5A+Plo2Vz38\nTx0KlhESWh0vIZms/+Zp5P1ic+F2QkIr4yWkCUfL9uoPdes0n5DQusie2bB3R9bX/+xSQ0ho\nXWQhPd67Bd/h+ZlbXS8nJFjGc0i77plZGnNVn3zZTIQE63gN6cPuqbsacm/WDUVIsI3XkH6c\n/7tV5sEVs/usaNn3eL+4uMk5R1avbFBKSLCL15D6z3ZqzGuOs7nbn1r0PTYfc3f5B927Nsgz\nf2vxVECAPH/Q2JLYt3g5trip6U8YdzVbtrhcyq92sIzXkLrd4jidHootnuAzZPEV5jWkcX1W\nOyPOjN3sf9Yjq+vWbVtZXr5qe4ZdhATLeA1pffshzr+bfhcXmR9ncc2qmT2S9/H1X7jfbR8h\nwTKeH0faeJ9TN6eDifxgV+YrVg40p5bMLyubO7HADKpy2UhIsIzmmQ01H7r+gKk3Jbo0taq9\nN1LqspGQYBlf30Wo1+T0ekI/l42EBMt4CunwUTJfMXpber2grctGQoJlPIXU0tcjFY5Pr8cN\ncNlISLCMt5Byzri0Ja9HKo0sPpBc7Z1n3N51iJBgGU8hXdfDFN7wVvZXrB5s8otLZkyfNDrP\njHJLhZBgGW93Nhx+7pJ2ZsjdWdzznfrX7ijKif8WGB2+pNZtHyHBMp7vtau+f4SJXvT0oWyv\nXPPepk0VBzNsIiRYRnH3d8VNA8xJ12zUDJRASLCM5nGkupfPyvZdhLJCSLCMIqQjKy7taL62\nUDNQAiHBMt5Demd2H5N/5SuqgRIICZbxGFL1/cNNZPQj+4QTxRESLOMppBWXtjcDF3yonCeJ\nkGAZj89sGHHz/3munnAqQoJlfH2uXdYICZbxFNJjRxFORUiwDJ9qDggQEiBASIAAIQEChAQI\nEBIgQEiAACEBAoQECBASIGBXSPuevvXWp9Wv2QCy5HL7syqkFT07jxzZuWcLP2UT0HC7/dkU\n0oZ2N+53nP03tlO+zwqQJdfbn00hjUm9mev4Mcd9AOAYrrc/i0I6kLsyuXgheuC4TwA04X77\nsyikT8y7ycW75pPjPgHQhPvtz6KQ9rdJvVXRy22y+lgzQMn99mdRSM7IqcnTqSOP+wDAMVxv\nfzaF9GLu3XWOU3dX7qrjPgBwDNfbn00hOY/knTJhwsl5jx73fx9ohtvtz6qQnB33XHXVPTuO\n+z8PNMvl9mdXSEBIERIgQEiAACEBAoQECBASIEBIgAAhAQKEBAgQEiBASIAAIQEChAQIEBIg\nQEiAACEBAoQECBASIEBIgAAhAQKEBAgQEiBASIAAIQEChAQIEBIgQEiAACEBAoQECBASIEBI\ngAAhAQKEBAgQEiBASIAAIQEChAQIEBIgQEiAACEBAoQECBASIEBIgAAhAQKEBAgQEiBASIAA\nIQEChAQIEBIgQEiAACEBAoQECBASIEBIgAAhAQKEBAgEFlLVhy4XEhIs429Ib55fOPLe2sRy\nltt3ISRYxteQ/tTO5EXNf6+KrwkJrYmvIV0QfbruwB3R/7bXISS0Lr6G1O8n8a+r2p5fS0ho\nXXwNKTovcfKouZaQ0Lr4GlLfHyRP55gyQkKr4mtI10buORQ/rZtkrruGkNCK+BrS5/3NOYlF\n3bXGEBJaEX8fR9o17brU6venEBJaEZ4iBAgQEiBASIBAUCG9X1zc5JyqaVMbjCIk2CWokDYf\nc68dIcFiQYVUs2WLy6X8agfL8DcSIOB3SHXbVpaXr9qeYRchwTL+hlQ1s4dJ6L9wv9s+QoJl\nfA2pcqA5tWR+WdnciQVmUJXLRkKCZXwNaUp0aWpVe2+k1GUjIcEyvobUa3J6PaGfy0ZCgmX8\nfWHfben1grYuGwkJlvE1pMLx6fW4AS4bCQmW8TWk0sjiA8nV3nlmlstGQoJlfA2perDJLy6Z\nMX3S6Dwzyi0VQoJl/H0c6eAdRTnxh5Giw5fUuu0jJFjG96cI1by3aVPFwQybCAmW4bl2mWwc\nf3K7b5d+2vyFW684td03pv4/fydyc+jOEZ27Fz8R9BgSa7/RzkRP+UPQY2SHkDJ4LHrxvy2/\n69u9tjZ34fMdzl2y/N4RXdb5PdXfs++s7vOeWXpthyl1QU/i3QOR/Am3XH6iWRj0IFkhJHcf\ntP9t/OTQuKIjx174eddfxk+OTCl0feagj35R+Nf4yYaOjwQ9iWe7c087HD8dEXkv6FGyQUju\n5g5OnlbmvHLshXf3T/yvdvZ0fsrHkVwc7Px4cnHj0GAHEfjHSPLX6ZrcHwU8SVYIyd0FM1OL\nb9117IWTf5JanPMrv+Zx97bZkVysaGf973bf6ZZaDDwt0DmyREjuvj8ntRjy62MvvLz+uYPn\n3+DXPO7+bHYnFy/luD68YIOh3VOL004OdI4sEZK7a8YkT/d1fO7YC28pSp4eKXjQv4nc/K3t\nC8nFr78e7CACV+Qkf292OpwT7CDZISR369usSpzO7t3M/QkV0ScTp3fm7/JzJhfjv5N4iO6z\nPrcGPYln70YuTpxeY14MeJKsEFIGMzv+89bqdVdGm304o6ztTW9+uak0JzT3kW3vO+IPOz96\n4uRhYbkb0YOppujxvz410lwQ9CBZIaQM6v61vzGR4X9q/tInTzPGDFru70huPpnQ1pj86/YG\nPYfCwg6xg9vW7QWgIUJImX32hss0uzd/4d8k2Ti0dVszD3nZafuT7wc9QrYICRAgJECAkAAB\nQgIECAkQICRAgJAAAUICBAgJECAkQICQAAFCAgQICRAgJECAkAABQgIECAkQICRAgJAAAUIC\nBAgJECAkQICQAAFCAgQICRAgJECAkAABQgIECAkQICRAgJAAAUICBAgJECAkQICQAAFCAgQI\nCRAgJECAkAABQgIECAkQICRAgJAAAUICBAgJECAkQICQAAFCAgQICRAgJECAkAABQgIECAkQ\nICRAgJAAAUICBAgJECAkQICQAAFCAgQICRAgJECAkAABQgIECAkQICRAgJAAAUICBAgJECAk\nQICQAAFCAgQICRAgJECAkAABQgIE/A6pbtvK8vJV2zPsIiRYxt+Qqmb2MAn9F+5320dIsIyv\nIVUONKeWzC8rmzuxwAyqctlISLCMryFNiS5NrWrvjZS6bCQkWMbXkHpNTq8n9HPZSEiwjK8h\nRW9Lrxe0ddlISLCMryEVjk+vxw1w2UhIsIyvIZVGFh9IrvbOM7NcNhISLONrSNWDTX5xyYzp\nk0bnmVFuqRASLOPv40gH7yjKiT+MFB2+pNZtHyHBMr4/RajmvU2bKg5m2ERIsAzPtQMECAkQ\nCCqk94uLm5zzQfeuDfLMXsG/AfgmqJA2m6bf5cjqlQ1+azL9FQWESlAh1WzZ4nLpWkKCXcL5\nNxIhwTLhfGEfIcEy4XxhHyHBMuF8YR8hwTLhfGEfIcEy4XxhHyHBMuF8YR8hwTLhfGEfIcEy\n4XxhHyHBMuF8YR8hwTLhfGEfIcEy4XxhHyHBMjzXDhAgJECAkAABQgIECAkQICRAgJAAAUIC\nBMIZ0gYDWGZDi2/mxz8k542NctcWPhYybWYHPUETY78d9ARN3GcWBT1CE2f9w9+7fb3R8lu5\nDyEdB3ecEfQETeW8GPQETcw6L+gJmthl3N60LQglJcJvRkgahJQJIYUQIWVESBkREiFlRkgZ\nERIhZUZIGRESIWVGSBkREiFlRkgZERIhZUZIGRESIWVGSBkREiFlRkgZEZLzu2FBT9BUh1eC\nnqCJm8YFPUETX0TeDXqEJqZOFX4zO0Oq+SToCZr6oC7oCZrY81nQEzS1LegBmqpy+xCVlrIz\nJCBkCAkQICRAgJAAAUICBAgJECAkQICQAAFCAgQICRAgJECAkAABQgIECAkQICRAgJAAAatC\neij1WQG3HLUM1vNnderyvdXxVXVpYbT3lMpgx2k0UEgOUbv6T3j4MCSHqNFAwkNkVUh3momz\n4l46ahmofzenzL2+e9u1jnNwsPnhbZOjA5Uvu/Q0UEgO0dzEELMGtN8dkkPUaCDhIbIqpPnp\nz62Z/1/4CJvj4LNOZ+x1nIpO0xznDvPPsTP+l5kZloFCcoiSNubcGpZDlJQYSHiIrAqp1FQ0\nswzSYrMifhJ/w4ai/APx5dd6BPruDY0GCskhSqg94xsHw3KIEpIDCQ+RVSFNMrtqP97VdBmk\nMR0OOQe+jK9qcooT55SYQN/kIz1QWA5Rwp1mdWgOUUJiIOUhsiqki8yvuhpz2uNHL4NUePrr\n342YUx5ynPdM8l3S5puV4RgoLIcobm/3eEIhOURxyYGUh8iqkEabkxc9Oqezuf+oZZDyC3vP\nXHZXf/O4s8lMT5yz2JSHY6CwHKK4fzLxt/0LySGKSw6kPERWhbRqWewPaecv7bodbLwMUjvz\nSOxrZadetZvMjMQ5ZebpcAwUlkMUs/+ks+InITlETsNAykNkVUgpF5v/bGYZiBNz9sVPfmT+\nXGEmJc6ZawJ98+L0QPXnBH2IYv5nom4nJIfIaRionuIQ2RjSVealZpaBGJJzKH4yzaw9mDs6\ncc5E81E4Bqo/J+hDFHNhTnX8JCSHyGkYqJ7iENkU0p77/iNxOtJsa7QMciJnhlkXP/m+2e4M\ny4v/LDhS0C8kA4XlEMUC6nhmchGOQ5QeSHmIbArpSJ9Ob8dOnjFnNF4GamPk7AOOs6HNtx1n\niVkQO+NfzM0hGSgsh8hxNpspyUU4DlF6IOUhsikk59lIxyk3XRzpvOmoZaCuM0U3/6xD29WO\nUzvKjLv50si39oVloLAcIudJc2tyEZJDlB5IeIisCsl59bwTcguuqGiyDFLd/YPadzk/8bfq\nnusLo32m7w7PQCE5RLEfQXelVuE4RI0G0h0iu0ICQoqQAAFCAgQICRAgJECAkAABQgIECAkQ\nICRAgJAAAUICBAgJECAkQICQAAFCAgQICRAgJECAkAABQgIECAkQICRAgJAAAUICBAgJECAk\nQICQAAFCAgQICRAgJECAkAABQgIECAkQICRAgJAAAUIKgZmmwXcV329R8B93+ZVDSCHwbGnM\niWZG7OtdmXdnVGmWC74LWoSQwuKbpkb0nZ4lJP8RUlikQvp0Wv/oSePin0o+0VRP7dFh2Pp9\npQUdR8Q/wP4iUzmlR9uv33f0tgnms3PaP+s46y86MVr4kw8d54L4r4hrYifVsUsPm+L0lvSV\noEZIYZEMaWdhl1mP3d633R8dZ5I55+bXH27ff+ysjctO6Hko3sPQWWvXnGseOGrb5eay827f\n4mxsX7Bwyez8Hp87r11u5j29u3FIqS2NrgQ1QgqLZEhX526Ifd2ef6bjTDFXx5bjzSWxr6Vm\nbTykibHlF+0GHLVtsvn+kdj6vsGrY1/vMfc4zqLEr3aNQkptaXQlqBFSWCRCqjtp8I64MWZP\nLKSVsbN/ZR6Lfb3PLIuH9Gx84zmm8uhtj9d/i0M1q8zMZkJKbml8JagRUlgkQvq04X7wv8Ru\n/ltjZ883L8W+PmCeiIf0dnzjJPP60ds2Jq7/6FknxM8obTak+JbGV4IaIYVFIqQKU7Q8qTp2\n848/HDTfrHEaQvoovnGaeenYbc4cc+ZDf3ztwb8TUnxL4ytBjZDCIvUTqajhjGZCiv+Icn5s\n3jx2W02HfvFf2FY0DWlfOqTGV4IaIYVF8s6Gk9onflzsdJoN6ffxy4aancdu+9BcHD9jTjqk\ni0z80rfSITW+EtqClZMAAAEtSURBVNQIKSxS99qZX8a+7uw1ttmQLogt3418vZlt+yNnxL5u\n7mOucpwyU574Ti/Hvt7YKKRGV4IaIYVFMqTP+psrH769f/SFZkM6Z+z99w2I3wV3zDZnrLnq\niZu6Pp/b9z/2LjNDf/OfzmtmyEvr5ozKT4fU6EpQI6SwSD2zYcfV/XJP+MF6p9mQKq4raHv6\nw81tc3Ze1r3L2Wucmzv12nHohx26PuU4D5/eoefULwpGNmxpdCWoEZI9JpiPgx4Bfw8h2YOQ\nQoyQ7EFIIUZI9iCkECMkQICQAAFCAgQICRAgJECAkAABQgIECAkQICRAgJAAAUICBAgJECAk\nQICQAAFCAgQICRAgJECAkAABQgIECAkQICRAgJAAAUICBAgJECAkQICQAAFCAgT+P9FRuQB/\nRTZ+AAAAAElFTkSuQmCC",
- "text/plain": [
- "plot without title"
- "metadata": {},
- "source": [
- "plot(data=data, Malfunction/Count ~ Temperature, ylim=c(0,1))"
- "metadata": {},
- "source": [
- "At first glance, the dependence does not look very important, but let's try to\n",
- "estimate the impact of temperature $t$ on the probability of O-ring malfunction."
- "metadata": {},
- "source": [
- "## Estimation of the temperature influence\n",
- "\n",
- "Suppose that each of the six O-rings is damaged with the same\n",
- "probability and independently of the others and that this probability\n",
- "depends only on the temperature. If $p(t)$ is this probability, the\n",
- "number $D$ of malfunctioning O-rings during a flight at\n",
- "temperature $t$ follows a binomial law with parameters $n=6$ and\n",
- "$p=p(t)$. To link $p(t)$ to $t$, we will therefore perform a\n",
- "logistic regression."
- "execution_count": 5,
- "metadata": {},
- "outputs": [
- "data": {
- "text/plain": [
- "\n",
- "Call:\n",
- "glm(formula = Malfunction/Count ~ Temperature, family = binomial(link = \"logit\"), \n",
- " data = data, weights = Count)\n",
- "\n",
- "Deviance Residuals: \n",
- " 2 9 10 11 14 21 23 \n",
- "-0.3015 -0.2836 -0.2919 -0.3015 0.6891 0.6560 -0.2850 \n",
- "\n",
- "Coefficients:\n",
- " Estimate Std. Error z value Pr(>|z|)\n",
- "(Intercept) -1.389528 3.195752 -0.435 0.664\n",
- "Temperature 0.001416 0.049773 0.028 0.977\n",
- "\n",
- "(Dispersion parameter for binomial family taken to be 1)\n",
- "\n",
- " Null deviance: 1.3347 on 6 degrees of freedom\n",
- "Residual deviance: 1.3339 on 5 degrees of freedom\n",
- "AIC: 18.894\n",
- "\n",
- "Number of Fisher Scoring iterations: 4\n"
- "metadata": {},
- "source": [
- "logistic_reg = glm(data=data, Malfunction/Count ~ Temperature, weights=Count, \n",
- " family=binomial(link='logit'))\n",
- "summary(logistic_reg)"
- "metadata": {},
- "source": [
- "The most likely estimator of the temperature parameter is 0.0014\n",
- "and the standard error of this estimator is 0.122, in other words we\n",
- "cannot distinguish any particular impact and we must take our\n",
- "estimates with caution."
- "metadata": {},
- "source": [
- "## Estimation of the probability of O-ring malfunction\n",
- "\n",
- "The expected temperature on the take-off day is 31°F. Let's try to\n",
- "estimate the probability of O-ring malfunction at\n",
- "this temperature from the model we just built:"
- "execution_count": 6,
- "metadata": {},
- "outputs": [
- "data": {
- "image/png": "iVBORw0KGgoAAAANSUhEUgAAA0gAAANICAMAAADKOT/pAAAC/VBMVEUAAAABAQECAgIDAwME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\nQgIECAkQICRA4H8AHOKqM1UAAAADSURBVHhzjEM0knQAAAAASUVORK5CYII=",
- "text/plain": [
- "metadata": {},
- "source": [
- "tempv = seq(from=30, to=90, by = .5)\n",
- "rmv <- predict(logistic_reg,list(Temperature=tempv),type=\"response\")\n",
- "plot(tempv,rmv,type=\"l\",ylim=c(0,1))\n",
- "points(data=data, Malfunction/Count ~ Temperature)"
- "metadata": {
- "hideCode": false,
- "hidePrompt": false,
- "scrolled": true
- "source": [
- "As expected from the initial data, the\n",
- "temperature has no significant impact on the probability of failure of the\n",
- "O-rings. It will be about 0.2, as in the tests\n",
- "where we had a failure of at least one joint. Let's get back\n",
- "to the initial dataset to estimate the probability of failure:"
- "execution_count": 7,
- "metadata": {},
- "outputs": [
- "data": {
- "text/html": [
- "0.0652173913043478"
- "text/latex": [
- "text/plain": [
- "[1] 0.06521739"
- "metadata": {},
- "source": [
- "data_full = read.csv(\"shuttle.csv\",header=T)\n",
- "sum(data_full$Malfunction)/sum(data_full$Count)"
- "metadata": {},
- "source": [
- "This probability is thus about $p=0.065$. Knowing that there is\n",
- "a primary and a secondary O-ring on each of the three parts of the\n",
- "launcher, the probability of failure of both joints of a launcher\n",
- "is $p^2 \\approx 0.00425$. The probability of failure of any one of the\n",
- "launchers is $1-(1-p^2)^3 \\approx 1.2\\%$. That would really be\n",
- "bad luck.... Everything is under control, so the takeoff can happen\n",
- "tomorrow as planned.\n",
- "\n",
- "But the next day, the Challenger shuttle exploded and took away\n",
- "with her the seven crew members. The public was shocked and in\n",
- "the subsequent investigation, the reliability of the\n",
- "O-rings was questioned. Beyond the internal communication problems\n",
- "of NASA, which have a lot to do with this fiasco, the previous analysis\n",
- "includes (at least) a small problem.... Can you find it?\n",
- "You are free to modify this analysis and to look at this dataset\n",
- "from all angles in order to to explain what's wrong."
- "execution_count": null,
- "metadata": {},
- "outputs": [],
- "source": []
- "metadata": {
- "celltoolbar": "Hide code",
- "kernelspec": {
- "display_name": "R",
- "language": "R",
- "name": "ir"
- "language_info": {
- "codemirror_mode": "r",
- "file_extension": ".r",
- "mimetype": "text/x-r-source",
- "name": "R",
- "pygments_lexer": "r",
- "version": "3.6.1"
- "nbformat": 4,
- "nbformat_minor": 2
