Commit dc4f8ad0 authored by Linamaria GALLEGOS's avatar Linamaria GALLEGOS
Exercice 02-3
parent f0de5039
......@@ -11,83 +11,89 @@
* Quelques explications
Le but de ce document est de faire un calcul simple soit même
document.
toto = np.array([14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0])
mean = np.mean(toto)
print(mean)
amin = np.amin(toto)
print(amin)
amax = np.amax(toto)
print(amax)
mediane = np.median(toto, 0)
print(mediane)
std = np.std(toto, 0, ddof = 1)
print(std)
print("Hello world!")
: Hello world!
~C-c C-c~).
import numpy
x=numpy.linspace(-15,15)
print(x)
: 14.113000000000001
: 2.8
: 23.4
: 14.5
: 4.334094455301447
#+begin_src python :results output file :session *python* :var matplot_lib_filename="figuretoto2.png" :exports both
fig,ax = plt.subplots(1)
ax.plot(toto, color = 'blue', linewidth=1)
ax.grid(color='gray', linestyle='dotted', linewidth=1)
plt.xlim(0,100)
plt.ylim(0,25)
[[file:figuretoto2.png]]
plt.figure(figsize=(10,5))
plt.plot(x,numpy.cos(x)/x)
plt.tight_layout()
#+begin_src python :results output file :session *python* :var matplot_lib_filename="figuretoto3.png" :exports both
ax.hist(toto, color = 'blue', edgecolor='black', linewidth=1)
plt.xlim(0,25)
plt.ylim(0,25)
[[file:./cosxsx.png]]
compréhensible sur GitLab.
[[file:figuretoto3.png]]
ls
#exercice_python_fr.org#
exercice.ipynb
exercice_R_en.org
exercice_R_fr.org
exercice_en.Rmd
exercice_en.ipynb
exercice_fr.Rmd
exercice_fr.ipynb
exercice_python_en.org
