Update toy_document_en.Rmd
parent 491bfc16
title: "Your title"
author: "Your name"
date: "Today's date"
title: "On the computation of pi"
author: "Arnaud Legrand"
date: "25 juin 2018"
output: html_document
##Asking the maths library
My computer tells me that π is *approximatively*
```{r setup, include=FALSE}
## Some explanations
```{r pressure, echo=FALSE}
plot(pressure)
pi
\ No newline at end of file
