Commit 6b0532c0 authored by Tommy Rushton's avatar Tommy Rushton
Finish 3-2.
parent 1f57d1d1
...@@ -61,8 +61,8 @@ Alright, looks good 👍 ...@@ -61,8 +61,8 @@ Alright, looks good 👍
** Sanitise the data ** Sanitise the data
But there may be problems with the data. Let's check for the obvious But the data may not be without its issues. Let's check for the
case of missing/empty data: obvious case of missing/empty data:
#+begin_src python :results output :exports both #+begin_src python :results output :exports both
valid_table = [] valid_table = []
...@@ -97,18 +97,18 @@ separators in the resulting table (which contains the first five and ...@@ -97,18 +97,18 @@ separators in the resulting table (which contains the first five and
last five weeks' data): last five weeks' data):
#+begin_src python :results value :exports both #+begin_src python :results value :exports both
[('week', 'inc'), None] + data[:5] + [None] + data[-5:] [('week', 'incidence'), None] + data[:5] + [None] + data[-5:]
#+end_src #+end_src
#+RESULTS: #+RESULTS:
| week | inc | | week | incidence |
| 202416 | 19330 | | 202416 | 19330 |
| 202415 | 24807 | | 202415 | 24807 |
| 202414 | 16181 | | 202414 | 16181 |
| 202413 | 18322 | | 202413 | 18322 |
| 202412 | 12818 | | 202412 | 12818 |
| 199101 | 15565 | | 199101 | 15565 |
| 199052 | 19375 | | 199052 | 19375 |
| 199051 | 19080 | | 199051 | 19080 |
...@@ -118,8 +118,8 @@ last five weeks' data): ...@@ -118,8 +118,8 @@ last five weeks' data):
** Convert dates ** Convert dates
Dates are represented in ISO 8601 format (YYYYWW) so let's parse Dates are represented in ISO 8601 format (YYYYWW) so let's parse
those. It should already be sorted chronologically, but let's make those. Entries are sorted chronologically, but in reverse, so we'll
sure of that too. fix that here too.
#+begin_src python :results silent :exports both #+begin_src python :results silent :exports both
import datetime import datetime
...@@ -133,18 +133,18 @@ Let's check again: ...@@ -133,18 +133,18 @@ Let's check again:
data_as_str = [(str(date), str(inc)) for date, inc in converted_data] data_as_str = [(str(date), str(inc)) for date, inc in converted_data]
[('date', 'inc'), None] + data_as_str[:5] + [None] + data_as_str[-5:] [('date', 'incidence'), None] + data_as_str[:5] + [None] + data_as_str[-5:]
#+end_src #+end_src
| date | inc | | date | incidence |
| 1990-12-03 | 1143 | | 1990-12-03 | 1143 |
| 1990-12-10 | 11079 | | 1990-12-10 | 11079 |
| 1990-12-17 | 19080 | | 1990-12-17 | 19080 |
| 1990-12-24 | 19375 | | 1990-12-24 | 19375 |
| 1990-12-31 | 15565 | | 1990-12-31 | 15565 |
| 2024-03-18 | 12818 | | 2024-03-18 | 12818 |
| 2024-03-25 | 18322 | | 2024-03-25 | 18322 |
| 2024-04-01 | 16181 | | 2024-04-01 | 16181 |
...@@ -156,17 +156,19 @@ data_as_str = [(str(date), str(inc)) for date, inc in converted_data] ...@@ -156,17 +156,19 @@ data_as_str = [(str(date), str(inc)) for date, inc in converted_data]
So, now we can take a look at incidence over time. (The 'flu notebook So, now we can take a look at incidence over time. (The 'flu notebook
switches to R here, but we're going to stick with python.) switches to R here, but we're going to stick with python.)
#+begin_src python :results output file :var filename="./incidence.png" :exports both #+begin_src python :results value file :var filename="./incidence.png" :exports both
import matplotlib.pyplot as plt import matplotlib.pyplot as plt
plt.clf() plt.clf()
date,incidence = zip(*converted_data) date,incidence = zip(*converted_data)
plt.figure(figsize=(7.5,5))
plt.plot(date,incidence) plt.plot(date,incidence)
plt.tight_layout() # plt.tight_layout()
plt.savefig(filename) plt.savefig(filename)
print(filename) filename
#+end_src #+end_src
...@@ -174,17 +176,17 @@ print(filename) ...@@ -174,17 +176,17 @@ print(filename)
And we can zoom in on a period of, say, five years: And we can zoom in on a period of, say, five years:
#+begin_src python :results output file :var filename="./incidence-zoom.png" :exports both #+begin_src python :results value file :var filename="./incidence-zoom.png" :exports both
plt.clf() plt.clf()
start = 10 start = 15
years = 5 years = 5
date,incidence = zip(*converted_data[52*start:52*(start+years)]) date,incidence = zip(*converted_data[52*start:52*(start+years)])
#+end_src #+end_src
...@@ -192,3 +194,78 @@ print(filename) ...@@ -192,3 +194,78 @@ print(filename)
It looks like incidence peaks in the spring, with lowest numbers It looks like incidence peaks in the spring, with lowest numbers
around September. around September.
* Study of annual incidence
** Compute annual incidence
So, let's calculate the incidence for each year. We'll define this is
as the sum of the incidence reports from the beginning of September in
year /N-1/ to the end of August in year /N/.
def annual_incidence(year):
start = datetime.datetime.strptime(f"{year-1}-09-01", '%Y-%m-%d').date()
end = datetime.datetime.strptime(f"{year}-09-01", '%Y-%m-%d').date()
weeks = [d for d in converted_data if d[0] > start and d[0] <= end]
return sum([w[1] for w in weeks])
That was quick and dirty and not entirely a nice time.
Now we can define the years we're interested in. These are the years
for which we have a full year's worth of data:
years = range(1991, 2024)
NB. The second argument to ~range~ is non-inclusive.
Now we can perform a list comprehension to get the incidence for each
year:
incidence_per_year = [(y,annual_incidence(y)) for y in years]
head, *tail = incidence_per_year
head
| 1991 | 553895 |
** Visual Inspection
Now we can plot incidence against year.
#+begin_src python :results value file :var filename="./annual_incidence.png" :exports both
years,incidences = zip(*incidence_per_year)
plt.bar(years,incidences)
plt.ylabel("Annual incidence")
filename
[[file:./annual_incidence.png]]
Eyeballing the plots, it looks like although 2003-04 had the greatest
spikes in terms of weekly cases, 2009-10 featured longer spells of
consistently high numbers of cases.
Anyway, let's get the strongest and weakest epidemics:
key = lambda y: y[1]
strongest = max(incidence_per_year, key=key)
weakest = min(incidence_per_year, key=key)
(strongest,weakest)
| 2009 | 841233 |
| 2020 | 221183 |
module3/exo2/incidence-zoom.png
54.1 KB | W: | H:
53.2 KB | W: | H:
  • 2-up
  • Swipe
  • Onion skin
module3/exo2/incidence.png
62.3 KB | W: | H:
63 KB | W: | H:
  • 2-up
  • Swipe
  • Onion skin
