Commit c005bd82 authored by Tommy Rushton's avatar Tommy Rushton
Bring things closer into line with target notebook.
parent 3fcff9f3
......@@ -8,12 +8,10 @@
* Table of Contents
* Asking the math library
My computer tells me that \pi is /approximatively/
My computer tells me that $\pi$ is /approximatively/
#+begin_src python :results value :session :exports both
from math import *
......@@ -24,8 +22,7 @@ pi
: 3.141592653589793
* * Buffon's needle
Applying the method of
[[https://en.wikipedia.org/wiki/Buffon%2527s_needle_problem][Buffon's needle]] we get the *approximation*
Applying the method of [[https://en.wikipedia.org/wiki/Buffon%2527s_needle_problem][Buffon's needle]], we get the *approximation*
......@@ -42,10 +39,7 @@ theta = np.random.uniform(size=N, low=0, high=pi/2)
* Using a surface fraction argument
A method that is easier to understand and does not make use of the
$\sin$ function is based on the fact that if $X ~ U(0,1)$ and $Y ~
U(0,1)$, then $P[X^2 + Y^2 \leq 1] = \pi/4$ (see
[[https://en.wikipedia.org/wiki/Monte_Carlo_method]["Monte Carlo
Method" on Wikipedia]]). The following code uses this approach:
$\sin$ function is based on the fact that if $X \sim U(0,1)$ and $Y \sim U(0,1)$, then $P[X^2 + Y^2 \leq 1] = \pi/4$ (see [[https://en.wikipedia.org/wiki/Monte_Carlo_method]["Monte Carlo Method" on Wikipedia]]). The following code uses this approach:
#+begin_src python :results output file :session :var matplot_lib_filename="figure_pi_mc2.png" :exports both
