Unfortunately there are many ways to indicate the absence of a data value in a dataset. Here we check for a common one: empty fields. For completeness, we should also look for non-numerical data in numerical columns. We don't do this here, but checks in later processing steps would catch such anomalies.
There are only two columns that we will need for our analysis: the first (~"week"~) and the third (~"inc"~). We check the names in the header to be sure we pick the right data. We make a new table containing just the two columns required, without the header.
#+BEGIN_SRC python :results silent :exports both
@@ -146,21 +134,6 @@ Let's look at the first and last lines. We insert ~None~ to indicate to org-mode
It is always prudent to verify if the data looks credible. A simple fact we can check for is that weeks are given as six-digit integers (four for the year, two for the week), and that the incidence values are positive integers.
#+BEGIN_SRC python :results output :exports both
@@ -171,8 +144,6 @@ for week, inc in data:
print("Suspicious value in column 'inc': ", (week, inc))
#+END_SRC
#+END_SRC
No problem - fine!
No problem - fine!
** Date conversion
** Date conversion
@@ -192,21 +163,6 @@ str_data = [(str(date), str(inc)) for date, inc in converted_data]
A list sorted by decreasing annual incidence makes it easy to find the most important ones:
#+BEGIN_SRC R :results output :exports both
head(annnual_inc[order(-annnual_inc$incidence),])
#+END_SRC
#+END_SRC
: year incidence
: 4 1989 5460155
: 5 1990 5233987
: 1 1986 5100540
: 28 2013 4182265
: 25 2010 4085126
: 14 1999 3897443
Finally, a histogram clearly shows the few very strong epidemics, which affect about 10% of the French population, but are rare: there were three of them in the course of 35 years. The typical epidemic affects only half as many people.
#+BEGIN_SRC R :results output graphics file :file annual-inc-hist.png :exports both
hist(annnual_inc$incidence, breaks=10, xlab="Annual incidence", ylab="Number of observations", main="")
