Premier commit - Test Gitlab
parent 784246b7
"cells": [
"execution_count": 1,
"ename": "ERROR",
"evalue": "Error in print(x): object 'x' not found\n",
"output_type": "error",
"traceback": [
"Error in print(x): object 'x' not found\nTraceback:\n",
"1. print(x)"
"print(x)"
"execution_count": null,
"source": []
"kernelspec": {
"display_name": "Python 3",
"language": "python",
"name": "python3"
"language_info": {
"codemirror_mode": "r",
"file_extension": ".r",
"mimetype": "text/x-r-source",
"name": "R",
"pygments_lexer": "r",
"version": "3.4.1"
"nbformat": 4,
"nbformat_minor": 2
"cells": [],
"kernelspec": {
"name": "python3"
"language_info": {
"codemirror_mode": {
"name": "ipython",
"version": 3
"file_extension": ".py",
"mimetype": "text/x-python",
"name": "python",
"pygments_lexer": "ipython3",
"version": "3.6.3"
"nbformat": 4,
"nbformat_minor": 2
"cells": [],
"cells": [
"execution_count": 6,
"3.141592653589793\n"
"from math import *\n",
"print(pi)"
"Mais calculé avec la __méthode__ des [aiguilles de Buffon](https://fr.wikipedia.org/wiki/Aiguille_de_Buffon), on obtiendrait comme __approximation__ :\n"
"source": []
"kernelspec": {
......@@ -16,10 +65,9 @@
"name": "python",
"version": "3.6.3"
"version": "3.6.4"
"nbformat": 4,
"nbformat_minor": 2
