no commit message
parent 78e6dbe5
...@@ -16,7 +16,7 @@ ...@@ -16,7 +16,7 @@
"execution_count": 1, "execution_count": 22,
"outputs": [], "outputs": [],
"source": [ "source": [
...@@ -29,7 +29,7 @@ ...@@ -29,7 +29,7 @@
"execution_count": 2, "execution_count": 23,
...@@ -38,14 +38,14 @@ ...@@ -38,14 +38,14 @@
"execution_count": 18, "execution_count": 26,
"outputs": [ "outputs": [
"name": "stdout", "name": "stdout",
"output_type": "stream", "output_type": "stream",
"text": [ "text": [
" Valeur moyenne : 23.4\n", " Valeur moyenne : 14.113000000000001\n",
" Ecart-type : 4.334094455301447\n", " Ecart-type : 4.334094455301447\n",
" Valeur min : 2.8\n", " Valeur min : 2.8\n",
" Valeur max : 23.4\n", " Valeur max : 23.4\n",
...@@ -54,7 +54,7 @@ ...@@ -54,7 +54,7 @@
"data_moy = np.max(data)\n", "data_moy = np.mean(data) # np.average\n",
"data_ecart_type = np.std(data,ddof=1)\n", "data_ecart_type = np.std(data,ddof=1)\n",
"data_min = np.min(data)\n", "data_min = np.min(data)\n",
"data_max = np.max(data)\n", "data_max = np.max(data)\n",
...@@ -62,6 +62,13 @@ ...@@ -62,6 +62,13 @@
"print(f' Valeur moyenne : {data_moy}\\n Ecart-type : {data_ecart_type}')\n", "print(f' Valeur moyenne : {data_moy}\\n Ecart-type : {data_ecart_type}')\n",
"print(f' Valeur min : {data_min}\\n Valeur max : {data_max}\\n Valeur mediane : {data_med} ')" "print(f' Valeur min : {data_min}\\n Valeur max : {data_max}\\n Valeur mediane : {data_med} ')"
"execution_count": null,
"source": []
"metadata": { "metadata": {
This diff is collapsed.
