par1
parent d84b936a
"cells": [ "cells": [
"# 1 On the computation of π"
"## Asking the maths library\n",
"execution_count": 2, "execution_count": 7,
"outputs": [ "outputs": [
...@@ -18,9 +33,17 @@ ...@@ -18,9 +33,17 @@
"print(pi)" "print(pi)"
"## Buffon's needle\n",
"Applying the method of [Buffon's needle](https://en.wikipedia.org/wiki/Buffon%27s_needle_problem), we get the __approximation__"
"execution_count": 3, "execution_count": 8,
...@@ -29,7 +52,7 @@ ...@@ -29,7 +52,7 @@
"3.128911138923655" "3.128911138923655"
"output_type": "execute_result" "output_type": "execute_result"
...@@ -43,9 +66,17 @@ ...@@ -43,9 +66,17 @@
"2/(sum((x+np.sin(theta))>1)/N)" "2/(sum((x+np.sin(theta))>1)/N)"
"A method that is easier to understand and does not make use of the $\\sin$ function is based on the fact that if $X\\sim U(0,1)$ and $Y\\sim U(0,1)$, then $P[X^2+Y^2\\leq 1] = \\pi/4$ (see [\"Monte Carlo method\" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:"
"execution_count": 4, "execution_count": 9,
...@@ -64,6 +95,7 @@ ...@@ -64,6 +95,7 @@
"source": [ "source": [
"%matplotlib inline\n", "%matplotlib inline\n",
"import matplotlib.pyplot as plt\n", "import matplotlib.pyplot as plt\n",
"np.random.seed(seed=42)\n", "np.random.seed(seed=42)\n",
"N = 1000\n", "N = 1000\n",
"x = np.random.uniform(size=N, low=0, high=1)\n", "x = np.random.uniform(size=N, low=0, high=1)\n",
...@@ -71,15 +103,23 @@ ...@@ -71,15 +103,23 @@
"\n", "\n",
"accept = (x*x+y*y) <= 1\n", "accept = (x*x+y*y) <= 1\n",
"reject = np.logical_not(accept)\n", "reject = np.logical_not(accept)\n",
"fig, ax = plt.subplots(1)\n", "fig, ax = plt.subplots(1)\n",
"ax.scatter(x[accept], y[accept], c='b', alpha=0.2, edgecolor=None)\n", "ax.scatter(x[accept], y[accept], c='b', alpha=0.2, edgecolor=None)\n",
"ax.scatter(x[reject], y[reject], c='r', alpha=0.2, edgecolor=None)\n", "ax.scatter(x[reject], y[reject], c='r', alpha=0.2, edgecolor=None)\n",
"ax.set_aspect('equal')" "ax.set_aspect('equal')"
"It is then straightforward to obtain a (not really good) approximation to $\\pi$ by counting how many times, on average, $X^2 + Y^2$ is smaller than 1:"
"execution_count": 5, "execution_count": 11,
...@@ -88,7 +128,7 @@ ...@@ -88,7 +128,7 @@
"3.112" "3.112"
