Commit 6dd120f8 authored by MigAP's avatar MigAP
exercice 3
parent 91c2fc9f
......@@ -91,3 +91,45 @@ faisant ~<p~, ~<P~ ou ~<PP~ suivi de ~Tab~).
* Exo 3
#+begin_src python :results output file :session python :exports both
data = np.array([ 14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0 ])
indx = np.arange(100);
plt.figure(figsize=(10,5))
plt.plot(indx,data)
plt.tight_layout()
plt.savefig("graph1.png")
print("graph1.png")
[[file:graph1.png]]
File "<stdin>", line 1, in <module>
File "/tmp/babel-9WZjyx/python-UVznjd", line 10, in <module>
plt.gird(True)
AttributeError: module 'matplotlib.pyplot' has no attribute 'gird']]
plt.hist(data, bins=10)
plt.tight_layout()
plt.savefig("graph2.png")
print("graph2.png")
[[file:graph2.png]]
