d76bb037743742eedff662532efb18c3
3d853e7c
3d853e7c
Calculer des statistiques
1d770c2e
151 additions
3 deletions
+151
-3
exercice.ipynb
module2/exo2/exercice.ipynb
+151
-3
3d853e7c
"cells": [],
"cells": [
"# Savoir faire un calcul simple soi-même"
"execution_count": 1,
"import numpy as np\n",
"import pandas as pd"
"On importe les packages"
"execution_count": 2,
"data = [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9, 12.2, 9.9, 2.9, 2.8, 15.4, \n",
" 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, \n",
" 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, \n",
" 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, \n",
" 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, \n",
" 15.7, 10.2, 8.9, 21.0]\n"
"On définit la liste de données "
"execution_count": 3,
"mean = np.mean(data)\n",
"std_dev = np.std(data)\n",
"minimum = np.min(data)\n",
"median = np.median(data)\n",
"maximum = np.max(data)"
"On calcule les statistiques demandées"
"execution_count": 5,
"text/html": [
"<div>\n",
"<style scoped>\n",
" vertical-align: middle;\n",
" }\n",
" vertical-align: top;\n",
" }\n",
" .dataframe thead th {\n",
" text-align: right;\n",
" }\n",
"</style>\n",
" <thead>\n",
" <th></th>\n",
" <th>Maximum</th>\n",
" <th>Mean</th>\n",
" <th>Median</th>\n",
" <th>Minimum</th>\n",
" <th>Standard Deviation</th>\n",
" </tr>\n",
" </thead>\n",
" <tbody>\n",
" <tr>\n",
" <th>0</th>\n",
" <td>23.4</td>\n",
" <td>14.113</td>\n",
" <td>14.5</td>\n",
" <td>2.8</td>\n",
" <td>4.31237</td>\n",
" </tr>\n",
" </tbody>\n",
"</table>\n",
"</div>"
" Maximum Mean Median Minimum Standard Deviation\n",
"0 23.4 14.113 14.5 2.8 4.31237"
"results = pd.DataFrame({\n",
" 'Mean': [mean],\n",
" 'Standard Deviation': [std_dev],\n",
" 'Minimum': [minimum],\n",
" 'Median': [median],\n",
" 'Maximum': [maximum]\n",
"})\n",
"results"
"On crée un DataFrame pour afficher les résultats"
"execution_count": null,
"source": []
"kernelspec": {
"display_name": "Python 3",
@@ -16,10 +165,9 @@
"name": "python",
"pygments_lexer": "ipython3",
"version": "3.6.
3
"version": "3.6.
4
"nbformat": 4,
"nbformat_minor": 2
