"execution_count": 1,
@@ -18,6 +37,24 @@
@@ -18,6 +37,24 @@
" print(pi)"
" print(pi)"
"execution_count": null,
"## Buffon's needle"
"Applying the method of [Buffon's needle](https://en.wikipedia.org/wiki/Buffon%27s_needle_problem), we get the __approximation__"
"execution_count": 2,
@@ -43,6 +80,24 @@
@@ -43,6 +80,24 @@
" 2/(sum((x+np.sin(theta))>1)/N)"
"## Using a surface fraction argument"
"A method that is easier to understand and does not make use of the $\\sin$ function is based on the fact that if $X\\sim U(0,1)$ and $Y\\sim U(0,1)$, then $P[X^2+Y^2\\leq 1] = \\pi/4$ (see [\"Monte Carlo method\" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:"
"execution_count": 3,
@@ -77,6 +132,15 @@
@@ -77,6 +132,15 @@
" ax.set_aspect('equal')"
"It is then straightforward to obtain a (not really good) approximation to $\\pi$ by counting how many times, on average, $X^2 + Y^2$ is smaller than 1:"
