diff --git a/module2/exo1/Analyse de l'incidence de la varicelle-Copy1.ipynb b/module2/exo1/Analyse de l'incidence de la varicelle-Copy1.ipynb new file mode 100644 index 0000000000000000000000000000000000000000..d0fc61e78725a3ea2a11966ac3a57e5ed6b7bf7c --- /dev/null +++ b/module2/exo1/Analyse de l'incidence de la varicelle-Copy1.ipynb @@ -0,0 +1,203 @@ +{ + "cells": [ + { + "cell_type": "code", + "execution_count": 1, + "metadata": {}, + "outputs": [], + "source": [ + "%matplotlib inline\n", + "import matplotlib.pyplot as plt\n", + "import pandas as pd\n", + "import isoweek" + ] + }, + { + "cell_type": "code", + "execution_count": 5, + "metadata": {}, + "outputs": [ + { + "ename": "FileNotFoundError", + "evalue": "File b'incidence-PAY-3.csv' does not exist", + "output_type": "error", + "traceback": [ + "\u001b[0;31m---------------------------------------------------------------------------\u001b[0m", + "\u001b[0;31mFileNotFoundError\u001b[0m Traceback (most recent call last)", + "\u001b[0;32m\u001b[0m in \u001b[0;36m\u001b[0;34m\u001b[0m\n\u001b[0;32m----> 1\u001b[0;31m \u001b[0mraw_data\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mpd\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread_csv\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m\"incidence-PAY-3.csv\"\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 2\u001b[0m \u001b[0mraw_data\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36mparser_f\u001b[0;34m(filepath_or_buffer, sep, delimiter, header, names, index_col, usecols, squeeze, prefix, mangle_dupe_cols, dtype, engine, converters, true_values, false_values, skipinitialspace, skiprows, nrows, na_values, keep_default_na, na_filter, verbose, skip_blank_lines, parse_dates, infer_datetime_format, keep_date_col, date_parser, dayfirst, iterator, chunksize, compression, thousands, decimal, lineterminator, quotechar, quoting, escapechar, comment, encoding, dialect, tupleize_cols, error_bad_lines, warn_bad_lines, skipfooter, skip_footer, doublequote, delim_whitespace, as_recarray, compact_ints, use_unsigned, low_memory, buffer_lines, memory_map, float_precision)\u001b[0m\n\u001b[1;32m 707\u001b[0m skip_blank_lines=skip_blank_lines)\n\u001b[1;32m 708\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 709\u001b[0;31m \u001b[0;32mreturn\u001b[0m \u001b[0m_read\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mfilepath_or_buffer\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mkwds\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 710\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 711\u001b[0m \u001b[0mparser_f\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m__name__\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mname\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36m_read\u001b[0;34m(filepath_or_buffer, kwds)\u001b[0m\n\u001b[1;32m 447\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 448\u001b[0m \u001b[0;31m# Create the parser.\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 449\u001b[0;31m \u001b[0mparser\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mTextFileReader\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mfilepath_or_buffer\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0;34m**\u001b[0m\u001b[0mkwds\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 450\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 451\u001b[0m \u001b[0;32mif\u001b[0m \u001b[0mchunksize\u001b[0m \u001b[0;32mor\u001b[0m \u001b[0miterator\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36m__init__\u001b[0;34m(self, f, engine, **kwds)\u001b[0m\n\u001b[1;32m 816\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0moptions\u001b[0m\u001b[0;34m[\u001b[0m\u001b[0;34m'has_index_names'\u001b[0m\u001b[0;34m]\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mkwds\u001b[0m\u001b[0;34m[\u001b[0m\u001b[0;34m'has_index_names'\u001b[0m\u001b[0;34m]\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 817\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 818\u001b[0;31m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_make_engine\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mengine\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 819\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 820\u001b[0m \u001b[0;32mdef\u001b[0m \u001b[0mclose\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mself\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36m_make_engine\u001b[0;34m(self, engine)\u001b[0m\n\u001b[1;32m 1047\u001b[0m \u001b[0;32mdef\u001b[0m \u001b[0m_make_engine\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mself\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mengine\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;34m'c'\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1048\u001b[0m \u001b[0;32mif\u001b[0m \u001b[0mengine\u001b[0m \u001b[0;34m==\u001b[0m \u001b[0;34m'c'\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m-> 1049\u001b[0;31m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_engine\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mCParserWrapper\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mf\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0;34m**\u001b[0m\u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0moptions\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 1050\u001b[0m \u001b[0;32melse\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1051\u001b[0m \u001b[0;32mif\u001b[0m \u001b[0mengine\u001b[0m \u001b[0;34m==\u001b[0m \u001b[0;34m'python'\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36m__init__\u001b[0;34m(self, src, **kwds)\u001b[0m\n\u001b[1;32m 1693\u001b[0m \u001b[0mkwds\u001b[0m\u001b[0;34m[\u001b[0m\u001b[0;34m'allow_leading_cols'\u001b[0m\u001b[0;34m]\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mindex_col\u001b[0m \u001b[0;32mis\u001b[0m \u001b[0;32mnot\u001b[0m \u001b[0;32mFalse\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1694\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m-> 1695\u001b[0;31m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_reader\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mparsers\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mTextReader\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0msrc\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0;34m**\u001b[0m\u001b[0mkwds\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 1696\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1697\u001b[0m \u001b[0;31m# XXX\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32mpandas/_libs/parsers.pyx\u001b[0m in \u001b[0;36mpandas._libs.parsers.TextReader.__cinit__\u001b[0;34m()\u001b[0m\n", + "\u001b[0;32mpandas/_libs/parsers.pyx\u001b[0m in \u001b[0;36mpandas._libs.parsers.TextReader._setup_parser_source\u001b[0;34m()\u001b[0m\n", + "\u001b[0;31mFileNotFoundError\u001b[0m: File b'incidence-PAY-3.csv' does not exist" + ] + } + ], + "source": [ + "raw_data = pd.read_csv(\"incidence-PAY-3.csv\")\n", + "raw_data" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "raw_data[raw_data.isnull().any(axis=1)]" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "data = raw_data.dropna().copy()\n", + "data" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "def convert_week(year_and_week_int):\n", + " year_and_week_str = str(year_and_week_int)\n", + " year = int(year_and_week_str[:4])\n", + " week = int(year_and_week_str[4:])\n", + " w = isoweek.Week(year, week)\n", + " return pd.Period(w.day(0), 'W')\n", + "\n", + "data['period'] = [convert_week(yw) for yw in data['week']]" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "sorted_data = data.set_index('period').sort_index()" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "periods = sorted_data.index\n", + "for p1, p2 in zip(periods[:-1], periods[1:]):\n", + " delta = p2.to_timestamp() - p1.end_time\n", + " if delta > pd.Timedelta('1s'):\n", + " print(p1, p2)" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "sorted_data['inc'].plot()" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "sorted_data['inc'][-200:].plot()" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "first_septembre_week = [pd.Period(pd.Timestamp(y, 9, 1), 'W')\n", + " for y in range(1985,\n", + " sorted_data.index[-1].year)]" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "year = []\n", + "yearly_incidence = []\n", + "for week1, week2 in zip(first_septembre_week[:-1],\n", + " first_septembre_week[1:]):\n", + " one_year = sorted_data['inc'][week1:week2-1]\n", + " assert abs(len(one_year)-52) < 2\n", + " yearly_incidence.append(one_year.sum())\n", + " year.append(week2.year)\n", + "yearly_incidence = pd.Series(data=yearly_incidence, index=year)" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "yearly_incidence.plot(style='*')" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "yearly_incidence.sort_values()" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "yearly_incidence.hist(xrot=20)" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [] + } + ], + "metadata": { + "kernelspec": { + "display_name": "Python 3", + "language": "python", + "name": "python3" + }, + "language_info": { + "codemirror_mode": { + "name": "ipython", + "version": 3 + }, + "file_extension": ".py", + "mimetype": "text/x-python", + "name": "python", + "nbconvert_exporter": "python", + "pygments_lexer": "ipython3", + "version": "3.6.4" + } + }, + "nbformat": 4, + "nbformat_minor": 2 +} diff --git a/module2/exo1/Analyse de l'incidence de la varicelle.ipynb b/module2/exo1/Analyse de l'incidence de la varicelle.ipynb new file mode 100644 index 0000000000000000000000000000000000000000..d0fc61e78725a3ea2a11966ac3a57e5ed6b7bf7c --- /dev/null +++ b/module2/exo1/Analyse de l'incidence de la varicelle.ipynb @@ -0,0 +1,203 @@ +{ + "cells": [ + { + "cell_type": "code", + "execution_count": 1, + "metadata": {}, + "outputs": [], + "source": [ + "%matplotlib inline\n", + "import matplotlib.pyplot as plt\n", + "import pandas as pd\n", + "import isoweek" + ] + }, + { + "cell_type": "code", + "execution_count": 5, + "metadata": {}, + "outputs": [ + { + "ename": "FileNotFoundError", + "evalue": "File b'incidence-PAY-3.csv' does not exist", + "output_type": "error", + "traceback": [ + "\u001b[0;31m---------------------------------------------------------------------------\u001b[0m", + "\u001b[0;31mFileNotFoundError\u001b[0m Traceback (most recent call last)", + "\u001b[0;32m\u001b[0m in \u001b[0;36m\u001b[0;34m\u001b[0m\n\u001b[0;32m----> 1\u001b[0;31m \u001b[0mraw_data\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mpd\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread_csv\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m\"incidence-PAY-3.csv\"\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 2\u001b[0m \u001b[0mraw_data\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36mparser_f\u001b[0;34m(filepath_or_buffer, sep, delimiter, header, names, index_col, usecols, squeeze, prefix, mangle_dupe_cols, dtype, engine, converters, true_values, false_values, skipinitialspace, skiprows, nrows, na_values, keep_default_na, na_filter, verbose, skip_blank_lines, parse_dates, infer_datetime_format, keep_date_col, date_parser, dayfirst, iterator, chunksize, compression, thousands, decimal, lineterminator, quotechar, quoting, escapechar, comment, encoding, dialect, tupleize_cols, error_bad_lines, warn_bad_lines, skipfooter, skip_footer, doublequote, delim_whitespace, as_recarray, compact_ints, use_unsigned, low_memory, buffer_lines, memory_map, float_precision)\u001b[0m\n\u001b[1;32m 707\u001b[0m skip_blank_lines=skip_blank_lines)\n\u001b[1;32m 708\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 709\u001b[0;31m \u001b[0;32mreturn\u001b[0m \u001b[0m_read\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mfilepath_or_buffer\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mkwds\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 710\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 711\u001b[0m \u001b[0mparser_f\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m__name__\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mname\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36m_read\u001b[0;34m(filepath_or_buffer, kwds)\u001b[0m\n\u001b[1;32m 447\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 448\u001b[0m \u001b[0;31m# Create the parser.\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 449\u001b[0;31m \u001b[0mparser\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mTextFileReader\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mfilepath_or_buffer\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0;34m**\u001b[0m\u001b[0mkwds\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 450\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 451\u001b[0m \u001b[0;32mif\u001b[0m \u001b[0mchunksize\u001b[0m \u001b[0;32mor\u001b[0m \u001b[0miterator\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36m__init__\u001b[0;34m(self, f, engine, **kwds)\u001b[0m\n\u001b[1;32m 816\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0moptions\u001b[0m\u001b[0;34m[\u001b[0m\u001b[0;34m'has_index_names'\u001b[0m\u001b[0;34m]\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mkwds\u001b[0m\u001b[0;34m[\u001b[0m\u001b[0;34m'has_index_names'\u001b[0m\u001b[0;34m]\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 817\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 818\u001b[0;31m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_make_engine\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mengine\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 819\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 820\u001b[0m \u001b[0;32mdef\u001b[0m \u001b[0mclose\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mself\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36m_make_engine\u001b[0;34m(self, engine)\u001b[0m\n\u001b[1;32m 1047\u001b[0m \u001b[0;32mdef\u001b[0m \u001b[0m_make_engine\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mself\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mengine\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;34m'c'\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1048\u001b[0m \u001b[0;32mif\u001b[0m \u001b[0mengine\u001b[0m \u001b[0;34m==\u001b[0m \u001b[0;34m'c'\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m-> 1049\u001b[0;31m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_engine\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mCParserWrapper\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mf\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0;34m**\u001b[0m\u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0moptions\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 1050\u001b[0m \u001b[0;32melse\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1051\u001b[0m \u001b[0;32mif\u001b[0m \u001b[0mengine\u001b[0m \u001b[0;34m==\u001b[0m \u001b[0;34m'python'\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36m__init__\u001b[0;34m(self, src, **kwds)\u001b[0m\n\u001b[1;32m 1693\u001b[0m \u001b[0mkwds\u001b[0m\u001b[0;34m[\u001b[0m\u001b[0;34m'allow_leading_cols'\u001b[0m\u001b[0;34m]\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mindex_col\u001b[0m \u001b[0;32mis\u001b[0m \u001b[0;32mnot\u001b[0m \u001b[0;32mFalse\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1694\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m-> 1695\u001b[0;31m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_reader\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mparsers\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mTextReader\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0msrc\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0;34m**\u001b[0m\u001b[0mkwds\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 1696\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1697\u001b[0m \u001b[0;31m# XXX\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32mpandas/_libs/parsers.pyx\u001b[0m in \u001b[0;36mpandas._libs.parsers.TextReader.__cinit__\u001b[0;34m()\u001b[0m\n", + "\u001b[0;32mpandas/_libs/parsers.pyx\u001b[0m in \u001b[0;36mpandas._libs.parsers.TextReader._setup_parser_source\u001b[0;34m()\u001b[0m\n", + "\u001b[0;31mFileNotFoundError\u001b[0m: File b'incidence-PAY-3.csv' does not exist" + ] + } + ], + "source": [ + "raw_data = pd.read_csv(\"incidence-PAY-3.csv\")\n", + "raw_data" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "raw_data[raw_data.isnull().any(axis=1)]" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "data = raw_data.dropna().copy()\n", + "data" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "def convert_week(year_and_week_int):\n", + " year_and_week_str = str(year_and_week_int)\n", + " year = int(year_and_week_str[:4])\n", + " week = int(year_and_week_str[4:])\n", + " w = isoweek.Week(year, week)\n", + " return pd.Period(w.day(0), 'W')\n", + "\n", + "data['period'] = [convert_week(yw) for yw in data['week']]" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "sorted_data = data.set_index('period').sort_index()" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "periods = sorted_data.index\n", + "for p1, p2 in zip(periods[:-1], periods[1:]):\n", + " delta = p2.to_timestamp() - p1.end_time\n", + " if delta > pd.Timedelta('1s'):\n", + " print(p1, p2)" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "sorted_data['inc'].plot()" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "sorted_data['inc'][-200:].plot()" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "first_septembre_week = [pd.Period(pd.Timestamp(y, 9, 1), 'W')\n", + " for y in range(1985,\n", + " sorted_data.index[-1].year)]" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "year = []\n", + "yearly_incidence = []\n", + "for week1, week2 in zip(first_septembre_week[:-1],\n", + " first_septembre_week[1:]):\n", + " one_year = sorted_data['inc'][week1:week2-1]\n", + " assert abs(len(one_year)-52) < 2\n", + " yearly_incidence.append(one_year.sum())\n", + " year.append(week2.year)\n", + "yearly_incidence = pd.Series(data=yearly_incidence, index=year)" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "yearly_incidence.plot(style='*')" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "yearly_incidence.sort_values()" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "yearly_incidence.hist(xrot=20)" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [] + } + ], + "metadata": { + "kernelspec": { + "display_name": "Python 3", + "language": "python", + "name": "python3" + }, + "language_info": { + "codemirror_mode": { + "name": "ipython", + "version": 3 + }, + "file_extension": ".py", + "mimetype": "text/x-python", + "name": "python", + "nbconvert_exporter": "python", + "pygments_lexer": "ipython3", + "version": "3.6.4" + } + }, + "nbformat": 4, + "nbformat_minor": 2 +} diff --git a/module2/exo1/toy_notebook_fr.ipynb b/module2/exo1/toy_notebook_fr.ipynb deleted file mode 100644 index c6f02f6f7b4b693b04a99b716e995581b4d8254d..0000000000000000000000000000000000000000 --- a/module2/exo1/toy_notebook_fr.ipynb +++ /dev/null @@ -1,32 +0,0 @@ -{ - "cells": [ - { - "cell_type": "code", - "execution_count": null, - "metadata": {}, - "outputs": [], - "source": [] - } - ], - "metadata": { - "kernelspec": { - "display_name": "Python 3", - "language": "python", - "name": "python3" - }, - "language_info": { - "codemirror_mode": { - "name": "ipython", - "version": 3 - }, - "file_extension": ".py", - "mimetype": "text/x-python", - "name": "python", - "nbconvert_exporter": "python", - "pygments_lexer": "ipython3", - "version": "3.6.4" - } - }, - "nbformat": 4, - "nbformat_minor": 2 -} diff --git a/module3/exo3/Analyse de l'incidence de la varicelle.ipynb b/module3/exo3/Analyse de l'incidence de la varicelle.ipynb new file mode 100644 index 0000000000000000000000000000000000000000..a614970174046f83bf3fb13ced0d32fc09af63c0 --- /dev/null +++ b/module3/exo3/Analyse de l'incidence de la varicelle.ipynb @@ -0,0 +1,2328 @@ +{ + "cells": [ + { + "cell_type": "code", + "execution_count": 1, + "metadata": {}, + "outputs": [], + "source": [ + "%matplotlib inline\n", + "import matplotlib.pyplot as plt\n", + "import pandas as pd\n", + "import isoweek" + ] + }, + { + "cell_type": "code", + "execution_count": 2, + "metadata": {}, + "outputs": [ + { + "data": { + "text/html": [ + "
\n", + "\n", + "\n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + "
weekindicatorincinc_lowinc_upinc100inc100_lowinc100_upgeo_inseegeo_name
020210832090316885.024921.03226.038.0FRFrance
120210732239318303.026483.03428.040.0FRFrance
220210632318319134.027232.03529.041.0FRFrance
320210532242618445.026407.03428.040.0FRFrance
420210432580421491.030117.03932.046.0FRFrance
520210332181017894.025726.03327.039.0FRFrance
620210231732013906.020734.02621.031.0FRFrance
720210132179917778.025820.03327.039.0FRFrance
820205332122016498.025942.03225.039.0FRFrance
920205231642812285.020571.02519.031.0FRFrance
1020205132161917370.025868.03327.039.0FRFrance
1120205031684513220.020470.02620.032.0FRFrance
122020493129399923.015955.02015.025.0FRFrance
1320204831380410641.016967.02116.026.0FRFrance
1420204731908515285.022885.02923.035.0FRFrance
1520204632480120503.029099.03831.045.0FRFrance
1620204534251636857.048175.06556.074.0FRFrance
1720204434456738521.050613.06859.077.0FRFrance
1820204334373737523.049951.06657.075.0FRFrance
1920204233514529812.040478.05345.061.0FRFrance
2020204132787723206.032548.04235.049.0FRFrance
2120204032044316381.024505.03125.037.0FRFrance
2220203931981015900.023720.03024.036.0FRFrance
2320203832555921141.029977.03932.046.0FRFrance
2420203731848514649.022321.02822.034.0FRFrance
252020363103907646.013134.01612.020.0FRFrance
26202035399186842.012994.01510.020.0FRFrance
27202034360843090.09078.094.014.0FRFrance
28202033361063411.08801.095.013.0FRFrance
29202032359183330.08506.095.013.0FRFrance
186619852132609619621.032571.04735.059.0FRFrance
186719852032789620885.034907.05138.064.0FRFrance
186819851934315432821.053487.07859.097.0FRFrance
186919851834055529935.051175.07455.093.0FRFrance
187019851733405324366.043740.06244.080.0FRFrance
187119851635036236451.064273.09166.0116.0FRFrance
187219851536388145538.082224.011683.0149.0FRFrance
18731985143134545114400.0154690.0244207.0281.0FRFrance
18741985133197206176080.0218332.0357319.0395.0FRFrance
18751985123245240223304.0267176.0445405.0485.0FRFrance
18761985113276205252399.0300011.0501458.0544.0FRFrance
18771985103353231326279.0380183.0640591.0689.0FRFrance
18781985093369895341109.0398681.0670618.0722.0FRFrance
18791985083389886359529.0420243.0707652.0762.0FRFrance
18801985073471852432599.0511105.0855784.0926.0FRFrance
18811985063565825518011.0613639.01026939.01113.0FRFrance
18821985053637302592795.0681809.011551074.01236.0FRFrance
18831985043424937390794.0459080.0770708.0832.0FRFrance
18841985033213901174689.0253113.0388317.0459.0FRFrance
188519850239758680949.0114223.0177147.0207.0FRFrance
188619850138548965918.0105060.0155120.0190.0FRFrance
188719845238483060602.0109058.0154110.0198.0FRFrance
1888198451310172680242.0123210.0185146.0224.0FRFrance
18891984503123680101401.0145959.0225184.0266.0FRFrance
1890198449310107381684.0120462.0184149.0219.0FRFrance
189119844837862060634.096606.0143110.0176.0FRFrance
189219844737202954274.089784.013199.0163.0FRFrance
189319844638733067686.0106974.0159123.0195.0FRFrance
18941984453135223101414.0169032.0246184.0308.0FRFrance
189519844436842220056.0116788.012537.0213.0FRFrance
\n", + "
1896 rows × 10 columns
\n", + "
" + ], + "text/plain": [ + " week indicator inc inc_low inc_up inc100 inc100_low \\\n", + "0 202108 3 20903 16885.0 24921.0 32 26.0 \n", + "1 202107 3 22393 18303.0 26483.0 34 28.0 \n", + "2 202106 3 23183 19134.0 27232.0 35 29.0 \n", + "3 202105 3 22426 18445.0 26407.0 34 28.0 \n", + "4 202104 3 25804 21491.0 30117.0 39 32.0 \n", + "5 202103 3 21810 17894.0 25726.0 33 27.0 \n", + "6 202102 3 17320 13906.0 20734.0 26 21.0 \n", + "7 202101 3 21799 17778.0 25820.0 33 27.0 \n", + "8 202053 3 21220 16498.0 25942.0 32 25.0 \n", + "9 202052 3 16428 12285.0 20571.0 25 19.0 \n", + "10 202051 3 21619 17370.0 25868.0 33 27.0 \n", + "11 202050 3 16845 13220.0 20470.0 26 20.0 \n", + "12 202049 3 12939 9923.0 15955.0 20 15.0 \n", + "13 202048 3 13804 10641.0 16967.0 21 16.0 \n", + "14 202047 3 19085 15285.0 22885.0 29 23.0 \n", + "15 202046 3 24801 20503.0 29099.0 38 31.0 \n", + "16 202045 3 42516 36857.0 48175.0 65 56.0 \n", + "17 202044 3 44567 38521.0 50613.0 68 59.0 \n", + "18 202043 3 43737 37523.0 49951.0 66 57.0 \n", + "19 202042 3 35145 29812.0 40478.0 53 45.0 \n", + "20 202041 3 27877 23206.0 32548.0 42 35.0 \n", + "21 202040 3 20443 16381.0 24505.0 31 25.0 \n", + "22 202039 3 19810 15900.0 23720.0 30 24.0 \n", + "23 202038 3 25559 21141.0 29977.0 39 32.0 \n", + "24 202037 3 18485 14649.0 22321.0 28 22.0 \n", + "25 202036 3 10390 7646.0 13134.0 16 12.0 \n", + "26 202035 3 9918 6842.0 12994.0 15 10.0 \n", + "27 202034 3 6084 3090.0 9078.0 9 4.0 \n", + "28 202033 3 6106 3411.0 8801.0 9 5.0 \n", + "29 202032 3 5918 3330.0 8506.0 9 5.0 \n", + "... ... ... ... ... ... ... ... \n", + "1866 198521 3 26096 19621.0 32571.0 47 35.0 \n", + "1867 198520 3 27896 20885.0 34907.0 51 38.0 \n", + "1868 198519 3 43154 32821.0 53487.0 78 59.0 \n", + "1869 198518 3 40555 29935.0 51175.0 74 55.0 \n", + "1870 198517 3 34053 24366.0 43740.0 62 44.0 \n", + "1871 198516 3 50362 36451.0 64273.0 91 66.0 \n", + "1872 198515 3 63881 45538.0 82224.0 116 83.0 \n", + "1873 198514 3 134545 114400.0 154690.0 244 207.0 \n", + "1874 198513 3 197206 176080.0 218332.0 357 319.0 \n", + "1875 198512 3 245240 223304.0 267176.0 445 405.0 \n", + "1876 198511 3 276205 252399.0 300011.0 501 458.0 \n", + "1877 198510 3 353231 326279.0 380183.0 640 591.0 \n", + "1878 198509 3 369895 341109.0 398681.0 670 618.0 \n", + "1879 198508 3 389886 359529.0 420243.0 707 652.0 \n", + "1880 198507 3 471852 432599.0 511105.0 855 784.0 \n", + "1881 198506 3 565825 518011.0 613639.0 1026 939.0 \n", + "1882 198505 3 637302 592795.0 681809.0 1155 1074.0 \n", + "1883 198504 3 424937 390794.0 459080.0 770 708.0 \n", + "1884 198503 3 213901 174689.0 253113.0 388 317.0 \n", + "1885 198502 3 97586 80949.0 114223.0 177 147.0 \n", + "1886 198501 3 85489 65918.0 105060.0 155 120.0 \n", + "1887 198452 3 84830 60602.0 109058.0 154 110.0 \n", + "1888 198451 3 101726 80242.0 123210.0 185 146.0 \n", + "1889 198450 3 123680 101401.0 145959.0 225 184.0 \n", + "1890 198449 3 101073 81684.0 120462.0 184 149.0 \n", + "1891 198448 3 78620 60634.0 96606.0 143 110.0 \n", + "1892 198447 3 72029 54274.0 89784.0 131 99.0 \n", + "1893 198446 3 87330 67686.0 106974.0 159 123.0 \n", + "1894 198445 3 135223 101414.0 169032.0 246 184.0 \n", + "1895 198444 3 68422 20056.0 116788.0 125 37.0 \n", + "\n", + " inc100_up geo_insee geo_name \n", + "0 38.0 FR France \n", + "1 40.0 FR France \n", + "2 41.0 FR France \n", + "3 40.0 FR France \n", + "4 46.0 FR France \n", + "5 39.0 FR France \n", + "6 31.0 FR France \n", + "7 39.0 FR France \n", + "8 39.0 FR France \n", + "9 31.0 FR France \n", + "10 39.0 FR France \n", + "11 32.0 FR France \n", + "12 25.0 FR France \n", + "13 26.0 FR France \n", + "14 35.0 FR France \n", + "15 45.0 FR France \n", + "16 74.0 FR France \n", + "17 77.0 FR France \n", + "18 75.0 FR France \n", + "19 61.0 FR France \n", + "20 49.0 FR France \n", + "21 37.0 FR France \n", + "22 36.0 FR France \n", + "23 46.0 FR France \n", + "24 34.0 FR France \n", + "25 20.0 FR France \n", + "26 20.0 FR France \n", + "27 14.0 FR France \n", + "28 13.0 FR France \n", + "29 13.0 FR France \n", + "... ... ... ... \n", + "1866 59.0 FR France \n", + "1867 64.0 FR France \n", + "1868 97.0 FR France \n", + "1869 93.0 FR France \n", + "1870 80.0 FR France \n", + "1871 116.0 FR France \n", + "1872 149.0 FR France \n", + "1873 281.0 FR France \n", + "1874 395.0 FR France \n", + "1875 485.0 FR France \n", + "1876 544.0 FR France \n", + "1877 689.0 FR France \n", + "1878 722.0 FR France \n", + "1879 762.0 FR France \n", + "1880 926.0 FR France \n", + "1881 1113.0 FR France \n", + "1882 1236.0 FR France \n", + "1883 832.0 FR France \n", + "1884 459.0 FR France \n", + "1885 207.0 FR France \n", + "1886 190.0 FR France \n", + "1887 198.0 FR France \n", + "1888 224.0 FR France \n", + "1889 266.0 FR France \n", + "1890 219.0 FR France \n", + "1891 176.0 FR France \n", + "1892 163.0 FR France \n", + "1893 195.0 FR France \n", + "1894 308.0 FR France \n", + "1895 213.0 FR France \n", + "\n", + "[1896 rows x 10 columns]" + ] + }, + "execution_count": 2, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "raw_data = pd.read_csv(\"incidence-PAY-3.csv\",encoding=\"ISO-8859-1\",skiprows=1)\n", + "raw_data" + ] + }, + { + "cell_type": "code", + "execution_count": 3, + "metadata": {}, + "outputs": [ + { + "data": { + "text/html": [ + "
165919891930NaNNaN0NaNNaNFRFrance
\n", + "
" + ], + "text/plain": [ + " week indicator inc inc_low inc_up inc100 inc100_low inc100_up \\\n", + "1659 198919 3 0 NaN NaN 0 NaN NaN \n", + "\n", + " geo_insee geo_name \n", + "1659 FR France " + ] + }, + "execution_count": 3, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "raw_data[raw_data.isnull().any(axis=1)]" + ] + }, + { + "cell_type": "code", + "execution_count": 4, + "metadata": {}, + "outputs": [ + { + "data": { + "text/html": [ + "
\n", + "
1895 rows × 10 columns
\n", + "
" + ], + "text/plain": [ + " week indicator inc inc_low inc_up inc100 inc100_low \\\n", + "0 202108 3 20903 16885.0 24921.0 32 26.0 \n", + "1 202107 3 22393 18303.0 26483.0 34 28.0 \n", + "2 202106 3 23183 19134.0 27232.0 35 29.0 \n", + "3 202105 3 22426 18445.0 26407.0 34 28.0 \n", + "4 202104 3 25804 21491.0 30117.0 39 32.0 \n", + "5 202103 3 21810 17894.0 25726.0 33 27.0 \n", + "6 202102 3 17320 13906.0 20734.0 26 21.0 \n", + "7 202101 3 21799 17778.0 25820.0 33 27.0 \n", + "8 202053 3 21220 16498.0 25942.0 32 25.0 \n", + "9 202052 3 16428 12285.0 20571.0 25 19.0 \n", + "10 202051 3 21619 17370.0 25868.0 33 27.0 \n", + "11 202050 3 16845 13220.0 20470.0 26 20.0 \n", + "12 202049 3 12939 9923.0 15955.0 20 15.0 \n", + "13 202048 3 13804 10641.0 16967.0 21 16.0 \n", + "14 202047 3 19085 15285.0 22885.0 29 23.0 \n", + "15 202046 3 24801 20503.0 29099.0 38 31.0 \n", + "16 202045 3 42516 36857.0 48175.0 65 56.0 \n", + "17 202044 3 44567 38521.0 50613.0 68 59.0 \n", + "18 202043 3 43737 37523.0 49951.0 66 57.0 \n", + "19 202042 3 35145 29812.0 40478.0 53 45.0 \n", + "20 202041 3 27877 23206.0 32548.0 42 35.0 \n", + "21 202040 3 20443 16381.0 24505.0 31 25.0 \n", + "22 202039 3 19810 15900.0 23720.0 30 24.0 \n", + "23 202038 3 25559 21141.0 29977.0 39 32.0 \n", + "24 202037 3 18485 14649.0 22321.0 28 22.0 \n", + "25 202036 3 10390 7646.0 13134.0 16 12.0 \n", + "26 202035 3 9918 6842.0 12994.0 15 10.0 \n", + "27 202034 3 6084 3090.0 9078.0 9 4.0 \n", + "28 202033 3 6106 3411.0 8801.0 9 5.0 \n", + "29 202032 3 5918 3330.0 8506.0 9 5.0 \n", + "... ... ... ... ... ... ... ... \n", + "1866 198521 3 26096 19621.0 32571.0 47 35.0 \n", + "1867 198520 3 27896 20885.0 34907.0 51 38.0 \n", + "1868 198519 3 43154 32821.0 53487.0 78 59.0 \n", + "1869 198518 3 40555 29935.0 51175.0 74 55.0 \n", + "1870 198517 3 34053 24366.0 43740.0 62 44.0 \n", + "1871 198516 3 50362 36451.0 64273.0 91 66.0 \n", + "1872 198515 3 63881 45538.0 82224.0 116 83.0 \n", + "1873 198514 3 134545 114400.0 154690.0 244 207.0 \n", + "1874 198513 3 197206 176080.0 218332.0 357 319.0 \n", + "1875 198512 3 245240 223304.0 267176.0 445 405.0 \n", + "1876 198511 3 276205 252399.0 300011.0 501 458.0 \n", + "1877 198510 3 353231 326279.0 380183.0 640 591.0 \n", + "1878 198509 3 369895 341109.0 398681.0 670 618.0 \n", + "1879 198508 3 389886 359529.0 420243.0 707 652.0 \n", + "1880 198507 3 471852 432599.0 511105.0 855 784.0 \n", + "1881 198506 3 565825 518011.0 613639.0 1026 939.0 \n", + "1882 198505 3 637302 592795.0 681809.0 1155 1074.0 \n", + "1883 198504 3 424937 390794.0 459080.0 770 708.0 \n", + "1884 198503 3 213901 174689.0 253113.0 388 317.0 \n", + "1885 198502 3 97586 80949.0 114223.0 177 147.0 \n", + "1886 198501 3 85489 65918.0 105060.0 155 120.0 \n", + "1887 198452 3 84830 60602.0 109058.0 154 110.0 \n", + "1888 198451 3 101726 80242.0 123210.0 185 146.0 \n", + "1889 198450 3 123680 101401.0 145959.0 225 184.0 \n", + "1890 198449 3 101073 81684.0 120462.0 184 149.0 \n", + "1891 198448 3 78620 60634.0 96606.0 143 110.0 \n", + "1892 198447 3 72029 54274.0 89784.0 131 99.0 \n", + "1893 198446 3 87330 67686.0 106974.0 159 123.0 \n", + "1894 198445 3 135223 101414.0 169032.0 246 184.0 \n", + "1895 198444 3 68422 20056.0 116788.0 125 37.0 \n", + "\n", + " inc100_up geo_insee geo_name \n", + "0 38.0 FR France \n", + "1 40.0 FR France \n", + "2 41.0 FR France \n", + "3 40.0 FR France \n", + "4 46.0 FR France \n", + "5 39.0 FR France \n", + "6 31.0 FR France \n", + "7 39.0 FR France \n", + "8 39.0 FR France \n", + "9 31.0 FR France \n", + "10 39.0 FR France \n", + "11 32.0 FR France \n", + "12 25.0 FR France \n", + "13 26.0 FR France \n", + "14 35.0 FR France \n", + "15 45.0 FR France \n", + "16 74.0 FR France \n", + "17 77.0 FR France \n", + "18 75.0 FR France \n", + "19 61.0 FR France \n", + "20 49.0 FR France \n", + "21 37.0 FR France \n", + "22 36.0 FR France \n", + "23 46.0 FR France \n", + "24 34.0 FR France \n", + "25 20.0 FR France \n", + "26 20.0 FR France \n", + "27 14.0 FR France \n", + "28 13.0 FR France \n", + "29 13.0 FR France \n", + "... ... ... ... \n", + "1866 59.0 FR France \n", + "1867 64.0 FR France \n", + "1868 97.0 FR France \n", + "1869 93.0 FR France \n", + "1870 80.0 FR France \n", + "1871 116.0 FR France \n", + "1872 149.0 FR France \n", + "1873 281.0 FR France \n", + "1874 395.0 FR France \n", + "1875 485.0 FR France \n", + "1876 544.0 FR France \n", + "1877 689.0 FR France \n", + "1878 722.0 FR France \n", + "1879 762.0 FR France \n", + "1880 926.0 FR France \n", + "1881 1113.0 FR France \n", + "1882 1236.0 FR France \n", + "1883 832.0 FR France \n", + "1884 459.0 FR France \n", + "1885 207.0 FR France \n", + "1886 190.0 FR France \n", + "1887 198.0 FR France \n", + "1888 224.0 FR France \n", + "1889 266.0 FR France \n", + "1890 219.0 FR France \n", + "1891 176.0 FR France \n", + "1892 163.0 FR France \n", + "1893 195.0 FR France \n", + "1894 308.0 FR France \n", + "1895 213.0 FR France \n", + "\n", + "[1895 rows x 10 columns]" + ] + }, + "execution_count": 4, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "data = raw_data.dropna().copy()\n", + "data" + ] + }, + { + "cell_type": "code", + "execution_count": 5, + "metadata": {}, + "outputs": [], + "source": [ + "def convert_week(year_and_week_int):\n", + " year_and_week_str = str(year_and_week_int)\n", + " year = int(year_and_week_str[:4])\n", + " week = int(year_and_week_str[4:])\n", + " w = isoweek.Week(year, week)\n", + " return pd.Period(w.day(0), 'W')\n", + "\n", + "data['period'] = [convert_week(yw) for yw in data['week']]" + ] + }, + { + "cell_type": "code", + "execution_count": 6, + "metadata": {}, + "outputs": [], + "source": [ + "sorted_data = data.set_index('period').sort_index()" + ] + }, + { + "cell_type": "code", + "execution_count": 7, + "metadata": {}, + "outputs": [ + { + "name": "stdout", + "output_type": "stream", + "text": [ + "1989-05-01/1989-05-07 1989-05-15/1989-05-21\n" + ] + } + ], + "source": [ + "periods = sorted_data.index\n", + "for p1, p2 in zip(periods[:-1], periods[1:]):\n", + " delta = p2.to_timestamp() - p1.end_time\n", + " if delta > pd.Timedelta('1s'):\n", + " print(p1, p2)" + ] + }, + { + "cell_type": "code", + "execution_count": 8, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "" + ] + }, + "execution_count": 8, + "metadata": {}, + "output_type": "execute_result" + }, + { + "data": { + "image/png": "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\n", + "text/plain": [ + "
" + ] + }, + "metadata": { + "needs_background": "light" + }, + "output_type": "display_data" + } + ], + "source": [ + "sorted_data['inc'].plot()" + ] + }, + { + "cell_type": "code", + "execution_count": 9, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "" + ] + }, + "execution_count": 9, + "metadata": {}, + "output_type": "execute_result" + }, + { + "data": { + "image/png": "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\n", + "text/plain": [ + "
" + ] + }, + "metadata": { + "needs_background": "light" + }, + "output_type": "display_data" + } + ], + "source": [ + "sorted_data['inc'][-200:].plot()" + ] + }, + { + "cell_type": "code", + "execution_count": 10, + "metadata": {}, + "outputs": [], + "source": [ + "first_septembre_week = [pd.Period(pd.Timestamp(y, 9, 1), 'W')\n", + " for y in range(1985,\n", + " sorted_data.index[-1].year)]" + ] + }, + { + "cell_type": "code", + "execution_count": 11, + "metadata": {}, + "outputs": [], + "source": [ + "year = []\n", + "yearly_incidence = []\n", + "for week1, week2 in zip(first_septembre_week[:-1],\n", + " first_septembre_week[1:]):\n", + " one_year = sorted_data['inc'][week1:week2-1]\n", + " assert abs(len(one_year)-52) < 2\n", + " yearly_incidence.append(one_year.sum())\n", + " year.append(week2.year)\n", + "yearly_incidence = pd.Series(data=yearly_incidence, index=year)" + ] + }, + { + "cell_type": "code", + "execution_count": 12, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "" + ] + }, + "execution_count": 12, + "metadata": {}, + "output_type": "execute_result" + }, + { + "data": { + "image/png": "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\n", + "text/plain": [ + "
" + ] + }, + "metadata": { + "needs_background": "light" + }, + "output_type": "display_data" + } + ], + "source": [ + "yearly_incidence.plot(style='*')" + ] + }, + { + "cell_type": "code", + "execution_count": 13, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "2014 1601698\n", + "1991 1663610\n", + "1995 1828304\n", + "2020 2078964\n", + "2012 2183912\n", + "2003 2234514\n", + "2019 2254363\n", + "2006 2297262\n", + "2017 2322818\n", + "2001 2540826\n", + "1992 2590314\n", + "1993 2699482\n", + "2018 2701716\n", + "1988 2759663\n", + "2007 2786458\n", + "2011 2852504\n", + "2016 2859019\n", + "1987 2867464\n", + "2008 2984311\n", + "1998 3047298\n", + "2002 3115484\n", + "1994 3514133\n", + "1996 3540251\n", + "2009 3558474\n", + "2004 3572810\n", + "1997 3624129\n", + "2015 3647492\n", + "2000 3808190\n", + "2005 3831409\n", + "1999 3914003\n", + "2010 3992174\n", + "2013 4176872\n", + "1986 5050543\n", + "1990 5214494\n", + "1989 5461328\n", + "dtype: int64" + ] + }, + "execution_count": 13, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "yearly_incidence.sort_values()" + ] + }, + { + "cell_type": "code", + "execution_count": 14, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "" + ] + }, + "execution_count": 14, + "metadata": {}, + "output_type": "execute_result" + }, + { + "data": { + "image/png": "iVBORw0KGgoAAAANSUhEUgAAAXcAAAEKCAYAAADpfBXhAAAABHNCSVQICAgIfAhkiAAAAAlwSFlzAAALEgAACxIB0t1+/AAAADl0RVh0U29mdHdhcmUAbWF0cGxvdGxpYiB2ZXJzaW9uIDIuMi4zLCBodHRwOi8vbWF0cGxvdGxpYi5vcmcvIxREBQAAGgJJREFUeJzt3X2UHFWZx/HvQxIgZCCggUYDMr4gghkE0ugCq84AumBQj8gRFFRc2UEFRY1nN8uCrO6yRjS6qPgSlRcVGJWXs0oU9QgDgohMABkwgi5klSBB3gIDWWDg2T9utfQO3aSru2rqcvl9zpkz3V3VVb+6Xf101a2qbnN3REQkLRtVHUBERIqn4i4ikiAVdxGRBKm4i4gkSMVdRCRBKu4iIglScRcRSZCKu4hIglTcRUQSNLPMic+bN8/7+/tbDnvooYeYM2dOmbPvWszZIO58MWeDuPMpW/dizpc328qVK+929617nrG7l/a3cOFCb+fSSy9tO6xqMWdzjztfzNnc486nbN2LOV/ebMCYF1B/1S0jIpIgFXcRkQSpuIuIJEjFXUQkQSruIiIJylXczewjZnaTmd1oZuea2aZlBRMRke51XNzNbD7wIaDu7guAGcBhZQUTEZHu5e2WmQnMNrOZwGbAHcVHEhGRXpnn+A1VMzsOOBlYD/zU3Q9vMc4wMAxQq9UWjoyMtJzWxMQEfX193WQuXczZoPh842vWFTat2mxYu77z8Qfmzy1s3p1otF2Ry5xXu2WOeb2LORvEnS9vtqGhoZXuXu91vh0XdzPbCjgfOBS4H/g+cJ67f6fdc+r1uo+NjbUcNjo6yuDgYN680yLmbFB8vv4lKwqb1uKBSZaNd/6tFquXLips3p1otF2Ry5xXu2WOeb2LORvEnS9vNjMrpLjn6ZbZH7jN3f/i7o8BFwB79xpARESKl6e4/xH4GzPbzMwM2A9YVU4sERHpRcfF3d2vBs4DrgXGs+cuLymXiIj0INdX/rr7ScBJJWUREZGC6ApVEZEEqbiLiCRIxV1EJEEq7iIiCVJxFxFJkIq7iEiCVNxFRBKk4i4ikiAVdxGRBKm4i4gkSMVdRCRBKu4iIglScRcRSZCKu4hIglTcRUQSpOIuIpIgFXcRkQR1XNzNbCczu77p7wEz+3CZ4UREpDsd/8yeu98M7AZgZjOANcCFJeUSEZEedNstsx/w3+7+P0WGERGRYpi753+S2enAte7+pRbDhoFhgFqttnBkZKTlNCYmJujr68s97+kQczYoPt/4mnWFTas2G9au73z8gflzC5t3JxptV+Qy59VumWNe72LOBnHny5ttaGhopbvXe51v7uJuZhsDdwAvd/e1TzduvV73sbGxlsNGR0cZHBzMNe/pEnM2KD5f/5IVhU1r8cAky8Y77u1j9dJFhc27E422K3KZ82q3zDGvdzFng7jz5c1mZoUU9266ZQ4kbLU/bWEXEZHqdFPc3w6cW3QQEREpTq7ibmabAa8DLignjoiIFKHzzlHA3R8GnltSFhERKYiuUBURSZCKu4hIglTcRUQSpOIuIpIgFXcRkQSpuIuIJEjFXUQkQSruIiIJUnEXEUmQiruISIJU3EVEEqTiLiKSIBV3EZEEqbiLiCRIxV1EJEEq7iIiCVJxFxFJUN6f2dvSzM4zs9+Z2Soz26usYCIi0r1cP7MHnApc7O6HmNnGwGYlZBIRkR51XNzNbAvgNcCRAO7+KPBoObFERKQX5u6djWi2G7Ac+C3wCmAlcJy7PzRlvGFgGKBWqy0cGRlpOb2JiQn6+vq6T16S8TXrqM2Gteunf94D8+d2NF7RbTe+Zl1h08rbdp0uc1EabVfkMufVbpljfU9A3Nkg7nx5sw0NDa1093qv881T3OvAr4B93P1qMzsVeMDdT2z3nHq97mNjYy2HjY6OMjg4mD9xyfqXrGDxwCTLxvP2WPVu9dJFHY1XdNv1L1lR2LTytl2ny1yURtsVucx5tVvmWN8TEHc2iDtf3mxmVkhxz3NA9Xbgdne/Ort/HrBHrwFERKR4HRd3d78T+JOZ7ZQ9tB+hi0ZERCKTt+/hg8DZ2ZkytwLvKT6SiIj0Kldxd/frgZ77gkREpFy6QlVEJEEq7iIiCVJxFxFJkIq7iEiCVNxFRBKk4i4ikiAVdxGRBKm4i4gkSMVdRCRBKu4iIglScRcRSZCKu4hIglTcRUQSpOIuIpIgFXcRkQSpuIuIJEjFXUQkQbl+icnMVgMPAo8Dk0X8QreIiBQv72+oAgy5+92FJxERkcKoW0ZEJEHm7p2PbHYbcB/gwNfcfXmLcYaBYYBarbZwZGSk5bQmJibo6+vrJnOpxtesozYb1q6f/nkPzJ/b0XhFt934mnWFTStv23W6zEVptF2Ry5xXu2WO9T0BcWeDuPPlzTY0NLSyiC7vvMX9+e5+h5ltA/wM+KC7X95u/Hq97mNjYy2HjY6OMjg4mDNu+fqXrGDxwCTLxrvpserN6qWLOhqv6LbrX7KisGnlbbtOl7kojbYrcpnzarfMsb4nIO5sEHe+vNnMrJDinqtbxt3vyP7fBVwIvLLXACIiUryOi7uZzTGzzRu3gdcDN5YVTEREupen76EGXGhmjeed4+4Xl5JKRER60nFxd/dbgVeUmEVERAqiUyFFRBKk4i4ikiAVdxGRBKm4i4gkSMVdRCRBKu4iIglScRcRSZCKu4hIglTcRUQSpOIuIpIgFXcRkQSpuIuIJEjFXUQkQSruIiIJUnEXEUmQiruISIJU3EVEEpS7uJvZDDO7zswuKiOQiIj0rpst9+OAVUUHERGR4uQq7ma2HbAI+EY5cUREpAjm7p2PbHYe8Clgc+Bj7n5Qi3GGgWGAWq22cGRkpOW0JiYm6Ovr6yZzqcbXrKM2G9aurzpJezHny5ttYP7c8sK00Fjvxtesm9b5Nmu3zLG+JyDubBB3vrzZhoaGVrp7vdf5zux0RDM7CLjL3Vea2WC78dx9ObAcoF6v++Bg61FHR0dpN6xKRy5ZweKBSZaNd9w00y7mfHmzrT58sLwwLTTWuyOXrJjW+TZrt8yxvicg7mwQd76qsuXpltkHeJOZrQZGgH3N7DulpBIRkZ50XNzd/Z/dfTt37wcOAy5x9yNKSyYiIl3Tee4iIgnqquPW3UeB0UKTiIhIYbTlLiKSIBV3EZEEqbiLiCRIxV1EJEEq7iIiCVJxFxFJkIq7iEiCVNxFRBKk4i4ikiAVdxGRBKm4i4gkSMVdRCRBKu4iIglScRcRSZCKu4hIglTcRUQS1HFxN7NNzezXZvYbM7vJzD5RZjAREelenl9iegTY190nzGwWcIWZ/djdf1VSNhER6VLHxd3dHZjI7s7K/ryMUCIi0hsLNbvDkc1mACuBlwCnufs/tRhnGBgGqNVqC0dGRlpOa2Jigr6+vrbzGl+zruNcRavNhrXrK5v9BsWcL2+2gflzywvTQmO9q3L9arfMG3pPVCnmbBB3vrzZhoaGVrp7vdf55iruf32S2ZbAhcAH3f3GduPV63UfGxtrOWx0dJTBwcG28+hfsiJ3rqIsHphk2XhXvx0+LWLOlzfb6qWLSkzzVI31rsr1q90yb+g9UaWYs0Hc+fJmM7NCintXZ8u4+/3AKHBArwFERKR4ec6W2TrbYsfMZgP7A78rK5iIiHQvz77984Czsn73jYDvuftF5cQSEZFe5Dlb5gZg9xKziIhIQXSFqohIglTcRUQSpOIuIpIgFXcRkQSpuIuIJEjFXUQkQSruIiIJUnEXEUmQiruISIJU3EVEEqTiLiKSIBV3EZEEqbiLiCRIxV1EJEEq7iIiCVJxFxFJkIq7iEiC8vyG6vZmdqmZrTKzm8zsuDKDiYhI9/L8huoksNjdrzWzzYGVZvYzd/9tSdlERKRLHW+5u/uf3f3a7PaDwCpgflnBRESke+bu+Z9k1g9cDixw9wemDBsGhgFqtdrCkZGRltOYmJigr6+v7TzG16zLnasotdmwdn1ls9+gmPPlzTYwf255YVporHdVrl/tlP269tLWG3q/Vq1dvqpe5+a2ztt2Q0NDK9293muG3MXdzPqAy4CT3f2Cpxu3Xq/72NhYy2Gjo6MMDg62fW7/khW5chVp8cAky8bz9FhNr5jz5c22eumiEtM8VWO9q3L9aqfs17WXtt7Q+7Vq7fJV9To3t3XetjOzQop7rrNlzGwWcD5w9oYKu4iIVCfP2TIGfBNY5e6fKy+SiIj0Ks+W+z7AO4F9zez67O8NJeUSEZEedNzB5+5XAFZiFhERKYiuUBURSZCKu4hIglTcRUQSpOIuIpIgFXcRkQSpuIuIJEjFXUQkQSruIiIJUnEXEUmQiruISIJU3EVEEqTiLiKSIBV3EZEEqbiLiCRIxV1EJEEq7iIiCVJxFxFJUJ7fUD3dzO4ysxvLDCQiIr3Ls+V+JnBASTlERKRAHRd3d78cuLfELCIiUhBz985HNusHLnL3BU8zzjAwDFCr1RaOjIy0HG9iYoK+vr628xpfs67jXEWrzYa16yub/QbFnC/mbBB3vrKzDcyf2/VzN/R+fTrT8V6O7XVtbuu8bTc0NLTS3eu9Zii8uDer1+s+NjbWctjo6CiDg4Ntn9u/ZEXHuYq2eGCSZeMzK5v/hsScL+ZsEHe+srOtXrqo6+du6P36dKbjvRzb69rc1nnbzswKKe46W0ZEJEEq7iIiCcpzKuS5wFXATmZ2u5m9t7xYIiLSi447qdz97WUGERGR4qhbRkQkQSruIiIJUnEXEUmQiruISIJU3EVEEqTiLiKSIBV3EZEEqbiLiCRIxV1EJEEq7iIiCVJxFxFJkIq7iEiCVNxFRBKk4i4ikiAVdxGRBKm4i4gkSMVdRCRBuYq7mR1gZjeb2R/MbElZoUREpDd5fkN1BnAacCCwC/B2M9ulrGAiItK9PFvurwT+4O63uvujwAjw5nJiiYhIL8zdOxvR7BDgAHc/Krv/TuBV7n7slPGGgeHs7k7AzW0mOQ+4u5vQ0yDmbBB3vpizQdz5lK17MefLm20Hd9+615nOzDGutXjsKZ8M7r4cWL7BiZmNuXs9x/ynTczZIO58MWeDuPMpW/dizldVtjzdMrcD2zfd3w64o9g4IiJShDzF/RpgRzN7oZltDBwG/KCcWCIi0ouOu2XcfdLMjgV+AswATnf3m3qY9wa7bioUczaIO1/M2SDufMrWvZjzVZKt4wOqIiLyzKErVEVEEqTiLiKSIBV3EZEEPSOLu5nNN7P5VedoxcxeZGYfMbN9q87SSsz5lK17MeeLORvEna+XbM+o4m5m/WZ2GXAx8Bkze3XVmZqZ2d8CPyN89877zOz9FUf6f2LOp2zdizlfzNkg7nw9Z3P3qP+ATZtuHwx8Nrv9buD7wEB23yrIti/wwsb8gY8DR2T3XwX8EBhUPmV7tuSLOVvs+YrOFuWWu5ltYWZfNbNbgM+a2Q7ZoLcAf8xujwB/AI5qPG0a8+1iZjcA/wqcYWb7emjxXYBtAdz9auCXwHuUT9lSzxdzttjzlZUtyuIOHABsSli4R4GPm9lswi7KGwHc/RHgPODV2f0nygpjZtuZ2RZNDx0KnO/uryF8yLzDzHYEzmnky1wILDCzTZ6t+ZQtzXwxZ4s933Rlq6y4WzDTzN5rZr8ws+PM7MXZ4JcAj7r7JPB54D7gCOCnwPPM7DnZeLcAfzKzvUrKuLOZ/Qi4AvikmTW+4vh/gc2y298D7gQWET5Zn9u0p3Ev4VsxX/Fsy6dsaeaLOVvs+aY7W2XFPdvteC3wLuAUYBPg69ngO4G7sk+oPxEW6MWERvgtT36l8CzgnuzxQpjZnKa7uwG3u3s/cAnw2ezxe4FHzGxzd78X+D3w/CzHL4GPZuNtDDwOrH425FO2NPPFnC32fFVmm7bibmZ7mdmnzezI7L4BOwMXu/sP3f0UYAcz2xtYQ/gk2zl7+iqgL3vsS8AbzOyNhA+GGvCbHrNtZWZnmtk1wFIz2zrLNwBcaWbm7j8A7jezRYQ9hs2z4WT3twGeIOxpbGNmXwfOBSbd/a5U8ylb92LOF3O22PPFkm1airuZvRz4CvAg8DYz+2g27/nAg9mCA5wJvINQrCeBvbPHryUcSX7Y3S8HlgBHAvsA/+buTzRNoxuvyeb3BsKBiuOBLQhfkLZttpcBcFaW79fZshwI4O5XZdOY6e6rgKOBm4D/cPf30LuY8ylbmvlizhZ7vjiytTuNpts/whb2UYRdkJnZY58Djstu14EvAIcA+wM/aXru9oTdFgjF/DrCrzntDvwX8LymcXOfppQ17tHAZYSunXnZ498DPpTdfiGwNBu+J6F/bEbTsv0lm858wh7FscAZwJeBOT22XbT5lE2vq9rumZPNveBTIc1sN8JBzzcDJwEnZIPWEH6DFcIn0JXAW4GfA9ua2a5mNstD//oaM3u1u19C+KrMTwMXAOe6+58b8/KsdXI6CHgT8AlgL0JfP4SzcBp7CX8CfgEc6O7XED55h7J5TgBXA3u6+xrgnYRuoTuBE9z9oS4y0bTX8cYY82Wia7tnSLuB2q4Xarsu5fmZvacws1cCOwI/dfe/ELbKb3H3I81sD+BkM6sDo8Dfmdlm7v6wmf0GeBvhHM5zgH8AvmBm64Fx4LZsFl8FznH3dTkymbu7me1J2OX5BbDCw6mTLwVudfdLzOw2wlWurwdWAm8xs3nufreZ/R54yMxeAHwROMLMtiH8+tQ9hN0o3H0MGOuy7eqEPZwHgc8AdwEvqjLfM6HtYmw3tZ3arup60kquLXcLZpnZu8zsOkJn/5ZAo/g+DqzOtsKvJexm7AU8zJOn9wA8Rtgd2ZawdX4job/9MuBud78dwtZ5l4X9NcDphKPN+wOfykZ5ArjFzGa7+21Zvl0JL9gdhPNNG8sxg9A+52cZDwcWAsu9h/NfzWyumZ2RTfc24FR3v8vMNiJ8qleSz8xmZG33WsJuYTRtl613fWZ2JpG1W5ZvdtZ2g0S23pnZJmY2J+K22yLituszs03N7CwibLsN6qTvBpgD7J3d3jIL94UW4x1HuGR2fnb/EEL/+g6Erwu4LHt8U0KXzLym5+4ObNxJninz3Ax4H0/uAcwCPgwckw3fCrghm/6hhP6v/mzYQdmyzMtujwNzCf39P2rOA2yUN9uUfOcSri7rI3Q1Hd00TuPYxLHAv09Xvux1PYqwwi0mHPSJou2asl2QrVdbx9JuTc/dHFhB+FUygI/E0HZN2X4EfC27fwrwvhjajvCeeDehBpwfU9s1ZbsE+G72WFTrXad/G9xyN7PjgVuBFWZWc/f7Cf1Ed2R95W+yJy8iuopwULRxMdKVhAOrD7v7WcB9ZvZtwoHSm4G/9im5+3Xu/uiG8kzJti1wETAIfJtw0OJgwt7CZDbd+wgHYz9E6AvbhidPsbyccK79o+5+EfBNwlWvpxGOZD/WlK+bT/7mfN8C3p/luwXYycyWZltUf2/hwqyLCXszpeezcP7tzwkr3teB1xOOg+xJ2FqqrO2mZFtOOIvgYMI1Di+rst2mmE24PuPFZjaPsN7PyKZb2XrXlG1jwnr2fEJXxwIz+1SVbWdmswjH3Q4BPuPub80G7d403arWu+Zsp7h7Y8t7HNil6rbLrYNPskHCrsY3gI9kj+1JKFq3Z+HPAZZlw04GPtn0/GuA3bPbmxBOD9qziE8mwgr8qqb7RxK2UN4N/Lrp8ecDd2S3jyFc4rtV9vwfAi9oGndeEdna5HsX4Sj4S4HvZn9vB/6TcL7/dOfbsun2PxLeTIdH0nbN2T5GOJ3sRTG0W9M0303ofz0ReC/hANs1VbfdlGwnEPZ85sXSdoS9scOnPHYocHXVbdcm2wuy+VfedrmWpYOFbZy2cygwmt2eRdiqmpvd34Gw1b4nYXfwPMIW148Jn1iblBI+9HkZ/PW3YPfgya6fewjnlDbG/RlZoSXsSv00G+efSmvcp+bbHbiisfI2jTeLcNB53+z+ydORL5vXFoTjHWuBT2b37wFqVbbdlGx3ZvOdQ9blV2W7Nb2e7yF0uR0MnJ09dneVbdcm20j2WPOpxFWucwcR9l6XZRk+ntWQe4FtqlzvpmS7lPBlXtvFsN7lXpYcC/1cwsVEL8/uz5wy/EzgkMZKROiCOJqSCvuUeTdW6LN48nz6bwOfzm4/h7Dn8YKmF2cBTV8nPI35jml+LLu9bdZ+u1aU7wOE83GXE/q5f5m94SyCtmtkO41wytlLImq37xO6YeYSTgY4gXBywIlVr3dTsv2ccObZHhG13U8Ie2PbE7aIjyNsIFa+3k3JdjbhawJ2jKXtOv1rFJ2OmNmXgQfcfUl2fyPCeZnHAC8HDvWc/eZFMbPtCH1cH3T3Wyx8Cdlwlms+cL0Xc2Vcr/ne7+63Zo/tTuimWpTl+0BV+bI8uxE+kK8i9CMuIGy1VNp2WbYFhDfcFwlnXx1Ehe1mZn2Ebo9NCG31MsIFKscTtpp3pKK2a5FtR8LxitcRjoHtR2i/ytY5y06Lzm6/gvBevZJwCX6l692UbAsIV8SfSviG2krXuzzynue+HDg1O/CwM2El3ofwohxfVWHP7E52jryZHUU4HnA8oTvpdx5OzaxSI98fs3y3EVaSScLW/HVVhsvcQzgoeIK7f8vMjgBuiiTb/YR+4xsJr+ssqm23ScKZFY8RttgfJ7wHxoGPVtx27bI9YmZvIhT9Ste5RvHM3E84DnWiu59T9Xo3JduDhA3YVcC/UP1617G8W+6HEQ6ePkL4prJL3P3mkrLlYmZXEg64rSacY/oJd7+h0lBNpuS7E1gSQ9uZ2VzCltw7CN+fvxw4zd0fe9onToMW2b7p7suqTdVadoFKo3/7zqrzNMuyHQKc4eFMlMqZ2SaE3214J2Hv+ivAlz18zXelWmRb7u6frzZVfh0XdzPblXC+53mEg0eFfc1ur7I9iZMIW8Pf8XBlWzRizmdmMwldMY8QssX0ukabrcHMZgBPeJ6tpGkSczYAMzuacNrtt2N7bWPO1qlcW+4iIvLMEOvP7ImISA9U3EVEEqTiLiKSIBV3EZEEqbiLiCRIxV1EJEEq7iIiCfo/R0mXI/0GTP0AAAAASUVORK5CYII=\n", + "text/plain": [ + "
" + ] + }, + "metadata": { + "needs_background": "light" + }, + "output_type": "display_data" + } + ], + "source": [ + "yearly_incidence.hist(xrot=20)" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [] + } + ], + "metadata": { + "kernelspec": { + "display_name": "Python 3", + "language": "python", + "name": "python3" + }, + "language_info": { + "codemirror_mode": { + "name": "ipython", + "version": 3 + }, + "file_extension": ".py", + "mimetype": "text/x-python", + "name": "python", + "nbconvert_exporter": "python", + "pygments_lexer": "ipython3", + "version": "3.6.4" + } + }, + "nbformat": 4, + "nbformat_minor": 4 +} diff --git a/module3/exo3/incidence-PAY-3.csv b/module3/exo3/incidence-PAY-3.csv new file mode 100644 index 0000000000000000000000000000000000000000..5a12fb1d86d518a2c710b3ec1529f6b8240bb039 --- /dev/null +++ b/module3/exo3/incidence-PAY-3.csv @@ -0,0 +1,1898 @@ +# @source="réseau Sentinelles, INSERM, Sorbonne Université, http://www.sentiweb.fr", @meta={"period":[198444,202108],"geo":["PAY","1"],"geo_ref":"insee","indicator":"3","type":"all","conf_int":true,"compact":false}, @date=2021-03-10T05:45:01+01:00 +week,indicator,inc,inc_low,inc_up,inc100,inc100_low,inc100_up,geo_insee,geo_name +202108,3,20903,16885,24921,32,26,38,FR,France +202107,3,22393,18303,26483,34,28,40,FR,France +202106,3,23183,19134,27232,35,29,41,FR,France +202105,3,22426,18445,26407,34,28,40,FR,France +202104,3,25804,21491,30117,39,32,46,FR,France +202103,3,21810,17894,25726,33,27,39,FR,France +202102,3,17320,13906,20734,26,21,31,FR,France +202101,3,21799,17778,25820,33,27,39,FR,France +202053,3,21220,16498,25942,32,25,39,FR,France +202052,3,16428,12285,20571,25,19,31,FR,France +202051,3,21619,17370,25868,33,27,39,FR,France +202050,3,16845,13220,20470,26,20,32,FR,France +202049,3,12939,9923,15955,20,15,25,FR,France +202048,3,13804,10641,16967,21,16,26,FR,France +202047,3,19085,15285,22885,29,23,35,FR,France +202046,3,24801,20503,29099,38,31,45,FR,France +202045,3,42516,36857,48175,65,56,74,FR,France +202044,3,44567,38521,50613,68,59,77,FR,France +202043,3,43737,37523,49951,66,57,75,FR,France +202042,3,35145,29812,40478,53,45,61,FR,France +202041,3,27877,23206,32548,42,35,49,FR,France +202040,3,20443,16381,24505,31,25,37,FR,France +202039,3,19810,15900,23720,30,24,36,FR,France +202038,3,25559,21141,29977,39,32,46,FR,France +202037,3,18485,14649,22321,28,22,34,FR,France +202036,3,10390,7646,13134,16,12,20,FR,France +202035,3,9918,6842,12994,15,10,20,FR,France +202034,3,6084,3090,9078,9,4,14,FR,France +202033,3,6106,3411,8801,9,5,13,FR,France +202032,3,5918,3330,8506,9,5,13,FR,France +202031,3,4351,2269,6433,7,4,10,FR,France +202030,3,8179,5442,10916,12,8,16,FR,France +202029,3,8687,5860,11514,13,9,17,FR,France +202028,3,8325,5688,10962,13,9,17,FR,France +202027,3,4066,2406,5726,6,3,9,FR,France +202026,3,4039,2389,5689,6,3,9,FR,France +202025,3,2853,1488,4218,4,2,6,FR,France +202024,3,3058,1690,4426,5,3,7,FR,France +202023,3,4168,2468,5868,6,3,9,FR,France +202022,3,3580,1947,5213,5,3,7,FR,France +202021,3,6114,4026,8202,9,6,12,FR,France +202020,3,9315,6775,11855,14,10,18,FR,France +202019,3,11679,8722,14636,18,14,22,FR,France +202018,3,16398,12851,19945,25,20,30,FR,France +202017,3,18082,14454,21710,27,21,33,FR,France +202016,3,24165,19893,28437,37,31,43,FR,France +202015,3,41049,35377,46721,62,53,71,FR,France +202014,3,71666,64531,78801,109,98,120,FR,France +202013,3,107742,99187,116297,164,151,177,FR,France +202012,3,107283,98610,115956,163,150,176,FR,France +202011,3,112943,104468,121418,172,159,185,FR,France +202010,3,105145,96812,113478,160,147,173,FR,France +202009,3,110696,102066,119326,168,155,181,FR,France +202008,3,143753,133984,153522,218,203,233,FR,France +202007,3,183610,172812,194408,279,263,295,FR,France +202006,3,206669,195481,217857,314,297,331,FR,France +202005,3,187957,177445,198469,285,269,301,FR,France +202004,3,122331,113492,131170,186,173,199,FR,France +202003,3,78413,71330,85496,119,108,130,FR,France +202002,3,53614,47654,59574,81,72,90,FR,France +202001,3,36850,31608,42092,56,48,64,FR,France +201952,3,28135,23220,33050,43,36,50,FR,France +201951,3,29786,25042,34530,45,38,52,FR,France +201950,3,34223,29156,39290,52,44,60,FR,France +201949,3,25662,21414,29910,39,33,45,FR,France +201948,3,22367,18055,26679,34,27,41,FR,France +201947,3,18669,14759,22579,28,22,34,FR,France +201946,3,16030,12567,19493,24,19,29,FR,France +201945,3,10138,7160,13116,15,10,20,FR,France +201944,3,7822,5010,10634,12,8,16,FR,France +201943,3,9487,6448,12526,14,9,19,FR,France +201942,3,7747,5243,10251,12,8,16,FR,France +201941,3,7122,4720,9524,11,7,15,FR,France +201940,3,8505,5784,11226,13,9,17,FR,France +201939,3,7091,4462,9720,11,7,15,FR,France +201938,3,4897,2891,6903,7,4,10,FR,France +201937,3,3172,1367,4977,5,2,8,FR,France +201936,3,2295,728,3862,3,1,5,FR,France +201935,3,1010,2,2018,2,0,4,FR,France +201934,3,1672,279,3065,3,1,5,FR,France +201933,3,1593,68,3118,2,0,4,FR,France +201932,3,1592,71,3113,2,0,4,FR,France +201931,3,2337,695,3979,4,2,6,FR,France +201930,3,1944,415,3473,3,1,5,FR,France +201929,3,2096,420,3772,3,0,6,FR,France +201928,3,1195,125,2265,2,0,4,FR,France +201927,3,2466,848,4084,4,2,6,FR,France +201926,3,1798,402,3194,3,1,5,FR,France +201925,3,1544,389,2699,2,0,4,FR,France +201924,3,876,17,1735,1,0,2,FR,France +201923,3,2004,748,3260,3,1,5,FR,France +201922,3,2181,602,3760,3,1,5,FR,France +201921,3,2585,1102,4068,4,2,6,FR,France +201920,3,2891,1202,4580,4,1,7,FR,France +201919,3,3221,1509,4933,5,2,8,FR,France +201918,3,1385,278,2492,2,0,4,FR,France +201917,3,3166,1348,4984,5,2,8,FR,France +201916,3,3842,1973,5711,6,3,9,FR,France +201915,3,5932,3669,8195,9,6,12,FR,France +201914,3,12675,9167,16183,19,14,24,FR,France +201913,3,16513,12530,20496,25,19,31,FR,France +201912,3,22184,17786,26582,34,27,41,FR,France +201911,3,31553,26556,36550,48,40,56,FR,France +201910,3,49742,43268,56216,76,66,86,FR,France +201909,3,88354,79564,97144,134,121,147,FR,France +201908,3,172604,160024,185184,262,243,281,FR,France +201907,3,307338,291220,323456,467,443,491,FR,France +201906,3,394286,376782,411790,599,572,626,FR,France +201905,3,355785,339295,372275,540,515,565,FR,France +201904,3,241090,227261,254919,366,345,387,FR,France +201903,3,147063,135890,158236,223,206,240,FR,France +201902,3,75548,67632,83464,115,103,127,FR,France +201901,3,50295,43525,57065,76,66,86,FR,France +201852,3,37903,31375,44431,58,48,68,FR,France +201851,3,39259,32977,45541,60,50,70,FR,France +201850,3,27781,22638,32924,42,34,50,FR,France +201849,3,19738,15481,23995,30,24,36,FR,France +201848,3,19501,15275,23727,30,24,36,FR,France +201847,3,15949,12105,19793,24,18,30,FR,France +201846,3,11278,7957,14599,17,12,22,FR,France +201845,3,11065,7791,14339,17,12,22,FR,France +201844,3,6586,3875,9297,10,6,14,FR,France +201843,3,6550,3988,9112,10,6,14,FR,France +201842,3,7787,5129,10445,12,8,16,FR,France +201841,3,8048,5098,10998,12,8,16,FR,France +201840,3,7409,4717,10101,11,7,15,FR,France +201839,3,7174,4235,10113,11,7,15,FR,France +201838,3,7349,4399,10299,11,7,15,FR,France +201837,3,4915,2386,7444,7,3,11,FR,France +201836,3,3215,1349,5081,5,2,8,FR,France +201835,3,1506,239,2773,2,0,4,FR,France +201834,3,1368,116,2620,2,0,4,FR,France +201833,3,1962,5,3919,3,0,6,FR,France +201832,3,1839,183,3495,3,0,6,FR,France +201831,3,2048,242,3854,3,0,6,FR,France +201830,3,1951,202,3700,3,0,6,FR,France +201829,3,1951,252,3650,3,0,6,FR,France +201828,3,1654,52,3256,3,1,5,FR,France +201827,3,3266,1145,5387,5,2,8,FR,France +201826,3,3758,1493,6023,6,3,9,FR,France +201825,3,4580,2220,6940,7,3,11,FR,France +201824,3,3223,1351,5095,5,2,8,FR,France +201823,3,1207,136,2278,2,0,4,FR,France +201822,3,3202,1330,5074,5,2,8,FR,France +201821,3,2537,763,4311,4,1,7,FR,France +201820,3,2694,967,4421,4,1,7,FR,France +201819,3,1025,0,2098,2,0,4,FR,France +201818,3,3541,1416,5666,5,2,8,FR,France +201817,3,2573,1003,4143,4,2,6,FR,France +201816,3,4818,2724,6912,7,4,10,FR,France +201815,3,16311,12168,20454,25,19,31,FR,France +201814,3,22666,18092,27240,35,28,42,FR,France +201813,3,32680,25536,39824,50,39,61,FR,France +201812,3,52040,44590,59490,79,68,90,FR,France +201811,3,65159,56506,73812,99,86,112,FR,France +201810,3,93512,83989,103035,142,128,156,FR,France +201809,3,108545,98645,118445,165,150,180,FR,France +201808,3,131870,120950,142790,201,184,218,FR,France +201807,3,141138,130177,152099,215,198,232,FR,France +201806,3,138810,128164,149456,211,195,227,FR,France +201805,3,157839,146646,169032,240,223,257,FR,France +201804,3,175483,163835,187131,267,249,285,FR,France +201803,3,178329,166640,190018,271,253,289,FR,France +201802,3,198079,185663,210495,302,283,321,FR,France +201801,3,235493,220941,250045,358,336,380,FR,France +201752,3,299114,279359,318869,459,429,489,FR,France +201751,3,229448,214366,244530,352,329,375,FR,France +201750,3,129535,118787,140283,199,183,215,FR,France +201749,3,63789,56120,71458,98,86,110,FR,France +201748,3,37568,31541,43595,58,49,67,FR,France +201747,3,24972,19923,30021,38,30,46,FR,France +201746,3,13398,9948,16848,21,16,26,FR,France +201745,3,14035,8091,19979,22,13,31,FR,France +201744,3,8544,5318,11770,13,8,18,FR,France +201743,3,7300,4402,10198,11,7,15,FR,France +201742,3,9966,6503,13429,15,10,20,FR,France +201741,3,12434,8718,16150,19,13,25,FR,France +201740,3,12725,8690,16760,20,14,26,FR,France +201739,3,14949,10534,19364,23,16,30,FR,France +201738,3,11463,7438,15488,18,12,24,FR,France +201737,3,9716,6364,13068,15,10,20,FR,France +201736,3,2815,917,4713,4,1,7,FR,France +201735,3,2794,850,4738,4,1,7,FR,France +201734,3,2497,879,4115,4,2,6,FR,France +201733,3,2406,766,4046,4,1,7,FR,France +201732,3,2667,879,4455,4,1,7,FR,France +201731,3,3256,1158,5354,5,2,8,FR,France +201730,3,3759,1299,6219,6,2,10,FR,France +201729,3,5014,1989,8039,8,3,13,FR,France +201728,3,5271,2576,7966,8,4,12,FR,France +201727,3,3924,1432,6416,6,2,10,FR,France +201726,3,3171,1166,5176,5,2,8,FR,France +201725,3,837,0,1721,1,0,2,FR,France +201724,3,1566,248,2884,2,0,4,FR,France +201723,3,1664,203,3125,3,1,5,FR,France +201722,3,1305,92,2518,2,0,4,FR,France +201721,3,971,0,2046,1,0,3,FR,France +201720,3,2686,793,4579,4,1,7,FR,France +201719,3,3461,1490,5432,5,2,8,FR,France +201718,3,2102,515,3689,3,1,5,FR,France +201717,3,2071,428,3714,3,0,6,FR,France +201716,3,1380,222,2538,2,0,4,FR,France +201715,3,479,0,1242,1,0,2,FR,France +201714,3,1110,0,2549,2,0,4,FR,France +201713,3,7594,3808,11380,12,6,18,FR,France +201712,3,8780,4834,12726,13,7,19,FR,France +201711,3,7814,4329,11299,12,7,17,FR,France +201710,3,11802,7964,15640,18,12,24,FR,France +201709,3,13111,9099,17123,20,14,26,FR,France +201708,3,29545,23136,35954,45,35,55,FR,France +201707,3,59590,49764,69416,91,76,106,FR,France +201706,3,93628,82560,104696,144,127,161,FR,France +201705,3,193677,179255,208099,297,275,319,FR,France +201704,3,256428,240618,272238,394,370,418,FR,France +201703,3,267276,251345,283207,410,386,434,FR,France +201702,3,260588,245070,276106,400,376,424,FR,France +201701,3,255535,239743,271327,392,368,416,FR,France +201652,3,224489,207799,241179,345,319,371,FR,France +201651,3,187704,172655,202753,288,265,311,FR,France +201650,3,126570,115081,138059,194,176,212,FR,France +201649,3,76390,67374,85406,117,103,131,FR,France +201648,3,40502,33949,47055,62,52,72,FR,France +201647,3,22270,17612,26928,34,27,41,FR,France +201646,3,20816,16125,25507,32,25,39,FR,France +201645,3,15957,11448,20466,24,17,31,FR,France +201644,3,15145,10357,19933,23,16,30,FR,France +201643,3,9378,5830,12926,14,9,19,FR,France +201642,3,12920,9044,16796,20,14,26,FR,France +201641,3,13909,9709,18109,21,15,27,FR,France +201640,3,13379,8969,17789,21,14,28,FR,France +201639,3,10598,6814,14382,16,10,22,FR,France +201638,3,5969,3073,8865,9,5,13,FR,France +201637,3,4065,1538,6592,6,2,10,FR,France +201636,3,2372,473,4271,4,1,7,FR,France +201635,3,3420,1350,5490,5,2,8,FR,France +201634,3,2233,0,4643,3,0,7,FR,France +201633,3,1567,0,3938,2,0,6,FR,France +201632,3,2100,93,4107,3,0,6,FR,France +201631,3,3691,0,9120,6,0,14,FR,France +201630,3,3209,644,5774,5,1,9,FR,France +201629,3,1469,0,3073,2,0,4,FR,France +201628,3,2725,357,5093,4,0,8,FR,France +201627,3,5905,2343,9467,9,4,14,FR,France +201626,3,4186,1636,6736,6,2,10,FR,France +201625,3,4611,1560,7662,7,2,12,FR,France +201624,3,4977,2404,7550,8,4,12,FR,France +201623,3,4893,2416,7370,8,4,12,FR,France +201622,3,5667,3015,8319,9,5,13,FR,France +201621,3,5603,2475,8731,9,4,14,FR,France +201620,3,3908,1679,6137,6,3,9,FR,France +201619,3,4738,2308,7168,7,3,11,FR,France +201618,3,8204,4394,12014,13,7,19,FR,France +201617,3,13385,8822,17948,21,14,28,FR,France +201616,3,25670,19632,31708,39,30,48,FR,France +201615,3,48441,39824,57058,74,61,87,FR,France +201614,3,92603,81261,103945,142,125,159,FR,France +201613,3,170654,156387,184921,262,240,284,FR,France +201612,3,272174,254338,290010,418,391,445,FR,France +201611,3,304543,286453,322633,467,439,495,FR,France +201610,3,261822,245799,277845,402,377,427,FR,France +201609,3,229943,214533,245353,353,329,377,FR,France +201608,3,195067,180874,209260,299,277,321,FR,France +201607,3,207359,193223,221495,318,296,340,FR,France +201606,3,196143,182672,209614,301,280,322,FR,France +201605,3,178963,166296,191630,275,256,294,FR,France +201604,3,148473,136591,160355,228,210,246,FR,France +201603,3,75277,66630,83924,116,103,129,FR,France +201602,3,44617,37821,51413,68,58,78,FR,France +201601,3,42263,35556,48970,65,55,75,FR,France +201553,3,24835,19106,30564,38,29,47,FR,France +201552,3,19495,14319,24671,30,22,38,FR,France +201551,3,29080,23014,35146,45,36,54,FR,France +201550,3,25043,19812,30274,39,31,47,FR,France +201549,3,21479,16686,26272,33,26,40,FR,France +201548,3,16428,12273,20583,25,19,31,FR,France +201547,3,14959,10856,19062,23,17,29,FR,France +201546,3,12599,8237,16961,20,13,27,FR,France +201545,3,13577,9192,17962,21,14,28,FR,France +201544,3,14596,10025,19167,23,16,30,FR,France +201543,3,16749,11745,21753,26,18,34,FR,France +201542,3,18675,13613,23737,29,21,37,FR,France +201541,3,13585,9830,17340,21,15,27,FR,France +201540,3,13100,9349,16851,20,14,26,FR,France +201539,3,8595,5671,11519,13,8,18,FR,France +201538,3,8402,4929,11875,13,8,18,FR,France +201537,3,8817,4089,13545,14,7,21,FR,France +201536,3,1922,440,3404,3,1,5,FR,France +201535,3,229,0,644,0,0,1,FR,France +201534,3,760,0,1618,1,0,2,FR,France +201533,3,1537,208,2866,2,0,4,FR,France +201532,3,1594,66,3122,2,0,4,FR,France +201531,3,2845,475,5215,4,0,8,FR,France +201530,3,2447,353,4541,4,1,7,FR,France +201529,3,2389,332,4446,4,1,7,FR,France +201528,3,2089,105,4073,3,0,6,FR,France +201527,3,2257,393,4121,3,0,6,FR,France +201526,3,2536,774,4298,4,1,7,FR,France +201525,3,2607,680,4534,4,1,7,FR,France +201524,3,2849,1000,4698,4,1,7,FR,France +201523,3,2702,857,4547,4,1,7,FR,France +201522,3,4262,1989,6535,7,3,11,FR,France +201521,3,5547,2875,8219,9,5,13,FR,France +201520,3,4594,2040,7148,7,3,11,FR,France +201519,3,6307,3256,9358,10,5,15,FR,France +201518,3,3664,1544,5784,6,3,9,FR,France +201517,3,6382,3523,9241,10,6,14,FR,France +201516,3,12098,7913,16283,19,13,25,FR,France +201515,3,19458,14192,24724,30,22,38,FR,France +201514,3,30940,24617,37263,48,38,58,FR,France +201513,3,49563,41986,57140,77,65,89,FR,France +201512,3,70024,61079,78969,109,95,123,FR,France +201511,3,99295,88838,109752,154,138,170,FR,France +201510,3,143931,131682,156180,223,204,242,FR,France +201509,3,238947,222902,254992,370,345,395,FR,France +201508,3,409972,388670,431274,635,602,668,FR,France +201507,3,517750,494301,541199,802,766,838,FR,France +201506,3,533317,510627,556007,827,792,862,FR,France +201505,3,457911,436964,478858,710,678,742,FR,France +201504,3,292161,275491,308831,453,427,479,FR,France +201503,3,153931,141290,166572,239,219,259,FR,France +201502,3,104096,93358,114834,161,144,178,FR,France +201501,3,70962,60505,81419,110,94,126,FR,France +201452,3,63168,52705,73631,98,82,114,FR,France +201451,3,45346,38002,52690,71,60,82,FR,France +201450,3,42182,35049,49315,66,55,77,FR,France +201449,3,33537,27281,39793,52,42,62,FR,France +201448,3,28156,21896,34416,44,34,54,FR,France +201447,3,18158,13186,23130,28,20,36,FR,France +201446,3,14764,10174,19354,23,16,30,FR,France +201445,3,16172,11449,20895,25,18,32,FR,France +201444,3,15500,10464,20536,24,16,32,FR,France +201443,3,16011,10653,21369,25,17,33,FR,France +201442,3,21651,15828,27474,34,25,43,FR,France +201441,3,22486,16295,28677,35,25,45,FR,France +201440,3,16526,11583,21469,26,18,34,FR,France +201439,3,8583,5054,12112,13,8,18,FR,France +201438,3,10567,6496,14638,16,10,22,FR,France +201437,3,7714,3780,11648,12,6,18,FR,France +201436,3,5018,1949,8087,8,3,13,FR,France +201435,3,2268,355,4181,4,1,7,FR,France +201434,3,2367,250,4484,4,1,7,FR,France +201433,3,2358,0,4875,4,0,8,FR,France +201432,3,3229,447,6011,5,1,9,FR,France +201431,3,4143,349,7937,6,0,12,FR,France +201430,3,4631,902,8360,7,1,13,FR,France +201429,3,5122,1258,8986,8,2,14,FR,France +201428,3,4145,1200,7090,6,1,11,FR,France +201427,3,4823,1997,7649,8,4,12,FR,France +201426,3,3858,1235,6481,6,2,10,FR,France +201425,3,4564,1276,7852,7,2,12,FR,France +201424,3,2007,249,3765,3,0,6,FR,France +201423,3,5164,1853,8475,8,3,13,FR,France +201422,3,6907,1856,11958,11,3,19,FR,France +201421,3,4523,1039,8007,7,2,12,FR,France +201420,3,5881,2432,9330,9,4,14,FR,France +201419,3,3588,1277,5899,6,2,10,FR,France +201418,3,4708,1654,7762,7,2,12,FR,France +201417,3,2989,625,5353,5,1,9,FR,France +201416,3,7057,3381,10733,11,5,17,FR,France +201415,3,10800,6762,14838,17,11,23,FR,France +201414,3,19217,13490,24944,30,21,39,FR,France +201413,3,21577,15435,27719,34,24,44,FR,France +201412,3,23524,17260,29788,37,27,47,FR,France +201411,3,44513,35939,53087,69,56,82,FR,France +201410,3,86105,73497,98713,134,114,154,FR,France +201409,3,147035,131889,162181,229,205,253,FR,France +201408,3,188419,171950,204888,293,267,319,FR,France +201407,3,208726,191283,226169,325,298,352,FR,France +201406,3,160403,145280,175526,250,226,274,FR,France +201405,3,120261,107176,133346,187,167,207,FR,France +201404,3,85280,74414,96146,133,116,150,FR,France +201403,3,64159,54089,74229,100,84,116,FR,France +201402,3,46850,38202,55498,73,60,86,FR,France +201401,3,35624,27451,43797,55,42,68,FR,France +201352,3,30142,22721,37563,47,35,59,FR,France +201351,3,29787,23215,36359,47,37,57,FR,France +201350,3,24055,18214,29896,38,29,47,FR,France +201349,3,18071,13058,23084,28,20,36,FR,France +201348,3,17606,12195,23017,28,20,36,FR,France +201347,3,22636,16343,28929,35,25,45,FR,France +201346,3,13340,8367,18313,21,13,29,FR,France +201345,3,10596,6057,15135,17,10,24,FR,France +201344,3,10193,5622,14764,16,9,23,FR,France +201343,3,15780,9497,22063,25,15,35,FR,France +201342,3,14830,9545,20115,23,15,31,FR,France +201341,3,12391,7265,17517,19,11,27,FR,France +201340,3,9794,5140,14448,15,8,22,FR,France +201339,3,5371,1704,9038,8,2,14,FR,France +201338,3,9324,4198,14450,15,7,23,FR,France +201337,3,5027,1752,8302,8,3,13,FR,France +201336,3,4639,1425,7853,7,2,12,FR,France +201335,3,1291,0,3112,2,0,5,FR,France +201334,3,1889,0,4912,3,0,8,FR,France +201333,3,4740,348,9132,7,0,14,FR,France +201332,3,4709,549,8869,7,0,14,FR,France +201331,3,2270,0,5811,4,0,10,FR,France +201330,3,2169,0,4630,3,0,7,FR,France +201329,3,1696,0,3558,3,0,6,FR,France +201328,3,983,0,2168,2,0,4,FR,France +201327,3,4278,1327,7229,7,2,12,FR,France +201326,3,3488,839,6137,5,1,9,FR,France +201325,3,2735,0,5826,4,0,9,FR,France +201324,3,7245,2997,11493,11,4,18,FR,France +201323,3,16094,8918,23270,25,14,36,FR,France +201322,3,7245,2923,11567,11,4,18,FR,France +201321,3,5974,2401,9547,9,3,15,FR,France +201320,3,3831,1245,6417,6,2,10,FR,France +201319,3,1166,0,2680,2,0,4,FR,France +201318,3,3415,757,6073,5,1,9,FR,France +201317,3,7941,2950,12932,12,4,20,FR,France +201316,3,9520,4758,14282,15,8,22,FR,France +201315,3,19357,13311,25403,30,21,39,FR,France +201314,3,36855,27737,45973,58,44,72,FR,France +201313,3,43236,34048,52424,68,54,82,FR,France +201312,3,60822,50414,71230,95,79,111,FR,France +201311,3,84308,72456,96160,132,113,151,FR,France +201310,3,165558,148471,182645,259,232,286,FR,France +201309,3,259984,239067,280901,407,374,440,FR,France +201308,3,351626,327537,375715,550,512,588,FR,France +201307,3,470076,443682,496470,736,695,777,FR,France +201306,3,471647,445112,498182,738,696,780,FR,France +201305,3,492026,464729,519323,770,727,813,FR,France +201304,3,391525,367182,415868,613,575,651,FR,France +201303,3,224661,207134,242188,352,325,379,FR,France +201302,3,184159,168343,199975,288,263,313,FR,France +201301,3,163491,147340,179642,256,231,281,FR,France +201252,3,159290,141978,176602,251,224,278,FR,France +201251,3,113901,99835,127967,179,157,201,FR,France +201250,3,79918,68086,91750,126,107,145,FR,France +201249,3,47537,38711,56363,75,61,89,FR,France +201248,3,43006,32863,53149,68,52,84,FR,France +201247,3,39223,29140,49306,62,46,78,FR,France +201246,3,26436,18286,34586,42,29,55,FR,France +201245,3,18893,12799,24987,30,20,40,FR,France +201244,3,13106,8784,17428,21,14,28,FR,France +201243,3,17791,11284,24298,28,18,38,FR,France +201242,3,13096,8369,17823,21,14,28,FR,France +201241,3,18675,12010,25340,29,19,39,FR,France +201240,3,17873,11545,24201,28,18,38,FR,France +201239,3,20257,14180,26334,32,22,42,FR,France +201238,3,14715,9178,20252,23,14,32,FR,France +201237,3,7775,3509,12041,12,5,19,FR,France +201236,3,6384,2420,10348,10,4,16,FR,France +201235,3,8277,2206,14348,13,3,23,FR,France +201234,3,3858,0,8641,6,0,14,FR,France +201233,3,6492,840,12144,10,1,19,FR,France +201232,3,6381,0,14034,10,0,22,FR,France +201231,3,2696,0,5763,4,0,9,FR,France +201230,3,1834,0,4194,3,0,7,FR,France +201229,3,6329,1424,11234,10,2,18,FR,France +201228,3,4628,1091,8165,7,1,13,FR,France +201227,3,4162,1487,6837,7,3,11,FR,France +201226,3,4819,1097,8541,8,2,14,FR,France +201225,3,2669,530,4808,4,1,7,FR,France +201224,3,5977,2335,9619,9,3,15,FR,France +201223,3,2361,576,4146,4,1,7,FR,France +201222,3,5772,2435,9109,9,4,14,FR,France +201221,3,3722,821,6623,6,1,11,FR,France +201220,3,2731,897,4565,4,1,7,FR,France +201219,3,3267,1317,5217,5,2,8,FR,France +201218,3,2328,569,4087,4,1,7,FR,France +201217,3,6982,2701,11263,11,4,18,FR,France +201216,3,11455,6874,16036,18,11,25,FR,France +201215,3,20437,13435,27439,32,21,43,FR,France +201214,3,36740,27799,45681,58,44,72,FR,France +201213,3,62917,50171,75663,99,79,119,FR,France +201212,3,84738,71566,97910,133,112,154,FR,France +201211,3,128945,113778,144112,203,179,227,FR,France +201210,3,174704,157337,192071,275,248,302,FR,France +201209,3,225648,206810,244486,355,325,385,FR,France +201208,3,287293,264901,309685,452,417,487,FR,France +201207,3,263557,242711,284403,415,382,448,FR,France +201206,3,175123,158942,191304,276,251,301,FR,France +201205,3,106110,92524,119696,167,146,188,FR,France +201204,3,67778,56784,78772,107,90,124,FR,France +201203,3,49440,40981,57899,78,65,91,FR,France +201202,3,40507,32652,48362,64,52,76,FR,France +201201,3,45104,35640,54568,71,56,86,FR,France +201152,3,36532,28367,44697,58,45,71,FR,France +201151,3,25835,19002,32668,41,30,52,FR,France +201150,3,24155,18145,30165,38,28,48,FR,France +201149,3,27209,20376,34042,43,32,54,FR,France +201148,3,32358,24451,40265,51,38,64,FR,France +201147,3,17627,11780,23474,28,19,37,FR,France +201146,3,22368,15730,29006,35,24,46,FR,France +201145,3,18104,11995,24213,29,19,39,FR,France +201144,3,14050,8471,19629,22,13,31,FR,France +201143,3,21522,14251,28793,34,22,46,FR,France +201142,3,16932,11363,22501,27,18,36,FR,France +201141,3,7486,4024,10948,12,7,17,FR,France +201140,3,14053,8659,19447,22,13,31,FR,France +201139,3,17021,11062,22980,27,18,36,FR,France +201138,3,14007,8465,19549,22,13,31,FR,France +201137,3,8365,4174,12556,13,6,20,FR,France +201136,3,4606,1714,7498,7,2,12,FR,France +201135,3,4178,1634,6722,7,3,11,FR,France +201134,3,3312,683,5941,5,1,9,FR,France +201133,3,2421,0,5277,4,0,9,FR,France +201132,3,2590,119,5061,4,0,8,FR,France +201131,3,2409,320,4498,4,1,7,FR,France +201130,3,3972,1395,6549,6,2,10,FR,France +201129,3,2265,717,3813,4,2,6,FR,France +201128,3,1977,255,3699,3,0,6,FR,France +201127,3,3524,551,6497,6,1,11,FR,France +201126,3,1155,0,2685,2,0,4,FR,France +201125,3,3791,1006,6576,6,2,10,FR,France +201124,3,3507,1149,5865,6,2,10,FR,France +201123,3,3406,1170,5642,5,1,9,FR,France +201122,3,3122,1125,5119,5,2,8,FR,France +201121,3,2694,769,4619,4,1,7,FR,France +201120,3,3951,1443,6459,6,2,10,FR,France +201119,3,5416,1995,8837,9,4,14,FR,France +201118,3,5306,1815,8797,8,2,14,FR,France +201117,3,2659,310,5008,4,0,8,FR,France +201116,3,5061,1988,8134,8,3,13,FR,France +201115,3,6557,3038,10076,10,4,16,FR,France +201114,3,7352,3784,10920,12,6,18,FR,France +201113,3,8749,5213,12285,14,8,20,FR,France +201112,3,12491,7845,17137,20,13,27,FR,France +201111,3,14619,10009,19229,23,16,30,FR,France +201110,3,33628,26073,41183,53,41,65,FR,France +201109,3,54522,46057,62987,86,73,99,FR,France +201108,3,78392,67885,88899,124,107,141,FR,France +201107,3,149219,134798,163640,236,213,259,FR,France +201106,3,216579,200236,232922,343,317,369,FR,France +201105,3,278192,260235,296149,440,412,468,FR,France +201104,3,278218,259626,296810,440,411,469,FR,France +201103,3,275882,257313,294451,437,408,466,FR,France +201102,3,308949,288320,329578,489,456,522,FR,France +201101,3,309933,288190,331676,490,456,524,FR,France +201052,3,228105,208046,248164,363,331,395,FR,France +201051,3,158957,142576,175338,253,227,279,FR,France +201050,3,104874,91639,118109,167,146,188,FR,France +201049,3,54971,46418,63524,88,74,102,FR,France +201048,3,36982,29304,44660,59,47,71,FR,France +201047,3,26598,20123,33073,42,32,52,FR,France +201046,3,15465,10915,20015,25,18,32,FR,France +201045,3,9040,5772,12308,14,9,19,FR,France +201044,3,15833,10255,21411,25,16,34,FR,France +201043,3,16002,11001,21003,25,17,33,FR,France +201042,3,18709,13376,24042,30,22,38,FR,France +201041,3,17352,12182,22522,28,20,36,FR,France +201040,3,18331,12824,23838,29,20,38,FR,France +201039,3,11978,7913,16043,19,13,25,FR,France +201038,3,8936,4906,12966,14,8,20,FR,France +201037,3,5318,2551,8085,8,4,12,FR,France +201036,3,4954,2058,7850,8,3,13,FR,France +201035,3,4279,1604,6954,7,3,11,FR,France +201034,3,4926,566,9286,8,1,15,FR,France +201033,3,2950,0,6507,5,0,11,FR,France +201032,3,671,0,1522,1,0,2,FR,France +201031,3,2732,509,4955,4,0,8,FR,France +201030,3,3989,1068,6910,6,1,11,FR,France +201029,3,4123,1531,6715,7,3,11,FR,France +201028,3,1209,0,2640,2,0,4,FR,France +201027,3,2494,433,4555,4,1,7,FR,France +201026,3,5808,2454,9162,9,4,14,FR,France +201025,3,8019,4395,11643,13,7,19,FR,France +201024,3,3584,1657,5511,6,3,9,FR,France +201023,3,4016,1905,6127,6,3,9,FR,France +201022,3,6251,3664,8838,10,6,14,FR,France +201021,3,3860,1636,6084,6,2,10,FR,France +201020,3,2470,442,4498,4,1,7,FR,France +201019,3,2273,636,3910,4,1,7,FR,France +201018,3,4095,1639,6551,7,3,11,FR,France +201017,3,2216,817,3615,4,2,6,FR,France +201016,3,3471,1085,5857,6,2,10,FR,France +201015,3,3990,1376,6604,6,2,10,FR,France +201014,3,6188,3191,9185,10,5,15,FR,France +201013,3,6705,3665,9745,11,6,16,FR,France +201012,3,6727,3582,9872,11,6,16,FR,France +201011,3,8692,5002,12382,14,8,20,FR,France +201010,3,8844,5465,12223,14,9,19,FR,France +201009,3,12081,7334,16828,19,11,27,FR,France +201008,3,15433,10422,20444,25,17,33,FR,France +201007,3,19690,11728,27652,31,18,44,FR,France +201006,3,27858,18883,36833,44,30,58,FR,France +201005,3,22197,17019,27375,35,27,43,FR,France +201004,3,33817,26151,41483,54,42,66,FR,France +201003,3,36236,27936,44536,58,45,71,FR,France +201002,3,40691,32891,48491,65,53,77,FR,France +201001,3,66574,56164,76984,106,89,123,FR,France +200953,3,96141,81818,110464,153,130,176,FR,France +200952,3,172872,153238,192506,275,244,306,FR,France +200951,3,247809,229140,266478,395,365,425,FR,France +200950,3,379424,355974,402874,604,567,641,FR,France +200949,3,473718,447756,499680,754,713,795,FR,France +200948,3,467551,441506,493596,744,703,785,FR,France +200947,3,378924,355752,402096,603,566,640,FR,France +200946,3,223847,203918,243776,356,324,388,FR,France +200945,3,147046,131155,162937,234,209,259,FR,France +200944,3,170231,151298,189164,271,241,301,FR,France +200943,3,131408,114883,147933,209,183,235,FR,France +200942,3,99387,84491,114283,158,134,182,FR,France +200941,3,100802,86381,115223,160,137,183,FR,France +200940,3,111587,97628,125546,178,156,200,FR,France +200939,3,121267,106153,136381,193,169,217,FR,France +200938,3,137924,121242,154606,220,193,247,FR,France +200937,3,101332,87522,115142,161,139,183,FR,France +200936,3,46024,36435,55613,73,58,88,FR,France +200935,3,31660,23669,39651,50,37,63,FR,France +200934,3,24985,17699,32271,40,28,52,FR,France +200933,3,24435,16308,32562,39,26,52,FR,France +200932,3,23151,14624,31678,37,23,51,FR,France +200931,3,30255,9818,50692,48,15,81,FR,France +200930,3,13868,7861,19875,22,12,32,FR,France +200929,3,10704,5314,16094,17,8,26,FR,France +200928,3,15516,273,30759,25,1,49,FR,France +200927,3,10354,2760,17948,16,4,28,FR,France +200926,3,9932,5257,14607,16,9,23,FR,France +200925,3,7619,4026,11212,12,6,18,FR,France +200924,3,7794,3409,12179,12,5,19,FR,France +200923,3,4342,1975,6709,7,3,11,FR,France +200922,3,6390,3020,9760,10,5,15,FR,France +200921,3,7118,3704,10532,11,6,16,FR,France +200920,3,9482,5804,13160,15,9,21,FR,France +200919,3,7538,4299,10777,12,7,17,FR,France +200918,3,9627,5121,14133,15,8,22,FR,France +200917,3,9537,5267,13807,15,8,22,FR,France +200916,3,14666,9218,20114,23,14,32,FR,France +200915,3,17533,12137,22929,28,19,37,FR,France +200914,3,26324,19150,33498,42,31,53,FR,France +200913,3,27737,20781,34693,44,33,55,FR,France +200912,3,38811,29935,47687,62,48,76,FR,France +200911,3,40410,30705,50115,64,49,79,FR,France +200910,3,53395,41943,64847,85,67,103,FR,France +200909,3,70558,57400,83716,112,91,133,FR,France +200908,3,109100,94840,123360,174,151,197,FR,France +200907,3,141531,125101,157961,225,199,251,FR,France +200906,3,276274,252759,299789,440,403,477,FR,France +200905,3,401868,375032,428704,640,597,683,FR,France +200904,3,545313,512892,577734,868,816,920,FR,France +200903,3,520957,487271,554643,829,775,883,FR,France +200902,3,287145,262869,311421,457,418,496,FR,France +200901,3,200349,180878,219820,319,288,350,FR,France +200852,3,198418,115769,281067,323,188,458,FR,France +200851,3,112588,96656,128520,184,158,210,FR,France +200850,3,51746,43319,60173,84,70,98,FR,France +200849,3,34950,27527,42373,57,45,69,FR,France +200848,3,25604,18563,32645,42,31,53,FR,France +200847,3,18706,10838,26574,30,17,43,FR,France +200846,3,10899,5461,16337,18,9,27,FR,France +200845,3,12472,7082,17862,20,11,29,FR,France +200844,3,9772,5661,13883,16,9,23,FR,France +200843,3,9345,5541,13149,15,9,21,FR,France +200842,3,9087,5572,12602,15,9,21,FR,France +200841,3,9925,5637,14213,16,9,23,FR,France +200840,3,7869,4535,11203,13,8,18,FR,France +200839,3,2195,506,3884,4,1,7,FR,France +200838,3,3679,1481,5877,6,2,10,FR,France +200837,3,2429,561,4297,4,1,7,FR,France +200836,3,2512,492,4532,4,1,7,FR,France +200835,3,1901,0,4869,3,0,8,FR,France +200834,3,2552,0,6509,4,0,10,FR,France +200833,3,7229,0,16106,12,0,26,FR,France +200832,3,4378,107,8649,7,0,14,FR,France +200831,3,3972,621,7323,6,1,11,FR,France +200830,3,3821,643,6999,6,1,11,FR,France +200829,3,2055,0,4225,3,0,7,FR,France +200828,3,3257,208,6306,5,0,10,FR,France +200827,3,2862,474,5250,5,1,9,FR,France +200826,3,897,0,2062,1,0,3,FR,France +200825,3,2006,360,3652,3,0,6,FR,France +200824,3,3217,823,5611,5,1,9,FR,France +200823,3,2906,1006,4806,5,2,8,FR,France +200822,3,1792,451,3133,3,1,5,FR,France +200821,3,3642,925,6359,6,2,10,FR,France +200820,3,6452,2790,10114,11,5,17,FR,France +200819,3,5173,1485,8861,8,2,14,FR,France +200818,3,5315,1770,8860,9,3,15,FR,France +200817,3,10150,5835,14465,17,10,24,FR,France +200816,3,11876,7054,16698,19,11,27,FR,France +200815,3,22871,16253,29489,37,26,48,FR,France +200814,3,45610,27907,63313,74,45,103,FR,France +200813,3,38600,29300,47900,63,48,78,FR,France +200812,3,53169,43299,63039,87,71,103,FR,France +200811,3,62014,50430,73598,101,82,120,FR,France +200810,3,90342,75729,104955,147,123,171,FR,France +200809,3,119696,104205,135187,195,170,220,FR,France +200808,3,198688,180749,216627,324,295,353,FR,France +200807,3,286498,264535,308461,467,431,503,FR,France +200806,3,377097,350714,403480,615,572,658,FR,France +200805,3,344050,320436,367664,561,523,599,FR,France +200804,3,290196,268193,312199,473,437,509,FR,France +200803,3,260268,233385,287151,424,380,468,FR,France +200802,3,160872,145311,176433,262,237,287,FR,France +200801,3,102562,88547,116577,167,144,190,FR,France +200752,3,86742,72295,101189,141,117,165,FR,France +200751,3,61954,51764,72144,101,84,118,FR,France +200750,3,45366,36923,53809,74,60,88,FR,France +200749,3,38351,26177,50525,63,43,83,FR,France +200748,3,48174,35418,60930,79,58,100,FR,France +200747,3,30716,23351,38081,50,38,62,FR,France +200746,3,18204,12267,24141,30,20,40,FR,France +200745,3,15521,10195,20847,25,16,34,FR,France +200744,3,13904,9072,18736,23,15,31,FR,France +200743,3,16212,10778,21646,26,17,35,FR,France +200742,3,20197,13955,26439,33,23,43,FR,France +200741,3,12987,8464,17510,21,14,28,FR,France +200740,3,13517,2983,24051,22,5,39,FR,France +200739,3,15985,7519,24451,26,12,40,FR,France +200738,3,4769,837,8701,8,2,14,FR,France +200737,3,1449,300,2598,2,0,4,FR,France +200736,3,1100,0,2424,2,0,4,FR,France +200735,3,1177,0,2872,2,0,5,FR,France +200734,3,3353,654,6052,5,1,9,FR,France +200733,3,4189,360,8018,7,1,13,FR,France +200732,3,132,0,688,0,0,1,FR,France +200731,3,1965,0,4461,3,0,7,FR,France +200730,3,2158,0,4583,4,0,8,FR,France +200729,3,3406,240,6572,6,1,11,FR,France +200728,3,1459,0,3467,2,0,5,FR,France +200727,3,1453,0,3382,2,0,5,FR,France +200726,3,157,0,513,0,0,1,FR,France +200725,3,3699,0,7778,6,0,13,FR,France +200724,3,2854,481,5227,5,1,9,FR,France +200723,3,5343,2164,8522,9,4,14,FR,France +200722,3,7689,4224,11154,13,7,19,FR,France +200721,3,4319,1659,6979,7,3,11,FR,France +200720,3,6400,2685,10115,10,4,16,FR,France +200719,3,3012,703,5321,5,1,9,FR,France +200718,3,2232,348,4116,4,1,7,FR,France +200717,3,4705,1736,7674,8,3,13,FR,France +200716,3,3817,1438,6196,6,2,10,FR,France +200715,3,4757,717,8797,8,1,15,FR,France +200714,3,11377,6957,15797,19,12,26,FR,France +200713,3,21271,13093,29449,35,22,48,FR,France +200712,3,25433,17717,33149,41,28,54,FR,France +200711,3,30764,23356,38172,50,38,62,FR,France +200710,3,49469,40368,58570,81,66,96,FR,France +200709,3,138901,117018,160784,226,190,262,FR,France +200708,3,316747,284988,348506,516,464,568,FR,France +200707,3,417698,386505,448891,681,630,732,FR,France +200706,3,500016,466668,533364,815,761,869,FR,France +200705,3,375457,346822,404092,612,565,659,FR,France +200704,3,209878,189332,230424,342,309,375,FR,France +200703,3,126161,110596,141726,206,181,231,FR,France +200702,3,82849,69493,96205,135,113,157,FR,France +200701,3,70842,58613,83071,115,95,135,FR,France +200652,3,78190,64191,92189,128,105,151,FR,France +200651,3,62734,50210,75258,103,82,124,FR,France +200650,3,35668,27280,44056,58,44,72,FR,France +200649,3,18773,13164,24382,31,22,40,FR,France +200648,3,16439,11225,21653,27,18,36,FR,France +200647,3,16104,9343,22865,26,15,37,FR,France +200646,3,14032,5590,22474,23,9,37,FR,France +200645,3,12285,7745,16825,20,13,27,FR,France +200644,3,8031,4172,11890,13,7,19,FR,France +200643,3,21157,12483,29831,35,21,49,FR,France +200642,3,16673,8249,25097,27,13,41,FR,France +200641,3,13920,9081,18759,23,15,31,FR,France +200640,3,11950,7132,16768,20,12,28,FR,France +200639,3,8945,4333,13557,15,7,23,FR,France +200638,3,2532,138,4926,4,0,8,FR,France +200637,3,1786,233,3339,3,0,6,FR,France +200636,3,1107,0,2346,2,0,4,FR,France +200635,3,2170,0,4760,4,0,8,FR,France +200634,3,1572,0,3756,3,0,7,FR,France +200633,3,0,0,0,0,0,0,FR,France +200632,3,0,0,0,0,0,0,FR,France +200631,3,1773,0,3892,3,0,6,FR,France +200630,3,665,0,1614,1,0,3,FR,France +200629,3,1339,0,3260,2,0,5,FR,France +200628,3,843,0,2245,1,0,3,FR,France +200627,3,1351,0,3031,2,0,5,FR,France +200626,3,4564,1506,7622,7,2,12,FR,France +200625,3,6259,2072,10446,10,3,17,FR,France +200624,3,4279,964,7594,7,2,12,FR,France +200623,3,4532,1489,7575,7,2,12,FR,France +200622,3,5807,2667,8947,10,5,15,FR,France +200621,3,4661,1761,7561,8,3,13,FR,France +200620,3,8859,4754,12964,15,8,22,FR,France +200619,3,5083,2011,8155,8,3,13,FR,France +200618,3,4454,1632,7276,7,2,12,FR,France +200617,3,17762,11802,23722,29,19,39,FR,France +200616,3,22096,15420,28772,36,25,47,FR,France +200615,3,26969,19631,34307,44,32,56,FR,France +200614,3,40321,31022,49620,66,51,81,FR,France +200613,3,77053,63531,90575,126,104,148,FR,France +200612,3,108004,93005,123003,177,152,202,FR,France +200611,3,122437,106388,138486,201,175,227,FR,France +200610,3,124749,109104,140394,204,178,230,FR,France +200609,3,164150,146099,182201,269,239,299,FR,France +200608,3,199088,178830,219346,326,293,359,FR,France +200607,3,243908,221071,266745,400,363,437,FR,France +200606,3,256758,235190,278326,421,386,456,FR,France +200605,3,184928,166901,202955,303,273,333,FR,France +200604,3,104620,90909,118331,171,149,193,FR,France +200603,3,66255,55727,76783,109,92,126,FR,France +200602,3,39211,31418,47004,64,51,77,FR,France +200601,3,34603,26269,42937,57,43,71,FR,France +200552,3,32132,24389,39875,53,40,66,FR,France +200551,3,40344,28397,52291,67,47,87,FR,France +200550,3,36880,28635,45125,61,47,75,FR,France +200549,3,27589,20576,34602,46,34,58,FR,France +200548,3,24860,17839,31881,41,29,53,FR,France +200547,3,26884,19810,33958,44,32,56,FR,France +200546,3,23967,17155,30779,40,29,51,FR,France +200545,3,14609,8709,20509,24,14,34,FR,France +200544,3,20481,13625,27337,34,23,45,FR,France +200543,3,18045,11916,24174,30,20,40,FR,France +200542,3,23653,15209,32097,39,25,53,FR,France +200541,3,26466,18270,34662,44,30,58,FR,France +200540,3,26647,18088,35206,44,30,58,FR,France +200539,3,23994,15381,32607,40,26,54,FR,France +200538,3,21881,13979,29783,36,23,49,FR,France +200537,3,10347,5384,15310,17,9,25,FR,France +200536,3,7082,2806,11358,12,5,19,FR,France +200535,3,2448,0,4987,4,0,8,FR,France +200534,3,5281,539,10023,9,1,17,FR,France +200533,3,2815,0,6252,5,0,11,FR,France +200532,3,1572,0,3690,3,0,6,FR,France +200531,3,3767,0,10955,6,0,18,FR,France +200530,3,2203,0,5072,4,0,9,FR,France +200529,3,3965,739,7191,7,2,12,FR,France +200528,3,1988,96,3880,3,0,6,FR,France +200527,3,2305,0,4713,4,0,8,FR,France +200526,3,4720,1385,8055,8,2,14,FR,France +200525,3,2354,0,4747,4,0,8,FR,France +200524,3,5892,2029,9755,10,4,16,FR,France +200523,3,5246,1722,8770,9,3,15,FR,France +200522,3,3935,1031,6839,6,1,11,FR,France +200521,3,4284,474,8094,7,1,13,FR,France +200520,3,7841,3611,12071,13,6,20,FR,France +200519,3,7638,3346,11930,13,6,20,FR,France +200518,3,2755,388,5122,5,1,9,FR,France +200517,3,7166,3530,10802,12,6,18,FR,France +200516,3,9741,5344,14138,16,9,23,FR,France +200515,3,14881,9018,20744,25,15,35,FR,France +200514,3,21988,14834,29142,36,24,48,FR,France +200513,3,42971,33053,52889,71,55,87,FR,France +200512,3,90040,75374,104706,149,125,173,FR,France +200511,3,183032,161407,204657,302,266,338,FR,France +200510,3,222526,199990,245062,367,330,404,FR,France +200509,3,251784,229464,274104,416,379,453,FR,France +200508,3,277423,254825,300021,458,421,495,FR,France +200507,3,459444,430026,488862,759,710,808,FR,France +200506,3,568610,536207,601013,939,885,993,FR,France +200505,3,568285,534912,601658,938,883,993,FR,France +200504,3,316856,292011,341701,523,482,564,FR,France +200503,3,154208,137061,171355,255,227,283,FR,France +200502,3,88853,75576,102130,147,125,169,FR,France +200501,3,55801,45339,66263,92,75,109,FR,France +200453,3,40695,31926,49464,68,53,83,FR,France +200452,3,32687,24316,41058,54,40,68,FR,France +200451,3,46209,36017,56401,77,60,94,FR,France +200450,3,42358,31865,52851,70,53,87,FR,France +200449,3,27092,17910,36274,45,30,60,FR,France +200448,3,30522,21236,39808,51,36,66,FR,France +200447,3,21148,13386,28910,35,22,48,FR,France +200446,3,13934,8335,19533,23,14,32,FR,France +200445,3,15658,9703,21613,26,16,36,FR,France +200444,3,23166,14852,31480,38,24,52,FR,France +200443,3,16780,10545,23015,28,18,38,FR,France +200442,3,20480,13909,27051,34,23,45,FR,France +200441,3,15852,9789,21915,26,16,36,FR,France +200440,3,25639,17291,33987,43,29,57,FR,France +200439,3,22680,13222,32138,38,22,54,FR,France +200438,3,17483,9417,25549,29,16,42,FR,France +200437,3,9103,4768,13438,15,8,22,FR,France +200436,3,7753,3596,11910,13,6,20,FR,France +200435,3,4408,775,8041,7,1,13,FR,France +200434,3,4501,610,8392,7,1,13,FR,France +200433,3,1697,0,4046,3,0,7,FR,France +200432,3,3496,0,8181,6,0,14,FR,France +200431,3,2949,20,5878,5,0,10,FR,France +200430,3,3557,642,6472,6,1,11,FR,France +200429,3,5164,1162,9166,9,2,16,FR,France +200428,3,6358,2224,10492,11,4,18,FR,France +200427,3,7486,3040,11932,12,5,19,FR,France +200426,3,7113,0,14709,12,0,25,FR,France +200425,3,3275,508,6042,5,0,10,FR,France +200424,3,6737,2394,11080,11,4,18,FR,France +200423,3,9792,807,18777,16,1,31,FR,France +200422,3,8077,3482,12672,13,5,21,FR,France +200421,3,8073,3588,12558,13,6,20,FR,France +200420,3,7885,3454,12316,13,6,20,FR,France +200419,3,7235,3101,11369,12,5,19,FR,France +200418,3,5108,1830,8386,8,3,13,FR,France +200417,3,3647,523,6771,6,1,11,FR,France +200416,3,5265,1359,9171,9,3,15,FR,France +200415,3,8272,3655,12889,14,6,22,FR,France +200414,3,15657,8888,22426,26,15,37,FR,France +200413,3,8316,4067,12565,14,7,21,FR,France +200412,3,12482,6899,18065,21,12,30,FR,France +200411,3,13964,7879,20049,23,13,33,FR,France +200410,3,22531,14164,30898,37,23,51,FR,France +200409,3,12618,7283,17953,21,12,30,FR,France +200408,3,17738,11055,24421,29,18,40,FR,France +200407,3,25484,17228,33740,42,28,56,FR,France +200406,3,27452,19505,35399,46,33,59,FR,France +200405,3,35110,25869,44351,58,43,73,FR,France +200404,3,44571,35266,53876,74,59,89,FR,France +200403,3,60482,50389,70575,100,83,117,FR,France +200402,3,95234,81407,109061,158,135,181,FR,France +200401,3,109116,84565,133667,181,140,222,FR,France +200352,3,72239,5520,138958,121,10,232,FR,France +200351,3,445464,389214,501714,744,650,838,FR,France +200350,3,522427,491781,553073,873,822,924,FR,France +200349,3,555492,524706,586278,928,877,979,FR,France +200348,3,514668,485364,543972,860,811,909,FR,France +200347,3,332927,305972,359882,556,511,601,FR,France +200346,3,146101,126840,165362,244,212,276,FR,France +200345,3,95565,80900,110230,160,135,185,FR,France +200344,3,54703,43193,66213,91,72,110,FR,France +200343,3,45834,36611,55057,77,62,92,FR,France +200342,3,39010,28885,49135,65,48,82,FR,France +200341,3,29579,21478,37680,49,35,63,FR,France +200340,3,30862,19484,42240,52,33,71,FR,France +200339,3,26592,18927,34257,44,31,57,FR,France +200338,3,14811,8777,20845,25,15,35,FR,France +200337,3,14735,7495,21975,25,13,37,FR,France +200336,3,10951,3732,18170,18,6,30,FR,France +200335,3,1504,0,3349,3,0,6,FR,France +200334,3,2194,0,4889,4,0,9,FR,France +200333,3,1504,0,3921,3,0,7,FR,France +200332,3,1619,0,4072,3,0,7,FR,France +200331,3,5164,0,10601,9,0,18,FR,France +200330,3,3183,28,6338,5,0,10,FR,France +200329,3,6801,450,13152,11,0,22,FR,France +200328,3,3975,609,7341,7,1,13,FR,France +200327,3,2293,0,4605,4,0,8,FR,France +200326,3,5333,2138,8528,9,4,14,FR,France +200325,3,2602,0,5228,4,0,8,FR,France +200324,3,8429,0,19483,14,0,32,FR,France +200323,3,4821,1479,8163,8,2,14,FR,France +200322,3,2573,158,4988,4,0,8,FR,France +200321,3,5563,2465,8661,9,4,14,FR,France +200320,3,7554,3748,11360,13,7,19,FR,France +200319,3,8325,3777,12873,14,6,22,FR,France +200318,3,12268,6392,18144,20,10,30,FR,France +200317,3,46253,36234,56272,77,60,94,FR,France +200316,3,50759,39835,61683,85,67,103,FR,France +200315,3,69269,55778,82760,116,93,139,FR,France +200314,3,70084,55374,84794,117,92,142,FR,France +200313,3,70335,56370,84300,118,95,141,FR,France +200312,3,88582,73568,103596,148,123,173,FR,France +200311,3,99729,83353,116105,167,140,194,FR,France +200310,3,121516,104361,138671,203,174,232,FR,France +200309,3,177255,151800,202710,296,253,339,FR,France +200308,3,222638,194269,251007,372,325,419,FR,France +200307,3,237104,207851,266357,396,347,445,FR,France +200306,3,206955,177973,235937,346,298,394,FR,France +200305,3,151864,125877,177851,254,211,297,FR,France +200304,3,95356,76211,114501,159,127,191,FR,France +200303,3,50983,38264,63702,85,64,106,FR,France +200302,3,31447,21706,41188,53,37,69,FR,France +200301,3,31228,19202,43254,52,32,72,FR,France +200252,3,47016,33692,60340,79,57,101,FR,France +200251,3,47629,36912,58346,80,62,98,FR,France +200250,3,35221,26217,44225,59,44,74,FR,France +200249,3,24656,16900,32412,41,28,54,FR,France +200248,3,19799,12868,26730,33,21,45,FR,France +200247,3,16449,9214,23684,28,16,40,FR,France +200246,3,12753,5779,19727,21,9,33,FR,France +200245,3,19304,8475,30133,32,14,50,FR,France +200244,3,18082,10671,25493,30,18,42,FR,France +200243,3,14326,7548,21104,24,13,35,FR,France +200242,3,13774,7800,19748,23,13,33,FR,France +200241,3,11036,5650,16422,19,10,28,FR,France +200240,3,8137,3375,12899,14,6,22,FR,France +200239,3,15989,9892,22086,27,17,37,FR,France +200238,3,7067,3299,10835,12,6,18,FR,France +200237,3,12409,4981,19837,21,9,33,FR,France +200236,3,1679,0,4072,3,0,7,FR,France +200235,3,2126,0,6301,4,0,11,FR,France +200234,3,2843,0,7483,5,0,13,FR,France +200233,3,2670,0,5462,4,0,9,FR,France +200232,3,1087,0,3003,2,0,5,FR,France +200231,3,5455,399,10511,9,1,17,FR,France +200230,3,3601,0,7836,6,0,13,FR,France +200229,3,5576,379,10773,9,0,18,FR,France +200228,3,6602,0,14289,11,0,24,FR,France +200227,3,1882,0,6151,3,0,10,FR,France +200226,3,4523,0,12320,8,0,21,FR,France +200225,3,4765,1076,8454,8,2,14,FR,France +200224,3,12063,7174,16952,20,12,28,FR,France +200223,3,15468,9806,21130,26,16,36,FR,France +200222,3,4854,1696,8012,8,3,13,FR,France +200221,3,5901,2212,9590,10,4,16,FR,France +200220,3,3803,1215,6391,6,2,10,FR,France +200219,3,6139,2598,9680,10,4,16,FR,France +200218,3,6083,2646,9520,10,4,16,FR,France +200217,3,7223,2678,11768,12,4,20,FR,France +200216,3,17762,9887,25637,30,17,43,FR,France +200215,3,21654,13662,29646,36,23,49,FR,France +200214,3,23877,15709,32045,40,26,54,FR,France +200213,3,27497,16289,38705,46,27,65,FR,France +200212,3,33510,20938,46082,56,35,77,FR,France +200211,3,40426,29171,51681,68,49,87,FR,France +200210,3,42915,24537,61293,72,41,103,FR,France +200209,3,63735,48368,79102,107,81,133,FR,France +200208,3,117204,95548,138860,197,161,233,FR,France +200207,3,170251,137065,203437,286,230,342,FR,France +200206,3,325084,296111,354057,546,497,595,FR,France +200205,3,456186,422559,489813,767,710,824,FR,France +200204,3,504715,470859,538571,848,791,905,FR,France +200203,3,383720,353019,414421,645,593,697,FR,France +200202,3,244028,217752,270304,410,366,454,FR,France +200201,3,115422,95696,135148,194,161,227,FR,France +200152,3,57999,43225,72773,98,73,123,FR,France +200151,3,45961,36017,55905,78,61,95,FR,France +200150,3,31309,22878,39740,53,39,67,FR,France +200149,3,34792,23268,46316,59,40,78,FR,France +200148,3,43283,20164,66402,73,34,112,FR,France +200147,3,27455,20021,34889,46,33,59,FR,France +200146,3,21127,14294,27960,36,24,48,FR,France +200145,3,20766,13979,27553,35,24,46,FR,France +200144,3,11410,6593,16227,19,11,27,FR,France +200143,3,23311,15652,30970,39,26,52,FR,France +200142,3,18963,11652,26274,32,20,44,FR,France +200141,3,20241,14032,26450,34,24,44,FR,France +200140,3,18113,9971,26255,31,17,45,FR,France +200139,3,25407,7785,43029,43,13,73,FR,France +200138,3,9736,4985,14487,16,8,24,FR,France +200137,3,8025,3527,12523,14,6,22,FR,France +200136,3,4663,654,8672,8,1,15,FR,France +200135,3,4399,0,9810,7,0,16,FR,France +200134,3,2990,0,6419,5,0,11,FR,France +200133,3,0,0,0,0,0,0,FR,France +200132,3,0,0,0,0,0,0,FR,France +200131,3,18999,4286,33712,32,7,57,FR,France +200130,3,2144,0,5670,4,0,10,FR,France +200129,3,2408,0,5215,4,0,9,FR,France +200128,3,3555,553,6557,6,1,11,FR,France +200127,3,4739,1122,8356,8,2,14,FR,France +200126,3,3335,466,6204,6,1,11,FR,France +200125,3,2643,527,4759,4,0,8,FR,France +200124,3,4784,2158,7410,8,4,12,FR,France +200123,3,6299,3161,9437,11,6,16,FR,France +200122,3,4544,2006,7082,8,4,12,FR,France +200121,3,8925,4094,13756,15,7,23,FR,France +200120,3,15269,8883,21655,26,15,37,FR,France +200119,3,17369,10575,24163,29,18,40,FR,France +200118,3,21043,14262,27824,36,25,47,FR,France +200117,3,25787,19109,32465,44,33,55,FR,France +200116,3,24025,16833,31217,41,29,53,FR,France +200115,3,24188,17340,31036,41,29,53,FR,France +200114,3,40429,31774,49084,68,53,83,FR,France +200113,3,48644,39517,57771,82,67,97,FR,France +200112,3,45411,35780,55042,77,61,93,FR,France +200111,3,49809,40534,59084,84,68,100,FR,France +200110,3,46649,37240,56058,79,63,95,FR,France +200109,3,58623,47346,69900,99,80,118,FR,France +200108,3,77423,63237,91609,131,107,155,FR,France +200107,3,126970,107898,146042,215,183,247,FR,France +200106,3,225969,198142,253796,382,335,429,FR,France +200105,3,278674,249486,307862,471,422,520,FR,France +200104,3,209193,189129,229257,354,320,388,FR,France +200103,3,139823,124243,155403,236,210,262,FR,France +200102,3,105356,92392,118320,178,156,200,FR,France +200101,3,98930,84599,113261,167,143,191,FR,France +200052,3,143525,124203,162847,244,211,277,FR,France +200051,3,125224,108719,141729,213,185,241,FR,France +200050,3,99177,84857,113497,169,145,193,FR,France +200049,3,74170,54196,94144,126,92,160,FR,France +200048,3,43642,34064,53220,74,58,90,FR,France +200047,3,64848,11322,118374,110,19,201,FR,France +200046,3,20598,14053,27143,35,24,46,FR,France +200045,3,25375,17229,33521,43,29,57,FR,France +200044,3,16330,9762,22898,28,17,39,FR,France +200043,3,36951,27693,46209,63,47,79,FR,France +200042,3,41200,30772,51628,70,52,88,FR,France +200041,3,40022,30939,49105,68,53,83,FR,France +200040,3,27237,19986,34488,46,34,58,FR,France +200039,3,19338,12649,26027,33,22,44,FR,France +200038,3,7417,3193,11641,13,6,20,FR,France +200037,3,2243,0,4722,4,0,8,FR,France +200036,3,2990,0,6416,5,0,11,FR,France +200035,3,5590,0,12003,10,0,21,FR,France +200034,3,5188,0,12418,9,0,21,FR,France +200033,3,1690,0,3859,3,0,7,FR,France +200032,3,1405,0,4239,2,0,7,FR,France +200031,3,2159,0,4744,4,0,8,FR,France +200030,3,218,0,783,0,0,1,FR,France +200029,3,1532,0,3751,3,0,7,FR,France +200028,3,1071,0,2881,2,0,5,FR,France +200027,3,2427,150,4704,4,0,8,FR,France +200026,3,1997,0,4996,3,0,8,FR,France +200025,3,4239,221,8257,7,0,14,FR,France +200024,3,5411,1122,9700,9,2,16,FR,France +200023,3,8757,4101,13413,15,7,23,FR,France +200022,3,4966,1694,8238,8,2,14,FR,France +200021,3,4271,1389,7153,7,2,12,FR,France +200020,3,4520,1478,7562,8,3,13,FR,France +200019,3,13867,8548,19186,24,15,33,FR,France +200018,3,5386,2261,8511,9,4,14,FR,France +200017,3,7018,1581,12455,12,3,21,FR,France +200016,3,5328,1433,9223,9,2,16,FR,France +200015,3,12020,6436,17604,20,11,29,FR,France +200014,3,10942,5691,16193,19,10,28,FR,France +200013,3,8572,3443,13701,15,6,24,FR,France +200012,3,7081,3097,11065,12,5,19,FR,France +200011,3,12172,7447,16897,21,13,29,FR,France +200010,3,9091,5450,12732,15,9,21,FR,France +200009,3,14631,9200,20062,25,16,34,FR,France +200008,3,23647,17172,30122,40,29,51,FR,France +200007,3,59173,48440,69906,101,83,119,FR,France +200006,3,146517,129961,163073,249,221,277,FR,France +200005,3,261687,239983,283391,445,408,482,FR,France +200004,3,374822,349785,399859,637,594,680,FR,France +200003,3,484233,456706,511760,824,777,871,FR,France +200002,3,521069,492185,549953,886,837,935,FR,France +200001,3,541945,511326,572564,922,870,974,FR,France +199952,3,387655,360652,414658,663,617,709,FR,France +199951,3,272075,250906,293244,465,429,501,FR,France +199950,3,181113,164571,197655,310,282,338,FR,France +199949,3,112328,99058,125598,192,169,215,FR,France +199948,3,58710,48651,68769,100,83,117,FR,France +199947,3,35912,23462,48362,61,40,82,FR,France +199946,3,8601,1503,15699,15,3,27,FR,France +199945,3,17781,10817,24745,30,18,42,FR,France +199944,3,18238,12870,23606,31,22,40,FR,France +199943,3,18135,12601,23669,31,22,40,FR,France +199942,3,19183,13258,25108,33,23,43,FR,France +199941,3,25171,18689,31653,43,32,54,FR,France +199940,3,24185,16184,32186,41,27,55,FR,France +199939,3,28553,20776,36330,49,36,62,FR,France +199938,3,12430,7759,17101,21,13,29,FR,France +199937,3,7543,4283,10803,13,7,19,FR,France +199936,3,8191,2827,13555,14,5,23,FR,France +199935,3,3334,1188,5480,6,2,10,FR,France +199934,3,7600,0,27730,13,0,47,FR,France +199933,3,9757,354,19160,17,1,33,FR,France +199932,3,7149,0,15077,12,0,26,FR,France +199931,3,2640,0,5463,5,0,10,FR,France +199930,3,1478,0,3153,3,0,6,FR,France +199929,3,3983,498,7468,7,1,13,FR,France +199928,3,3731,712,6750,6,1,11,FR,France +199927,3,5004,1597,8411,9,3,15,FR,France +199926,3,3459,699,6219,6,1,11,FR,France +199925,3,5302,2057,8547,9,3,15,FR,France +199924,3,4327,1646,7008,7,2,12,FR,France +199923,3,5370,2374,8366,9,4,14,FR,France +199922,3,4404,1643,7165,8,3,13,FR,France +199921,3,4180,1485,6875,7,2,12,FR,France +199920,3,6073,2775,9371,10,4,16,FR,France +199919,3,6241,3220,9262,11,6,16,FR,France +199918,3,3057,678,5436,5,1,9,FR,France +199917,3,2904,701,5107,5,1,9,FR,France +199916,3,7539,3360,11718,13,6,20,FR,France +199915,3,11535,6814,16256,20,12,28,FR,France +199914,3,18730,13131,24329,32,22,42,FR,France +199913,3,38453,29560,47346,66,51,81,FR,France +199912,3,58090,48072,68108,99,82,116,FR,France +199911,3,91329,78686,103972,156,134,178,FR,France +199910,3,147976,131058,164894,253,224,282,FR,France +199909,3,207450,188710,226190,355,323,387,FR,France +199908,3,313293,292280,334306,536,500,572,FR,France +199907,3,524136,496702,551570,896,849,943,FR,France +199906,3,493908,466605,521211,844,797,891,FR,France +199905,3,476884,449696,504072,815,769,861,FR,France +199904,3,368514,345131,391897,630,590,670,FR,France +199903,3,242388,224208,260568,414,383,445,FR,France +199902,3,160657,145209,176105,275,249,301,FR,France +199901,3,130133,115125,145141,222,196,248,FR,France +199853,3,107611,92301,122921,185,159,211,FR,France +199852,3,72373,61032,83714,124,105,143,FR,France +199851,3,78179,67156,89202,134,115,153,FR,France +199850,3,54775,45478,64072,94,78,110,FR,France +199849,3,33385,26332,40438,57,45,69,FR,France +199848,3,22636,16668,28604,39,29,49,FR,France +199847,3,14505,9746,19264,25,17,33,FR,France +199846,3,13804,9049,18559,24,16,32,FR,France +199845,3,13021,8113,17929,22,14,30,FR,France +199844,3,12631,7410,17852,22,13,31,FR,France +199843,3,12180,7125,17235,21,12,30,FR,France +199842,3,18885,12726,25044,32,21,43,FR,France +199841,3,24196,17506,30886,42,31,53,FR,France +199840,3,20235,14114,26356,35,25,45,FR,France +199839,3,17075,11538,22612,29,20,38,FR,France +199838,3,10837,6336,15338,19,11,27,FR,France +199837,3,6968,3227,10709,12,6,18,FR,France +199836,3,3033,580,5486,5,1,9,FR,France +199835,3,2491,0,5022,4,0,8,FR,France +199834,3,3853,589,7117,7,1,13,FR,France +199833,3,2934,0,6598,5,0,11,FR,France +199832,3,1308,0,2894,2,0,5,FR,France +199831,3,12147,0,29237,21,0,50,FR,France +199830,3,5309,1628,8990,9,3,15,FR,France +199829,3,6486,2465,10507,11,4,18,FR,France +199828,3,9577,4464,14690,16,7,25,FR,France +199827,3,12358,7158,17558,21,12,30,FR,France +199826,3,10415,6547,14283,18,11,25,FR,France +199825,3,18246,13050,23442,31,22,40,FR,France +199824,3,16263,11126,21400,28,19,37,FR,France +199823,3,8553,4911,12195,15,9,21,FR,France +199822,3,5181,2669,7693,9,5,13,FR,France +199821,3,4751,2416,7086,8,4,12,FR,France +199820,3,12129,8099,16159,21,14,28,FR,France +199819,3,24118,17906,30330,41,30,52,FR,France +199818,3,31612,24512,38712,54,42,66,FR,France +199817,3,61148,51894,70402,105,89,121,FR,France +199816,3,123195,109878,136512,211,188,234,FR,France +199815,3,171603,156715,186491,294,268,320,FR,France +199814,3,319092,298398,339786,547,512,582,FR,France +199813,3,298212,278513,317911,512,478,546,FR,France +199812,3,263585,246356,280814,452,422,482,FR,France +199811,3,220578,204894,236262,378,351,405,FR,France +199810,3,202354,186304,218404,347,319,375,FR,France +199809,3,227553,209970,245136,390,360,420,FR,France +199808,3,271362,252005,290719,465,432,498,FR,France +199807,3,190187,173694,206680,326,298,354,FR,France +199806,3,88217,76829,99605,151,131,171,FR,France +199805,3,45180,36970,53390,77,63,91,FR,France +199804,3,30005,23272,36738,51,39,63,FR,France +199803,3,23900,18221,29579,41,31,51,FR,France +199802,3,31143,23994,38292,53,41,65,FR,France +199801,3,24809,17786,31832,43,31,55,FR,France +199752,3,29039,21984,36094,50,38,62,FR,France +199751,3,34924,27737,42111,60,48,72,FR,France +199750,3,33527,26388,40666,58,46,70,FR,France +199749,3,15978,11147,20809,27,19,35,FR,France +199748,3,11507,7744,15270,20,14,26,FR,France +199747,3,11059,7151,14967,19,12,26,FR,France +199746,3,8073,4613,11533,14,8,20,FR,France +199745,3,18202,13113,23291,31,22,40,FR,France +199744,3,19770,14405,25135,34,25,43,FR,France +199743,3,16707,11945,21469,29,21,37,FR,France +199742,3,15340,10351,20329,26,17,35,FR,France +199741,3,16933,11941,21925,29,20,38,FR,France +199740,3,13292,8709,17875,23,15,31,FR,France +199739,3,10189,6279,14099,18,11,25,FR,France +199738,3,3231,1061,5401,6,2,10,FR,France +199737,3,4542,1949,7135,8,4,12,FR,France +199736,3,5131,2205,8057,9,4,14,FR,France +199735,3,1842,0,3740,3,0,6,FR,France +199734,3,3226,0,6717,6,0,12,FR,France +199733,3,1799,0,4368,3,0,7,FR,France +199732,3,2086,0,4411,4,0,8,FR,France +199731,3,1386,0,3332,2,0,5,FR,France +199730,3,2116,0,4919,4,0,9,FR,France +199729,3,1973,0,4347,3,0,7,FR,France +199728,3,1560,216,2904,3,1,5,FR,France +199727,3,2540,754,4326,4,1,7,FR,France +199726,3,5582,2699,8465,10,5,15,FR,France +199725,3,4012,1090,6934,7,2,12,FR,France +199724,3,4696,1824,7568,8,3,13,FR,France +199723,3,4709,2136,7282,8,4,12,FR,France +199722,3,2283,665,3901,4,1,7,FR,France +199721,3,2108,664,3552,4,2,6,FR,France +199720,3,3257,1519,4995,6,3,9,FR,France +199719,3,4646,2436,6856,8,4,12,FR,France +199718,3,5246,2764,7728,9,5,13,FR,France +199717,3,14236,9906,18566,24,17,31,FR,France +199716,3,12169,8111,16227,21,14,28,FR,France +199715,3,9516,6192,12840,16,10,22,FR,France +199714,3,13602,9659,17545,23,16,30,FR,France +199713,3,18032,13345,22719,31,23,39,FR,France +199712,3,17199,12707,21691,30,22,38,FR,France +199711,3,19988,15419,24557,34,26,42,FR,France +199710,3,21903,17338,26468,38,30,46,FR,France +199709,3,29860,24261,35459,51,41,61,FR,France +199708,3,55445,47857,63033,95,82,108,FR,France +199707,3,70876,62518,79234,122,108,136,FR,France +199706,3,76906,68152,85660,132,117,147,FR,France +199705,3,95900,86095,105705,165,148,182,FR,France +199704,3,96896,87079,106713,167,150,184,FR,France +199703,3,143844,131917,155771,248,227,269,FR,France +199702,3,211578,197395,225761,364,340,388,FR,France +199701,3,280440,263783,297097,483,454,512,FR,France +199652,3,388201,369211,407191,670,637,703,FR,France +199651,3,640627,617388,663866,1106,1066,1146,FR,France +199650,3,535205,514568,555842,924,888,960,FR,France +199649,3,411498,393335,429661,710,679,741,FR,France +199648,3,195568,182563,208573,338,316,360,FR,France +199647,3,71980,63619,80341,124,110,138,FR,France +199646,3,32138,26358,37918,55,45,65,FR,France +199645,3,25551,20136,30966,44,35,53,FR,France +199644,3,10753,7230,14276,19,13,25,FR,France +199643,3,12971,9311,16631,22,16,28,FR,France +199642,3,11929,8472,15386,21,15,27,FR,France +199641,3,9918,6674,13162,17,11,23,FR,France +199640,3,10765,7067,14463,19,13,25,FR,France +199639,3,8377,5183,11571,14,8,20,FR,France +199638,3,9470,5965,12975,16,10,22,FR,France +199637,3,2925,829,5021,5,1,9,FR,France +199636,3,1122,23,2221,2,0,4,FR,France +199635,3,1674,93,3255,3,0,6,FR,France +199634,3,1273,122,2424,2,0,4,FR,France +199633,3,540,0,1246,1,0,2,FR,France +199632,3,1453,176,2730,3,1,5,FR,France +199631,3,3010,752,5268,5,1,9,FR,France +199630,3,2992,706,5278,5,1,9,FR,France +199629,3,1559,144,2974,3,1,5,FR,France +199628,3,3109,541,5677,5,1,9,FR,France +199627,3,4456,1595,7317,8,3,13,FR,France +199626,3,2871,1138,4604,5,2,8,FR,France +199625,3,2308,856,3760,4,1,7,FR,France +199624,3,2490,1067,3913,4,2,6,FR,France +199623,3,2819,1262,4376,5,2,8,FR,France +199622,3,4005,1984,6026,7,4,10,FR,France +199621,3,7042,4291,9793,12,7,17,FR,France +199620,3,10619,7365,13873,18,12,24,FR,France +199619,3,11898,8065,15731,21,14,28,FR,France +199618,3,18338,13352,23324,32,23,41,FR,France +199617,3,24954,19100,30808,43,33,53,FR,France +199616,3,29313,23868,34758,51,42,60,FR,France +199615,3,51703,43644,59762,89,75,103,FR,France +199614,3,44414,36774,52054,77,64,90,FR,France +199613,3,30622,25062,36182,53,43,63,FR,France +199612,3,31818,25852,37784,55,45,65,FR,France +199611,3,24427,19499,29355,42,33,51,FR,France +199610,3,20910,16198,25622,36,28,44,FR,France +199609,3,19594,15228,23960,34,26,42,FR,France +199608,3,19046,14850,23242,33,26,40,FR,France +199607,3,23041,18338,27744,40,32,48,FR,France +199606,3,21810,17153,26467,38,30,46,FR,France +199605,3,25275,20410,30140,44,36,52,FR,France +199604,3,43359,36948,49770,75,64,86,FR,France +199603,3,54691,48016,61366,94,82,106,FR,France +199602,3,105606,96106,115106,182,166,198,FR,France +199601,3,223830,209274,238386,386,361,411,FR,France +199552,3,397122,378252,415992,688,655,721,FR,France +199551,3,749988,725434,774542,1299,1256,1342,FR,France +199550,3,604926,583100,626752,1047,1009,1085,FR,France +199549,3,375500,358200,392800,650,620,680,FR,France +199548,3,206446,193457,219435,357,335,379,FR,France +199547,3,120472,110526,130418,209,192,226,FR,France +199546,3,62380,55042,69718,108,95,121,FR,France +199545,3,29791,24523,35059,52,43,61,FR,France +199544,3,13168,9820,16516,23,17,29,FR,France +199543,3,16188,12389,19987,28,21,35,FR,France +199542,3,15178,11387,18969,26,19,33,FR,France +199541,3,14980,10851,19109,26,19,33,FR,France +199540,3,16245,11610,20880,28,20,36,FR,France +199539,3,18499,13844,23154,32,24,40,FR,France +199538,3,13123,9410,16836,23,17,29,FR,France +199537,3,4895,2666,7124,8,4,12,FR,France +199536,3,3659,1574,5744,6,2,10,FR,France +199535,3,2496,644,4348,4,1,7,FR,France +199534,3,1887,214,3560,3,0,6,FR,France +199533,3,905,0,2007,2,0,4,FR,France +199532,3,700,0,1699,1,0,3,FR,France +199531,3,1946,92,3800,3,0,6,FR,France +199530,3,1898,46,3750,3,0,6,FR,France +199529,3,2148,687,3609,4,1,7,FR,France +199528,3,3312,1430,5194,6,3,9,FR,France +199527,3,4853,2683,7023,8,4,12,FR,France +199526,3,4986,2911,7061,9,5,13,FR,France +199525,3,4571,2520,6622,8,4,12,FR,France +199524,3,8058,5054,11062,14,9,19,FR,France +199523,3,13820,9801,17839,24,17,31,FR,France +199522,3,14124,9999,18249,24,17,31,FR,France +199521,3,11931,8655,15207,21,15,27,FR,France +199520,3,18846,14311,23381,33,25,41,FR,France +199519,3,26261,21488,31034,45,37,53,FR,France +199518,3,39231,33258,45204,68,58,78,FR,France +199517,3,88640,79343,97937,153,137,169,FR,France +199516,3,140488,129439,151537,243,224,262,FR,France +199515,3,181007,169110,192904,313,292,334,FR,France +199514,3,248704,235144,262264,431,408,454,FR,France +199513,3,209839,197191,222487,363,341,385,FR,France +199512,3,122434,112497,132371,212,195,229,FR,France +199511,3,81730,73346,90114,142,127,157,FR,France +199510,3,49387,42703,56071,86,74,98,FR,France +199509,3,39696,33259,46133,69,58,80,FR,France +199508,3,38008,32225,43791,66,56,76,FR,France +199507,3,30550,25479,35621,53,44,62,FR,France +199506,3,37351,32007,42695,65,56,74,FR,France +199505,3,27876,23218,32534,48,40,56,FR,France +199504,3,27643,22818,32468,48,40,56,FR,France +199503,3,24844,20391,29297,43,35,51,FR,France +199502,3,23480,19249,27711,41,34,48,FR,France +199501,3,26556,21916,31196,46,38,54,FR,France +199452,3,22036,17495,26577,38,30,46,FR,France +199451,3,26912,21750,32074,47,38,56,FR,France +199450,3,28831,23470,34192,50,41,59,FR,France +199449,3,21161,16559,25763,37,29,45,FR,France +199448,3,18487,14456,22518,32,25,39,FR,France +199447,3,15206,11578,18834,26,20,32,FR,France +199446,3,14252,10525,17979,25,19,31,FR,France +199445,3,12152,8448,15856,21,15,27,FR,France +199444,3,11307,7688,14926,20,14,26,FR,France +199443,3,11254,8002,14506,20,14,26,FR,France +199442,3,14406,10653,18159,25,18,32,FR,France +199441,3,14073,10341,17805,24,18,30,FR,France +199440,3,15962,11850,20074,28,21,35,FR,France +199439,3,15878,11643,20113,28,21,35,FR,France +199438,3,15366,11100,19632,27,20,34,FR,France +199437,3,5949,3561,8337,10,6,14,FR,France +199436,3,2806,1133,4479,5,2,8,FR,France +199435,3,4556,2358,6754,8,4,12,FR,France +199434,3,3459,1444,5474,6,2,10,FR,France +199433,3,4272,977,7567,7,1,13,FR,France +199432,3,4786,1613,7959,8,2,14,FR,France +199431,3,5027,1580,8474,9,3,15,FR,France +199430,3,2100,520,3680,4,1,7,FR,France +199429,3,1188,0,2384,2,0,4,FR,France +199428,3,1581,316,2846,3,1,5,FR,France +199427,3,713,0,1459,1,0,2,FR,France +199426,3,990,80,1900,2,0,4,FR,France +199425,3,5431,3222,7640,9,5,13,FR,France +199424,3,6288,3723,8853,11,7,15,FR,France +199423,3,6440,1052,11828,11,2,20,FR,France +199422,3,845,0,2449,1,0,4,FR,France +199421,3,2197,395,3999,4,1,7,FR,France +199420,3,2217,852,3582,4,2,6,FR,France +199419,3,1483,406,2560,3,1,5,FR,France +199418,3,3705,1940,5470,6,3,9,FR,France +199417,3,2288,1064,3512,4,2,6,FR,France +199416,3,5156,3176,7136,9,6,12,FR,France +199415,3,6952,4678,9226,12,8,16,FR,France +199414,3,4671,2784,6558,8,5,11,FR,France +199413,3,3343,1641,5045,6,3,9,FR,France +199412,3,4305,2412,6198,7,4,10,FR,France +199411,3,5399,3327,7471,9,5,13,FR,France +199410,3,4548,2529,6567,8,4,12,FR,France +199409,3,5635,3251,8019,10,6,14,FR,France +199408,3,9539,6652,12426,17,12,22,FR,France +199407,3,14639,11188,18090,25,19,31,FR,France +199406,3,17308,13395,21221,30,23,37,FR,France +199405,3,18489,14290,22688,32,25,39,FR,France +199404,3,23712,19048,28376,41,33,49,FR,France +199403,3,29882,24817,34947,52,43,61,FR,France +199402,3,47402,41415,53389,82,72,92,FR,France +199401,3,118119,108182,128056,205,188,222,FR,France +199352,3,233137,218608,247666,406,381,431,FR,France +199351,3,377472,359792,395152,658,627,689,FR,France +199350,3,627639,607097,648181,1094,1058,1130,FR,France +199349,3,898045,873419,922671,1565,1522,1608,FR,France +199348,3,527582,507752,547412,920,885,955,FR,France +199347,3,241371,226769,255973,421,396,446,FR,France +199346,3,76034,68003,84065,133,119,147,FR,France +199345,3,32289,27022,37556,56,47,65,FR,France +199344,3,17832,14015,21649,31,24,38,FR,France +199343,3,15098,11333,18863,26,19,33,FR,France +199342,3,19187,14893,23481,33,26,40,FR,France +199341,3,18285,14384,22186,32,25,39,FR,France +199340,3,13805,10348,17262,24,18,30,FR,France +199339,3,14783,11173,18393,26,20,32,FR,France +199338,3,10492,7329,13655,18,12,24,FR,France +199337,3,7023,4503,9543,12,8,16,FR,France +199336,3,4361,2445,6277,8,5,11,FR,France +199335,3,5589,3066,8112,10,6,14,FR,France +199334,3,2984,1209,4759,5,2,8,FR,France +199333,3,3217,758,5676,6,2,10,FR,France +199332,3,3755,1051,6459,7,2,12,FR,France +199331,3,4163,1768,6558,7,3,11,FR,France +199330,3,4055,1907,6203,7,3,11,FR,France +199329,3,3714,1668,5760,6,2,10,FR,France +199328,3,1774,484,3064,3,1,5,FR,France +199327,3,2574,918,4230,4,1,7,FR,France +199326,3,3048,1450,4646,5,2,8,FR,France +199325,3,8348,5260,11436,15,10,20,FR,France +199324,3,6624,3747,9501,12,7,17,FR,France +199323,3,7424,4302,10546,13,8,18,FR,France +199322,3,3432,1849,5015,6,3,9,FR,France +199321,3,5942,3670,8214,10,6,14,FR,France +199320,3,5137,3157,7117,9,6,12,FR,France +199319,3,4593,2725,6461,8,5,11,FR,France +199318,3,5027,3075,6979,9,6,12,FR,France +199317,3,8111,5138,11084,14,9,19,FR,France +199316,3,24932,19468,30396,43,33,53,FR,France +199315,3,22181,17147,27215,39,30,48,FR,France +199314,3,38266,30865,45667,67,54,80,FR,France +199313,3,62987,54506,71468,110,95,125,FR,France +199312,3,63493,55956,71030,111,98,124,FR,France +199311,3,80548,72628,88468,140,126,154,FR,France +199310,3,127910,117688,138132,223,205,241,FR,France +199309,3,184150,171378,196922,321,299,343,FR,France +199308,3,222932,209051,236813,389,365,413,FR,France +199307,3,248494,234936,262052,433,409,457,FR,France +199306,3,286939,271830,302048,500,474,526,FR,France +199305,3,255890,241516,270264,446,421,471,FR,France +199304,3,193107,181261,204953,337,316,358,FR,France +199303,3,147854,137256,158452,258,240,276,FR,France +199302,3,90269,82164,98374,157,143,171,FR,France +199301,3,75288,67244,83332,131,117,145,FR,France +199253,3,56622,49107,64137,99,86,112,FR,France +199252,3,49588,42568,56608,87,75,99,FR,France +199251,3,41156,35024,47288,72,61,83,FR,France +199250,3,40100,34699,45501,70,61,79,FR,France +199249,3,39146,33847,44445,69,60,78,FR,France +199248,3,32392,27499,37285,57,48,66,FR,France +199247,3,26276,21797,30755,46,38,54,FR,France +199246,3,22758,18462,27054,40,32,48,FR,France +199245,3,22023,17804,26242,39,32,46,FR,France +199244,3,27619,22945,32293,48,40,56,FR,France +199243,3,24969,20704,29234,44,37,51,FR,France +199242,3,29980,25261,34699,52,44,60,FR,France +199241,3,24091,19953,28229,42,35,49,FR,France +199240,3,17593,13885,21301,31,25,37,FR,France +199239,3,13535,10301,16769,24,18,30,FR,France +199238,3,9837,7106,12568,17,12,22,FR,France +199237,3,7480,5130,9830,13,9,17,FR,France +199236,3,5155,2958,7352,9,5,13,FR,France +199235,3,6383,3687,9079,11,6,16,FR,France +199234,3,2953,922,4984,5,1,9,FR,France +199233,3,4046,1549,6543,7,3,11,FR,France +199232,3,4963,2215,7711,9,4,14,FR,France +199231,3,4233,1733,6733,7,3,11,FR,France +199230,3,3091,1145,5037,5,2,8,FR,France +199229,3,3586,1583,5589,6,2,10,FR,France +199228,3,4179,2133,6225,7,3,11,FR,France +199227,3,5568,3134,8002,10,6,14,FR,France +199226,3,5886,3229,8543,10,5,15,FR,France +199225,3,5304,2805,7803,9,5,13,FR,France +199224,3,5928,3482,8374,10,6,14,FR,France +199223,3,3914,1855,5973,7,3,11,FR,France +199222,3,4899,2641,7157,9,5,13,FR,France +199221,3,5059,2889,7229,9,5,13,FR,France +199220,3,4308,2226,6390,8,4,12,FR,France +199219,3,2982,1181,4783,5,2,8,FR,France +199218,3,3887,1777,5997,7,3,11,FR,France +199217,3,3614,1216,6012,6,2,10,FR,France +199216,3,5460,2934,7986,10,6,14,FR,France +199215,3,8642,5029,12255,15,9,21,FR,France +199214,3,11346,7536,15156,20,13,27,FR,France +199213,3,11693,8096,15290,20,14,26,FR,France +199212,3,11752,7834,15670,21,14,28,FR,France +199211,3,11689,7575,15803,20,13,27,FR,France +199210,3,19224,12971,25477,34,23,45,FR,France +199209,3,26629,20275,32983,47,36,58,FR,France +199208,3,37667,30887,44447,66,54,78,FR,France +199207,3,57312,48777,65847,100,85,115,FR,France +199206,3,112450,99989,124911,197,175,219,FR,France +199205,3,165474,151342,179606,290,265,315,FR,France +199204,3,147959,133595,162323,259,234,284,FR,France +199203,3,137893,122944,152842,241,215,267,FR,France +199202,3,185852,166558,205146,325,291,359,FR,France +199201,3,247688,222574,272802,434,390,478,FR,France +199152,3,349815,325499,374131,615,572,658,FR,France +199151,3,378413,355928,400898,666,626,706,FR,France +199150,3,198721,182878,214564,350,322,378,FR,France +199149,3,93903,82992,104814,165,146,184,FR,France +199148,3,45173,37384,52962,79,65,93,FR,France +199147,3,35691,28224,43158,63,50,76,FR,France +199146,3,23685,17531,29839,42,31,53,FR,France +199145,3,19565,13551,25579,34,23,45,FR,France +199144,3,21571,15477,27665,38,27,49,FR,France +199143,3,28842,21958,35726,51,39,63,FR,France +199142,3,27483,20385,34581,48,36,60,FR,France +199141,3,28185,20655,35715,50,37,63,FR,France +199140,3,26740,16049,37431,47,28,66,FR,France +199139,3,14373,8734,20012,25,15,35,FR,France +199138,3,7460,3700,11220,13,6,20,FR,France +199137,3,2429,434,4424,4,0,8,FR,France +199136,3,2380,0,4882,4,0,8,FR,France +199135,3,2372,0,5025,4,0,9,FR,France +199134,3,2099,0,5104,4,0,9,FR,France +199133,3,1654,0,4102,3,0,7,FR,France +199132,3,625,0,2190,1,0,4,FR,France +199131,3,2464,0,5830,4,0,10,FR,France +199130,3,2382,0,6857,4,0,12,FR,France +199129,3,3837,40,7634,7,0,14,FR,France +199128,3,3297,152,6442,6,0,12,FR,France +199127,3,3164,934,5394,6,2,10,FR,France +199126,3,6376,3324,9428,11,6,16,FR,France +199125,3,8218,4776,11660,14,8,20,FR,France +199124,3,8223,4660,11786,14,8,20,FR,France +199123,3,6801,3596,10006,12,6,18,FR,France +199122,3,6050,2682,9418,11,5,17,FR,France +199121,3,6391,3385,9397,11,6,16,FR,France +199120,3,8633,4683,12583,15,8,22,FR,France +199119,3,7785,3986,11584,14,7,21,FR,France +199118,3,10856,6457,15255,19,11,27,FR,France +199117,3,15603,10950,20256,27,19,35,FR,France +199116,3,15665,11184,20146,28,20,36,FR,France +199115,3,15062,10715,19409,26,18,34,FR,France +199114,3,27862,21583,34141,49,38,60,FR,France +199113,3,32179,25829,38529,57,46,68,FR,France +199112,3,27873,22312,33434,49,39,59,FR,France +199111,3,46186,38876,53496,81,68,94,FR,France +199110,3,88750,77784,99716,156,137,175,FR,France +199109,3,139093,124326,153860,245,219,271,FR,France +199108,3,216369,198630,234108,381,350,412,FR,France +199107,3,208836,191789,225883,367,337,397,FR,France +199106,3,134737,121280,148194,237,213,261,FR,France +199105,3,73564,62716,84412,129,110,148,FR,France +199104,3,48253,39031,57475,85,69,101,FR,France +199103,3,29382,22258,36506,52,39,65,FR,France +199102,3,29759,22044,37474,52,38,66,FR,France +199101,3,42927,33706,52148,76,60,92,FR,France +199052,3,41262,31607,50917,73,56,90,FR,France +199051,3,46924,37544,56304,83,66,100,FR,France +199050,3,44125,36137,52113,78,64,92,FR,France +199049,3,38379,30603,46155,68,54,82,FR,France +199048,3,29571,22315,36827,52,39,65,FR,France +199047,3,23358,15890,30826,41,28,54,FR,France +199046,3,20246,7930,32562,36,14,58,FR,France +199045,3,17571,11591,23551,31,20,42,FR,France +199044,3,16182,10305,22059,29,19,39,FR,France +199043,3,17579,11588,23570,31,20,42,FR,France +199042,3,13011,7875,18147,23,14,32,FR,France +199041,3,19723,13330,26116,35,24,46,FR,France +199040,3,20433,14614,26252,36,26,46,FR,France +199039,3,15618,10315,20921,28,19,37,FR,France +199038,3,11146,6197,16095,20,11,29,FR,France +199037,3,4051,1022,7080,7,2,12,FR,France +199036,3,2542,124,4960,4,0,8,FR,France +199035,3,934,0,2681,2,0,5,FR,France +199034,3,201,0,595,0,0,1,FR,France +199033,3,0,0,0,0,0,0,FR,France +199032,3,1399,0,3849,2,0,6,FR,France +199031,3,881,0,2206,2,0,4,FR,France +199030,3,425,0,1262,1,0,2,FR,France +199029,3,1077,0,2643,2,0,5,FR,France +199028,3,959,0,2252,2,0,4,FR,France +199027,3,2948,793,5103,5,1,9,FR,France +199026,3,7236,2651,11821,13,5,21,FR,France +199025,3,7879,3136,12622,14,6,22,FR,France +199024,3,5727,2460,8994,10,4,16,FR,France +199023,3,3655,1043,6267,6,1,11,FR,France +199022,3,4196,1292,7100,7,2,12,FR,France +199021,3,1004,0,2367,2,0,4,FR,France +199020,3,4506,1771,7241,8,3,13,FR,France +199019,3,5897,2440,9354,10,4,16,FR,France +199018,3,1738,141,3335,3,0,6,FR,France +199017,3,5278,2197,8359,9,4,14,FR,France +199016,3,8129,3754,12504,14,6,22,FR,France +199015,3,11707,5831,17583,21,11,31,FR,France +199014,3,12862,8177,17547,23,15,31,FR,France +199013,3,21879,15088,28670,39,27,51,FR,France +199012,3,17035,11135,22935,30,20,40,FR,France +199011,3,20018,14311,25725,35,25,45,FR,France +199010,3,16294,11045,21543,29,20,38,FR,France +199009,3,21793,15460,28126,39,28,50,FR,France +199008,3,26110,19342,32878,46,34,58,FR,France +199007,3,61742,49720,73764,109,88,130,FR,France +199006,3,399984,353345,446623,707,625,789,FR,France +199005,3,161765,146354,177176,286,259,313,FR,France +199004,3,287771,267698,307844,509,474,544,FR,France +199003,3,315466,296550,334382,558,525,591,FR,France +199002,3,345060,326087,364033,610,576,644,FR,France +199001,3,483600,460913,506287,855,815,895,FR,France +198952,3,581149,556023,606275,1035,990,1080,FR,France +198951,3,821540,793846,849234,1463,1414,1512,FR,France +198950,3,749283,723633,774933,1334,1288,1380,FR,France +198949,3,358043,340053,376033,638,606,670,FR,France +198948,3,119087,108253,129921,212,193,231,FR,France +198947,3,40963,33897,48029,73,60,86,FR,France +198946,3,23547,17952,29142,42,32,52,FR,France +198945,3,22711,16999,28423,40,30,50,FR,France +198944,3,23405,17475,29335,42,31,53,FR,France +198943,3,29549,23287,35811,53,42,64,FR,France +198942,3,39410,32172,46648,70,57,83,FR,France +198941,3,43763,35245,52281,78,63,93,FR,France +198940,3,31453,24288,38618,56,43,69,FR,France +198939,3,24622,18425,30819,44,33,55,FR,France +198938,3,18296,13483,23109,33,24,42,FR,France +198937,3,12022,8082,15962,21,14,28,FR,France +198936,3,4769,2299,7239,8,4,12,FR,France +198935,3,4661,1696,7626,8,3,13,FR,France +198934,3,6039,2185,9893,11,4,18,FR,France +198933,3,7940,3858,12022,14,7,21,FR,France +198932,3,7114,2361,11867,13,5,21,FR,France +198931,3,2721,0,5478,5,0,10,FR,France +198930,3,3168,561,5775,6,1,11,FR,France +198929,3,3909,1504,6314,7,3,11,FR,France +198928,3,1284,105,2463,2,0,4,FR,France +198927,3,3641,1350,5932,6,2,10,FR,France +198926,3,5753,2885,8621,10,5,15,FR,France +198925,3,6299,3454,9144,11,6,16,FR,France +198924,3,6337,3537,9137,11,6,16,FR,France +198923,3,11779,7984,15574,21,14,28,FR,France +198922,3,9104,4764,13444,16,8,24,FR,France +198921,3,9554,4316,14792,17,8,26,FR,France +198920,3,6093,1023,11163,11,2,20,FR,France +198919,3,0,,,0,,,FR,France +198918,3,13452,1365,25539,24,2,46,FR,France +198917,3,10949,7147,14751,19,12,26,FR,France +198916,3,10908,7494,14322,19,13,25,FR,France +198915,3,9667,6209,13125,17,11,23,FR,France +198914,3,15230,10469,19991,27,19,35,FR,France +198913,3,10564,6767,14361,19,12,26,FR,France +198912,3,13419,9542,17296,24,17,31,FR,France +198911,3,16633,12140,21126,30,22,38,FR,France +198910,3,12387,8750,16024,22,16,28,FR,France +198909,3,12895,9183,16607,23,16,30,FR,France +198908,3,19746,15258,24234,35,27,43,FR,France +198907,3,27277,21760,32794,49,39,59,FR,France +198906,3,47844,40320,55368,85,72,98,FR,France +198905,3,52840,45665,60015,94,81,107,FR,France +198904,3,54942,47750,62134,98,85,111,FR,France +198903,3,66010,58065,73955,118,104,132,FR,France +198902,3,112284,102003,122565,200,182,218,FR,France +198901,3,202266,188305,216227,360,335,385,FR,France +198852,3,467971,447033,488909,837,800,874,FR,France +198851,3,872748,846468,899028,1562,1515,1609,FR,France +198850,3,1001824,974799,1028849,1793,1745,1841,FR,France +198849,3,966523,940068,992978,1729,1682,1776,FR,France +198848,3,637811,614785,660837,1141,1100,1182,FR,France +198847,3,246062,231234,260890,440,413,467,FR,France +198846,3,92484,83160,101808,165,148,182,FR,France +198845,3,53940,46148,61732,97,83,111,FR,France +198844,3,42106,35336,48876,75,63,87,FR,France +198843,3,38252,31909,44595,68,57,79,FR,France +198842,3,45495,38467,52523,81,68,94,FR,France +198841,3,46336,39344,53328,83,70,96,FR,France +198840,3,39882,33507,46257,71,60,82,FR,France +198839,3,43730,36755,50705,78,66,90,FR,France +198838,3,35243,29367,41119,63,52,74,FR,France +198837,3,15537,11911,19163,28,22,34,FR,France +198836,3,7539,4840,10238,13,8,18,FR,France +198835,3,7797,4762,10832,14,9,19,FR,France +198834,3,4950,2005,7895,9,4,14,FR,France +198833,3,7937,3861,12013,14,7,21,FR,France +198832,3,7033,2595,11471,13,5,21,FR,France +198831,3,8758,3591,13925,16,7,25,FR,France +198830,3,4205,1224,7186,8,3,13,FR,France +198829,3,6103,1013,11193,11,2,20,FR,France +198828,3,8562,3483,13641,15,6,24,FR,France +198827,3,4690,2196,7184,8,4,12,FR,France +198826,3,7065,3905,10225,13,7,19,FR,France +198825,3,7657,4664,10650,14,9,19,FR,France +198824,3,6676,3978,9374,12,7,17,FR,France +198823,3,8695,5755,11635,16,11,21,FR,France +198822,3,11566,8282,14850,21,15,27,FR,France +198821,3,11107,7742,14472,20,14,26,FR,France +198820,3,14118,10223,18013,25,18,32,FR,France +198819,3,18260,13847,22673,33,25,41,FR,France +198818,3,20415,16281,24549,37,30,44,FR,France +198817,3,21750,17436,26064,39,31,47,FR,France +198816,3,33730,27496,39964,60,49,71,FR,France +198815,3,70616,61754,79478,126,110,142,FR,France +198814,3,123868,113211,134525,222,203,241,FR,France +198813,3,193710,181519,205901,347,325,369,FR,France +198812,3,283445,268834,298056,507,481,533,FR,France +198811,3,316175,300858,331492,566,539,593,FR,France +198810,3,235142,222004,248280,421,397,445,FR,France +198809,3,135564,125263,145865,243,225,261,FR,France +198808,3,87753,78449,97057,157,140,174,FR,France +198807,3,77099,68423,85775,138,122,154,FR,France +198806,3,69349,61502,77196,124,110,138,FR,France +198805,3,72705,64952,80458,130,116,144,FR,France +198804,3,72818,64944,80692,130,116,144,FR,France +198803,3,68869,60922,76816,123,109,137,FR,France +198802,3,59743,51907,67579,107,93,121,FR,France +198801,3,60929,52573,69285,109,94,124,FR,France +198753,3,47257,38170,56344,85,69,101,FR,France +198752,3,11935,2353,21517,21,4,38,FR,France +198751,3,47744,34266,61222,86,62,110,FR,France +198750,3,57767,50181,65353,104,90,118,FR,France +198749,3,49380,42461,56299,89,77,101,FR,France +198748,3,41871,35115,48627,75,63,87,FR,France +198747,3,29688,23465,35911,53,42,64,FR,France +198746,3,37216,30199,44233,67,54,80,FR,France +198745,3,35456,29024,41888,64,52,76,FR,France +198744,3,41024,33829,48219,74,61,87,FR,France +198743,3,46356,38370,54342,83,69,97,FR,France +198742,3,38021,30236,45806,68,54,82,FR,France +198741,3,42021,32016,52026,76,58,94,FR,France +198740,3,24641,15930,33352,44,28,60,FR,France +198739,3,32328,23548,41108,58,42,74,FR,France +198738,3,16782,11870,21694,30,21,39,FR,France +198737,3,11208,6542,15874,20,12,28,FR,France +198736,3,7906,4014,11798,14,7,21,FR,France +198735,3,6149,2970,9328,11,5,17,FR,France +198734,3,6631,2734,10528,12,5,19,FR,France +198733,3,6404,1834,10974,12,4,20,FR,France +198732,3,7215,2353,12077,13,4,22,FR,France +198731,3,8233,3655,12811,15,7,23,FR,France +198730,3,4642,1301,7983,8,2,14,FR,France +198729,3,4389,913,7865,8,2,14,FR,France +198728,3,2702,138,5266,5,0,10,FR,France +198727,3,10171,5904,14438,18,10,26,FR,France +198726,3,12341,7824,16858,22,14,30,FR,France +198725,3,23413,15490,31336,42,28,56,FR,France +198724,3,11289,7282,15296,20,13,27,FR,France +198723,3,15857,10943,20771,29,20,38,FR,France +198722,3,14887,9743,20031,27,18,36,FR,France +198721,3,17619,12649,22589,32,23,41,FR,France +198720,3,10344,6454,14234,19,12,26,FR,France +198719,3,12539,7943,17135,23,15,31,FR,France +198718,3,16095,10330,21860,29,19,39,FR,France +198717,3,21256,14850,27662,38,26,50,FR,France +198716,3,32416,25100,39732,58,45,71,FR,France +198715,3,44292,36456,52128,80,66,94,FR,France +198714,3,50642,41866,59418,91,75,107,FR,France +198713,3,62246,52749,71743,112,95,129,FR,France +198712,3,59625,50653,68597,107,91,123,FR,France +198711,3,53561,45035,62087,96,81,111,FR,France +198710,3,93067,80519,105615,167,144,190,FR,France +198709,3,147006,133519,160493,264,240,288,FR,France +198708,3,217779,202179,233379,391,363,419,FR,France +198707,3,288180,270718,305642,518,487,549,FR,France +198706,3,296702,279051,314353,533,501,565,FR,France +198705,3,236046,219483,252609,424,394,454,FR,France +198704,3,158333,143625,173041,285,259,311,FR,France +198703,3,103841,91699,115983,187,165,209,FR,France +198702,3,74213,64014,84412,133,115,151,FR,France +198701,3,69745,59207,80283,125,106,144,FR,France +198652,3,76263,64958,87568,138,118,158,FR,France +198651,3,72920,63047,82793,132,114,150,FR,France +198650,3,73413,64019,82807,133,116,150,FR,France +198649,3,56296,48229,64363,102,87,117,FR,France +198648,3,46031,38578,53484,83,70,96,FR,France +198647,3,36740,29710,43770,66,53,79,FR,France +198646,3,32134,25327,38941,58,46,70,FR,France +198645,3,38964,31382,46546,70,56,84,FR,France +198644,3,28646,22048,35244,52,40,64,FR,France +198643,3,27532,20842,34222,50,38,62,FR,France +198642,3,31815,25124,38506,57,45,69,FR,France +198641,3,32864,25939,39789,59,47,71,FR,France +198640,3,33516,26776,40256,60,48,72,FR,France +198639,3,28665,22477,34853,52,41,63,FR,France +198638,3,26615,20479,32751,48,37,59,FR,France +198637,3,15998,10802,21194,29,20,38,FR,France +198636,3,9182,4982,13382,17,9,25,FR,France +198635,3,10587,4470,16704,19,8,30,FR,France +198634,3,5762,858,10666,10,1,19,FR,France +198633,3,3115,554,5676,6,1,11,FR,France +198632,3,1027,0,2311,2,0,4,FR,France +198631,3,2247,0,4574,4,0,8,FR,France +198630,3,2346,141,4551,4,0,8,FR,France +198629,3,3654,931,6377,7,2,12,FR,France +198628,3,2327,0,5318,4,0,9,FR,France +198627,3,7529,3353,11705,14,6,22,FR,France +198626,3,8778,5106,12450,16,9,23,FR,France +198625,3,11075,6804,15346,20,12,28,FR,France +198624,3,11160,7252,15068,20,13,27,FR,France +198623,3,14372,9896,18848,26,18,34,FR,France +198622,3,9717,5594,13840,18,11,25,FR,France +198621,3,14460,9575,19345,26,17,35,FR,France +198620,3,17133,12106,22160,31,22,40,FR,France +198619,3,22177,16008,28346,40,29,51,FR,France +198618,3,31736,24115,39357,57,43,71,FR,France +198617,3,34874,27440,42308,63,50,76,FR,France +198616,3,41196,32894,49498,74,59,89,FR,France +198615,3,42659,33537,51781,77,61,93,FR,France +198614,3,49792,39728,59856,90,72,108,FR,France +198613,3,87249,63562,110936,157,114,200,FR,France +198612,3,124777,97237,152317,225,175,275,FR,France +198611,3,168146,151035,185257,303,272,334,FR,France +198610,3,257305,231225,283385,464,417,511,FR,France +198609,3,321140,296644,345636,580,536,624,FR,France +198608,3,448786,419219,478353,810,757,863,FR,France +198607,3,490723,460150,521296,886,831,941,FR,France +198606,3,439300,411764,466836,793,743,843,FR,France +198605,3,364727,339868,389586,658,613,703,FR,France +198604,3,348509,322464,374554,629,582,676,FR,France +198603,3,271539,248654,294424,490,449,531,FR,France +198602,3,178138,159344,196932,322,288,356,FR,France +198601,3,112614,96539,128689,203,174,232,FR,France +198552,3,86452,72250,100654,157,131,183,FR,France +198551,3,114666,99538,129794,208,181,235,FR,France +198550,3,86031,73604,98458,156,133,179,FR,France +198549,3,65931,55326,76536,120,101,139,FR,France +198548,3,68291,57581,79001,124,105,143,FR,France +198547,3,66177,55221,77133,120,100,140,FR,France +198546,3,70534,58788,82280,128,107,149,FR,France +198545,3,57514,47167,67861,104,85,123,FR,France +198544,3,67356,55744,78968,122,101,143,FR,France +198543,3,87402,74208,100596,158,134,182,FR,France +198542,3,76218,64604,87832,138,117,159,FR,France +198541,3,45712,36755,54669,83,67,99,FR,France +198540,3,49739,40335,59143,90,73,107,FR,France +198539,3,39819,31234,48404,72,56,88,FR,France +198538,3,27605,20614,34596,50,37,63,FR,France +198537,3,22219,15626,28812,40,28,52,FR,France +198536,3,27986,18992,36980,51,35,67,FR,France +198535,3,30215,18546,41884,55,34,76,FR,France +198534,3,40389,24786,55992,73,45,101,FR,France +198533,3,22611,8819,36403,41,16,66,FR,France +198532,3,7488,1851,13125,14,4,24,FR,France +198531,3,16958,8479,25437,31,16,46,FR,France +198530,3,11598,5507,17689,21,10,32,FR,France +198529,3,13054,6474,19634,24,12,36,FR,France +198528,3,14588,7659,21517,26,13,39,FR,France +198527,3,19670,11761,27579,36,22,50,FR,France +198526,3,18609,12637,24581,34,23,45,FR,France +198525,3,19362,12454,26270,35,22,48,FR,France +198524,3,19855,13577,26133,36,25,47,FR,France +198523,3,19373,10010,28736,35,18,52,FR,France +198522,3,24099,17190,31008,44,31,57,FR,France +198521,3,26096,19621,32571,47,35,59,FR,France +198520,3,27896,20885,34907,51,38,64,FR,France +198519,3,43154,32821,53487,78,59,97,FR,France +198518,3,40555,29935,51175,74,55,93,FR,France +198517,3,34053,24366,43740,62,44,80,FR,France +198516,3,50362,36451,64273,91,66,116,FR,France +198515,3,63881,45538,82224,116,83,149,FR,France +198514,3,134545,114400,154690,244,207,281,FR,France +198513,3,197206,176080,218332,357,319,395,FR,France +198512,3,245240,223304,267176,445,405,485,FR,France +198511,3,276205,252399,300011,501,458,544,FR,France +198510,3,353231,326279,380183,640,591,689,FR,France +198509,3,369895,341109,398681,670,618,722,FR,France +198508,3,389886,359529,420243,707,652,762,FR,France +198507,3,471852,432599,511105,855,784,926,FR,France +198506,3,565825,518011,613639,1026,939,1113,FR,France +198505,3,637302,592795,681809,1155,1074,1236,FR,France +198504,3,424937,390794,459080,770,708,832,FR,France +198503,3,213901,174689,253113,388,317,459,FR,France +198502,3,97586,80949,114223,177,147,207,FR,France +198501,3,85489,65918,105060,155,120,190,FR,France +198452,3,84830,60602,109058,154,110,198,FR,France +198451,3,101726,80242,123210,185,146,224,FR,France +198450,3,123680,101401,145959,225,184,266,FR,France +198449,3,101073,81684,120462,184,149,219,FR,France +198448,3,78620,60634,96606,143,110,176,FR,France +198447,3,72029,54274,89784,131,99,163,FR,France +198446,3,87330,67686,106974,159,123,195,FR,France +198445,3,135223,101414,169032,246,184,308,FR,France +198444,3,68422,20056,116788,125,37,213,FR,France
