ec6c2d38b7cace4ce8fa0c82ca665c1e
d72c0a95
d72c0a95
Exercice 3 final
fa8ff059
31 additions
81 deletions
+31
-81
exercice_python_fr.org
module2/exo3/exercice_python_fr.org
+31
-81
d72c0a95
#+TITLE:
Votre titr
e
#+AUTHOR:
Votre nom
#+DATE:
La date du jour
#+TITLE:
Réaliser un affichage graphiqu
e
#+AUTHOR:
GNIBGA Wedan Emmnanuel
#+DATE:
08/12/2021
* Quelques explications
document.
print("Hello world!")
#+begin_src emacs-lisp :results silent :exports none
(org-babel-do-load-languages
'org-babel-load-languages
'((python .t)))
(setq org-babel-python-command "python3")
: Hello world!
~C-c C-c~).
import numpy
x=numpy.linspace(-15,15)
print(x)
#+begin_src python :results silent :session :exports results
plt.figure(figsize=(10,5))
plt.plot(x,numpy.cos(x)/x)
plt.tight_layout()
arr = [ 14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1,
7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3,
11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1,
4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7,
17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5,
16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8,
14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4,
16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0 ]
fig1=plt.figure()
plt.plot(arr)
plt.grid(True, linestyle='dotted', color='black')
fig1.savefig("./plot.png")
fig2=plt.figure()
plt.hist(arr,"auto",facecolor='b', edgecolor='black', linewidth=1)
plt.grid(True,linestyle='dotted',color='black')
fig2.savefig("./histogram.png")
[[file:./cosxsx.png]]
compréhensible sur GitLab.
[[file:./plot.png]]
[[file:./histogram.png]]
