Commit aa0ca19b authored by Nicolas CAZAYOUS's avatar Nicolas CAZAYOUS
pushable
parent 4f60af95
#+TITLE: À propos du calcul de \pi #+TITLE: À propos du calcul de \pi
#+AUTHOR: Konrad Hinsen #+AUTHOR: Konrad Hinsen
#+DATE: <2025-03-12 mer.> #+DATE: <2019-03-28 Thu 11:06>
#+LANGUAGE: fr #+LANGUAGE: fr
#+OPTIONS: toc:t num:t
#+PROPERTY: header-args :eval never-export #+PROPERTY: header-args :eval never-export
#+PROPERTY: header-args :exports both
#+PROPERTY: header-args :session session
#+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/htmlize.css"/> #+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/htmlize.css"/>
#+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/readtheorg.css"/> #+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/readtheorg.css"/>
...@@ -11,100 +14,11 @@ ...@@ -11,100 +14,11 @@
#+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/lib/js/jquery.stickytableheaders.js"></script> #+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/lib/js/jquery.stickytableheaders.js"></script>
#+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/readtheorg/js/readtheorg.js"></script> #+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/readtheorg/js/readtheorg.js"></script>
* Quelques explications
document.
print("Hello world!")
: Hello world!
~C-c C-c~).
import numpy
x=numpy.linspace(-15,15)
print(x)
plt.figure(figsize=(10,5))
plt.plot(x,numpy.cos(x)/x)
plt.tight_layout()
[[file:./cosxsx.png]]
compréhensible sur GitLab.
* TODO avant d'exporter
- [ ] supprimer le titre d'explications
- [ ] enlever les print()
- [ ] changer la date Created: 2019-03-28 Thu 11:06
- [ ] la question de [[http://validator.w3.org/check?uri=referer][Validate]]
- [ ] commit et push le plot
* En demandant à la lib maths * En demandant à la lib maths
Mon ordinateur m'indique que \pi vaut /approximativement/: Mon ordinateur m'indique que \pi vaut /approximativement/:
#+BEGIN_SRC python :results output :exports both :session ma-session #+BEGIN_SRC python
from math import * from math import *
pi pi
print(pi)
#+END_SRC #+END_SRC
#+RESULTS: #+RESULTS:
...@@ -112,21 +26,21 @@ print(pi) ...@@ -112,21 +26,21 @@ print(pi)
* En utilisant la méthode des aiguilles de Buffon * En utilisant la méthode des aiguilles de Buffon
Mais calculé avec la *méthode* des [[https://fr.wikipedia.org/wiki/Aiguille_de_Buffon][aiguilles de Buffon]], on obtiendrait comme *approximation* : Mais calculé avec la *méthode* des [[https://fr.wikipedia.org/wiki/Aiguille_de_Buffon][aiguilles de Buffon]], on obtiendrait comme *approximation* :
import numpy as np import numpy as np
np.random.seed(seed=42) np.random.seed(seed=42)
N = 10000 N = 10000
x = np.random.uniform(size=N, low=0, high=1) x = np.random.uniform(size=N, low=0, high=1)
theta = np.random.uniform(size=N, low=0, high=pi/2) theta = np.random.uniform(size=N, low=0, high=pi/2)
print(2/(sum((x+np.sin(theta))>1)/N)) 2/(sum((x+np.sin(theta))>1)/N)
#+END_SRC #+END_SRC
: 3.128911138923655 : 3.128911138923655
* Avec un argument "fréquentiel" de surface * Avec un argument "fréquentiel" de surface
Sinon, une méthode plus simple à comprendre et ne faisant pas intervenir d'appel à la fonction sinus se base sur le fait que si \(X \sim U(0,1)) et \(Y \sim U(0,1)) alors \(P[X²+Y²\leq1]=\pi/4) (voir [[https://fr.wikipedia.org/wiki/M%C3%A9thode_de_Monte-Carlo#D%C3%A9termination_de_la_valeur_de_%CF%80][méthode de Monte Carlo sur Wikipedia]]). Le code suivant illustre ce fait : Sinon, une méthode plus simple à comprendre et ne faisant pas intervenir d'appel à la fonction sinus se base sur le fait que si \(X \sim U(0,1)\) et \(Y \sim U(0,1)\) alors \(P[X²+Y²\leq1]=\pi/4\) (voir [[https://fr.wikipedia.org/wiki/M%C3%A9thode_de_Monte-Carlo#D%C3%A9termination_de_la_valeur_de_%CF%80][méthode de Monte Carlo sur Wikipedia]]). Le code suivant illustre ce fait :
#+BEGIN_SRC python :results output :exports both :session ma-session #+BEGIN_SRC python :results file output :var matplot_lib_filename=(org-babel-temp-file "figure" ".png")
import matplotlib.pyplot as plt import matplotlib.pyplot as plt
...@@ -147,9 +61,14 @@ print(matplot_lib_filename) ...@@ -147,9 +61,14 @@ print(matplot_lib_filename)
#+END_SRC #+END_SRC
[[file:/tmp/babel-3yj5Cw/figureMmK9Ox.png]]
Il est alors aisé d'obtenir une approximation (pas terrible) de \pi en comptant combien de fois, en moyenne, =insérer formule de maths= est inférieur à 1 :
#+BEGIN_SRC python :results output :exports both Il est alors aisé d'obtenir une approximation (pas terrible) de \pi en comptant combien de fois, en moyenne, \(X^{2} + Y^{2}\) est inférieur à 1 :
#+BEGIN_SRC python
4*np.mean(accept) 4*np.mean(accept)
#+END_SRC #+END_SRC
: 3.112
