Update exercice_fr.Rmd 3
parent 781aa9c5
...@@ -10,27 +10,6 @@ output: html_document ...@@ -10,27 +10,6 @@ output: html_document
## Quelques explications
```{r pressure, echo=FALSE}
plot(pressure)
```{r, echo=FALSE} ```{r, echo=FALSE}
