Exercice2
parent 77955e6a
"cells": [],
"cells": [
"execution_count": 2,
"La moyenne : 14.113000000000001\n",
"Le minimum : 2.8\n",
"Le maximum : 23.4\n",
"La médiane : 14.5\n",
"L'écart type : 4.334094455301447\n"
"import numpy as st\n",
"from scipy import stats\n",
"liste = [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]\n",
"moyenne = st.mean(liste)\n",
"minimum = st.amin(liste)\n",
"maximum = st.amax(liste)\n",
"mediane = st.median(liste)\n",
"ecart = st.std(liste, ddof=1)\n",
"print(\"La moyenne : \", moyenne)\n",
"print(\"Le minimum : \", minimum)\n",
"print(\"Le maximum : \", maximum)\n",
"print(\"La médiane : \",mediane)\n",
"print(\"L'écart type : \",ecart)"
"execution_count": null,
"source": []
"kernelspec": {
"display_name": "Python 3",
......@@ -16,10 +62,9 @@
"name": "python",
"pygments_lexer": "ipython3",
"version": "3.6.3"
"version": "3.6.4"
"nbformat": 4,
"nbformat_minor": 2
