Update toy_document_orgmode_R_en.org
parent 6d66cb65
#+TITLE: Your title
#+AUTHOR: Your name
#+DATE: Today's date
# -*- coding: utf-8 -*-
#+TITLE: On the computation of pi
#+AUTHOR: Jessica Dagostini
#+HTML_HEAD: <link rel="stylesheet" title="Standard" href="http://orgmode.org/worg/style/worg.css" type="text/css" />
#+STARTUP: overview indent inlineimages logdrawer
#+LANGUAGE: en
* Some explanations
https://orgmode.org/guide/.
Like we showed in the video, R code is included as follows (and is
exxecuted by typing ~C-c C-c~):
print("Hello world!")
#+EXPORT_SELECT_TAGS: Blog
#+OPTIONS: H:2 num:t toc:t \n:nil @:t ::t |:t ^:t -:t f:t *:t <:t
#+OPTIONS: TeX:t LaTeX:nil skip:nil d:nil todo:t pri:nil tags:not-in-toc
* Table of Contents
- [[Asking the maths library][1. Asking the maths library]]
- [[Buffon's needle][2. Buffon's needle]]
- [[Using a surface fraction argument][3. Using a surface frcation argument]]
* Asking the maths library
My computer tells me that \pi is /approximatively/
pi
: [1] "Hello world!"
And now the same but in an R session. This is the most frequent
situation, because R is really an interactive language. With a
session, R's state, i.e. the values of all the variables, remains
persistent from one code block to the next. The code is still executed
using ~C-c C-c~.
: [1] 3.141593
* Buffon's needle
Applying the method of [[https://en.wikipedia.org/wiki/Buffon's_needle_problem][Buffon's needle]], we get the *aprproximation*
set.seed(42)
N = 100000
x = runif(N)
theta = pi/2*runif(N)
2/(mean(x+sin(theta)>1))
: speed dist
: Min. : 4.0 Min. : 2.00
: 1st Qu.:12.0 1st Qu.: 26.00
: Median :15.0 Median : 36.00
: Mean :15.4 Mean : 42.98
: 3rd Qu.:19.0 3rd Qu.: 56.00
: Max. :25.0 Max. :120.00
plot(cars)
: [1] 3.14327
* Using a surface fraction argument
A method that is easier to understand and does not make use of the sin
function is based on the fact that if $X ∼ U(0,1)$ and $Y ~ U(0,1)$,
then $P[X^2 + Y^2 \leq 1] = \pi/4$ (see [[https://en.wikipedia.org/wiki/Monte_Carlo_method]["Monte Carlo method" on
Wikipedia]]). The following code uses this approach:
#+begin_src R :results output graphics :file (org-babel-temp-file "figure" ".png") :exports both :width 600 :height 400 :session *R*
set.seed(42)
N = 1000
library(ggplot2)
[[file:./cars.png]]
transparent and reproducible.
the org document. It's a plain file, here named ~cars.png~. You have
understandable on GitLab.
[[file:/tmp/babel-12624X4Q/figure12624Gry.png]]
quickly create code blocks in R by typing ~<r~ or ~<R~ followed by
~Tab~.
It is then straightforward to obtain a (not really good) approximation
to \pi by counting how many times, on average, $X² + Y²$ is smaller then
1:
4*mean(df$Accept)
: [1] 3.156
