@@ -34,8 +39,7 @@
@@ -34,8 +39,7 @@
"## Buffon’s needle\n",
"Applying the method of [Buffon’s needle](https://en.wikipedia.org/wiki/Buffon%27s_needle_problem), we get the __approximation__"
"Applying the method of [Buffon’s needle](https://en.wikipedia.org/wiki/Buffon%27s_needle_problem), we get the **approximation**"
@@ -68,9 +72,7 @@
@@ -68,9 +72,7 @@
"A method that is easier to understand and does not make use of the sin function is based on the fact that if $X \\sim U(0, 1)$ and $Y \\sim U(0, 1)$, then $P[X^2 + Y^2 \\le 1] = \\pi/4$ (see [\"Monte Carlo method\" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:"
"A method that is easier to understand and does not make use of the sin function is based on the fact that if $X \\sim U(0, 1)$ and $Y \\sim U(0, 1)$, then $P[X^2 + Y^2 \\le 1] = \\pi/4$ (see [\"Monte Carlo method\"\n",
"on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:"
@@ -113,8 +115,7 @@
@@ -113,8 +115,7 @@
"It is then straightforward to obtain a (not really good) approximation to $\\pi$ by counting how\n",
"It is then straightforward to obtain a (not really good) approximation to $\\pi$ by counting how many times, on average, $X^2 + Y^2$ is smaller than 1:"
"many times, on average, $X^2 + Y^2$ is smaller than 1:"
