@@ -26,11 +26,15 @@ if sys.version_info.major < 3 or sys.version_info.minor < 6:
print("Please use Python 3.6 (or higher)!")
#+END_SRC
#+END_SRC
#+BEGIN_SRC emacs-lisp :results output
(unless (featurep 'ob-python)
(print "Please activate python in org-babel (org-babel-do-languages)!"))
#+END_SRC
#+END_SRC
** R 3.4
** R 3.4
We use only basic R functionality, so a earlier version might be OK, but we did not test this.
@@ -39,6 +43,8 @@ We use only basic R functionality, so a earlier version might be OK, but we did
(print "Please activate R in org-babel (org-babel-do-languages)!"))
#+END_SRC
#+END_SRC
* Data preprocessing
The data on the incidence of influenza-like illness are available from the Web site of the [[http://www.sentiweb.fr/][Réseau Sentinelles]]. We download them as a file in CSV format, in which each line corresponds to a week in the observation period. Only the complete dataset, starting in 1984 and ending with a recent week, is available for download. The URL is:
| ~week~ | ISO8601 Yearweek number as numeric (year*100 + week nubmer) |
| ~indicator~ | Unique identifier of the indicator, see metadata document https://www.sentiweb.fr/meta.json |
| ~inc~ | Estimated incidence value for the time step, in the geographic level |
@@ -62,14 +68,29 @@ This is the documentation of the data from [[https://ns.sentiweb.fr/incidence/cs
The [[https://en.wikipedia.org/wiki/ISO_8601][ISO-8601]] format is popular in Europe, but less so in North America. This may explain why few software packages handle this format. The Python language does it since version 3.6. We therefore use Python for the pre-processing phase, which has the advantage of not requiring any additional library. (Note: we will explain in module 4 why it is desirable for reproducibility to use as few external libraries as possible.)
** Download
** Getting the data
First we import the data used for our computational document into Org. We check for the existence of an ~incidence.csv~ file in the same directory and download it from Sentinel if it does not exist.
After downloading the raw data, we extract the part we are interested in. We first split the file into lines, of which we discard the first one that contains a comment. We then split the remaining lines into columns.
Unfortunately there are many ways to indicate the absence of a data value in a dataset. Here we check for a common one: empty fields. For completeness, we should also look for non-numerical data in numerical columns. We don't do this here, but checks in later processing steps would catch such anomalies.
There are only two columns that we will need for our analysis: the first (~"week"~) and the third (~"inc"~). We check the names in the header to be sure we pick the right data. We make a new table containing just the two columns required, without the header.
#+BEGIN_SRC python :results silent
@@ -100,7 +131,7 @@ week = [row[0] for row in valid_table]
assert week[0] == 'week'
del week[0]
del week[0]
inc = [row[2] for row in valid_table]
assert inc[0] == 'inc
assert inc[0] == 'inc'
del inc[0]
del inc[0]
data = list(zip(week, inc))
#+END_SRC
#+END_SRC
@@ -110,6 +141,21 @@ Let's look at the first and last lines. We insert ~None~ to indicate to org-mode
It is always prudent to verify if the data looks credible. A simple fact we can check for is that weeks are given as six-digit integers (four for the year, two for the week), and that the incidence values are positive integers.
#+BEGIN_SRC python :results output
@@ -120,6 +166,8 @@ for week, inc in data:
print("Suspicious value in column 'inc': ", (week, inc))
#+END_SRC
#+END_SRC
No problem - fine!
No problem - fine!
** Date conversion
** Date conversion
@@ -139,6 +187,21 @@ str_data = [(str(date), str(inc)) for date, inc in converted_data]
