Update exercice_fr.Rmd
parent 6f161f73
title: "Votre titre"
author: "Votre nom"
date: "La date du jour"
title: "Exercice 2"
author: "C. Haldin"
date: "16/9/21"
output: html_document
```{r setup, include=FALSE}
## Quelques explications
## Création du vecteur des données
```{r }
data <- c(14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8,
10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4,
17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3,
14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1,
13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1,
19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7,
16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7,
10.2, 8.9, 21.0)
```{r pressure, echo=FALSE}
plot(pressure)
## Quelques stats simples
```{r }
install.packages("prettyR")
library("prettyR")
describe(data, num.desc=c("mean","sd","min","max","median"))
