f5c490e9182da42b1c30e92aadd353a4
2801306f
2801306f
Alexandre Jesus
Code for exercise 2
bacfb8ae
34 additions
73 deletions
+34
-73
exercice_R_en.org
module2/exo2/exercice_R_en.org
+34
-73
2801306f
#+TITLE: Your title
#+AUTHOR: Your name
#+DATE: Today's date
#+TITLE: Exercise 2
#+LANGUAGE: en
* Doing some calculations
* Some explanations
First we put the dataset in variable
https://orgmode.org/guide/.
Like we showed in the video, R code is included as follows (and is
exxecuted by typing ~C-c C-c~):
print("Hello world!")
: [1] "Hello world!"
And now the same but in an R session. This is the most frequent
situation, because R is really an interactive language. With a
session, R's state, i.e. the values of all the variables, remains
persistent from one code block to the next. The code is still executed
using ~C-c C-c~.
#+BEGIN_SRC R :results output :exports both :session *R*
x <- c(14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0)
x
#+END_SRC
: speed dist
: Min. : 4.0 Min. : 2.00
: 1st Qu.:12.0 1st Qu.: 26.00
: Median :15.0 Median : 36.00
: Mean :15.4 Mean : 42.98
: 3rd Qu.:19.0 3rd Qu.: 56.00
: Max. :25.0 Max. :120.00
plot(cars)
: [1] 14.0 7.6 11.2 12.8 12.5 9.9 14.9 9.4 16.9 10.2 14.9 18.1 7.3 9.8 10.9
: [16] 12.2 9.9 2.9 2.8 15.4 15.7 9.7 13.1 13.2 12.3 11.7 16.0 12.4 17.9 12.2
: [31] 16.2 18.7 8.9 11.9 12.1 14.6 12.1 4.7 3.9 16.9 16.8 11.3 14.4 15.7 14.0
: [46] 13.6 18.0 13.6 19.9 13.7 17.0 20.5 9.9 12.5 13.2 16.1 13.5 6.3 6.4 17.6
: [61] 19.1 12.8 15.5 16.3 15.2 14.6 19.1 14.4 21.4 15.1 19.6 21.7 11.3 15.0 14.3
: [76] 16.8 14.0 6.8 8.2 19.9 20.4 14.6 16.4 18.7 16.8 15.8 20.4 15.8 22.4 16.2
: [91] 20.3 23.4 12.1 15.5 15.4 18.4 15.7 10.2 8.9 21.0
Now we calculate the required values
round(mean(x), 2)
round(min(x), 2)
round(max(x), 2)
round(median(x), 2)
round(sd(x), 2)
#+END_SRC
[[file:./cars.png]]
transparent and reproducible.
the org document. It's a plain file, here named ~cars.png~. You have
understandable on GitLab.
quickly create code blocks in R by typing ~<r~ or ~<R~ followed by
~Tab~.
: [1] 14.11
: [1] 2.8
: [1] 23.4
: [1] 14.5
: [1] 4.33
