diff --git a/module3/exo3/exercice.ipynb b/module3/exo3/exercice.ipynb index ff8b5f16dc505a03321fcbd87c115b0d28e1b63b..9f9884b822ffe7c11dd1efd3ed8c1f97e4dc1353 100644 --- a/module3/exo3/exercice.ipynb +++ b/module3/exo3/exercice.ipynb @@ -9,7 +9,7 @@ }, { "cell_type": "code", - "execution_count": 17, + "execution_count": 1, "metadata": {}, "outputs": [], "source": [ @@ -21,7 +21,7 @@ }, { "cell_type": "code", - "execution_count": 18, + "execution_count": 2, "metadata": {}, "outputs": [], "source": [ @@ -30,7 +30,7 @@ }, { "cell_type": "code", - "execution_count": 19, + "execution_count": 3, "metadata": {}, "outputs": [], "source": [ @@ -44,7 +44,7 @@ }, { "cell_type": "code", - "execution_count": 20, + "execution_count": 4, "metadata": {}, "outputs": [ { @@ -54,7 +54,7 @@ "traceback": [ "\u001b[0;31m---------------------------------------------------------------------------\u001b[0m", "\u001b[0;31mParserError\u001b[0m Traceback (most recent call last)", - "\u001b[0;32m\u001b[0m in \u001b[0;36m\u001b[0;34m\u001b[0m\n\u001b[0;32m----> 1\u001b[0;31m \u001b[0mraw_data\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mpd\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread_csv\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mdata_file\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mskiprows\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;36m1\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 2\u001b[0m \u001b[0mraw_data\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32m\u001b[0m in \u001b[0;36m\u001b[0;34m\u001b[0m\n\u001b[0;32m----> 1\u001b[0;31m \u001b[0mraw_data\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mpd\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread_csv\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mdata_file\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mskiprows\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;36m1\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 2\u001b[0m \u001b[0mraw_data\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36mparser_f\u001b[0;34m(filepath_or_buffer, sep, delimiter, header, names, index_col, usecols, squeeze, prefix, mangle_dupe_cols, dtype, engine, converters, true_values, false_values, skipinitialspace, skiprows, nrows, na_values, keep_default_na, na_filter, verbose, skip_blank_lines, parse_dates, infer_datetime_format, keep_date_col, date_parser, dayfirst, iterator, chunksize, compression, thousands, decimal, lineterminator, quotechar, quoting, escapechar, comment, encoding, dialect, tupleize_cols, error_bad_lines, warn_bad_lines, skipfooter, skip_footer, doublequote, delim_whitespace, as_recarray, compact_ints, use_unsigned, low_memory, buffer_lines, memory_map, float_precision)\u001b[0m\n\u001b[1;32m 707\u001b[0m skip_blank_lines=skip_blank_lines)\n\u001b[1;32m 708\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 709\u001b[0;31m \u001b[0;32mreturn\u001b[0m \u001b[0m_read\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mfilepath_or_buffer\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mkwds\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 710\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 711\u001b[0m \u001b[0mparser_f\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m__name__\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mname\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36m_read\u001b[0;34m(filepath_or_buffer, kwds)\u001b[0m\n\u001b[1;32m 453\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 454\u001b[0m \u001b[0;32mtry\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 455\u001b[0;31m \u001b[0mdata\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mparser\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mnrows\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 456\u001b[0m \u001b[0;32mfinally\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 457\u001b[0m \u001b[0mparser\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mclose\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36mread\u001b[0;34m(self, nrows)\u001b[0m\n\u001b[1;32m 1067\u001b[0m \u001b[0;32mraise\u001b[0m \u001b[0mValueError\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m'skipfooter not supported for iteration'\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1068\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m-> 1069\u001b[0;31m \u001b[0mret\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_engine\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mnrows\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 1070\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1071\u001b[0m \u001b[0;32mif\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0moptions\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mget\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m'as_recarray'\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", @@ -75,10 +75,299 @@ }, { "cell_type": "code", - "execution_count": null, + "execution_count": 14, "metadata": {}, - "outputs": [], - "source": [] + "outputs": [ + { + "ename": "ParserError", + "evalue": "Error tokenizing data. C error: Expected 1 fields in line 33, saw 4\n", + "output_type": "error", + "traceback": [ + "\u001b[0;31m---------------------------------------------------------------------------\u001b[0m", + "\u001b[0;31mParserError\u001b[0m Traceback (most recent call last)", + "\u001b[0;32m\u001b[0m in \u001b[0;36m\u001b[0;34m\u001b[0m\n\u001b[0;32m----> 1\u001b[0;31m \u001b[0mraw_data\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mpd\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread_csv\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mdata_file\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 2\u001b[0m \u001b[0mraw_data\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36mparser_f\u001b[0;34m(filepath_or_buffer, sep, delimiter, header, names, index_col, usecols, squeeze, prefix, mangle_dupe_cols, dtype, engine, converters, true_values, false_values, skipinitialspace, skiprows, nrows, na_values, keep_default_na, na_filter, verbose, skip_blank_lines, parse_dates, infer_datetime_format, keep_date_col, date_parser, dayfirst, iterator, chunksize, compression, thousands, decimal, lineterminator, quotechar, quoting, escapechar, comment, encoding, dialect, tupleize_cols, error_bad_lines, warn_bad_lines, skipfooter, skip_footer, doublequote, delim_whitespace, as_recarray, compact_ints, use_unsigned, low_memory, buffer_lines, memory_map, float_precision)\u001b[0m\n\u001b[1;32m 707\u001b[0m skip_blank_lines=skip_blank_lines)\n\u001b[1;32m 708\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 709\u001b[0;31m \u001b[0;32mreturn\u001b[0m \u001b[0m_read\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mfilepath_or_buffer\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mkwds\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 710\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 711\u001b[0m \u001b[0mparser_f\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m__name__\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mname\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36m_read\u001b[0;34m(filepath_or_buffer, kwds)\u001b[0m\n\u001b[1;32m 453\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 454\u001b[0m \u001b[0;32mtry\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 455\u001b[0;31m \u001b[0mdata\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mparser\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mnrows\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 456\u001b[0m \u001b[0;32mfinally\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 457\u001b[0m \u001b[0mparser\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mclose\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36mread\u001b[0;34m(self, nrows)\u001b[0m\n\u001b[1;32m 1067\u001b[0m \u001b[0;32mraise\u001b[0m \u001b[0mValueError\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m'skipfooter not supported for iteration'\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1068\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m-> 1069\u001b[0;31m \u001b[0mret\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_engine\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mnrows\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 1070\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1071\u001b[0m \u001b[0;32mif\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0moptions\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mget\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m'as_recarray'\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36mread\u001b[0;34m(self, nrows)\u001b[0m\n\u001b[1;32m 1837\u001b[0m \u001b[0;32mdef\u001b[0m \u001b[0mread\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mself\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mnrows\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;32mNone\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1838\u001b[0m \u001b[0;32mtry\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m-> 1839\u001b[0;31m \u001b[0mdata\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_reader\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mnrows\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 1840\u001b[0m \u001b[0;32mexcept\u001b[0m \u001b[0mStopIteration\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1841\u001b[0m \u001b[0;32mif\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_first_chunk\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32mpandas/_libs/parsers.pyx\u001b[0m in \u001b[0;36mpandas._libs.parsers.TextReader.read\u001b[0;34m()\u001b[0m\n", + "\u001b[0;32mpandas/_libs/parsers.pyx\u001b[0m in \u001b[0;36mpandas._libs.parsers.TextReader._read_low_memory\u001b[0;34m()\u001b[0m\n", + "\u001b[0;32mpandas/_libs/parsers.pyx\u001b[0m in \u001b[0;36mpandas._libs.parsers.TextReader._read_rows\u001b[0;34m()\u001b[0m\n", + "\u001b[0;32mpandas/_libs/parsers.pyx\u001b[0m in \u001b[0;36mpandas._libs.parsers.TextReader._tokenize_rows\u001b[0;34m()\u001b[0m\n", + "\u001b[0;32mpandas/_libs/parsers.pyx\u001b[0m in \u001b[0;36mpandas._libs.parsers.raise_parser_error\u001b[0;34m()\u001b[0m\n", + "\u001b[0;31mParserError\u001b[0m: Error tokenizing data. C error: Expected 1 fields in line 33, saw 4\n" + ] + } + ], + "source": [ + "raw_data = pd.read_csv(data_file)\n", + "raw_data" + ] + }, + { + "cell_type": "code", + "execution_count": 15, + "metadata": {}, + "outputs": [ + { + "name": "stderr", + "output_type": "stream", + "text": [ + "b'Skipping line 33: expected 1 fields, saw 4\\nSkipping line 45: expected 1 fields, saw 2\\nSkipping line 46: expected 1 fields, saw 2\\nSkipping line 47: expected 1 fields, saw 2\\nSkipping line 48: expected 1 fields, saw 2\\nSkipping line 49: expected 1 fields, saw 2\\nSkipping line 50: expected 1 fields, saw 2\\nSkipping line 51: expected 1 fields, saw 2\\nSkipping line 52: expected 1 fields, saw 2\\nSkipping line 53: expected 1 fields, saw 2\\nSkipping line 54: expected 1 fields, saw 2\\nSkipping line 55: expected 1 fields, saw 2\\nSkipping line 56: expected 1 fields, saw 2\\nSkipping line 57: expected 1 fields, saw 2\\nSkipping line 58: expected 1 fields, saw 2\\nSkipping line 59: expected 1 fields, saw 2\\nSkipping line 60: expected 1 fields, saw 2\\nSkipping line 61: expected 1 fields, saw 2\\nSkipping line 62: expected 1 fields, saw 2\\nSkipping line 63: expected 1 fields, saw 2\\nSkipping line 64: expected 1 fields, saw 2\\nSkipping line 65: expected 1 fields, saw 2\\nSkipping line 66: expected 1 fields, saw 2\\nSkipping line 67: expected 1 fields, saw 2\\nSkipping line 68: expected 1 fields, saw 2\\nSkipping line 69: expected 1 fields, saw 2\\nSkipping line 70: expected 1 fields, saw 2\\nSkipping line 71: expected 1 fields, saw 2\\nSkipping line 72: expected 1 fields, saw 2\\nSkipping line 73: expected 1 fields, saw 2\\nSkipping line 74: expected 1 fields, saw 2\\nSkipping line 75: expected 1 fields, saw 2\\nSkipping line 76: expected 1 fields, saw 2\\nSkipping line 77: expected 1 fields, saw 2\\nSkipping line 78: expected 1 fields, saw 2\\nSkipping line 79: expected 1 fields, saw 2\\nSkipping line 80: expected 1 fields, saw 2\\nSkipping line 81: expected 1 fields, saw 2\\nSkipping line 82: expected 1 fields, saw 2\\nSkipping line 83: expected 1 fields, saw 2\\nSkipping line 84: expected 1 fields, saw 2\\nSkipping line 85: expected 1 fields, saw 2\\nSkipping line 86: expected 1 fields, saw 2\\nSkipping line 87: expected 1 fields, saw 2\\nSkipping line 88: expected 1 fields, saw 2\\nSkipping line 89: expected 1 fields, saw 2\\nSkipping line 90: expected 1 fields, saw 2\\nSkipping line 91: expected 1 fields, saw 2\\nSkipping line 92: expected 1 fields, saw 2\\nSkipping line 93: expected 1 fields, saw 2\\nSkipping line 94: expected 1 fields, saw 2\\nSkipping line 95: expected 1 fields, saw 2\\nSkipping line 96: expected 1 fields, saw 2\\nSkipping line 97: expected 1 fields, saw 2\\nSkipping line 98: expected 1 fields, saw 2\\nSkipping line 99: expected 1 fields, saw 2\\nSkipping line 100: expected 1 fields, saw 2\\nSkipping line 101: expected 1 fields, saw 2\\nSkipping line 102: expected 1 fields, saw 2\\nSkipping line 103: expected 1 fields, saw 2\\nSkipping line 104: expected 1 fields, saw 2\\nSkipping line 105: expected 1 fields, saw 2\\nSkipping line 106: expected 1 fields, saw 2\\nSkipping line 107: expected 1 fields, saw 2\\nSkipping line 108: expected 1 fields, saw 2\\nSkipping line 109: expected 1 fields, saw 2\\nSkipping line 110: expected 1 fields, saw 2\\nSkipping line 111: expected 1 fields, saw 2\\nSkipping line 112: expected 1 fields, saw 2\\nSkipping line 113: expected 1 fields, saw 2\\nSkipping line 114: expected 1 fields, saw 2\\nSkipping line 115: expected 1 fields, saw 2\\nSkipping line 116: expected 1 fields, saw 2\\nSkipping line 117: expected 1 fields, saw 2\\nSkipping line 118: expected 1 fields, saw 2\\nSkipping line 119: expected 1 fields, saw 2\\nSkipping line 120: expected 1 fields, saw 2\\nSkipping line 121: expected 1 fields, saw 2\\nSkipping line 122: expected 1 fields, saw 2\\nSkipping line 123: expected 1 fields, saw 2\\nSkipping line 124: expected 1 fields, saw 2\\nSkipping line 125: expected 1 fields, saw 2\\nSkipping line 126: expected 1 fields, saw 2\\nSkipping line 127: expected 1 fields, saw 2\\nSkipping line 128: expected 1 fields, saw 2\\nSkipping line 129: expected 1 fields, saw 2\\nSkipping line 130: expected 1 fields, saw 2\\nSkipping line 131: expected 1 fields, saw 2\\nSkipping line 132: expected 1 fields, saw 2\\nSkipping line 133: expected 1 fields, saw 2\\nSkipping line 134: expected 1 fields, saw 2\\nSkipping line 135: expected 1 fields, saw 2\\nSkipping line 136: expected 1 fields, saw 2\\nSkipping line 137: expected 1 fields, saw 2\\nSkipping line 138: expected 1 fields, saw 2\\nSkipping line 139: expected 1 fields, saw 2\\nSkipping line 140: expected 1 fields, saw 2\\nSkipping line 141: expected 1 fields, saw 2\\nSkipping line 142: expected 1 fields, saw 2\\nSkipping line 143: expected 1 fields, saw 2\\nSkipping line 144: expected 1 fields, saw 2\\nSkipping line 145: expected 1 fields, saw 2\\nSkipping line 146: expected 1 fields, saw 2\\nSkipping line 147: expected 1 fields, saw 2\\nSkipping line 148: expected 1 fields, saw 2\\nSkipping line 149: expected 1 fields, saw 2\\nSkipping line 150: expected 1 fields, saw 2\\nSkipping line 151: expected 1 fields, saw 2\\nSkipping line 152: expected 1 fields, saw 2\\nSkipping line 153: expected 1 fields, saw 2\\nSkipping line 154: expected 1 fields, saw 2\\nSkipping line 155: expected 1 fields, saw 2\\nSkipping line 156: expected 1 fields, saw 2\\nSkipping line 157: expected 1 fields, saw 2\\nSkipping line 158: expected 1 fields, saw 2\\nSkipping line 159: expected 1 fields, saw 2\\nSkipping line 160: expected 1 fields, saw 2\\nSkipping line 161: expected 1 fields, saw 2\\nSkipping line 162: expected 1 fields, saw 2\\nSkipping line 163: expected 1 fields, saw 2\\nSkipping line 164: expected 1 fields, saw 2\\nSkipping line 165: expected 1 fields, saw 2\\nSkipping line 166: expected 1 fields, saw 2\\nSkipping line 167: expected 1 fields, saw 2\\nSkipping line 168: expected 1 fields, saw 2\\nSkipping line 169: expected 1 fields, saw 2\\nSkipping line 170: expected 1 fields, saw 2\\nSkipping line 171: expected 1 fields, saw 2\\nSkipping line 172: expected 1 fields, saw 2\\nSkipping line 173: expected 1 fields, saw 2\\nSkipping line 174: expected 1 fields, saw 2\\nSkipping line 175: expected 1 fields, saw 2\\nSkipping line 176: expected 1 fields, saw 2\\nSkipping line 177: expected 1 fields, saw 2\\nSkipping line 178: expected 1 fields, saw 2\\nSkipping line 179: expected 1 fields, saw 2\\nSkipping line 180: expected 1 fields, saw 2\\nSkipping line 181: expected 1 fields, saw 2\\nSkipping line 182: expected 1 fields, saw 2\\nSkipping line 183: expected 1 fields, saw 2\\nSkipping line 184: expected 1 fields, saw 2\\nSkipping line 185: expected 1 fields, saw 2\\nSkipping line 186: expected 1 fields, saw 2\\nSkipping line 187: expected 1 fields, saw 2\\nSkipping line 188: expected 1 fields, saw 2\\nSkipping line 189: expected 1 fields, saw 2\\nSkipping line 190: expected 1 fields, saw 2\\nSkipping line 191: expected 1 fields, saw 2\\nSkipping line 192: expected 1 fields, saw 2\\nSkipping line 193: expected 1 fields, saw 2\\nSkipping line 194: expected 1 fields, saw 2\\nSkipping line 195: expected 1 fields, saw 2\\nSkipping line 196: expected 1 fields, saw 2\\nSkipping line 197: expected 1 fields, saw 2\\nSkipping line 198: expected 1 fields, saw 2\\nSkipping line 199: expected 1 fields, saw 2\\nSkipping line 200: expected 1 fields, saw 2\\nSkipping line 201: expected 1 fields, saw 2\\nSkipping line 202: expected 1 fields, saw 2\\nSkipping line 203: expected 1 fields, saw 2\\nSkipping line 204: expected 1 fields, saw 2\\nSkipping line 205: expected 1 fields, saw 2\\nSkipping line 206: expected 1 fields, saw 2\\nSkipping line 207: expected 1 fields, saw 2\\nSkipping line 208: expected 1 fields, saw 2\\nSkipping line 209: expected 1 fields, saw 2\\nSkipping line 210: expected 1 fields, saw 2\\nSkipping line 211: expected 1 fields, saw 2\\nSkipping line 212: expected 1 fields, saw 2\\nSkipping line 213: expected 1 fields, saw 2\\nSkipping line 214: expected 1 fields, saw 2\\nSkipping line 215: expected 1 fields, saw 2\\nSkipping line 216: expected 1 fields, saw 2\\nSkipping line 217: expected 1 fields, saw 2\\nSkipping line 218: expected 1 fields, saw 2\\nSkipping line 219: expected 1 fields, saw 2\\nSkipping line 220: expected 1 fields, saw 2\\nSkipping line 221: expected 1 fields, saw 2\\nSkipping line 222: expected 1 fields, saw 2\\nSkipping line 223: expected 1 fields, saw 2\\nSkipping line 224: expected 1 fields, saw 2\\nSkipping line 225: expected 1 fields, saw 2\\nSkipping line 226: expected 1 fields, saw 2\\nSkipping line 227: expected 1 fields, saw 2\\nSkipping line 228: expected 1 fields, saw 2\\nSkipping line 229: expected 1 fields, saw 2\\nSkipping line 230: expected 1 fields, saw 2\\nSkipping line 231: expected 1 fields, saw 2\\nSkipping line 232: expected 1 fields, saw 2\\nSkipping line 233: expected 1 fields, saw 2\\nSkipping line 234: expected 1 fields, saw 2\\nSkipping line 235: expected 1 fields, saw 2\\nSkipping line 236: expected 1 fields, saw 2\\nSkipping line 237: expected 1 fields, saw 2\\nSkipping line 238: expected 1 fields, saw 2\\nSkipping line 239: expected 1 fields, saw 2\\nSkipping line 240: expected 1 fields, saw 2\\nSkipping line 241: expected 1 fields, saw 2\\nSkipping line 242: expected 1 fields, saw 2\\nSkipping line 243: expected 1 fields, saw 2\\nSkipping line 244: expected 1 fields, saw 2\\nSkipping line 245: expected 1 fields, saw 2\\nSkipping line 246: expected 1 fields, saw 2\\nSkipping line 247: expected 1 fields, saw 2\\nSkipping line 248: expected 1 fields, saw 2\\nSkipping line 249: expected 1 fields, saw 2\\nSkipping line 250: expected 1 fields, saw 2\\nSkipping line 251: expected 1 fields, saw 2\\nSkipping line 252: expected 1 fields, saw 2\\nSkipping line 253: expected 1 fields, saw 2\\nSkipping line 254: expected 1 fields, saw 2\\nSkipping line 255: expected 1 fields, saw 2\\nSkipping line 256: expected 1 fields, saw 2\\nSkipping line 257: expected 1 fields, saw 2\\nSkipping line 258: expected 1 fields, saw 2\\nSkipping line 259: expected 1 fields, saw 2\\nSkipping line 260: expected 1 fields, saw 2\\nSkipping line 261: expected 1 fields, saw 2\\nSkipping line 262: expected 1 fields, saw 2\\nSkipping line 263: expected 1 fields, saw 2\\nSkipping line 264: expected 1 fields, saw 2\\nSkipping line 265: expected 1 fields, saw 2\\nSkipping line 266: expected 1 fields, saw 2\\nSkipping line 267: expected 1 fields, saw 2\\nSkipping line 268: expected 1 fields, saw 2\\nSkipping line 269: expected 1 fields, saw 2\\nSkipping line 270: expected 1 fields, saw 2\\nSkipping line 271: expected 1 fields, saw 2\\nSkipping line 272: expected 1 fields, saw 2\\nSkipping line 273: expected 1 fields, saw 2\\nSkipping line 274: expected 1 fields, saw 2\\nSkipping line 275: expected 1 fields, saw 2\\nSkipping line 276: expected 1 fields, saw 2\\nSkipping line 277: expected 1 fields, saw 2\\nSkipping line 278: expected 1 fields, saw 2\\nSkipping line 279: expected 1 fields, saw 2\\nSkipping line 280: expected 1 fields, saw 2\\nSkipping line 281: expected 1 fields, saw 2\\nSkipping line 282: expected 1 fields, saw 2\\nSkipping line 283: expected 1 fields, saw 2\\nSkipping line 284: expected 1 fields, saw 2\\nSkipping line 285: expected 1 fields, saw 2\\nSkipping line 286: expected 1 fields, saw 2\\nSkipping line 287: expected 1 fields, saw 2\\nSkipping line 288: expected 1 fields, saw 2\\nSkipping line 289: expected 1 fields, saw 2\\nSkipping line 290: expected 1 fields, saw 2\\nSkipping line 291: expected 1 fields, saw 2\\nSkipping line 292: expected 1 fields, saw 2\\nSkipping line 293: expected 1 fields, saw 2\\nSkipping line 294: expected 1 fields, saw 2\\nSkipping line 295: expected 1 fields, saw 2\\nSkipping line 296: expected 1 fields, saw 2\\nSkipping line 297: expected 1 fields, saw 2\\nSkipping line 298: expected 1 fields, saw 2\\nSkipping line 299: expected 1 fields, saw 2\\nSkipping line 300: expected 1 fields, saw 2\\nSkipping line 301: expected 1 fields, saw 2\\nSkipping line 302: expected 1 fields, saw 2\\nSkipping line 303: expected 1 fields, saw 2\\nSkipping line 304: expected 1 fields, saw 2\\nSkipping line 305: expected 1 fields, saw 2\\nSkipping line 306: expected 1 fields, saw 2\\nSkipping line 307: expected 1 fields, saw 2\\nSkipping line 308: expected 1 fields, saw 2\\nSkipping line 309: expected 1 fields, saw 2\\nSkipping line 310: expected 1 fields, saw 2\\nSkipping line 311: expected 1 fields, saw 2\\nSkipping line 312: expected 1 fields, saw 2\\nSkipping line 313: expected 1 fields, saw 2\\nSkipping line 314: expected 1 fields, saw 2\\nSkipping line 315: expected 1 fields, saw 2\\nSkipping line 316: expected 1 fields, saw 2\\nSkipping line 317: expected 1 fields, saw 2\\nSkipping line 318: expected 1 fields, saw 2\\nSkipping line 319: expected 1 fields, saw 2\\nSkipping line 320: expected 1 fields, saw 2\\nSkipping line 321: expected 1 fields, saw 2\\nSkipping line 322: expected 1 fields, saw 2\\nSkipping line 323: expected 1 fields, saw 2\\nSkipping line 324: expected 1 fields, saw 2\\nSkipping line 325: expected 1 fields, saw 2\\nSkipping line 326: expected 1 fields, saw 2\\nSkipping line 327: expected 1 fields, saw 2\\nSkipping line 328: expected 1 fields, saw 2\\nSkipping line 329: expected 1 fields, saw 2\\nSkipping line 330: expected 1 fields, saw 2\\nSkipping line 331: expected 1 fields, saw 2\\nSkipping line 332: expected 1 fields, saw 2\\nSkipping line 333: expected 1 fields, saw 2\\nSkipping line 334: expected 1 fields, saw 2\\nSkipping line 335: expected 1 fields, saw 2\\nSkipping line 336: expected 1 fields, saw 2\\nSkipping line 337: expected 1 fields, saw 2\\nSkipping line 338: expected 1 fields, saw 2\\nSkipping line 339: expected 1 fields, saw 2\\nSkipping line 340: expected 1 fields, saw 2\\nSkipping line 341: expected 1 fields, saw 2\\nSkipping line 342: expected 1 fields, saw 2\\nSkipping line 343: expected 1 fields, saw 2\\nSkipping line 344: expected 1 fields, saw 2\\nSkipping line 345: expected 1 fields, saw 2\\nSkipping line 346: expected 1 fields, saw 2\\nSkipping line 347: expected 1 fields, saw 2\\nSkipping line 348: expected 1 fields, saw 2\\nSkipping line 349: expected 1 fields, saw 2\\nSkipping line 350: expected 1 fields, saw 2\\nSkipping line 351: expected 1 fields, saw 2\\nSkipping line 352: expected 1 fields, saw 2\\nSkipping line 353: expected 1 fields, saw 2\\nSkipping line 354: expected 1 fields, saw 2\\nSkipping line 355: expected 1 fields, saw 2\\nSkipping line 356: expected 1 fields, saw 2\\nSkipping line 357: expected 1 fields, saw 2\\nSkipping line 358: expected 1 fields, saw 2\\nSkipping line 359: expected 1 fields, saw 2\\nSkipping line 360: expected 1 fields, saw 2\\nSkipping line 361: expected 1 fields, saw 2\\nSkipping line 362: expected 1 fields, saw 2\\nSkipping line 363: expected 1 fields, saw 2\\nSkipping line 364: expected 1 fields, saw 2\\nSkipping line 365: expected 1 fields, saw 2\\nSkipping line 366: expected 1 fields, saw 2\\nSkipping line 367: expected 1 fields, saw 2\\nSkipping line 368: expected 1 fields, saw 2\\nSkipping line 369: expected 1 fields, saw 2\\nSkipping line 370: expected 1 fields, saw 2\\nSkipping line 371: expected 1 fields, saw 2\\nSkipping line 372: expected 1 fields, saw 2\\nSkipping line 373: expected 1 fields, saw 2\\nSkipping line 374: expected 1 fields, saw 2\\nSkipping line 375: expected 1 fields, saw 2\\nSkipping line 376: expected 1 fields, saw 2\\nSkipping line 377: expected 1 fields, saw 2\\nSkipping line 378: expected 1 fields, saw 2\\nSkipping line 379: expected 1 fields, saw 2\\nSkipping line 380: expected 1 fields, saw 2\\nSkipping line 381: expected 1 fields, saw 2\\nSkipping line 382: expected 1 fields, saw 2\\nSkipping line 383: expected 1 fields, saw 2\\nSkipping line 384: expected 1 fields, saw 2\\nSkipping line 385: expected 1 fields, saw 2\\nSkipping line 386: expected 1 fields, saw 2\\nSkipping line 387: expected 1 fields, saw 2\\nSkipping line 388: expected 1 fields, saw 2\\nSkipping line 389: expected 1 fields, saw 2\\nSkipping line 390: expected 1 fields, saw 2\\nSkipping line 391: expected 1 fields, saw 2\\nSkipping line 392: expected 1 fields, saw 2\\nSkipping line 393: expected 1 fields, saw 2\\nSkipping line 394: expected 1 fields, saw 2\\nSkipping line 395: expected 1 fields, saw 2\\nSkipping line 396: expected 1 fields, saw 2\\nSkipping line 397: expected 1 fields, saw 2\\nSkipping line 398: expected 1 fields, saw 2\\nSkipping line 399: expected 1 fields, saw 2\\nSkipping line 400: expected 1 fields, saw 2\\nSkipping line 401: expected 1 fields, saw 2\\nSkipping line 402: expected 1 fields, saw 2\\nSkipping line 403: expected 1 fields, saw 2\\nSkipping line 404: expected 1 fields, saw 2\\nSkipping line 405: expected 1 fields, saw 2\\nSkipping line 406: expected 1 fields, saw 2\\nSkipping line 407: expected 1 fields, saw 2\\nSkipping line 408: expected 1 fields, saw 2\\nSkipping line 409: expected 1 fields, saw 2\\nSkipping line 410: expected 1 fields, saw 2\\nSkipping line 411: expected 1 fields, saw 2\\nSkipping line 412: expected 1 fields, saw 2\\nSkipping line 413: expected 1 fields, saw 2\\nSkipping line 414: expected 1 fields, saw 2\\nSkipping line 415: expected 1 fields, saw 2\\nSkipping line 416: expected 1 fields, saw 2\\nSkipping line 417: expected 1 fields, saw 2\\nSkipping line 418: expected 1 fields, saw 2\\nSkipping line 419: expected 1 fields, saw 2\\nSkipping line 420: expected 1 fields, saw 2\\nSkipping line 421: expected 1 fields, saw 2\\nSkipping line 422: expected 1 fields, saw 2\\nSkipping line 423: expected 1 fields, saw 2\\nSkipping line 424: expected 1 fields, saw 2\\nSkipping line 425: expected 1 fields, saw 2\\nSkipping line 426: expected 1 fields, saw 2\\nSkipping line 427: expected 1 fields, saw 2\\nSkipping line 428: expected 1 fields, saw 2\\nSkipping line 429: expected 1 fields, saw 2\\nSkipping line 430: expected 1 fields, saw 2\\nSkipping line 431: expected 1 fields, saw 2\\nSkipping line 432: expected 1 fields, saw 2\\nSkipping line 433: expected 1 fields, saw 2\\nSkipping line 434: expected 1 fields, saw 2\\nSkipping line 435: expected 1 fields, saw 2\\nSkipping line 436: expected 1 fields, saw 2\\nSkipping line 437: expected 1 fields, saw 2\\nSkipping line 438: expected 1 fields, saw 2\\nSkipping line 439: expected 1 fields, saw 2\\nSkipping line 440: expected 1 fields, saw 2\\nSkipping line 441: expected 1 fields, saw 2\\nSkipping line 442: expected 1 fields, saw 2\\nSkipping line 443: expected 1 fields, saw 2\\nSkipping line 444: expected 1 fields, saw 2\\nSkipping line 445: expected 1 fields, saw 2\\nSkipping line 446: expected 1 fields, saw 2\\nSkipping line 447: expected 1 fields, saw 2\\nSkipping line 448: expected 1 fields, saw 2\\nSkipping line 449: expected 1 fields, saw 2\\nSkipping line 450: expected 1 fields, saw 2\\nSkipping line 451: expected 1 fields, saw 2\\nSkipping line 452: expected 1 fields, saw 2\\nSkipping line 453: expected 1 fields, saw 2\\nSkipping line 454: expected 1 fields, saw 2\\nSkipping line 455: expected 1 fields, saw 2\\nSkipping line 456: expected 1 fields, saw 2\\nSkipping line 457: expected 1 fields, saw 2\\nSkipping line 458: expected 1 fields, saw 2\\nSkipping line 459: expected 1 fields, saw 2\\nSkipping line 460: expected 1 fields, saw 2\\nSkipping line 461: expected 1 fields, saw 2\\nSkipping line 462: expected 1 fields, saw 2\\nSkipping line 463: expected 1 fields, saw 2\\nSkipping line 464: expected 1 fields, saw 2\\nSkipping line 465: expected 1 fields, saw 2\\nSkipping line 466: expected 1 fields, saw 2\\nSkipping line 467: expected 1 fields, saw 2\\nSkipping line 468: expected 1 fields, saw 2\\nSkipping line 469: expected 1 fields, saw 2\\nSkipping line 470: expected 1 fields, saw 2\\nSkipping line 471: expected 1 fields, saw 2\\nSkipping line 472: expected 1 fields, saw 2\\nSkipping line 473: expected 1 fields, saw 2\\nSkipping line 474: expected 1 fields, saw 2\\nSkipping line 475: expected 1 fields, saw 2\\nSkipping line 476: expected 1 fields, saw 2\\nSkipping line 477: expected 1 fields, saw 2\\nSkipping line 478: expected 1 fields, saw 2\\nSkipping line 479: expected 1 fields, saw 2\\nSkipping line 480: expected 1 fields, saw 2\\nSkipping line 481: expected 1 fields, saw 2\\nSkipping line 482: expected 1 fields, saw 2\\nSkipping line 483: expected 1 fields, saw 2\\nSkipping line 484: expected 1 fields, saw 2\\nSkipping line 485: expected 1 fields, saw 2\\nSkipping line 486: expected 1 fields, saw 2\\nSkipping line 487: expected 1 fields, saw 2\\nSkipping line 488: expected 1 fields, saw 2\\nSkipping line 489: expected 1 fields, saw 2\\nSkipping line 490: expected 1 fields, saw 2\\nSkipping line 491: expected 1 fields, saw 2\\nSkipping line 492: expected 1 fields, saw 2\\nSkipping line 493: expected 1 fields, saw 2\\nSkipping line 494: expected 1 fields, saw 2\\nSkipping line 495: expected 1 fields, saw 2\\nSkipping line 496: expected 1 fields, saw 2\\nSkipping line 497: expected 1 fields, saw 2\\nSkipping line 498: expected 1 fields, saw 2\\nSkipping line 499: expected 1 fields, saw 2\\nSkipping line 500: expected 1 fields, saw 2\\nSkipping line 501: expected 1 fields, saw 2\\nSkipping line 502: expected 1 fields, saw 2\\nSkipping line 503: expected 1 fields, saw 2\\nSkipping line 504: expected 1 fields, saw 2\\nSkipping line 505: expected 1 fields, saw 2\\nSkipping line 506: expected 1 fields, saw 2\\nSkipping line 507: expected 1 fields, saw 2\\nSkipping line 508: expected 1 fields, saw 2\\nSkipping line 509: expected 1 fields, saw 2\\nSkipping line 510: expected 1 fields, saw 2\\nSkipping line 511: expected 1 fields, saw 2\\nSkipping line 512: expected 1 fields, saw 2\\nSkipping line 513: expected 1 fields, saw 2\\nSkipping line 514: expected 1 fields, saw 2\\nSkipping line 515: expected 1 fields, saw 2\\nSkipping line 516: expected 1 fields, saw 2\\nSkipping line 517: expected 1 fields, saw 2\\nSkipping line 518: expected 1 fields, saw 2\\nSkipping line 519: expected 1 fields, saw 2\\nSkipping line 520: expected 1 fields, saw 2\\nSkipping line 521: expected 1 fields, saw 2\\nSkipping line 522: expected 1 fields, saw 2\\nSkipping line 523: expected 1 fields, saw 2\\nSkipping line 524: expected 1 fields, saw 2\\nSkipping line 525: expected 1 fields, saw 2\\nSkipping line 526: expected 1 fields, saw 2\\nSkipping line 527: expected 1 fields, saw 2\\nSkipping line 528: expected 1 fields, saw 2\\nSkipping line 529: expected 1 fields, saw 2\\nSkipping line 530: expected 1 fields, saw 2\\nSkipping line 531: expected 1 fields, saw 2\\nSkipping line 532: expected 1 fields, saw 2\\nSkipping line 533: expected 1 fields, saw 2\\nSkipping line 534: expected 1 fields, saw 2\\nSkipping line 535: expected 1 fields, saw 2\\nSkipping line 536: expected 1 fields, saw 2\\nSkipping line 537: expected 1 fields, saw 2\\nSkipping line 538: expected 1 fields, saw 2\\nSkipping line 539: expected 1 fields, saw 2\\nSkipping line 540: expected 1 fields, saw 2\\nSkipping line 541: expected 1 fields, saw 2\\nSkipping line 542: expected 1 fields, saw 2\\nSkipping line 543: expected 1 fields, saw 2\\nSkipping line 544: expected 1 fields, saw 2\\nSkipping line 545: expected 1 fields, saw 2\\nSkipping line 546: expected 1 fields, saw 2\\nSkipping line 547: expected 1 fields, saw 2\\nSkipping line 548: expected 1 fields, saw 2\\nSkipping line 549: expected 1 fields, saw 2\\nSkipping line 550: expected 1 fields, saw 2\\nSkipping line 551: expected 1 fields, saw 2\\nSkipping line 552: expected 1 fields, saw 2\\nSkipping line 553: expected 1 fields, saw 2\\nSkipping line 554: expected 1 fields, saw 2\\nSkipping line 555: expected 1 fields, saw 2\\nSkipping line 556: expected 1 fields, saw 2\\nSkipping line 557: expected 1 fields, saw 2\\nSkipping line 558: expected 1 fields, saw 2\\nSkipping line 559: expected 1 fields, saw 2\\nSkipping line 560: expected 1 fields, saw 2\\nSkipping line 561: expected 1 fields, saw 2\\nSkipping line 562: expected 1 fields, saw 2\\nSkipping line 563: expected 1 fields, saw 2\\nSkipping line 564: expected 1 fields, saw 2\\nSkipping line 565: expected 1 fields, saw 2\\nSkipping line 566: expected 1 fields, saw 2\\nSkipping line 567: expected 1 fields, saw 2\\nSkipping line 568: expected 1 fields, saw 2\\nSkipping line 569: expected 1 fields, saw 2\\nSkipping line 570: expected 1 fields, saw 2\\nSkipping line 571: expected 1 fields, saw 2\\nSkipping line 572: expected 1 fields, saw 2\\nSkipping line 573: expected 1 fields, saw 2\\nSkipping line 574: expected 1 fields, saw 2\\nSkipping line 575: expected 1 fields, saw 2\\nSkipping line 576: expected 1 fields, saw 2\\nSkipping line 577: expected 1 fields, saw 2\\nSkipping line 578: expected 1 fields, saw 2\\nSkipping line 579: expected 1 fields, saw 2\\nSkipping line 580: expected 1 fields, saw 2\\nSkipping line 581: expected 1 fields, saw 2\\nSkipping line 582: expected 1 fields, saw 2\\nSkipping line 583: expected 1 fields, saw 2\\nSkipping line 584: expected 1 fields, saw 2\\nSkipping line 585: expected 1 fields, saw 2\\nSkipping line 586: expected 1 fields, saw 2\\nSkipping line 587: expected 1 fields, saw 2\\nSkipping line 588: expected 1 fields, saw 2\\nSkipping line 589: expected 1 fields, saw 2\\nSkipping line 590: expected 1 fields, saw 2\\nSkipping line 591: expected 1 fields, saw 2\\nSkipping line 592: expected 1 fields, saw 2\\nSkipping line 593: expected 1 fields, saw 2\\nSkipping line 594: expected 1 fields, saw 2\\nSkipping line 595: expected 1 fields, saw 2\\nSkipping line 596: expected 1 fields, saw 2\\nSkipping line 597: expected 1 fields, saw 2\\nSkipping line 598: expected 1 fields, saw 2\\nSkipping line 599: expected 1 fields, saw 2\\nSkipping line 600: expected 1 fields, saw 2\\nSkipping line 601: expected 1 fields, saw 2\\nSkipping line 602: expected 1 fields, saw 2\\nSkipping line 603: expected 1 fields, saw 2\\nSkipping line 604: expected 1 fields, saw 2\\nSkipping line 605: expected 1 fields, saw 2\\nSkipping line 606: expected 1 fields, saw 2\\nSkipping line 607: expected 1 fields, saw 2\\nSkipping line 608: expected 1 fields, saw 2\\nSkipping line 609: expected 1 fields, saw 2\\nSkipping line 610: expected 1 fields, saw 2\\nSkipping line 611: expected 1 fields, saw 2\\nSkipping line 612: expected 1 fields, saw 2\\nSkipping line 613: expected 1 fields, saw 2\\nSkipping line 614: expected 1 fields, saw 2\\nSkipping line 615: expected 1 fields, saw 2\\nSkipping line 616: expected 1 fields, saw 2\\nSkipping line 617: expected 1 fields, saw 2\\nSkipping line 618: expected 1 fields, saw 2\\nSkipping line 619: expected 1 fields, saw 2\\nSkipping line 620: expected 1 fields, saw 2\\nSkipping line 621: expected 1 fields, saw 2\\nSkipping line 622: expected 1 fields, saw 2\\nSkipping line 623: expected 1 fields, saw 2\\nSkipping line 624: expected 1 fields, saw 2\\nSkipping line 625: expected 1 fields, saw 2\\nSkipping line 626: expected 1 fields, saw 2\\nSkipping line 627: expected 1 fields, saw 2\\nSkipping line 628: expected 1 fields, saw 2\\nSkipping line 629: expected 1 fields, saw 2\\nSkipping line 630: expected 1 fields, saw 2\\nSkipping line 631: expected 1 fields, saw 2\\nSkipping line 632: expected 1 fields, saw 2\\nSkipping line 633: expected 1 fields, saw 2\\nSkipping line 634: expected 1 fields, saw 2\\nSkipping line 635: expected 1 fields, saw 2\\nSkipping line 636: expected 1 fields, saw 2\\nSkipping line 637: expected 1 fields, saw 2\\nSkipping line 638: expected 1 fields, saw 2\\nSkipping line 639: expected 1 fields, saw 2\\nSkipping line 640: expected 1 fields, saw 2\\nSkipping line 641: expected 1 fields, saw 2\\nSkipping line 642: expected 1 fields, saw 2\\nSkipping line 643: expected 1 fields, saw 2\\nSkipping line 644: expected 1 fields, saw 2\\nSkipping line 645: expected 1 fields, saw 2\\nSkipping line 646: expected 1 fields, saw 2\\nSkipping line 647: expected 1 fields, saw 2\\nSkipping line 648: expected 1 fields, saw 2\\nSkipping line 649: expected 1 fields, saw 2\\nSkipping line 650: expected 1 fields, saw 2\\nSkipping line 651: expected 1 fields, saw 2\\nSkipping line 652: expected 1 fields, saw 2\\nSkipping line 653: expected 1 fields, saw 2\\nSkipping line 654: expected 1 fields, saw 2\\nSkipping line 655: expected 1 fields, saw 2\\nSkipping line 656: expected 1 fields, saw 2\\nSkipping line 657: expected 1 fields, saw 2\\nSkipping line 658: expected 1 fields, saw 2\\nSkipping line 659: expected 1 fields, saw 2\\nSkipping line 660: expected 1 fields, saw 2\\nSkipping line 661: expected 1 fields, saw 2\\nSkipping line 662: expected 1 fields, saw 2\\nSkipping line 663: expected 1 fields, saw 2\\nSkipping line 664: expected 1 fields, saw 2\\nSkipping line 665: expected 1 fields, saw 2\\nSkipping line 666: expected 1 fields, saw 2\\nSkipping line 667: expected 1 fields, saw 2\\nSkipping line 668: expected 1 fields, saw 2\\nSkipping line 669: expected 1 fields, saw 2\\nSkipping line 670: expected 1 fields, saw 2\\nSkipping line 671: expected 1 fields, saw 2\\nSkipping line 672: expected 1 fields, saw 2\\nSkipping line 673: expected 1 fields, saw 2\\nSkipping line 674: expected 1 fields, saw 2\\nSkipping line 675: expected 1 fields, saw 2\\nSkipping line 676: expected 1 fields, saw 2\\nSkipping line 677: expected 1 fields, saw 2\\nSkipping line 678: expected 1 fields, saw 2\\nSkipping line 679: expected 1 fields, saw 2\\nSkipping line 680: expected 1 fields, saw 2\\nSkipping line 681: expected 1 fields, saw 2\\nSkipping line 682: expected 1 fields, saw 2\\nSkipping line 683: expected 1 fields, saw 2\\nSkipping line 684: expected 1 fields, saw 2\\nSkipping line 685: expected 1 fields, saw 2\\nSkipping line 686: expected 1 fields, saw 2\\nSkipping line 687: expected 1 fields, saw 2\\nSkipping line 688: expected 1 fields, saw 2\\nSkipping line 689: expected 1 fields, saw 2\\nSkipping line 690: expected 1 fields, saw 2\\nSkipping line 691: expected 1 fields, saw 2\\nSkipping line 692: expected 1 fields, saw 2\\nSkipping line 693: expected 1 fields, saw 2\\nSkipping line 694: expected 1 fields, saw 2\\nSkipping line 695: expected 1 fields, saw 2\\nSkipping line 696: expected 1 fields, saw 2\\nSkipping line 697: expected 1 fields, saw 2\\nSkipping line 698: expected 1 fields, saw 2\\nSkipping line 699: expected 1 fields, saw 2\\nSkipping line 700: expected 1 fields, saw 2\\nSkipping line 701: expected 1 fields, saw 2\\nSkipping line 702: expected 1 fields, saw 2\\nSkipping line 703: expected 1 fields, saw 2\\nSkipping line 704: expected 1 fields, saw 2\\nSkipping line 705: expected 1 fields, saw 2\\nSkipping line 706: expected 1 fields, saw 2\\nSkipping line 707: expected 1 fields, saw 2\\nSkipping line 708: expected 1 fields, saw 2\\nSkipping line 709: expected 1 fields, saw 2\\nSkipping line 710: expected 1 fields, saw 2\\nSkipping line 711: expected 1 fields, saw 2\\nSkipping line 712: expected 1 fields, saw 2\\nSkipping line 713: expected 1 fields, saw 2\\nSkipping line 714: expected 1 fields, saw 2\\nSkipping line 715: expected 1 fields, saw 2\\nSkipping line 716: expected 1 fields, saw 2\\nSkipping line 717: expected 1 fields, saw 2\\nSkipping line 718: expected 1 fields, saw 2\\nSkipping line 719: expected 1 fields, saw 2\\nSkipping line 720: expected 1 fields, saw 2\\nSkipping line 721: expected 1 fields, saw 2\\nSkipping line 722: expected 1 fields, saw 2\\nSkipping line 723: expected 1 fields, saw 2\\nSkipping line 724: expected 1 fields, saw 2\\nSkipping line 725: expected 1 fields, saw 2\\nSkipping line 726: expected 1 fields, saw 2\\nSkipping line 727: expected 1 fields, saw 2\\nSkipping line 728: expected 1 fields, saw 2\\nSkipping line 729: expected 1 fields, saw 2\\nSkipping line 730: expected 1 fields, saw 2\\nSkipping line 731: expected 1 fields, saw 2\\nSkipping line 732: expected 1 fields, saw 2\\nSkipping line 733: expected 1 fields, saw 2\\nSkipping line 734: expected 1 fields, saw 2\\nSkipping line 735: expected 1 fields, saw 2\\nSkipping line 736: expected 1 fields, saw 2\\nSkipping line 737: expected 1 fields, saw 2\\nSkipping line 738: expected 1 fields, saw 2\\nSkipping line 739: expected 1 fields, saw 2\\nSkipping line 740: expected 1 fields, saw 2\\nSkipping line 741: expected 1 fields, saw 2\\nSkipping line 742: expected 1 fields, saw 2\\nSkipping line 743: expected 1 fields, saw 2\\nSkipping line 744: expected 1 fields, saw 2\\nSkipping line 745: expected 1 fields, saw 2\\nSkipping line 746: expected 1 fields, saw 2\\nSkipping line 747: expected 1 fields, saw 2\\nSkipping line 748: expected 1 fields, saw 2\\nSkipping line 749: expected 1 fields, saw 2\\nSkipping line 750: expected 1 fields, saw 2\\nSkipping line 751: expected 1 fields, saw 2\\nSkipping line 752: expected 1 fields, saw 2\\nSkipping line 753: expected 1 fields, saw 2\\nSkipping line 754: expected 1 fields, saw 2\\nSkipping line 755: expected 1 fields, saw 2\\nSkipping line 756: expected 1 fields, saw 2\\nSkipping line 757: expected 1 fields, saw 2\\nSkipping line 758: expected 1 fields, saw 2\\nSkipping line 759: expected 1 fields, saw 2\\nSkipping line 760: expected 1 fields, saw 2\\nSkipping line 761: expected 1 fields, saw 2\\nSkipping line 762: expected 1 fields, saw 2\\nSkipping line 763: expected 1 fields, saw 2\\nSkipping line 764: expected 1 fields, saw 2\\nSkipping line 765: expected 1 fields, saw 2\\nSkipping line 766: expected 1 fields, saw 2\\nSkipping line 767: expected 1 fields, saw 2\\nSkipping line 768: expected 1 fields, saw 2\\nSkipping line 769: expected 1 fields, saw 2\\nSkipping line 770: expected 1 fields, saw 2\\nSkipping line 771: expected 1 fields, saw 2\\nSkipping line 772: expected 1 fields, saw 2\\nSkipping line 773: expected 1 fields, saw 2\\nSkipping line 774: expected 1 fields, saw 2\\nSkipping line 775: expected 1 fields, saw 2\\nSkipping line 776: expected 1 fields, saw 2\\nSkipping line 777: expected 1 fields, saw 2\\nSkipping line 778: expected 1 fields, saw 2\\nSkipping line 779: expected 1 fields, saw 2\\nSkipping line 780: expected 1 fields, saw 2\\nSkipping line 781: expected 1 fields, saw 2\\nSkipping line 782: expected 1 fields, saw 2\\nSkipping line 783: expected 1 fields, saw 2\\nSkipping line 784: expected 1 fields, saw 2\\nSkipping line 785: expected 1 fields, saw 2\\nSkipping line 786: expected 1 fields, saw 2\\nSkipping line 787: expected 1 fields, saw 2\\nSkipping line 788: expected 1 fields, saw 2\\nSkipping line 789: expected 1 fields, saw 2\\nSkipping line 790: expected 1 fields, saw 2\\nSkipping line 791: expected 1 fields, saw 2\\nSkipping line 792: expected 1 fields, saw 2\\nSkipping line 793: expected 1 fields, saw 2\\nSkipping line 794: expected 1 fields, saw 2\\nSkipping line 795: expected 1 fields, saw 2\\nSkipping line 796: expected 1 fields, saw 2\\nSkipping line 797: expected 1 fields, saw 2\\nSkipping line 798: expected 1 fields, saw 2\\nSkipping line 799: expected 1 fields, saw 2\\nSkipping line 800: expected 1 fields, saw 2\\nSkipping line 801: expected 1 fields, saw 2\\nSkipping line 802: expected 1 fields, saw 2\\nSkipping line 803: expected 1 fields, saw 2\\nSkipping line 804: expected 1 fields, saw 2\\nSkipping line 805: expected 1 fields, saw 2\\nSkipping line 806: expected 1 fields, saw 2\\nSkipping line 807: expected 1 fields, saw 2\\nSkipping line 808: expected 1 fields, saw 2\\nSkipping line 809: expected 1 fields, saw 2\\nSkipping line 810: expected 1 fields, saw 2\\nSkipping line 811: expected 1 fields, saw 2\\nSkipping line 812: expected 1 fields, saw 2\\nSkipping line 813: expected 1 fields, saw 2\\nSkipping line 814: expected 1 fields, saw 2\\nSkipping line 815: expected 1 fields, saw 2\\nSkipping line 816: expected 1 fields, saw 2\\nSkipping line 817: expected 1 fields, saw 2\\nSkipping line 818: expected 1 fields, saw 2\\nSkipping line 819: expected 1 fields, saw 2\\nSkipping line 820: expected 1 fields, saw 2\\nSkipping line 821: expected 1 fields, saw 2\\nSkipping line 822: expected 1 fields, saw 2\\nSkipping line 823: expected 1 fields, saw 2\\nSkipping line 824: expected 1 fields, saw 2\\nSkipping line 825: expected 1 fields, saw 2\\nSkipping line 826: expected 1 fields, saw 2\\nSkipping line 827: expected 1 fields, saw 2\\nSkipping line 828: expected 1 fields, saw 2\\nSkipping line 829: expected 1 fields, saw 2\\nSkipping line 830: expected 1 fields, saw 2\\nSkipping line 831: expected 1 fields, saw 2\\nSkipping line 832: expected 1 fields, saw 2\\nSkipping line 833: expected 1 fields, saw 2\\nSkipping line 834: expected 1 fields, saw 2\\nSkipping line 835: expected 1 fields, saw 2\\nSkipping line 836: expected 1 fields, saw 2\\nSkipping line 837: expected 1 fields, saw 2\\nSkipping line 838: expected 1 fields, saw 2\\nSkipping line 839: expected 1 fields, saw 2\\nSkipping line 840: expected 1 fields, saw 2\\nSkipping line 841: expected 1 fields, saw 2\\nSkipping line 842: expected 1 fields, saw 2\\nSkipping line 843: expected 1 fields, saw 2\\nSkipping line 844: expected 1 fields, saw 2\\nSkipping line 845: expected 1 fields, saw 2\\nSkipping line 846: expected 1 fields, saw 2\\nSkipping line 847: expected 1 fields, saw 2\\nSkipping line 848: expected 1 fields, saw 2\\nSkipping line 849: expected 1 fields, saw 2\\nSkipping line 850: expected 1 fields, saw 2\\nSkipping line 851: expected 1 fields, saw 2\\nSkipping line 852: expected 1 fields, saw 2\\nSkipping line 853: expected 1 fields, saw 2\\nSkipping line 854: expected 1 fields, saw 2\\nSkipping line 855: expected 1 fields, saw 2\\nSkipping line 856: expected 1 fields, saw 2\\nSkipping line 857: expected 1 fields, saw 2\\nSkipping line 858: expected 1 fields, saw 2\\nSkipping line 859: expected 1 fields, saw 2\\nSkipping line 860: expected 1 fields, saw 2\\nSkipping line 861: expected 1 fields, saw 2\\nSkipping line 862: expected 1 fields, saw 2\\nSkipping line 863: expected 1 fields, saw 2\\nSkipping line 864: expected 1 fields, saw 2\\nSkipping line 865: expected 1 fields, saw 2\\nSkipping line 866: expected 1 fields, saw 2\\nSkipping line 867: expected 1 fields, saw 2\\nSkipping line 868: expected 1 fields, saw 2\\nSkipping line 869: expected 1 fields, saw 2\\nSkipping line 870: expected 1 fields, saw 2\\nSkipping line 871: expected 1 fields, saw 2\\nSkipping line 872: expected 1 fields, saw 2\\nSkipping line 873: expected 1 fields, saw 2\\nSkipping line 874: expected 1 fields, saw 2\\nSkipping line 875: expected 1 fields, saw 2\\nSkipping line 876: expected 1 fields, saw 2\\nSkipping line 877: expected 1 fields, saw 2\\nSkipping line 878: expected 1 fields, saw 2\\nSkipping line 879: expected 1 fields, saw 2\\nSkipping line 880: expected 1 fields, saw 2\\nSkipping line 881: expected 1 fields, saw 2\\nSkipping line 882: expected 1 fields, saw 2\\nSkipping line 883: expected 1 fields, saw 2\\nSkipping line 884: expected 1 fields, saw 2\\nSkipping line 885: expected 1 fields, saw 2\\nSkipping line 886: expected 1 fields, saw 2\\nSkipping line 887: expected 1 fields, saw 2\\nSkipping line 888: expected 1 fields, saw 2\\nSkipping line 889: expected 1 fields, saw 2\\nSkipping line 890: expected 1 fields, saw 2\\nSkipping line 891: expected 1 fields, saw 2\\nSkipping line 892: expected 1 fields, saw 2\\nSkipping line 893: expected 1 fields, saw 2\\nSkipping line 894: expected 1 fields, saw 2\\nSkipping line 895: expected 1 fields, saw 2\\nSkipping line 896: expected 1 fields, saw 2\\nSkipping line 897: expected 1 fields, saw 2\\nSkipping line 898: expected 1 fields, saw 2\\nSkipping line 899: expected 1 fields, saw 2\\nSkipping line 900: expected 1 fields, saw 2\\nSkipping line 901: expected 1 fields, saw 2\\nSkipping line 902: expected 1 fields, saw 2\\nSkipping line 903: expected 1 fields, saw 2\\nSkipping line 904: expected 1 fields, saw 2\\nSkipping line 905: expected 1 fields, saw 2\\nSkipping line 906: expected 1 fields, saw 2\\nSkipping line 907: expected 1 fields, saw 2\\nSkipping line 908: expected 1 fields, saw 2\\nSkipping line 909: expected 1 fields, saw 2\\nSkipping line 910: expected 1 fields, saw 2\\nSkipping line 911: expected 1 fields, saw 2\\nSkipping line 912: expected 1 fields, saw 2\\nSkipping line 913: expected 1 fields, saw 2\\nSkipping line 914: expected 1 fields, saw 2\\nSkipping line 915: expected 1 fields, saw 2\\nSkipping line 916: expected 1 fields, saw 2\\nSkipping line 917: expected 1 fields, saw 2\\nSkipping line 918: expected 1 fields, saw 2\\nSkipping line 919: expected 1 fields, saw 2\\nSkipping line 920: expected 1 fields, saw 2\\nSkipping line 921: expected 1 fields, saw 2\\nSkipping line 922: expected 1 fields, saw 2\\nSkipping line 923: expected 1 fields, saw 2\\nSkipping line 924: expected 1 fields, saw 2\\nSkipping line 925: expected 1 fields, saw 2\\nSkipping line 926: expected 1 fields, saw 2\\nSkipping line 927: expected 1 fields, saw 2\\nSkipping line 928: expected 1 fields, saw 2\\nSkipping line 929: expected 1 fields, saw 2\\nSkipping line 930: expected 1 fields, saw 2\\nSkipping line 931: expected 1 fields, saw 2\\nSkipping line 932: expected 1 fields, saw 2\\nSkipping line 933: expected 1 fields, saw 2\\nSkipping line 934: expected 1 fields, saw 2\\nSkipping line 935: expected 1 fields, saw 2\\nSkipping line 936: expected 1 fields, saw 2\\nSkipping line 937: expected 1 fields, saw 2\\nSkipping line 938: expected 1 fields, saw 2\\nSkipping line 939: expected 1 fields, saw 2\\nSkipping line 940: expected 1 fields, saw 2\\nSkipping line 941: expected 1 fields, saw 2\\nSkipping line 942: expected 1 fields, saw 2\\nSkipping line 943: expected 1 fields, saw 2\\nSkipping line 944: expected 1 fields, saw 2\\nSkipping line 945: expected 1 fields, saw 2\\nSkipping line 946: expected 1 fields, saw 2\\nSkipping line 947: expected 1 fields, saw 2\\nSkipping line 948: expected 1 fields, saw 2\\nSkipping line 949: expected 1 fields, saw 2\\nSkipping line 950: expected 1 fields, saw 2\\nSkipping line 951: expected 1 fields, saw 2\\nSkipping line 952: expected 1 fields, saw 2\\nSkipping line 953: expected 1 fields, saw 2\\nSkipping line 954: expected 1 fields, saw 2\\nSkipping line 955: expected 1 fields, saw 2\\nSkipping line 956: expected 1 fields, saw 2\\nSkipping line 957: expected 1 fields, saw 2\\nSkipping line 958: expected 1 fields, saw 2\\nSkipping line 959: expected 1 fields, saw 2\\nSkipping line 960: expected 1 fields, saw 2\\nSkipping line 961: expected 1 fields, saw 2\\nSkipping line 962: expected 1 fields, saw 2\\nSkipping line 963: expected 1 fields, saw 2\\nSkipping line 964: expected 1 fields, saw 2\\nSkipping line 965: expected 1 fields, saw 2\\nSkipping line 966: expected 1 fields, saw 2\\nSkipping line 967: expected 1 fields, saw 2\\nSkipping line 968: expected 1 fields, saw 2\\nSkipping line 969: expected 1 fields, saw 2\\nSkipping line 970: expected 1 fields, saw 2\\nSkipping line 971: expected 1 fields, saw 2\\nSkipping line 972: expected 1 fields, saw 2\\nSkipping line 973: expected 1 fields, saw 2\\nSkipping line 974: expected 1 fields, saw 2\\nSkipping line 975: expected 1 fields, saw 2\\nSkipping line 976: expected 1 fields, saw 2\\nSkipping line 977: expected 1 fields, saw 2\\nSkipping line 978: expected 1 fields, saw 2\\nSkipping line 979: expected 1 fields, saw 2\\nSkipping line 980: expected 1 fields, saw 2\\nSkipping line 981: expected 1 fields, saw 2\\nSkipping line 982: expected 1 fields, saw 2\\nSkipping line 983: expected 1 fields, saw 2\\nSkipping line 984: expected 1 fields, saw 2\\nSkipping line 985: expected 1 fields, saw 2\\nSkipping line 986: expected 1 fields, saw 2\\nSkipping line 987: expected 1 fields, saw 2\\nSkipping line 988: expected 1 fields, saw 2\\nSkipping line 989: expected 1 fields, saw 2\\nSkipping line 990: expected 1 fields, saw 2\\nSkipping line 991: expected 1 fields, saw 2\\nSkipping line 992: expected 1 fields, saw 2\\nSkipping line 993: expected 1 fields, saw 2\\nSkipping line 994: expected 1 fields, saw 2\\nSkipping line 995: expected 1 fields, saw 2\\nSkipping line 996: expected 1 fields, saw 2\\nSkipping line 997: expected 1 fields, saw 2\\nSkipping line 998: expected 1 fields, saw 2\\nSkipping line 999: expected 1 fields, saw 2\\nSkipping line 1000: expected 1 fields, saw 2\\nSkipping line 1001: expected 1 fields, saw 2\\nSkipping line 1002: expected 1 fields, saw 2\\nSkipping line 1003: expected 1 fields, saw 2\\nSkipping line 1004: expected 1 fields, saw 2\\nSkipping line 1005: expected 1 fields, saw 2\\nSkipping line 1006: expected 1 fields, saw 2\\nSkipping line 1007: expected 1 fields, saw 2\\nSkipping line 1008: expected 1 fields, saw 2\\nSkipping line 1009: expected 1 fields, saw 2\\nSkipping line 1010: expected 1 fields, saw 2\\nSkipping line 1011: expected 1 fields, saw 2\\nSkipping line 1012: expected 1 fields, saw 2\\nSkipping line 1013: expected 1 fields, saw 2\\nSkipping line 1014: expected 1 fields, saw 2\\nSkipping line 1015: expected 1 fields, saw 2\\nSkipping line 1016: expected 1 fields, saw 2\\nSkipping line 1017: expected 1 fields, saw 2\\nSkipping line 1018: expected 1 fields, saw 2\\nSkipping line 1019: expected 1 fields, saw 2\\nSkipping line 1020: expected 1 fields, saw 2\\nSkipping line 1021: expected 1 fields, saw 2\\nSkipping line 1022: expected 1 fields, saw 2\\nSkipping line 1023: expected 1 fields, saw 2\\nSkipping line 1024: expected 1 fields, saw 2\\nSkipping line 1025: expected 1 fields, saw 2\\nSkipping line 1026: expected 1 fields, saw 2\\nSkipping line 1027: expected 1 fields, saw 2\\nSkipping line 1028: expected 1 fields, saw 2\\nSkipping line 1029: expected 1 fields, saw 2\\nSkipping line 1030: expected 1 fields, saw 2\\nSkipping line 1031: expected 1 fields, saw 2\\nSkipping line 1032: expected 1 fields, saw 2\\nSkipping line 1033: expected 1 fields, saw 2\\nSkipping line 1034: expected 1 fields, saw 2\\nSkipping line 1035: expected 1 fields, saw 2\\nSkipping line 1036: expected 1 fields, saw 2\\nSkipping line 1037: expected 1 fields, saw 2\\nSkipping line 1038: expected 1 fields, saw 2\\nSkipping line 1039: expected 1 fields, saw 2\\nSkipping line 1040: expected 1 fields, saw 2\\nSkipping line 1041: expected 1 fields, saw 2\\nSkipping line 1042: expected 1 fields, saw 2\\nSkipping line 1043: expected 1 fields, saw 2\\nSkipping line 1044: expected 1 fields, saw 2\\nSkipping line 1045: expected 1 fields, saw 2\\nSkipping line 1046: expected 1 fields, saw 2\\nSkipping line 1047: expected 1 fields, saw 2\\nSkipping line 1048: expected 1 fields, saw 2\\nSkipping line 1049: expected 1 fields, saw 2\\nSkipping line 1050: expected 1 fields, saw 2\\nSkipping line 1051: expected 1 fields, saw 2\\nSkipping line 1052: expected 1 fields, saw 2\\nSkipping line 1053: expected 1 fields, saw 2\\nSkipping line 1054: expected 1 fields, saw 2\\nSkipping line 1055: expected 1 fields, saw 2\\nSkipping line 1056: expected 1 fields, saw 2\\nSkipping line 1057: expected 1 fields, saw 2\\nSkipping line 1058: expected 1 fields, saw 2\\nSkipping line 1059: expected 1 fields, saw 2\\nSkipping line 1060: expected 1 fields, saw 2\\nSkipping line 1061: expected 1 fields, saw 2\\nSkipping line 1062: expected 1 fields, saw 2\\nSkipping line 1063: expected 1 fields, saw 2\\nSkipping line 1064: expected 1 fields, saw 2\\nSkipping line 1065: expected 1 fields, saw 2\\nSkipping line 1066: expected 1 fields, saw 2\\nSkipping line 1067: expected 1 fields, saw 2\\nSkipping line 1068: expected 1 fields, saw 2\\nSkipping line 1069: expected 1 fields, saw 2\\nSkipping line 1070: expected 1 fields, saw 2\\nSkipping line 1071: expected 1 fields, saw 2\\nSkipping line 1072: expected 1 fields, saw 2\\nSkipping line 1073: expected 1 fields, saw 2\\nSkipping line 1074: expected 1 fields, saw 2\\nSkipping line 1075: expected 1 fields, saw 2\\nSkipping line 1076: expected 1 fields, saw 2\\nSkipping line 1077: expected 1 fields, saw 2\\nSkipping line 1078: expected 1 fields, saw 2\\nSkipping line 1079: expected 1 fields, saw 2\\nSkipping line 1080: expected 1 fields, saw 2\\nSkipping line 1081: expected 1 fields, saw 2\\nSkipping line 1082: expected 1 fields, saw 2\\nSkipping line 1083: expected 1 fields, saw 2\\nSkipping line 1084: expected 1 fields, saw 2\\nSkipping line 1085: expected 1 fields, saw 2\\nSkipping line 1086: expected 1 fields, saw 2\\nSkipping line 1087: expected 1 fields, saw 2\\nSkipping line 1088: expected 1 fields, saw 2\\nSkipping line 1089: expected 1 fields, saw 2\\nSkipping line 1090: expected 1 fields, saw 2\\nSkipping line 1091: expected 1 fields, saw 2\\nSkipping line 1092: expected 1 fields, saw 2\\nSkipping line 1093: expected 1 fields, saw 2\\nSkipping line 1094: expected 1 fields, saw 2\\nSkipping line 1095: expected 1 fields, saw 2\\nSkipping line 1096: expected 1 fields, saw 2\\nSkipping line 1097: expected 1 fields, saw 2\\nSkipping line 1098: expected 1 fields, saw 2\\nSkipping line 1099: expected 1 fields, saw 2\\nSkipping line 1100: expected 1 fields, saw 2\\nSkipping line 1101: expected 1 fields, saw 2\\nSkipping line 1102: expected 1 fields, saw 2\\nSkipping line 1103: expected 1 fields, saw 2\\nSkipping line 1104: expected 1 fields, saw 2\\nSkipping line 1105: expected 1 fields, saw 2\\nSkipping line 1106: expected 1 fields, saw 2\\nSkipping line 1107: expected 1 fields, saw 2\\nSkipping line 1108: expected 1 fields, saw 2\\nSkipping line 1109: expected 1 fields, saw 2\\nSkipping line 1110: expected 1 fields, saw 2\\nSkipping line 1111: expected 1 fields, saw 2\\nSkipping line 1112: expected 1 fields, saw 2\\nSkipping line 1113: expected 1 fields, saw 2\\nSkipping line 1114: expected 1 fields, saw 2\\nSkipping line 1115: expected 1 fields, saw 2\\nSkipping line 1116: expected 1 fields, saw 2\\nSkipping line 1117: expected 1 fields, saw 2\\nSkipping line 1118: expected 1 fields, saw 2\\nSkipping line 1119: expected 1 fields, saw 2\\nSkipping line 1120: expected 1 fields, saw 2\\nSkipping line 1121: expected 1 fields, saw 2\\nSkipping line 1122: expected 1 fields, saw 2\\nSkipping line 1123: expected 1 fields, saw 2\\nSkipping line 1124: expected 1 fields, saw 2\\nSkipping line 1125: expected 1 fields, saw 2\\nSkipping line 1126: expected 1 fields, saw 2\\nSkipping line 1127: expected 1 fields, saw 2\\nSkipping line 1128: expected 1 fields, saw 2\\nSkipping line 1129: expected 1 fields, saw 2\\nSkipping line 1130: expected 1 fields, saw 2\\nSkipping line 1131: expected 1 fields, saw 2\\nSkipping line 1132: expected 1 fields, saw 2\\nSkipping line 1133: expected 1 fields, saw 2\\nSkipping line 1134: expected 1 fields, saw 2\\nSkipping line 1135: expected 1 fields, saw 2\\nSkipping line 1136: expected 1 fields, saw 2\\nSkipping line 1137: expected 1 fields, saw 2\\nSkipping line 1138: expected 1 fields, saw 2\\nSkipping line 1139: expected 1 fields, saw 2\\nSkipping line 1140: expected 1 fields, saw 2\\nSkipping line 1141: expected 1 fields, saw 2\\nSkipping line 1142: expected 1 fields, saw 2\\nSkipping line 1143: expected 1 fields, saw 2\\nSkipping line 1144: expected 1 fields, saw 2\\nSkipping line 1145: expected 1 fields, saw 2\\nSkipping line 1146: expected 1 fields, saw 2\\nSkipping line 1147: expected 1 fields, saw 2\\nSkipping line 1148: expected 1 fields, saw 2\\nSkipping line 1149: expected 1 fields, saw 2\\nSkipping line 1150: expected 1 fields, saw 2\\nSkipping line 1151: expected 1 fields, saw 2\\nSkipping line 1152: expected 1 fields, saw 2\\nSkipping line 1153: expected 1 fields, saw 2\\nSkipping line 1154: expected 1 fields, saw 2\\nSkipping line 1155: expected 1 fields, saw 2\\nSkipping line 1156: expected 1 fields, saw 2\\nSkipping line 1157: expected 1 fields, saw 2\\nSkipping line 1158: expected 1 fields, saw 2\\nSkipping line 1159: expected 1 fields, saw 2\\nSkipping line 1160: expected 1 fields, saw 2\\nSkipping line 1161: expected 1 fields, saw 2\\nSkipping line 1162: expected 1 fields, saw 2\\nSkipping line 1163: expected 1 fields, saw 2\\nSkipping line 1164: expected 1 fields, saw 2\\nSkipping line 1165: expected 1 fields, saw 2\\nSkipping line 1166: expected 1 fields, saw 2\\nSkipping line 1167: expected 1 fields, saw 2\\nSkipping line 1168: expected 1 fields, saw 2\\nSkipping line 1169: expected 1 fields, saw 2\\nSkipping line 1170: expected 1 fields, saw 2\\nSkipping line 1171: expected 1 fields, saw 2\\nSkipping line 1172: expected 1 fields, saw 2\\nSkipping line 1173: expected 1 fields, saw 2\\nSkipping line 1174: expected 1 fields, saw 2\\nSkipping line 1175: expected 1 fields, saw 2\\nSkipping line 1176: expected 1 fields, saw 2\\nSkipping line 1177: expected 1 fields, saw 2\\nSkipping line 1178: expected 1 fields, saw 2\\nSkipping line 1179: expected 1 fields, saw 2\\nSkipping line 1180: expected 1 fields, saw 2\\nSkipping line 1181: expected 1 fields, saw 2\\nSkipping line 1182: expected 1 fields, saw 2\\nSkipping line 1183: expected 1 fields, saw 2\\nSkipping line 1184: expected 1 fields, saw 2\\nSkipping line 1185: expected 1 fields, saw 2\\nSkipping line 1186: expected 1 fields, saw 2\\nSkipping line 1187: expected 1 fields, saw 2\\nSkipping line 1188: expected 1 fields, saw 2\\nSkipping line 1189: expected 1 fields, saw 2\\nSkipping line 1190: expected 1 fields, saw 2\\nSkipping line 1191: expected 1 fields, saw 2\\nSkipping line 1192: expected 1 fields, saw 2\\nSkipping line 1193: expected 1 fields, saw 2\\nSkipping line 1194: expected 1 fields, saw 2\\nSkipping line 1195: expected 1 fields, saw 2\\nSkipping line 1196: expected 1 fields, saw 2\\nSkipping line 1197: expected 1 fields, saw 2\\nSkipping line 1198: expected 1 fields, saw 2\\nSkipping line 1199: expected 1 fields, saw 2\\nSkipping line 1200: expected 1 fields, saw 2\\nSkipping line 1201: expected 1 fields, saw 2\\nSkipping line 1202: expected 1 fields, saw 2\\nSkipping line 1203: expected 1 fields, saw 2\\nSkipping line 1204: expected 1 fields, saw 2\\nSkipping line 1205: expected 1 fields, saw 2\\nSkipping line 1206: expected 1 fields, saw 2\\nSkipping line 1207: expected 1 fields, saw 2\\nSkipping line 1208: expected 1 fields, saw 2\\nSkipping line 1209: expected 1 fields, saw 2\\nSkipping line 1210: expected 1 fields, saw 2\\nSkipping line 1211: expected 1 fields, saw 2\\nSkipping line 1212: expected 1 fields, saw 2\\nSkipping line 1213: expected 1 fields, saw 2\\nSkipping line 1214: expected 1 fields, saw 2\\nSkipping line 1215: expected 1 fields, saw 2\\nSkipping line 1216: expected 1 fields, saw 2\\nSkipping line 1217: expected 1 fields, saw 2\\nSkipping line 1218: expected 1 fields, saw 2\\nSkipping line 1219: expected 1 fields, saw 2\\nSkipping line 1220: expected 1 fields, saw 2\\nSkipping line 1221: expected 1 fields, saw 2\\nSkipping line 1222: expected 1 fields, saw 2\\nSkipping line 1223: expected 1 fields, saw 2\\nSkipping line 1224: expected 1 fields, saw 2\\nSkipping line 1225: expected 1 fields, saw 2\\nSkipping line 1226: expected 1 fields, saw 2\\nSkipping line 1227: expected 1 fields, saw 2\\nSkipping line 1228: expected 1 fields, saw 2\\nSkipping line 1229: expected 1 fields, saw 2\\nSkipping line 1230: expected 1 fields, saw 2\\nSkipping line 1231: expected 1 fields, saw 2\\nSkipping line 1232: expected 1 fields, saw 2\\nSkipping line 1233: expected 1 fields, saw 2\\nSkipping line 1234: expected 1 fields, saw 2\\nSkipping line 1235: expected 1 fields, saw 2\\nSkipping line 1236: expected 1 fields, saw 2\\nSkipping line 1237: expected 1 fields, saw 2\\nSkipping line 1238: expected 1 fields, saw 2\\nSkipping line 1239: expected 1 fields, saw 2\\nSkipping line 1240: expected 1 fields, saw 2\\nSkipping line 1241: expected 1 fields, saw 2\\nSkipping line 1242: expected 1 fields, saw 2\\nSkipping line 1243: expected 1 fields, saw 2\\nSkipping line 1244: expected 1 fields, saw 2\\nSkipping line 1245: expected 1 fields, saw 2\\nSkipping line 1246: expected 1 fields, saw 2\\nSkipping line 1247: expected 1 fields, saw 2\\nSkipping line 1248: expected 1 fields, saw 2\\nSkipping line 1249: expected 1 fields, saw 2\\nSkipping line 1250: expected 1 fields, saw 2\\nSkipping line 1251: expected 1 fields, saw 2\\nSkipping line 1252: expected 1 fields, saw 2\\nSkipping line 1253: expected 1 fields, saw 2\\nSkipping line 1254: expected 1 fields, saw 2\\nSkipping line 1255: expected 1 fields, saw 2\\nSkipping line 1256: expected 1 fields, saw 2\\nSkipping line 1257: expected 1 fields, saw 2\\nSkipping line 1258: expected 1 fields, saw 2\\nSkipping line 1259: expected 1 fields, saw 2\\nSkipping line 1260: expected 1 fields, saw 2\\nSkipping line 1261: expected 1 fields, saw 2\\nSkipping line 1262: expected 1 fields, saw 2\\nSkipping line 1263: expected 1 fields, saw 2\\nSkipping line 1264: expected 1 fields, saw 2\\nSkipping line 1265: expected 1 fields, saw 2\\nSkipping line 1266: expected 1 fields, saw 2\\nSkipping line 1267: expected 1 fields, saw 2\\nSkipping line 1268: expected 1 fields, saw 2\\nSkipping line 1269: expected 1 fields, saw 2\\nSkipping line 1270: expected 1 fields, saw 2\\nSkipping line 1271: expected 1 fields, saw 2\\nSkipping line 1272: expected 1 fields, saw 2\\nSkipping line 1273: expected 1 fields, saw 2\\nSkipping line 1274: expected 1 fields, saw 2\\nSkipping line 1275: expected 1 fields, saw 2\\nSkipping line 1276: expected 1 fields, saw 2\\nSkipping line 1277: expected 1 fields, saw 2\\nSkipping line 1278: expected 1 fields, saw 2\\nSkipping line 1279: expected 1 fields, saw 2\\nSkipping line 1280: expected 1 fields, saw 2\\nSkipping line 1281: expected 1 fields, saw 2\\nSkipping line 1282: expected 1 fields, saw 2\\nSkipping line 1283: expected 1 fields, saw 2\\nSkipping line 1284: expected 1 fields, saw 2\\nSkipping line 1285: expected 1 fields, saw 2\\nSkipping line 1286: expected 1 fields, saw 2\\nSkipping line 1287: expected 1 fields, saw 2\\nSkipping line 1288: expected 1 fields, saw 2\\nSkipping line 1289: expected 1 fields, saw 2\\nSkipping line 1290: expected 1 fields, saw 2\\nSkipping line 1291: expected 1 fields, saw 2\\nSkipping line 1292: expected 1 fields, saw 2\\nSkipping line 1293: expected 1 fields, saw 2\\nSkipping line 1294: expected 1 fields, saw 2\\nSkipping line 1295: expected 1 fields, saw 2\\nSkipping line 1296: expected 1 fields, saw 2\\nSkipping line 1297: expected 1 fields, saw 2\\nSkipping line 1298: expected 1 fields, saw 2\\nSkipping line 1299: expected 1 fields, saw 2\\nSkipping line 1300: expected 1 fields, saw 2\\nSkipping line 1301: expected 1 fields, saw 2\\nSkipping line 1302: expected 1 fields, saw 2\\nSkipping line 1303: expected 1 fields, saw 2\\nSkipping line 1304: expected 1 fields, saw 2\\nSkipping line 1305: expected 1 fields, saw 2\\nSkipping line 1306: expected 1 fields, saw 2\\nSkipping line 1307: expected 1 fields, saw 2\\nSkipping line 1308: expected 1 fields, saw 2\\nSkipping line 1309: expected 1 fields, saw 2\\nSkipping line 1310: expected 1 fields, saw 2\\nSkipping line 1311: expected 1 fields, saw 2\\nSkipping line 1312: expected 1 fields, saw 2\\nSkipping line 1313: expected 1 fields, saw 2\\nSkipping line 1314: expected 1 fields, saw 2\\nSkipping line 1315: expected 1 fields, saw 2\\nSkipping line 1316: expected 1 fields, saw 2\\nSkipping line 1317: expected 1 fields, saw 2\\nSkipping line 1318: expected 1 fields, saw 2\\nSkipping line 1319: expected 1 fields, saw 2\\nSkipping line 1320: expected 1 fields, saw 2\\nSkipping line 1321: expected 1 fields, saw 2\\nSkipping line 1322: expected 1 fields, saw 2\\nSkipping line 1323: expected 1 fields, saw 2\\nSkipping line 1324: expected 1 fields, saw 2\\nSkipping line 1325: expected 1 fields, saw 2\\nSkipping line 1326: expected 1 fields, saw 2\\nSkipping line 1327: expected 1 fields, saw 2\\nSkipping line 1328: expected 1 fields, saw 2\\nSkipping line 1329: expected 1 fields, saw 2\\nSkipping line 1330: expected 1 fields, saw 2\\nSkipping line 1331: expected 1 fields, saw 2\\nSkipping line 1332: expected 1 fields, saw 2\\nSkipping line 1333: expected 1 fields, saw 2\\nSkipping line 1334: expected 1 fields, saw 2\\nSkipping line 1335: expected 1 fields, saw 2\\nSkipping line 1336: expected 1 fields, saw 2\\nSkipping line 1337: expected 1 fields, saw 2\\nSkipping line 1338: expected 1 fields, saw 2\\nSkipping line 1339: expected 1 fields, saw 2\\nSkipping line 1340: expected 1 fields, saw 2\\nSkipping line 1341: expected 1 fields, saw 2\\nSkipping line 1342: expected 1 fields, saw 2\\nSkipping line 1343: expected 1 fields, saw 2\\nSkipping line 1344: expected 1 fields, saw 2\\nSkipping line 1345: expected 1 fields, saw 2\\nSkipping line 1346: expected 1 fields, saw 2\\nSkipping line 1347: expected 1 fields, saw 2\\nSkipping line 1348: expected 1 fields, saw 2\\nSkipping line 1349: expected 1 fields, saw 2\\nSkipping line 1350: expected 1 fields, saw 2\\nSkipping line 1351: expected 1 fields, saw 2\\nSkipping line 1352: expected 1 fields, saw 2\\nSkipping line 1353: expected 1 fields, saw 2\\nSkipping line 1354: expected 1 fields, saw 2\\nSkipping line 1355: expected 1 fields, saw 2\\nSkipping line 1356: expected 1 fields, saw 2\\nSkipping line 1357: expected 1 fields, saw 2\\nSkipping line 1358: expected 1 fields, saw 2\\nSkipping line 1359: expected 1 fields, saw 2\\nSkipping line 1360: expected 1 fields, saw 2\\nSkipping line 1361: expected 1 fields, saw 2\\nSkipping line 1362: expected 1 fields, saw 2\\nSkipping line 1363: expected 1 fields, saw 2\\nSkipping line 1364: expected 1 fields, saw 2\\nSkipping line 1365: expected 1 fields, saw 2\\nSkipping line 1366: expected 1 fields, saw 2\\nSkipping line 1367: expected 1 fields, saw 2\\nSkipping line 1368: expected 1 fields, saw 2\\nSkipping line 1369: expected 1 fields, saw 2\\nSkipping line 1370: expected 1 fields, saw 2\\nSkipping line 1371: expected 1 fields, saw 2\\nSkipping line 1372: expected 1 fields, saw 2\\nSkipping line 1373: expected 1 fields, saw 2\\nSkipping line 1374: expected 1 fields, saw 2\\nSkipping line 1375: expected 1 fields, saw 2\\nSkipping line 1376: expected 1 fields, saw 2\\nSkipping line 1377: expected 1 fields, saw 2\\nSkipping line 1378: expected 1 fields, saw 2\\nSkipping line 1379: expected 1 fields, saw 2\\nSkipping line 1380: expected 1 fields, saw 2\\nSkipping line 1381: expected 1 fields, saw 2\\nSkipping line 1382: expected 1 fields, saw 2\\nSkipping line 1383: expected 1 fields, saw 2\\nSkipping line 1384: expected 1 fields, saw 2\\nSkipping line 1385: expected 1 fields, saw 2\\nSkipping line 1386: expected 1 fields, saw 2\\nSkipping line 1387: expected 1 fields, saw 2\\nSkipping line 1388: expected 1 fields, saw 2\\nSkipping line 1389: expected 1 fields, saw 2\\nSkipping line 1390: expected 1 fields, saw 2\\nSkipping line 1391: expected 1 fields, saw 2\\nSkipping line 1392: expected 1 fields, saw 2\\nSkipping line 1393: expected 1 fields, saw 2\\nSkipping line 1394: expected 1 fields, saw 2\\nSkipping line 1395: expected 1 fields, saw 2\\nSkipping line 1396: expected 1 fields, saw 2\\nSkipping line 1397: expected 1 fields, saw 2\\nSkipping line 1398: expected 1 fields, saw 2\\nSkipping line 1399: expected 1 fields, saw 2\\nSkipping line 1400: expected 1 fields, saw 2\\nSkipping line 1401: expected 1 fields, saw 2\\nSkipping line 1402: expected 1 fields, saw 2\\nSkipping line 1403: expected 1 fields, saw 2\\nSkipping line 1404: expected 1 fields, saw 2\\nSkipping line 1405: expected 1 fields, saw 2\\nSkipping line 1406: expected 1 fields, saw 2\\nSkipping line 1407: expected 1 fields, saw 2\\nSkipping line 1408: expected 1 fields, saw 2\\nSkipping line 1409: expected 1 fields, saw 2\\nSkipping line 1410: expected 1 fields, saw 2\\nSkipping line 1411: expected 1 fields, saw 2\\nSkipping line 1412: expected 1 fields, saw 2\\nSkipping line 1413: expected 1 fields, saw 2\\nSkipping line 1414: expected 1 fields, saw 2\\nSkipping line 1415: expected 1 fields, saw 2\\nSkipping line 1416: expected 1 fields, saw 2\\nSkipping line 1417: expected 1 fields, saw 2\\nSkipping line 1418: expected 1 fields, saw 2\\nSkipping line 1419: expected 1 fields, saw 2\\nSkipping line 1420: expected 1 fields, saw 2\\nSkipping line 1421: expected 1 fields, saw 2\\nSkipping line 1422: expected 1 fields, saw 2\\nSkipping line 1423: expected 1 fields, saw 2\\nSkipping line 1424: expected 1 fields, saw 2\\nSkipping line 1425: expected 1 fields, saw 2\\nSkipping line 1426: expected 1 fields, saw 2\\nSkipping line 1427: expected 1 fields, saw 2\\nSkipping line 1428: expected 1 fields, saw 2\\nSkipping line 1429: expected 1 fields, saw 2\\nSkipping line 1430: expected 1 fields, saw 2\\nSkipping line 1431: expected 1 fields, saw 2\\nSkipping line 1432: expected 1 fields, saw 2\\nSkipping line 1433: expected 1 fields, saw 2\\nSkipping line 1434: expected 1 fields, saw 2\\nSkipping line 1435: expected 1 fields, saw 2\\nSkipping line 1436: expected 1 fields, saw 2\\nSkipping line 1437: expected 1 fields, saw 2\\nSkipping line 1438: expected 1 fields, saw 2\\nSkipping line 1439: expected 1 fields, saw 2\\nSkipping line 1440: expected 1 fields, saw 2\\nSkipping line 1441: expected 1 fields, saw 2\\nSkipping line 1442: expected 1 fields, saw 2\\nSkipping line 1443: expected 1 fields, saw 2\\nSkipping line 1444: expected 1 fields, saw 2\\nSkipping line 1445: expected 1 fields, saw 2\\nSkipping line 1446: expected 1 fields, saw 2\\nSkipping line 1447: expected 1 fields, saw 2\\nSkipping line 1448: expected 1 fields, saw 2\\nSkipping line 1449: expected 1 fields, saw 2\\nSkipping line 1450: expected 1 fields, saw 2\\nSkipping line 1451: expected 1 fields, saw 2\\nSkipping line 1452: expected 1 fields, saw 2\\nSkipping line 1453: expected 1 fields, saw 2\\nSkipping line 1454: expected 1 fields, saw 2\\nSkipping line 1455: expected 1 fields, saw 2\\nSkipping line 1456: expected 1 fields, saw 2\\nSkipping line 1457: expected 1 fields, saw 2\\nSkipping line 1458: expected 1 fields, saw 2\\nSkipping line 1459: expected 1 fields, saw 2\\nSkipping line 1460: expected 1 fields, saw 2\\nSkipping line 1461: expected 1 fields, saw 2\\nSkipping line 1462: expected 1 fields, saw 2\\nSkipping line 1463: expected 1 fields, saw 2\\nSkipping line 1464: expected 1 fields, saw 2\\nSkipping line 1465: expected 1 fields, saw 2\\nSkipping line 1466: expected 1 fields, saw 2\\nSkipping line 1467: expected 1 fields, saw 2\\nSkipping line 1468: expected 1 fields, saw 2\\nSkipping line 1469: expected 1 fields, saw 2\\nSkipping line 1470: expected 1 fields, saw 2\\nSkipping line 1471: expected 1 fields, saw 2\\nSkipping line 1472: expected 1 fields, saw 2\\nSkipping line 1473: expected 1 fields, saw 2\\nSkipping line 1474: expected 1 fields, saw 2\\nSkipping line 1475: expected 1 fields, saw 2\\nSkipping line 1476: expected 1 fields, saw 2\\nSkipping line 1477: expected 1 fields, saw 2\\nSkipping line 1478: expected 1 fields, saw 2\\nSkipping line 1479: expected 1 fields, saw 2\\nSkipping line 1480: expected 1 fields, saw 2\\nSkipping line 1481: expected 1 fields, saw 2\\nSkipping line 1482: expected 1 fields, saw 2\\nSkipping line 1483: expected 1 fields, saw 2\\nSkipping line 1484: expected 1 fields, saw 2\\nSkipping line 1485: expected 1 fields, saw 2\\nSkipping line 1486: expected 1 fields, saw 2\\nSkipping line 1487: expected 1 fields, saw 2\\nSkipping line 1488: expected 1 fields, saw 2\\nSkipping line 1489: expected 1 fields, saw 2\\nSkipping line 1490: expected 1 fields, saw 2\\nSkipping line 1491: expected 1 fields, saw 2\\nSkipping line 1492: expected 1 fields, saw 2\\nSkipping line 1493: expected 1 fields, saw 2\\nSkipping line 1494: expected 1 fields, saw 2\\nSkipping line 1495: expected 1 fields, saw 2\\nSkipping line 1496: expected 1 fields, saw 2\\nSkipping line 1497: expected 1 fields, saw 2\\nSkipping line 1498: expected 1 fields, saw 2\\nSkipping line 1499: expected 1 fields, saw 2\\nSkipping line 1500: expected 1 fields, saw 2\\nSkipping line 1501: expected 1 fields, saw 2\\nSkipping line 1502: expected 1 fields, saw 2\\nSkipping line 1503: expected 1 fields, saw 2\\nSkipping line 1504: expected 1 fields, saw 2\\nSkipping line 1505: expected 1 fields, saw 2\\nSkipping line 1506: expected 1 fields, saw 2\\nSkipping line 1507: expected 1 fields, saw 2\\nSkipping line 1508: expected 1 fields, saw 2\\nSkipping line 1509: expected 1 fields, saw 2\\nSkipping line 1510: expected 1 fields, saw 2\\nSkipping line 1511: expected 1 fields, saw 2\\nSkipping line 1512: expected 1 fields, saw 2\\nSkipping line 1513: expected 1 fields, saw 2\\nSkipping line 1514: expected 1 fields, saw 2\\nSkipping line 1515: expected 1 fields, saw 2\\nSkipping line 1516: expected 1 fields, saw 2\\nSkipping line 1517: expected 1 fields, saw 2\\nSkipping line 1518: expected 1 fields, saw 2\\nSkipping line 1519: expected 1 fields, saw 2\\nSkipping line 1520: expected 1 fields, saw 2\\nSkipping line 1521: expected 1 fields, saw 2\\nSkipping line 1522: expected 1 fields, saw 2\\nSkipping line 1523: expected 1 fields, saw 2\\nSkipping line 1524: expected 1 fields, saw 2\\nSkipping line 1525: expected 1 fields, saw 2\\nSkipping line 1526: expected 1 fields, saw 2\\nSkipping line 1527: expected 1 fields, saw 2\\nSkipping line 1528: expected 1 fields, saw 2\\nSkipping line 1529: expected 1 fields, saw 2\\nSkipping line 1530: expected 1 fields, saw 2\\nSkipping line 1531: expected 1 fields, saw 2\\nSkipping line 1532: expected 1 fields, saw 2\\nSkipping line 1533: expected 1 fields, saw 2\\nSkipping line 1534: expected 1 fields, saw 2\\nSkipping line 1535: expected 1 fields, saw 2\\nSkipping line 1536: expected 1 fields, saw 2\\nSkipping line 1537: expected 1 fields, saw 2\\nSkipping line 1538: expected 1 fields, saw 2\\nSkipping line 1539: expected 1 fields, saw 2\\nSkipping line 1540: expected 1 fields, saw 2\\nSkipping line 1541: expected 1 fields, saw 2\\nSkipping line 1542: expected 1 fields, saw 2\\nSkipping line 1543: expected 1 fields, saw 2\\nSkipping line 1544: expected 1 fields, saw 2\\nSkipping line 1545: expected 1 fields, saw 2\\nSkipping line 1546: expected 1 fields, saw 2\\nSkipping line 1547: expected 1 fields, saw 2\\nSkipping line 1548: expected 1 fields, saw 2\\nSkipping line 1549: expected 1 fields, saw 2\\nSkipping line 1550: expected 1 fields, saw 2\\nSkipping line 1551: expected 1 fields, saw 2\\nSkipping line 1552: expected 1 fields, saw 2\\nSkipping line 1553: expected 1 fields, saw 2\\nSkipping line 1554: expected 1 fields, saw 2\\nSkipping line 1555: expected 1 fields, saw 2\\nSkipping line 1556: expected 1 fields, saw 2\\nSkipping line 1557: expected 1 fields, saw 2\\nSkipping line 1558: expected 1 fields, saw 2\\nSkipping line 1559: expected 1 fields, saw 2\\nSkipping line 1560: expected 1 fields, saw 2\\nSkipping line 1561: expected 1 fields, saw 2\\nSkipping line 1562: expected 1 fields, saw 2\\nSkipping line 1563: expected 1 fields, saw 2\\nSkipping line 1564: expected 1 fields, saw 2\\nSkipping line 1565: expected 1 fields, saw 2\\nSkipping line 1566: expected 1 fields, saw 2\\nSkipping line 1567: expected 1 fields, saw 2\\nSkipping line 1568: expected 1 fields, saw 2\\nSkipping line 1569: expected 1 fields, saw 2\\nSkipping line 1570: expected 1 fields, saw 2\\nSkipping line 1571: expected 1 fields, saw 2\\nSkipping line 1572: expected 1 fields, saw 2\\nSkipping line 1573: expected 1 fields, saw 2\\nSkipping line 1574: expected 1 fields, saw 2\\nSkipping line 1575: expected 1 fields, saw 2\\nSkipping line 1576: expected 1 fields, saw 2\\nSkipping line 1577: expected 1 fields, saw 2\\nSkipping line 1578: expected 1 fields, saw 2\\nSkipping line 1579: expected 1 fields, saw 2\\nSkipping line 1580: expected 1 fields, saw 2\\nSkipping line 1581: expected 1 fields, saw 2\\nSkipping line 1582: expected 1 fields, saw 2\\nSkipping line 1583: expected 1 fields, saw 2\\nSkipping line 1584: expected 1 fields, saw 2\\nSkipping line 1585: expected 1 fields, saw 2\\nSkipping line 1586: expected 1 fields, saw 2\\nSkipping line 1587: expected 1 fields, saw 2\\nSkipping line 1588: expected 1 fields, saw 2\\nSkipping line 1589: expected 1 fields, saw 2\\nSkipping line 1590: expected 1 fields, saw 2\\nSkipping line 1591: expected 1 fields, saw 2\\nSkipping line 1592: expected 1 fields, saw 2\\nSkipping line 1593: expected 1 fields, saw 2\\nSkipping line 1594: expected 1 fields, saw 2\\nSkipping line 1595: expected 1 fields, saw 2\\nSkipping line 1596: expected 1 fields, saw 2\\nSkipping line 1597: expected 1 fields, saw 2\\nSkipping line 1598: expected 1 fields, saw 2\\nSkipping line 1599: expected 1 fields, saw 2\\nSkipping line 1600: expected 1 fields, saw 2\\nSkipping line 1601: expected 1 fields, saw 2\\nSkipping line 1602: expected 1 fields, saw 2\\nSkipping line 1603: expected 1 fields, saw 2\\nSkipping line 1604: expected 1 fields, saw 2\\nSkipping line 1605: expected 1 fields, saw 2\\nSkipping line 1606: expected 1 fields, saw 2\\nSkipping line 1607: expected 1 fields, saw 2\\nSkipping line 1608: expected 1 fields, saw 2\\nSkipping line 1609: expected 1 fields, saw 2\\nSkipping line 1610: expected 1 fields, saw 2\\nSkipping line 1611: expected 1 fields, saw 2\\nSkipping line 1612: expected 1 fields, saw 2\\nSkipping line 1613: expected 1 fields, saw 2\\nSkipping line 1614: expected 1 fields, saw 2\\nSkipping line 1615: expected 1 fields, saw 2\\nSkipping line 1616: expected 1 fields, saw 2\\nSkipping line 1617: expected 1 fields, saw 2\\nSkipping line 1618: expected 1 fields, saw 2\\nSkipping line 1619: expected 1 fields, saw 2\\nSkipping line 1620: expected 1 fields, saw 2\\nSkipping line 1621: expected 1 fields, saw 2\\nSkipping line 1622: expected 1 fields, saw 2\\nSkipping line 1623: expected 1 fields, saw 2\\nSkipping line 1624: expected 1 fields, saw 2\\nSkipping line 1625: expected 1 fields, saw 2\\nSkipping line 1626: expected 1 fields, saw 2\\nSkipping line 1627: expected 1 fields, saw 2\\nSkipping line 1628: expected 1 fields, saw 2\\nSkipping line 1629: expected 1 fields, saw 2\\nSkipping line 1630: expected 1 fields, saw 2\\nSkipping line 1631: expected 1 fields, saw 2\\nSkipping line 1632: expected 1 fields, saw 2\\nSkipping line 1633: expected 1 fields, saw 2\\nSkipping line 1634: expected 1 fields, saw 2\\nSkipping line 1635: expected 1 fields, saw 2\\nSkipping line 1636: expected 1 fields, saw 2\\nSkipping line 1637: expected 1 fields, saw 2\\nSkipping line 1638: expected 1 fields, saw 2\\nSkipping line 1639: expected 1 fields, saw 2\\nSkipping line 1640: expected 1 fields, saw 2\\nSkipping line 1641: expected 1 fields, saw 2\\nSkipping line 1642: expected 1 fields, saw 2\\nSkipping line 1643: expected 1 fields, saw 2\\nSkipping line 1644: expected 1 fields, saw 2\\nSkipping line 1645: expected 1 fields, saw 2\\nSkipping line 1646: expected 1 fields, saw 2\\nSkipping line 1647: expected 1 fields, saw 2\\nSkipping line 1648: expected 1 fields, saw 2\\nSkipping line 1649: expected 1 fields, saw 2\\nSkipping line 1650: expected 1 fields, saw 2\\nSkipping line 1651: expected 1 fields, saw 2\\nSkipping line 1652: expected 1 fields, saw 2\\nSkipping line 1653: expected 1 fields, saw 2\\nSkipping line 1654: expected 1 fields, saw 2\\nSkipping line 1655: expected 1 fields, saw 2\\nSkipping line 1656: expected 1 fields, saw 2\\nSkipping line 1657: expected 1 fields, saw 2\\nSkipping line 1658: expected 1 fields, saw 2\\nSkipping line 1659: expected 1 fields, saw 2\\nSkipping line 1660: expected 1 fields, saw 2\\nSkipping line 1661: expected 1 fields, saw 2\\nSkipping line 1662: expected 1 fields, saw 2\\nSkipping line 1663: expected 1 fields, saw 2\\nSkipping line 1664: expected 1 fields, saw 2\\nSkipping line 1665: expected 1 fields, saw 2\\nSkipping line 1666: expected 1 fields, saw 2\\nSkipping line 1667: expected 1 fields, saw 2\\nSkipping line 1668: expected 1 fields, saw 2\\nSkipping line 1669: expected 1 fields, saw 2\\nSkipping line 1670: expected 1 fields, saw 2\\nSkipping line 1671: expected 1 fields, saw 2\\nSkipping line 1672: expected 1 fields, saw 2\\nSkipping line 1673: expected 1 fields, saw 2\\nSkipping line 1674: expected 1 fields, saw 2\\nSkipping line 1675: expected 1 fields, saw 2\\nSkipping line 1676: expected 1 fields, saw 2\\nSkipping line 1677: expected 1 fields, saw 2\\nSkipping line 1678: expected 1 fields, saw 2\\nSkipping line 1679: expected 1 fields, saw 2\\nSkipping line 1680: expected 1 fields, saw 2\\nSkipping line 1681: expected 1 fields, saw 2\\nSkipping line 1682: expected 1 fields, saw 2\\nSkipping line 1683: expected 1 fields, saw 2\\nSkipping line 1684: expected 1 fields, saw 2\\nSkipping line 1685: expected 1 fields, saw 2\\nSkipping line 1686: expected 1 fields, saw 2\\nSkipping line 1687: expected 1 fields, saw 2\\nSkipping line 1688: expected 1 fields, saw 2\\nSkipping line 1689: expected 1 fields, saw 2\\nSkipping line 1690: expected 1 fields, saw 2\\nSkipping line 1691: expected 1 fields, saw 2\\nSkipping line 1692: expected 1 fields, saw 2\\nSkipping line 1693: expected 1 fields, saw 2\\nSkipping line 1694: expected 1 fields, saw 2\\nSkipping line 1695: expected 1 fields, saw 2\\nSkipping line 1696: expected 1 fields, saw 2\\nSkipping line 1697: expected 1 fields, saw 2\\nSkipping line 1698: expected 1 fields, saw 2\\nSkipping line 1699: expected 1 fields, saw 2\\nSkipping line 1700: expected 1 fields, saw 2\\nSkipping line 1701: expected 1 fields, saw 2\\nSkipping line 1702: expected 1 fields, saw 2\\nSkipping line 1703: expected 1 fields, saw 2\\nSkipping line 1704: expected 1 fields, saw 2\\nSkipping line 1705: expected 1 fields, saw 2\\nSkipping line 1706: expected 1 fields, saw 2\\nSkipping line 1707: expected 1 fields, saw 2\\nSkipping line 1708: expected 1 fields, saw 2\\nSkipping line 1709: expected 1 fields, saw 2\\nSkipping line 1710: expected 1 fields, saw 2\\nSkipping line 1711: expected 1 fields, saw 2\\nSkipping line 1712: expected 1 fields, saw 2\\nSkipping line 1713: expected 1 fields, saw 2\\nSkipping line 1714: expected 1 fields, saw 2\\nSkipping line 1715: expected 1 fields, saw 2\\nSkipping line 1716: expected 1 fields, saw 2\\nSkipping line 1717: expected 1 fields, saw 2\\nSkipping line 1718: expected 1 fields, saw 2\\nSkipping line 1719: expected 1 fields, saw 2\\nSkipping line 1720: expected 1 fields, saw 2\\nSkipping line 1721: expected 1 fields, saw 2\\nSkipping line 1722: expected 1 fields, saw 2\\nSkipping line 1723: expected 1 fields, saw 2\\nSkipping line 1724: expected 1 fields, saw 2\\nSkipping line 1725: expected 1 fields, saw 2\\nSkipping line 1726: expected 1 fields, saw 2\\nSkipping line 1727: expected 1 fields, saw 2\\nSkipping line 1728: expected 1 fields, saw 2\\nSkipping line 1729: expected 1 fields, saw 2\\nSkipping line 1730: expected 1 fields, saw 2\\nSkipping line 1731: expected 1 fields, saw 2\\nSkipping line 1732: expected 1 fields, saw 2\\nSkipping line 1733: expected 1 fields, saw 2\\nSkipping line 1734: expected 1 fields, saw 2\\nSkipping line 1735: expected 1 fields, saw 2\\nSkipping line 1736: expected 1 fields, saw 2\\nSkipping line 1737: expected 1 fields, saw 2\\nSkipping line 1738: expected 1 fields, saw 2\\nSkipping line 1739: expected 1 fields, saw 2\\nSkipping line 1740: expected 1 fields, saw 2\\nSkipping line 1741: expected 1 fields, saw 2\\nSkipping line 1742: expected 1 fields, saw 2\\nSkipping line 1743: expected 1 fields, saw 2\\nSkipping line 1744: expected 1 fields, saw 2\\nSkipping line 1745: expected 1 fields, saw 2\\nSkipping line 1746: expected 1 fields, saw 2\\nSkipping line 1747: expected 1 fields, saw 2\\nSkipping line 1748: expected 1 fields, saw 2\\nSkipping line 1749: expected 1 fields, saw 2\\nSkipping line 1750: expected 1 fields, saw 2\\nSkipping line 1751: expected 1 fields, saw 2\\nSkipping line 1752: expected 1 fields, saw 2\\nSkipping line 1753: expected 1 fields, saw 2\\nSkipping line 1754: expected 1 fields, saw 2\\nSkipping line 1755: expected 1 fields, saw 2\\nSkipping line 1756: expected 1 fields, saw 2\\nSkipping line 1757: expected 1 fields, saw 2\\nSkipping line 1758: expected 1 fields, saw 2\\nSkipping line 1759: expected 1 fields, saw 2\\nSkipping line 1760: expected 1 fields, saw 2\\nSkipping line 1761: expected 1 fields, saw 2\\nSkipping line 1762: expected 1 fields, saw 2\\nSkipping line 1763: expected 1 fields, saw 2\\nSkipping line 1764: expected 1 fields, saw 2\\nSkipping line 1765: expected 1 fields, saw 2\\nSkipping line 1766: expected 1 fields, saw 2\\nSkipping line 1767: expected 1 fields, saw 2\\nSkipping line 1768: expected 1 fields, saw 2\\nSkipping line 1769: expected 1 fields, saw 2\\nSkipping line 1770: expected 1 fields, saw 2\\nSkipping line 1771: expected 1 fields, saw 2\\nSkipping line 1772: expected 1 fields, saw 2\\nSkipping line 1773: expected 1 fields, saw 2\\nSkipping line 1774: expected 1 fields, saw 2\\nSkipping line 1775: expected 1 fields, saw 2\\nSkipping line 1776: expected 1 fields, saw 2\\nSkipping line 1777: expected 1 fields, saw 2\\nSkipping line 1778: expected 1 fields, saw 2\\nSkipping line 1779: expected 1 fields, saw 2\\nSkipping line 1780: expected 1 fields, saw 2\\nSkipping line 1781: expected 1 fields, saw 2\\nSkipping line 1782: expected 1 fields, saw 2\\nSkipping line 1783: expected 1 fields, saw 2\\nSkipping line 1784: expected 1 fields, saw 2\\nSkipping line 1785: expected 1 fields, saw 2\\nSkipping line 1786: expected 1 fields, saw 2\\nSkipping line 1787: expected 1 fields, saw 2\\nSkipping line 1788: expected 1 fields, saw 2\\nSkipping line 1789: expected 1 fields, saw 2\\nSkipping line 1790: expected 1 fields, saw 2\\nSkipping line 1791: expected 1 fields, saw 2\\nSkipping line 1792: expected 1 fields, saw 2\\nSkipping line 1793: expected 1 fields, saw 2\\nSkipping line 1794: expected 1 fields, saw 2\\nSkipping line 1795: expected 1 fields, saw 2\\nSkipping line 1796: expected 1 fields, saw 2\\nSkipping line 1797: expected 1 fields, saw 2\\nSkipping line 1798: expected 1 fields, saw 2\\nSkipping line 1799: expected 1 fields, saw 2\\nSkipping line 1800: expected 1 fields, saw 2\\nSkipping line 1801: expected 1 fields, saw 2\\nSkipping line 1802: expected 1 fields, saw 2\\nSkipping line 1803: expected 1 fields, saw 2\\nSkipping line 1804: expected 1 fields, saw 2\\nSkipping line 1805: expected 1 fields, saw 2\\nSkipping line 1806: expected 1 fields, saw 2\\nSkipping line 1807: expected 1 fields, saw 2\\nSkipping line 1808: expected 1 fields, saw 2\\nSkipping line 1809: expected 1 fields, saw 2\\nSkipping line 1810: expected 1 fields, saw 2\\nSkipping line 1811: expected 1 fields, saw 2\\nSkipping line 1812: expected 1 fields, saw 2\\nSkipping line 1813: expected 1 fields, saw 2\\nSkipping line 1814: expected 1 fields, saw 2\\nSkipping line 1815: expected 1 fields, saw 2\\nSkipping line 1816: expected 1 fields, saw 2\\nSkipping line 1817: expected 1 fields, saw 2\\nSkipping line 1818: expected 1 fields, saw 2\\nSkipping line 1819: expected 1 fields, saw 2\\nSkipping line 1820: expected 1 fields, saw 2\\nSkipping line 1821: expected 1 fields, saw 2\\nSkipping line 1822: expected 1 fields, saw 2\\nSkipping line 1823: expected 1 fields, saw 2\\nSkipping line 1824: expected 1 fields, saw 2\\nSkipping line 1825: expected 1 fields, saw 2\\nSkipping line 1826: expected 1 fields, saw 2\\nSkipping line 1827: expected 1 fields, saw 2\\nSkipping line 1828: expected 1 fields, saw 2\\nSkipping line 1829: expected 1 fields, saw 2\\nSkipping line 1830: expected 1 fields, saw 2\\nSkipping line 1831: expected 1 fields, saw 2\\nSkipping line 1832: expected 1 fields, saw 2\\nSkipping line 1833: expected 1 fields, saw 2\\nSkipping line 1834: expected 1 fields, saw 2\\nSkipping line 1835: expected 1 fields, saw 2\\nSkipping line 1836: expected 1 fields, saw 2\\nSkipping line 1837: expected 1 fields, saw 2\\nSkipping line 1838: expected 1 fields, saw 2\\nSkipping line 1839: expected 1 fields, saw 2\\nSkipping line 1840: expected 1 fields, saw 2\\nSkipping line 1841: expected 1 fields, saw 2\\nSkipping line 1842: expected 1 fields, saw 2\\nSkipping line 1843: expected 1 fields, saw 2\\nSkipping line 1844: expected 1 fields, saw 2\\nSkipping line 1845: expected 1 fields, saw 2\\nSkipping line 1846: expected 1 fields, saw 2\\nSkipping line 1847: expected 1 fields, saw 2\\nSkipping line 1848: expected 1 fields, saw 2\\nSkipping line 1849: expected 1 fields, saw 2\\nSkipping line 1850: expected 1 fields, saw 2\\nSkipping line 1851: expected 1 fields, saw 2\\nSkipping line 1852: expected 1 fields, saw 2\\nSkipping line 1853: expected 1 fields, saw 2\\nSkipping line 1854: expected 1 fields, saw 2\\nSkipping line 1855: expected 1 fields, saw 2\\nSkipping line 1856: expected 1 fields, saw 2\\nSkipping line 1857: expected 1 fields, saw 2\\nSkipping line 1858: expected 1 fields, saw 2\\nSkipping line 1859: expected 1 fields, saw 2\\nSkipping line 1860: expected 1 fields, saw 2\\nSkipping line 1861: expected 1 fields, saw 2\\nSkipping line 1862: expected 1 fields, saw 2\\nSkipping line 1863: expected 1 fields, saw 2\\nSkipping line 1864: expected 1 fields, saw 2\\nSkipping line 1865: expected 1 fields, saw 2\\nSkipping line 1866: expected 1 fields, saw 2\\nSkipping line 1867: expected 1 fields, saw 2\\nSkipping line 1868: expected 1 fields, saw 2\\nSkipping line 1869: expected 1 fields, saw 2\\nSkipping line 1870: expected 1 fields, saw 2\\nSkipping line 1871: expected 1 fields, saw 2\\nSkipping line 1872: expected 1 fields, saw 2\\nSkipping line 1873: expected 1 fields, saw 2\\nSkipping line 1874: expected 1 fields, saw 2\\nSkipping line 1875: expected 1 fields, saw 2\\nSkipping line 1876: expected 1 fields, saw 2\\nSkipping line 1877: expected 1 fields, saw 2\\nSkipping line 1878: expected 1 fields, saw 2\\nSkipping line 1879: expected 1 fields, saw 2\\nSkipping line 1880: expected 1 fields, saw 2\\nSkipping line 1881: expected 1 fields, saw 2\\nSkipping line 1882: expected 1 fields, saw 2\\nSkipping line 1883: expected 1 fields, saw 2\\nSkipping line 1884: expected 1 fields, saw 2\\nSkipping line 1885: expected 1 fields, saw 2\\nSkipping line 1886: expected 1 fields, saw 2\\nSkipping line 1887: expected 1 fields, saw 2\\nSkipping line 1888: expected 1 fields, saw 2\\nSkipping line 1889: expected 1 fields, saw 2\\nSkipping line 1890: expected 1 fields, saw 2\\nSkipping line 1891: expected 1 fields, saw 2\\nSkipping line 1892: expected 1 fields, saw 2\\nSkipping line 1893: expected 1 fields, saw 2\\nSkipping line 1894: expected 1 fields, saw 2\\nSkipping line 1895: expected 1 fields, saw 2\\nSkipping line 1896: expected 1 fields, saw 2\\nSkipping line 1897: expected 1 fields, saw 2\\nSkipping line 1898: expected 1 fields, saw 2\\nSkipping line 1899: expected 1 fields, saw 2\\nSkipping line 1900: expected 1 fields, saw 2\\nSkipping line 1901: expected 1 fields, saw 2\\nSkipping line 1902: expected 1 fields, saw 2\\nSkipping line 1903: expected 1 fields, saw 2\\nSkipping line 1904: expected 1 fields, saw 2\\nSkipping line 1905: expected 1 fields, saw 2\\nSkipping line 1906: expected 1 fields, saw 2\\nSkipping line 1907: expected 1 fields, saw 2\\nSkipping line 1908: expected 1 fields, saw 2\\nSkipping line 1909: expected 1 fields, saw 2\\nSkipping line 1910: expected 1 fields, saw 2\\nSkipping line 1911: expected 1 fields, saw 2\\nSkipping line 1912: expected 1 fields, saw 2\\nSkipping line 1913: expected 1 fields, saw 2\\nSkipping line 1914: expected 1 fields, saw 2\\nSkipping line 1915: expected 1 fields, saw 2\\nSkipping line 1916: expected 1 fields, saw 2\\nSkipping line 1917: expected 1 fields, saw 2\\nSkipping line 1918: expected 1 fields, saw 2\\nSkipping line 1919: expected 1 fields, saw 2\\nSkipping line 1920: expected 1 fields, saw 2\\nSkipping line 1921: expected 1 fields, saw 2\\nSkipping line 1922: expected 1 fields, saw 2\\nSkipping line 1923: expected 1 fields, saw 2\\nSkipping line 1924: expected 1 fields, saw 2\\nSkipping line 1925: expected 1 fields, saw 2\\nSkipping line 1926: expected 1 fields, saw 2\\nSkipping line 1927: expected 1 fields, saw 2\\nSkipping line 1928: expected 1 fields, saw 2\\nSkipping line 1929: expected 1 fields, saw 2\\nSkipping line 1930: expected 1 fields, saw 2\\nSkipping line 1931: expected 1 fields, saw 2\\nSkipping line 1932: expected 1 fields, saw 2\\nSkipping line 1933: expected 1 fields, saw 2\\nSkipping line 1934: expected 1 fields, saw 2\\nSkipping line 1935: expected 1 fields, saw 2\\nSkipping line 1936: expected 1 fields, saw 2\\nSkipping line 1937: expected 1 fields, saw 2\\nSkipping line 1938: expected 1 fields, saw 2\\nSkipping line 1939: expected 1 fields, saw 2\\nSkipping line 1940: expected 1 fields, saw 2\\nSkipping line 1941: expected 1 fields, saw 2\\nSkipping line 1942: expected 1 fields, saw 2\\nSkipping line 1943: expected 1 fields, saw 2\\nSkipping line 1944: expected 1 fields, saw 2\\nSkipping line 1945: expected 1 fields, saw 2\\nSkipping line 1946: expected 1 fields, saw 2\\nSkipping line 1947: expected 1 fields, saw 2\\nSkipping line 1948: expected 1 fields, saw 2\\nSkipping line 1949: expected 1 fields, saw 2\\nSkipping line 1950: expected 1 fields, saw 2\\nSkipping line 1951: expected 1 fields, saw 2\\nSkipping line 1952: expected 1 fields, saw 2\\nSkipping line 1953: expected 1 fields, saw 2\\nSkipping line 1954: expected 1 fields, saw 2\\nSkipping line 1955: expected 1 fields, saw 2\\nSkipping line 1956: expected 1 fields, saw 2\\nSkipping line 1957: expected 1 fields, saw 2\\nSkipping line 1958: expected 1 fields, saw 2\\nSkipping line 1959: expected 1 fields, saw 2\\nSkipping line 1960: expected 1 fields, saw 2\\nSkipping line 1961: expected 1 fields, saw 2\\nSkipping line 1962: expected 1 fields, saw 2\\nSkipping line 1963: expected 1 fields, saw 2\\nSkipping line 1964: expected 1 fields, saw 2\\nSkipping line 1965: expected 1 fields, saw 2\\nSkipping line 1966: expected 1 fields, saw 2\\nSkipping line 1967: expected 1 fields, saw 2\\nSkipping line 1968: expected 1 fields, saw 2\\nSkipping line 1969: expected 1 fields, saw 2\\nSkipping line 1970: expected 1 fields, saw 2\\nSkipping line 1971: expected 1 fields, saw 2\\nSkipping line 1972: expected 1 fields, saw 2\\nSkipping line 1973: expected 1 fields, saw 2\\nSkipping line 1974: expected 1 fields, saw 2\\nSkipping line 1975: expected 1 fields, saw 2\\nSkipping line 1976: expected 1 fields, saw 2\\nSkipping line 1977: expected 1 fields, saw 2\\nSkipping line 1978: expected 1 fields, saw 2\\nSkipping line 1979: expected 1 fields, saw 2\\nSkipping line 1980: expected 1 fields, saw 2\\nSkipping line 1981: expected 1 fields, saw 2\\nSkipping line 1982: expected 1 fields, saw 2\\nSkipping line 1983: expected 1 fields, saw 2\\nSkipping line 1984: expected 1 fields, saw 2\\nSkipping line 1985: expected 1 fields, saw 2\\nSkipping line 1986: expected 1 fields, saw 2\\nSkipping line 1987: expected 1 fields, saw 2\\nSkipping line 1988: expected 1 fields, saw 2\\nSkipping line 1989: expected 1 fields, saw 2\\nSkipping line 1990: expected 1 fields, saw 2\\nSkipping line 1991: expected 1 fields, saw 2\\nSkipping line 1992: expected 1 fields, saw 2\\nSkipping line 1993: expected 1 fields, saw 2\\nSkipping line 1994: expected 1 fields, saw 2\\nSkipping line 1995: expected 1 fields, saw 2\\nSkipping line 1996: expected 1 fields, saw 2\\nSkipping line 1997: expected 1 fields, saw 2\\nSkipping line 1998: expected 1 fields, saw 2\\nSkipping line 1999: expected 1 fields, saw 2\\nSkipping line 2000: expected 1 fields, saw 2\\nSkipping line 2001: expected 1 fields, saw 2\\nSkipping line 2002: expected 1 fields, saw 2\\nSkipping line 2003: expected 1 fields, saw 2\\nSkipping line 2004: expected 1 fields, saw 2\\nSkipping line 2005: expected 1 fields, saw 2\\nSkipping line 2006: expected 1 fields, saw 2\\nSkipping line 2007: expected 1 fields, saw 2\\nSkipping line 2008: expected 1 fields, saw 2\\nSkipping line 2009: expected 1 fields, saw 2\\nSkipping line 2010: expected 1 fields, saw 2\\nSkipping line 2011: expected 1 fields, saw 2\\nSkipping line 2012: expected 1 fields, saw 2\\nSkipping line 2013: expected 1 fields, saw 2\\nSkipping line 2014: expected 1 fields, saw 2\\nSkipping line 2015: expected 1 fields, saw 2\\nSkipping line 2016: expected 1 fields, saw 2\\nSkipping line 2017: expected 1 fields, saw 2\\nSkipping line 2018: expected 1 fields, saw 2\\nSkipping line 2019: expected 1 fields, saw 2\\nSkipping line 2020: expected 1 fields, saw 2\\nSkipping line 2021: expected 1 fields, saw 2\\nSkipping line 2022: expected 1 fields, saw 2\\nSkipping line 2023: expected 1 fields, saw 2\\nSkipping line 2024: expected 1 fields, saw 2\\nSkipping line 2025: expected 1 fields, saw 2\\nSkipping line 2026: expected 1 fields, saw 2\\nSkipping line 2027: expected 1 fields, saw 2\\nSkipping line 2028: expected 1 fields, saw 2\\nSkipping line 2029: expected 1 fields, saw 2\\nSkipping line 2030: expected 1 fields, saw 2\\nSkipping line 2031: expected 1 fields, saw 2\\nSkipping line 2032: expected 1 fields, saw 2\\nSkipping line 2033: expected 1 fields, saw 2\\nSkipping line 2034: expected 1 fields, saw 2\\nSkipping line 2035: expected 1 fields, saw 2\\nSkipping line 2036: expected 1 fields, saw 2\\nSkipping line 2037: expected 1 fields, saw 2\\nSkipping line 2038: expected 1 fields, saw 2\\nSkipping line 2039: expected 1 fields, saw 2\\nSkipping line 2040: expected 1 fields, saw 2\\nSkipping line 2041: expected 1 fields, saw 2\\nSkipping line 2042: expected 1 fields, saw 2\\nSkipping line 2043: expected 1 fields, saw 2\\nSkipping line 2044: expected 1 fields, saw 2\\nSkipping line 2045: expected 1 fields, saw 2\\nSkipping line 2046: expected 1 fields, saw 2\\nSkipping line 2047: expected 1 fields, saw 2\\nSkipping line 2048: expected 1 fields, saw 2\\nSkipping line 2049: expected 1 fields, saw 2\\nSkipping line 2050: expected 1 fields, saw 2\\nSkipping line 2051: expected 1 fields, saw 2\\nSkipping line 2052: expected 1 fields, saw 2\\nSkipping line 2053: expected 1 fields, saw 2\\nSkipping line 2054: expected 1 fields, saw 2\\nSkipping line 2055: expected 1 fields, saw 2\\nSkipping line 2056: expected 1 fields, saw 2\\nSkipping line 2057: expected 1 fields, saw 2\\nSkipping line 2058: expected 1 fields, saw 2\\nSkipping line 2059: expected 1 fields, saw 2\\nSkipping line 2060: expected 1 fields, saw 2\\nSkipping line 2061: expected 1 fields, saw 2\\nSkipping line 2062: expected 1 fields, saw 2\\nSkipping line 2063: expected 1 fields, saw 2\\nSkipping line 2064: expected 1 fields, saw 2\\nSkipping line 2065: expected 1 fields, saw 2\\nSkipping line 2066: expected 1 fields, saw 2\\nSkipping line 2067: expected 1 fields, saw 2\\nSkipping line 2068: expected 1 fields, saw 2\\nSkipping line 2069: expected 1 fields, saw 2\\nSkipping line 2070: expected 1 fields, saw 2\\nSkipping line 2071: expected 1 fields, saw 2\\nSkipping line 2072: expected 1 fields, saw 2\\nSkipping line 2073: expected 1 fields, saw 2\\nSkipping line 2074: expected 1 fields, saw 2\\nSkipping line 2075: expected 1 fields, saw 2\\nSkipping line 2076: expected 1 fields, saw 2\\nSkipping line 2077: expected 1 fields, saw 2\\nSkipping line 2078: expected 1 fields, saw 2\\nSkipping line 2079: expected 1 fields, saw 2\\nSkipping line 2080: expected 1 fields, saw 2\\nSkipping line 2081: expected 1 fields, saw 2\\nSkipping line 2082: expected 1 fields, saw 2\\nSkipping line 2083: expected 1 fields, saw 2\\nSkipping line 2084: expected 1 fields, saw 2\\nSkipping line 2085: expected 1 fields, saw 2\\nSkipping line 2086: expected 1 fields, saw 2\\nSkipping line 2087: expected 1 fields, saw 2\\nSkipping line 2088: expected 1 fields, saw 2\\nSkipping line 2089: expected 1 fields, saw 2\\nSkipping line 2090: expected 1 fields, saw 2\\nSkipping line 2091: expected 1 fields, saw 2\\nSkipping line 2092: expected 1 fields, saw 2\\nSkipping line 2093: expected 1 fields, saw 2\\nSkipping line 2094: expected 1 fields, saw 2\\nSkipping line 2095: expected 1 fields, saw 2\\nSkipping line 2096: expected 1 fields, saw 2\\nSkipping line 2097: expected 1 fields, saw 2\\nSkipping line 2098: expected 1 fields, saw 2\\nSkipping line 2099: expected 1 fields, saw 2\\nSkipping line 2100: expected 1 fields, saw 2\\nSkipping line 2101: expected 1 fields, saw 2\\nSkipping line 2102: expected 1 fields, saw 2\\nSkipping line 2103: expected 1 fields, saw 2\\nSkipping line 2104: expected 1 fields, saw 2\\nSkipping line 2105: expected 1 fields, saw 2\\nSkipping line 2106: expected 1 fields, saw 2\\nSkipping line 2107: expected 1 fields, saw 2\\nSkipping line 2108: expected 1 fields, saw 2\\nSkipping line 2109: expected 1 fields, saw 2\\nSkipping line 2110: expected 1 fields, saw 2\\nSkipping line 2111: expected 1 fields, saw 2\\nSkipping line 2112: expected 1 fields, saw 2\\nSkipping line 2113: expected 1 fields, saw 2\\nSkipping line 2114: expected 1 fields, saw 2\\nSkipping line 2115: expected 1 fields, saw 2\\nSkipping line 2116: expected 1 fields, saw 2\\nSkipping line 2117: expected 1 fields, saw 2\\nSkipping line 2118: expected 1 fields, saw 2\\nSkipping line 2119: expected 1 fields, saw 2\\nSkipping line 2120: expected 1 fields, saw 2\\nSkipping line 2121: expected 1 fields, saw 2\\nSkipping line 2122: expected 1 fields, saw 2\\nSkipping line 2123: expected 1 fields, saw 2\\nSkipping line 2124: expected 1 fields, saw 2\\nSkipping line 2125: expected 1 fields, saw 2\\nSkipping line 2126: expected 1 fields, saw 2\\nSkipping line 2127: expected 1 fields, saw 2\\nSkipping line 2128: expected 1 fields, saw 2\\nSkipping line 2129: expected 1 fields, saw 2\\nSkipping line 2130: expected 1 fields, saw 2\\nSkipping line 2131: expected 1 fields, saw 2\\nSkipping line 2132: expected 1 fields, saw 2\\nSkipping line 2133: expected 1 fields, saw 2\\nSkipping line 2134: expected 1 fields, saw 2\\nSkipping line 2135: expected 1 fields, saw 2\\nSkipping line 2136: expected 1 fields, saw 2\\nSkipping line 2137: expected 1 fields, saw 2\\nSkipping line 2138: expected 1 fields, saw 2\\nSkipping line 2139: expected 1 fields, saw 2\\nSkipping line 2140: expected 1 fields, saw 2\\nSkipping line 2141: expected 1 fields, saw 2\\nSkipping line 2142: expected 1 fields, saw 2\\nSkipping line 2143: expected 1 fields, saw 2\\nSkipping line 2144: expected 1 fields, saw 2\\nSkipping line 2145: expected 1 fields, saw 2\\nSkipping line 2146: expected 1 fields, saw 2\\nSkipping line 2147: expected 1 fields, saw 2\\nSkipping line 2148: expected 1 fields, saw 2\\nSkipping line 2149: expected 1 fields, saw 2\\nSkipping line 2150: expected 1 fields, saw 2\\nSkipping line 2151: expected 1 fields, saw 2\\nSkipping line 2152: expected 1 fields, saw 2\\nSkipping line 2153: expected 1 fields, saw 2\\nSkipping line 2154: expected 1 fields, saw 2\\nSkipping line 2155: expected 1 fields, saw 2\\nSkipping line 2156: expected 1 fields, saw 2\\nSkipping line 2157: expected 1 fields, saw 2\\nSkipping line 2158: expected 1 fields, saw 2\\nSkipping line 2159: expected 1 fields, saw 2\\nSkipping line 2160: expected 1 fields, saw 2\\nSkipping line 2161: expected 1 fields, saw 2\\nSkipping line 2162: expected 1 fields, saw 2\\nSkipping line 2163: expected 1 fields, saw 2\\nSkipping line 2164: expected 1 fields, saw 2\\nSkipping line 2165: expected 1 fields, saw 2\\nSkipping line 2166: expected 1 fields, saw 2\\nSkipping line 2167: expected 1 fields, saw 2\\nSkipping line 2168: expected 1 fields, saw 2\\nSkipping line 2169: expected 1 fields, saw 2\\nSkipping line 2170: expected 1 fields, saw 2\\nSkipping line 2171: expected 1 fields, saw 2\\nSkipping line 2172: expected 1 fields, saw 2\\nSkipping line 2173: expected 1 fields, saw 2\\nSkipping line 2174: expected 1 fields, saw 2\\nSkipping line 2175: expected 1 fields, saw 2\\nSkipping line 2176: expected 1 fields, saw 2\\nSkipping line 2177: expected 1 fields, saw 2\\nSkipping line 2178: expected 1 fields, saw 2\\nSkipping line 2179: expected 1 fields, saw 2\\nSkipping line 2180: expected 1 fields, saw 2\\nSkipping line 2181: expected 1 fields, saw 2\\nSkipping line 2182: expected 1 fields, saw 2\\nSkipping line 2183: expected 1 fields, saw 2\\nSkipping line 2184: expected 1 fields, saw 2\\nSkipping line 2185: expected 1 fields, saw 2\\nSkipping line 2186: expected 1 fields, saw 2\\nSkipping line 2187: expected 1 fields, saw 2\\nSkipping line 2188: expected 1 fields, saw 2\\nSkipping line 2189: expected 1 fields, saw 2\\nSkipping line 2190: expected 1 fields, saw 2\\nSkipping line 2191: expected 1 fields, saw 2\\nSkipping line 2192: expected 1 fields, saw 2\\nSkipping line 2193: expected 1 fields, saw 2\\nSkipping line 2194: expected 1 fields, saw 2\\nSkipping line 2195: expected 1 fields, saw 2\\nSkipping line 2196: expected 1 fields, saw 2\\nSkipping line 2197: expected 1 fields, saw 2\\nSkipping line 2198: expected 1 fields, saw 2\\nSkipping line 2199: expected 1 fields, saw 2\\nSkipping line 2200: expected 1 fields, saw 2\\nSkipping line 2201: expected 1 fields, saw 2\\nSkipping line 2202: expected 1 fields, saw 2\\nSkipping line 2203: expected 1 fields, saw 2\\nSkipping line 2204: expected 1 fields, saw 2\\nSkipping line 2205: expected 1 fields, saw 2\\nSkipping line 2206: expected 1 fields, saw 2\\nSkipping line 2207: expected 1 fields, saw 2\\nSkipping line 2208: expected 1 fields, saw 2\\nSkipping line 2209: expected 1 fields, saw 2\\nSkipping line 2210: expected 1 fields, saw 2\\nSkipping line 2211: expected 1 fields, saw 2\\nSkipping line 2212: expected 1 fields, saw 2\\nSkipping line 2213: expected 1 fields, saw 2\\nSkipping line 2214: expected 1 fields, saw 2\\nSkipping line 2215: expected 1 fields, saw 2\\nSkipping line 2216: expected 1 fields, saw 2\\nSkipping line 2217: expected 1 fields, saw 2\\nSkipping line 2218: expected 1 fields, saw 2\\nSkipping line 2219: expected 1 fields, saw 2\\nSkipping line 2220: expected 1 fields, saw 2\\nSkipping line 2221: expected 1 fields, saw 2\\nSkipping line 2222: expected 1 fields, saw 2\\nSkipping line 2223: expected 1 fields, saw 2\\nSkipping line 2224: expected 1 fields, saw 2\\nSkipping line 2225: expected 1 fields, saw 2\\nSkipping line 2226: expected 1 fields, saw 2\\nSkipping line 2227: expected 1 fields, saw 2\\nSkipping line 2228: expected 1 fields, saw 2\\nSkipping line 2229: expected 1 fields, saw 2\\nSkipping line 2230: expected 1 fields, saw 2\\nSkipping line 2231: expected 1 fields, saw 2\\nSkipping line 2232: expected 1 fields, saw 2\\nSkipping line 2233: expected 1 fields, saw 2\\nSkipping line 2234: expected 1 fields, saw 2\\nSkipping line 2235: expected 1 fields, saw 2\\nSkipping line 2236: expected 1 fields, saw 2\\nSkipping line 2237: expected 1 fields, saw 2\\nSkipping line 2238: expected 1 fields, saw 2\\nSkipping line 2239: expected 1 fields, saw 2\\nSkipping line 2240: expected 1 fields, saw 2\\nSkipping line 2241: expected 1 fields, saw 2\\nSkipping line 2242: expected 1 fields, saw 2\\nSkipping line 2243: expected 1 fields, saw 2\\nSkipping line 2244: expected 1 fields, saw 2\\nSkipping line 2245: expected 1 fields, saw 2\\nSkipping line 2246: expected 1 fields, saw 2\\nSkipping line 2247: expected 1 fields, saw 2\\nSkipping line 2248: expected 1 fields, saw 2\\nSkipping line 2249: expected 1 fields, saw 2\\nSkipping line 2250: expected 1 fields, saw 2\\nSkipping line 2251: expected 1 fields, saw 2\\nSkipping line 2252: expected 1 fields, saw 2\\nSkipping line 2253: expected 1 fields, saw 2\\nSkipping line 2254: expected 1 fields, saw 2\\nSkipping line 2255: expected 1 fields, saw 2\\nSkipping line 2256: expected 1 fields, saw 2\\nSkipping line 2257: expected 1 fields, saw 2\\nSkipping line 2258: expected 1 fields, saw 2\\nSkipping line 2259: expected 1 fields, saw 2\\nSkipping line 2260: expected 1 fields, saw 2\\nSkipping line 2261: expected 1 fields, saw 2\\nSkipping line 2262: expected 1 fields, saw 2\\nSkipping line 2263: expected 1 fields, saw 2\\nSkipping line 2264: expected 1 fields, saw 2\\nSkipping line 2265: expected 1 fields, saw 2\\nSkipping line 2266: expected 1 fields, saw 2\\nSkipping line 2267: expected 1 fields, saw 2\\nSkipping line 2268: expected 1 fields, saw 2\\nSkipping line 2269: expected 1 fields, saw 2\\nSkipping line 2270: expected 1 fields, saw 2\\nSkipping line 2271: expected 1 fields, saw 2\\nSkipping line 2272: expected 1 fields, saw 2\\nSkipping line 2273: expected 1 fields, saw 2\\nSkipping line 2274: expected 1 fields, saw 2\\nSkipping line 2275: expected 1 fields, saw 2\\nSkipping line 2276: expected 1 fields, saw 2\\nSkipping line 2277: expected 1 fields, saw 2\\nSkipping line 2278: expected 1 fields, saw 2\\nSkipping line 2279: expected 1 fields, saw 2\\nSkipping line 2280: expected 1 fields, saw 2\\nSkipping line 2281: expected 1 fields, saw 2\\nSkipping line 2282: expected 1 fields, saw 2\\nSkipping line 2283: expected 1 fields, saw 2\\nSkipping line 2284: expected 1 fields, saw 2\\nSkipping line 2285: expected 1 fields, saw 2\\nSkipping line 2286: expected 1 fields, saw 2\\nSkipping line 2287: expected 1 fields, saw 2\\nSkipping line 2288: expected 1 fields, saw 2\\nSkipping line 2289: expected 1 fields, saw 2\\nSkipping line 2290: expected 1 fields, saw 2\\nSkipping line 2291: expected 1 fields, saw 2\\nSkipping line 2292: expected 1 fields, saw 2\\nSkipping line 2293: expected 1 fields, saw 2\\nSkipping line 2294: expected 1 fields, saw 2\\nSkipping line 2295: expected 1 fields, saw 2\\nSkipping line 2296: expected 1 fields, saw 2\\nSkipping line 2297: expected 1 fields, saw 2\\nSkipping line 2298: expected 1 fields, saw 2\\nSkipping line 2299: expected 1 fields, saw 2\\nSkipping line 2300: expected 1 fields, saw 2\\nSkipping line 2301: expected 1 fields, saw 2\\nSkipping line 2302: expected 1 fields, saw 2\\nSkipping line 2303: expected 1 fields, saw 2\\nSkipping line 2304: expected 1 fields, saw 2\\nSkipping line 2305: expected 1 fields, saw 2\\nSkipping line 2306: expected 1 fields, saw 2\\nSkipping line 2307: expected 1 fields, saw 2\\nSkipping line 2308: expected 1 fields, saw 2\\nSkipping line 2309: expected 1 fields, saw 2\\nSkipping line 2310: expected 1 fields, saw 2\\nSkipping line 2311: expected 1 fields, saw 2\\nSkipping line 2312: expected 1 fields, saw 2\\nSkipping line 2313: expected 1 fields, saw 2\\nSkipping line 2314: expected 1 fields, saw 2\\nSkipping line 2315: expected 1 fields, saw 2\\nSkipping line 2316: expected 1 fields, saw 2\\nSkipping line 2317: expected 1 fields, saw 2\\nSkipping line 2318: expected 1 fields, saw 2\\nSkipping line 2319: expected 1 fields, saw 2\\nSkipping line 2320: expected 1 fields, saw 2\\nSkipping line 2321: expected 1 fields, saw 2\\nSkipping line 2322: expected 1 fields, saw 2\\nSkipping line 2323: expected 1 fields, saw 2\\nSkipping line 2324: expected 1 fields, saw 2\\nSkipping line 2325: expected 1 fields, saw 2\\nSkipping line 2326: expected 1 fields, saw 2\\nSkipping line 2327: expected 1 fields, saw 2\\nSkipping line 2328: expected 1 fields, saw 2\\nSkipping line 2329: expected 1 fields, saw 2\\nSkipping line 2330: expected 1 fields, saw 2\\nSkipping line 2331: expected 1 fields, saw 2\\nSkipping line 2332: expected 1 fields, saw 2\\nSkipping line 2333: expected 1 fields, saw 2\\nSkipping line 2334: expected 1 fields, saw 2\\nSkipping line 2335: expected 1 fields, saw 2\\nSkipping line 2336: expected 1 fields, saw 2\\nSkipping line 2337: expected 1 fields, saw 2\\nSkipping line 2338: expected 1 fields, saw 2\\nSkipping line 2339: expected 1 fields, saw 2\\nSkipping line 2340: expected 1 fields, saw 2\\nSkipping line 2341: expected 1 fields, saw 2\\nSkipping line 2342: expected 1 fields, saw 2\\nSkipping line 2343: expected 1 fields, saw 2\\nSkipping line 2344: expected 1 fields, saw 2\\nSkipping line 2345: expected 1 fields, saw 2\\nSkipping line 2346: expected 1 fields, saw 2\\nSkipping line 2347: expected 1 fields, saw 2\\nSkipping line 2348: expected 1 fields, saw 2\\nSkipping line 2349: expected 1 fields, saw 2\\nSkipping line 2350: expected 1 fields, saw 2\\nSkipping line 2351: expected 1 fields, saw 2\\nSkipping line 2352: expected 1 fields, saw 2\\nSkipping line 2353: expected 1 fields, saw 2\\nSkipping line 2354: expected 1 fields, saw 2\\nSkipping line 2355: expected 1 fields, saw 2\\nSkipping line 2356: expected 1 fields, saw 2\\nSkipping line 2357: expected 1 fields, saw 2\\nSkipping line 2358: expected 1 fields, saw 2\\nSkipping line 2359: expected 1 fields, saw 2\\nSkipping line 2360: expected 1 fields, saw 2\\nSkipping line 2361: expected 1 fields, saw 2\\nSkipping line 2362: expected 1 fields, saw 2\\nSkipping line 2363: expected 1 fields, saw 2\\nSkipping line 2364: expected 1 fields, saw 2\\nSkipping line 2365: expected 1 fields, saw 2\\nSkipping line 2366: expected 1 fields, saw 2\\nSkipping line 2367: expected 1 fields, saw 2\\nSkipping line 2368: expected 1 fields, saw 2\\nSkipping line 2369: expected 1 fields, saw 2\\nSkipping line 2370: expected 1 fields, saw 2\\nSkipping line 2371: expected 1 fields, saw 2\\nSkipping line 2372: expected 1 fields, saw 2\\nSkipping line 2373: expected 1 fields, saw 2\\nSkipping line 2374: expected 1 fields, saw 2\\nSkipping line 2375: expected 1 fields, saw 2\\nSkipping line 2376: expected 1 fields, saw 2\\nSkipping line 2377: expected 1 fields, saw 2\\nSkipping line 2378: expected 1 fields, saw 2\\nSkipping line 2379: expected 1 fields, saw 2\\nSkipping line 2380: expected 1 fields, saw 2\\nSkipping line 2381: expected 1 fields, saw 2\\nSkipping line 2382: expected 1 fields, saw 2\\nSkipping line 2383: expected 1 fields, saw 2\\nSkipping line 2384: expected 1 fields, saw 2\\nSkipping line 2385: expected 1 fields, saw 2\\nSkipping line 2386: expected 1 fields, saw 2\\nSkipping line 2387: expected 1 fields, saw 2\\nSkipping line 2388: expected 1 fields, saw 2\\nSkipping line 2389: expected 1 fields, saw 2\\nSkipping line 2390: expected 1 fields, saw 2\\nSkipping line 2391: expected 1 fields, saw 2\\nSkipping line 2392: expected 1 fields, saw 2\\nSkipping line 2393: expected 1 fields, saw 2\\nSkipping line 2394: expected 1 fields, saw 2\\nSkipping line 2395: expected 1 fields, saw 2\\nSkipping line 2396: expected 1 fields, saw 2\\nSkipping line 2397: expected 1 fields, saw 2\\nSkipping line 2398: expected 1 fields, saw 2\\nSkipping line 2399: expected 1 fields, saw 2\\nSkipping line 2400: expected 1 fields, saw 2\\nSkipping line 2401: expected 1 fields, saw 2\\nSkipping line 2402: expected 1 fields, saw 2\\nSkipping line 2403: expected 1 fields, saw 2\\nSkipping line 2404: expected 1 fields, saw 2\\nSkipping line 2405: expected 1 fields, saw 2\\nSkipping line 2406: expected 1 fields, saw 2\\nSkipping line 2407: expected 1 fields, saw 2\\nSkipping line 2408: expected 1 fields, saw 2\\nSkipping line 2409: expected 1 fields, saw 2\\nSkipping line 2410: expected 1 fields, saw 2\\nSkipping line 2411: expected 1 fields, saw 2\\nSkipping line 2412: expected 1 fields, saw 2\\nSkipping line 2413: expected 1 fields, saw 2\\nSkipping line 2414: expected 1 fields, saw 2\\nSkipping line 2415: expected 1 fields, saw 2\\nSkipping line 2416: expected 1 fields, saw 2\\nSkipping line 2417: expected 1 fields, saw 2\\nSkipping line 2418: expected 1 fields, saw 2\\nSkipping line 2419: expected 1 fields, saw 2\\nSkipping line 2420: expected 1 fields, saw 2\\nSkipping line 2421: expected 1 fields, saw 2\\nSkipping line 2422: expected 1 fields, saw 2\\nSkipping line 2423: expected 1 fields, saw 2\\nSkipping line 2424: expected 1 fields, saw 2\\nSkipping line 2425: expected 1 fields, saw 2\\nSkipping line 2426: expected 1 fields, saw 2\\nSkipping line 2427: expected 1 fields, saw 2\\nSkipping line 2428: expected 1 fields, saw 2\\nSkipping line 2429: expected 1 fields, saw 2\\nSkipping line 2430: expected 1 fields, saw 2\\nSkipping line 2431: expected 1 fields, saw 2\\nSkipping line 2432: expected 1 fields, saw 2\\nSkipping line 2433: expected 1 fields, saw 2\\nSkipping line 2434: expected 1 fields, saw 2\\nSkipping line 2435: expected 1 fields, saw 2\\nSkipping line 2436: expected 1 fields, saw 2\\nSkipping line 2437: expected 1 fields, saw 2\\nSkipping line 2438: expected 1 fields, saw 2\\nSkipping line 2439: expected 1 fields, saw 2\\nSkipping line 2440: expected 1 fields, saw 2\\nSkipping line 2441: expected 1 fields, saw 2\\nSkipping line 2442: expected 1 fields, saw 2\\nSkipping line 2443: expected 1 fields, saw 2\\nSkipping line 2444: expected 1 fields, saw 2\\nSkipping line 2445: expected 1 fields, saw 2\\nSkipping line 2446: expected 1 fields, saw 2\\nSkipping line 2447: expected 1 fields, saw 2\\nSkipping line 2448: expected 1 fields, saw 2\\nSkipping line 2449: expected 1 fields, saw 2\\nSkipping line 2450: expected 1 fields, saw 2\\nSkipping line 2451: expected 1 fields, saw 2\\nSkipping line 2452: expected 1 fields, saw 2\\nSkipping line 2453: expected 1 fields, saw 2\\nSkipping line 2454: expected 1 fields, saw 2\\nSkipping line 2455: expected 1 fields, saw 2\\nSkipping line 2456: expected 1 fields, saw 2\\nSkipping line 2457: expected 1 fields, saw 2\\nSkipping line 2458: expected 1 fields, saw 2\\nSkipping line 2459: expected 1 fields, saw 2\\nSkipping line 2460: expected 1 fields, saw 2\\nSkipping line 2461: expected 1 fields, saw 2\\nSkipping line 2462: expected 1 fields, saw 2\\nSkipping line 2463: expected 1 fields, saw 2\\nSkipping line 2464: expected 1 fields, saw 2\\nSkipping line 2465: expected 1 fields, saw 2\\nSkipping line 2466: expected 1 fields, saw 2\\nSkipping line 2467: expected 1 fields, saw 2\\nSkipping line 2468: expected 1 fields, saw 2\\nSkipping line 2469: expected 1 fields, saw 2\\nSkipping line 2470: expected 1 fields, saw 2\\nSkipping line 2471: expected 1 fields, saw 2\\nSkipping line 2472: expected 1 fields, saw 2\\nSkipping line 2473: expected 1 fields, saw 2\\nSkipping line 2474: expected 1 fields, saw 2\\nSkipping line 2475: expected 1 fields, saw 2\\nSkipping line 2476: expected 1 fields, saw 2\\nSkipping line 2477: expected 1 fields, saw 2\\nSkipping line 2478: expected 1 fields, saw 2\\nSkipping line 2479: expected 1 fields, saw 2\\nSkipping line 2480: expected 1 fields, saw 2\\nSkipping line 2481: expected 1 fields, saw 2\\nSkipping line 2482: expected 1 fields, saw 2\\nSkipping line 2483: expected 1 fields, saw 2\\nSkipping line 2484: expected 1 fields, saw 2\\nSkipping line 2485: expected 1 fields, saw 2\\nSkipping line 2486: expected 1 fields, saw 2\\nSkipping line 2487: expected 1 fields, saw 2\\nSkipping line 2488: expected 1 fields, saw 2\\nSkipping line 2489: expected 1 fields, saw 2\\nSkipping line 2490: expected 1 fields, saw 2\\nSkipping line 2491: expected 1 fields, saw 2\\nSkipping line 2492: expected 1 fields, saw 2\\nSkipping line 2493: expected 1 fields, saw 2\\nSkipping line 2494: expected 1 fields, saw 2\\nSkipping line 2495: expected 1 fields, saw 2\\nSkipping line 2496: expected 1 fields, saw 2\\nSkipping line 2497: expected 1 fields, saw 2\\nSkipping line 2498: expected 1 fields, saw 2\\nSkipping line 2499: expected 1 fields, saw 2\\nSkipping line 2500: expected 1 fields, saw 2\\nSkipping line 2501: expected 1 fields, saw 2\\nSkipping line 2502: expected 1 fields, saw 2\\nSkipping line 2503: expected 1 fields, saw 2\\nSkipping line 2504: expected 1 fields, saw 2\\nSkipping line 2505: expected 1 fields, saw 2\\nSkipping line 2506: expected 1 fields, saw 2\\nSkipping line 2507: expected 1 fields, saw 2\\nSkipping line 2508: expected 1 fields, saw 2\\nSkipping line 2509: expected 1 fields, saw 2\\nSkipping line 2510: expected 1 fields, saw 2\\nSkipping line 2511: expected 1 fields, saw 2\\nSkipping line 2512: expected 1 fields, saw 2\\nSkipping line 2513: expected 1 fields, saw 2\\nSkipping line 2514: expected 1 fields, saw 2\\nSkipping line 2515: expected 1 fields, saw 2\\nSkipping line 2516: expected 1 fields, saw 2\\nSkipping line 2517: expected 1 fields, saw 2\\nSkipping line 2518: expected 1 fields, saw 2\\nSkipping line 2519: expected 1 fields, saw 2\\nSkipping line 2520: expected 1 fields, saw 2\\nSkipping line 2521: expected 1 fields, saw 2\\nSkipping line 2522: expected 1 fields, saw 2\\nSkipping line 2523: expected 1 fields, saw 2\\nSkipping line 2524: expected 1 fields, saw 2\\nSkipping line 2525: expected 1 fields, saw 2\\nSkipping line 2526: expected 1 fields, saw 2\\nSkipping line 2527: expected 1 fields, saw 2\\nSkipping line 2528: expected 1 fields, saw 2\\nSkipping line 2529: expected 1 fields, saw 2\\nSkipping line 2530: expected 1 fields, saw 2\\nSkipping line 2531: expected 1 fields, saw 2\\nSkipping line 2532: expected 1 fields, saw 2\\nSkipping line 2533: expected 1 fields, saw 2\\nSkipping line 2534: expected 1 fields, saw 2\\nSkipping line 2535: expected 1 fields, saw 2\\nSkipping line 2536: expected 1 fields, saw 2\\nSkipping line 2537: expected 1 fields, saw 2\\nSkipping line 2538: expected 1 fields, saw 2\\nSkipping line 2539: expected 1 fields, saw 2\\nSkipping line 2540: expected 1 fields, saw 2\\nSkipping line 2541: expected 1 fields, saw 2\\nSkipping line 2542: expected 1 fields, saw 2\\nSkipping line 2543: expected 1 fields, saw 2\\nSkipping line 2544: expected 1 fields, saw 2\\nSkipping line 2545: expected 1 fields, saw 2\\nSkipping line 2546: expected 1 fields, saw 2\\nSkipping line 2547: expected 1 fields, saw 2\\nSkipping line 2548: expected 1 fields, saw 2\\nSkipping line 2549: expected 1 fields, saw 2\\nSkipping line 2550: expected 1 fields, saw 2\\nSkipping line 2551: expected 1 fields, saw 2\\nSkipping line 2552: expected 1 fields, saw 2\\nSkipping line 2553: expected 1 fields, saw 2\\nSkipping line 2554: expected 1 fields, saw 2\\nSkipping line 2555: expected 1 fields, saw 2\\nSkipping line 2556: expected 1 fields, saw 2\\nSkipping line 2557: expected 1 fields, saw 2\\nSkipping line 2558: expected 1 fields, saw 2\\nSkipping line 2559: expected 1 fields, saw 2\\nSkipping line 2560: expected 1 fields, saw 2\\nSkipping line 2561: expected 1 fields, saw 2\\nSkipping line 2562: expected 1 fields, saw 2\\nSkipping line 2563: expected 1 fields, saw 2\\nSkipping line 2564: expected 1 fields, saw 2\\nSkipping line 2565: expected 1 fields, saw 2\\nSkipping line 2566: expected 1 fields, saw 2\\nSkipping line 2567: expected 1 fields, saw 2\\nSkipping line 2568: expected 1 fields, saw 2\\nSkipping line 2569: expected 1 fields, saw 2\\nSkipping line 2570: expected 1 fields, saw 2\\nSkipping line 2571: expected 1 fields, saw 2\\nSkipping line 2572: expected 1 fields, saw 2\\nSkipping line 2573: expected 1 fields, saw 2\\nSkipping line 2574: expected 1 fields, saw 2\\nSkipping line 2575: expected 1 fields, saw 2\\nSkipping line 2576: expected 1 fields, saw 2\\nSkipping line 2577: expected 1 fields, saw 2\\nSkipping line 2578: expected 1 fields, saw 2\\nSkipping line 2579: expected 1 fields, saw 2\\nSkipping line 2580: expected 1 fields, saw 2\\nSkipping line 2581: expected 1 fields, saw 2\\nSkipping line 2582: expected 1 fields, saw 2\\nSkipping line 2583: expected 1 fields, saw 2\\nSkipping line 2584: expected 1 fields, saw 2\\nSkipping line 2585: expected 1 fields, saw 2\\nSkipping line 2586: expected 1 fields, saw 2\\nSkipping line 2587: expected 1 fields, saw 2\\nSkipping line 2588: expected 1 fields, saw 2\\nSkipping line 2589: expected 1 fields, saw 2\\nSkipping line 2590: expected 1 fields, saw 2\\nSkipping line 2591: expected 1 fields, saw 2\\nSkipping line 2592: expected 1 fields, saw 2\\nSkipping line 2593: expected 1 fields, saw 2\\nSkipping line 2594: expected 1 fields, saw 2\\nSkipping line 2595: expected 1 fields, saw 2\\nSkipping line 2596: expected 1 fields, saw 2\\nSkipping line 2597: expected 1 fields, saw 2\\nSkipping line 2598: expected 1 fields, saw 2\\nSkipping line 2599: expected 1 fields, saw 2\\nSkipping line 2600: expected 1 fields, saw 2\\nSkipping line 2601: expected 1 fields, saw 2\\nSkipping line 2602: expected 1 fields, saw 2\\nSkipping line 2603: expected 1 fields, saw 2\\nSkipping line 2604: expected 1 fields, saw 2\\nSkipping line 2605: expected 1 fields, saw 2\\nSkipping line 2606: expected 1 fields, saw 2\\nSkipping line 2607: expected 1 fields, saw 2\\nSkipping line 2608: expected 1 fields, saw 2\\nSkipping line 2609: expected 1 fields, saw 2\\nSkipping line 2610: expected 1 fields, saw 2\\nSkipping line 2611: expected 1 fields, saw 2\\nSkipping line 2612: expected 1 fields, saw 2\\nSkipping line 2613: expected 1 fields, saw 2\\nSkipping line 2614: expected 1 fields, saw 2\\nSkipping line 2615: expected 1 fields, saw 2\\nSkipping line 2616: expected 1 fields, saw 2\\nSkipping line 2617: expected 1 fields, saw 2\\nSkipping line 2618: expected 1 fields, saw 2\\nSkipping line 2619: expected 1 fields, saw 2\\nSkipping line 2620: expected 1 fields, saw 2\\nSkipping line 2621: expected 1 fields, saw 2\\nSkipping line 2622: expected 1 fields, saw 2\\nSkipping line 2623: expected 1 fields, saw 2\\nSkipping line 2624: expected 1 fields, saw 2\\nSkipping line 2625: expected 1 fields, saw 2\\nSkipping line 2626: expected 1 fields, saw 2\\nSkipping line 2627: expected 1 fields, saw 2\\nSkipping line 2628: expected 1 fields, saw 2\\nSkipping line 2629: expected 1 fields, saw 2\\nSkipping line 2630: expected 1 fields, saw 2\\nSkipping line 2631: expected 1 fields, saw 2\\nSkipping line 2632: expected 1 fields, saw 2\\nSkipping line 2633: expected 1 fields, saw 2\\nSkipping line 2634: expected 1 fields, saw 2\\nSkipping line 2635: expected 1 fields, saw 2\\nSkipping line 2636: expected 1 fields, saw 2\\nSkipping line 2637: expected 1 fields, saw 2\\nSkipping line 2638: expected 1 fields, saw 2\\nSkipping line 2639: expected 1 fields, saw 2\\nSkipping line 2640: expected 1 fields, saw 2\\nSkipping line 2641: expected 1 fields, saw 2\\nSkipping line 2642: expected 1 fields, saw 2\\nSkipping line 2643: expected 1 fields, saw 2\\nSkipping line 2644: expected 1 fields, saw 2\\nSkipping line 2645: expected 1 fields, saw 2\\nSkipping line 2646: expected 1 fields, saw 2\\nSkipping line 2647: expected 1 fields, saw 2\\nSkipping line 2648: expected 1 fields, saw 2\\nSkipping line 2649: expected 1 fields, saw 2\\nSkipping line 2650: expected 1 fields, saw 2\\nSkipping line 2651: expected 1 fields, saw 2\\nSkipping line 2652: expected 1 fields, saw 2\\nSkipping line 2653: expected 1 fields, saw 2\\nSkipping line 2654: expected 1 fields, saw 2\\nSkipping line 2655: expected 1 fields, saw 2\\nSkipping line 2656: expected 1 fields, saw 2\\nSkipping line 2657: expected 1 fields, saw 2\\nSkipping line 2658: expected 1 fields, saw 2\\nSkipping line 2659: expected 1 fields, saw 2\\nSkipping line 2660: expected 1 fields, saw 2\\nSkipping line 2661: expected 1 fields, saw 2\\nSkipping line 2662: expected 1 fields, saw 2\\nSkipping line 2663: expected 1 fields, saw 2\\nSkipping line 2664: expected 1 fields, saw 2\\nSkipping line 2665: expected 1 fields, saw 2\\nSkipping line 2666: expected 1 fields, saw 2\\nSkipping line 2667: expected 1 fields, saw 2\\nSkipping line 2668: expected 1 fields, saw 2\\nSkipping line 2669: expected 1 fields, saw 2\\nSkipping line 2670: expected 1 fields, saw 2\\nSkipping line 2671: expected 1 fields, saw 2\\nSkipping line 2672: expected 1 fields, saw 2\\nSkipping line 2673: expected 1 fields, saw 2\\nSkipping line 2674: expected 1 fields, saw 2\\nSkipping line 2675: expected 1 fields, saw 2\\nSkipping line 2676: expected 1 fields, saw 2\\nSkipping line 2677: expected 1 fields, saw 2\\nSkipping line 2678: expected 1 fields, saw 2\\nSkipping line 2679: expected 1 fields, saw 2\\nSkipping line 2680: expected 1 fields, saw 2\\nSkipping line 2681: expected 1 fields, saw 2\\nSkipping line 2682: expected 1 fields, saw 2\\nSkipping line 2683: expected 1 fields, saw 2\\nSkipping line 2684: expected 1 fields, saw 2\\nSkipping line 2685: expected 1 fields, saw 2\\nSkipping line 2686: expected 1 fields, saw 2\\nSkipping line 2687: expected 1 fields, saw 2\\nSkipping line 2688: expected 1 fields, saw 2\\nSkipping line 2689: expected 1 fields, saw 2\\nSkipping line 2690: expected 1 fields, saw 2\\nSkipping line 2691: expected 1 fields, saw 2\\nSkipping line 2692: expected 1 fields, saw 2\\nSkipping line 2693: expected 1 fields, saw 2\\nSkipping line 2694: expected 1 fields, saw 2\\nSkipping line 2695: expected 1 fields, saw 2\\nSkipping line 2696: expected 1 fields, saw 2\\nSkipping line 2697: expected 1 fields, saw 2\\nSkipping line 2698: expected 1 fields, saw 2\\nSkipping line 2699: expected 1 fields, saw 2\\nSkipping line 2700: expected 1 fields, saw 2\\nSkipping line 2701: expected 1 fields, saw 2\\nSkipping line 2702: expected 1 fields, saw 2\\nSkipping line 2703: expected 1 fields, saw 2\\nSkipping line 2704: expected 1 fields, saw 2\\nSkipping line 2705: expected 1 fields, saw 2\\nSkipping line 2706: expected 1 fields, saw 2\\nSkipping line 2707: expected 1 fields, saw 2\\nSkipping line 2708: expected 1 fields, saw 2\\nSkipping line 2709: expected 1 fields, saw 2\\nSkipping line 2710: expected 1 fields, saw 2\\nSkipping line 2711: expected 1 fields, saw 2\\nSkipping line 2712: expected 1 fields, saw 2\\nSkipping line 2713: expected 1 fields, saw 2\\nSkipping line 2714: expected 1 fields, saw 2\\nSkipping line 2715: expected 1 fields, saw 2\\nSkipping line 2716: expected 1 fields, saw 2\\nSkipping line 2717: expected 1 fields, saw 2\\nSkipping line 2718: expected 1 fields, saw 2\\nSkipping line 2719: expected 1 fields, saw 2\\nSkipping line 2720: expected 1 fields, saw 2\\nSkipping line 2721: expected 1 fields, saw 2\\nSkipping line 2722: expected 1 fields, saw 2\\nSkipping line 2723: expected 1 fields, saw 2\\nSkipping line 2724: expected 1 fields, saw 2\\nSkipping line 2725: expected 1 fields, saw 2\\nSkipping line 2726: expected 1 fields, saw 2\\nSkipping line 2727: expected 1 fields, saw 2\\nSkipping line 2728: expected 1 fields, saw 2\\nSkipping line 2729: expected 1 fields, saw 2\\nSkipping line 2730: expected 1 fields, saw 2\\nSkipping line 2731: expected 1 fields, saw 2\\nSkipping line 2732: expected 1 fields, saw 2\\nSkipping line 2733: expected 1 fields, saw 2\\nSkipping line 2734: expected 1 fields, saw 2\\nSkipping line 2735: expected 1 fields, saw 2\\nSkipping line 2736: expected 1 fields, saw 2\\nSkipping line 2737: expected 1 fields, saw 2\\nSkipping line 2738: expected 1 fields, saw 2\\nSkipping line 2739: expected 1 fields, saw 2\\nSkipping line 2740: expected 1 fields, saw 2\\nSkipping line 2741: expected 1 fields, saw 2\\nSkipping line 2742: expected 1 fields, saw 2\\nSkipping line 2743: expected 1 fields, saw 2\\nSkipping line 2744: expected 1 fields, saw 2\\nSkipping line 2745: expected 1 fields, saw 2\\nSkipping line 2746: expected 1 fields, saw 2\\nSkipping line 2747: expected 1 fields, saw 2\\nSkipping line 2748: expected 1 fields, saw 2\\nSkipping line 2749: expected 1 fields, saw 2\\nSkipping line 2750: expected 1 fields, saw 2\\nSkipping line 2751: expected 1 fields, saw 2\\nSkipping line 2752: expected 1 fields, saw 2\\nSkipping line 2753: expected 1 fields, saw 2\\nSkipping line 2754: expected 1 fields, saw 2\\nSkipping line 2755: expected 1 fields, saw 2\\nSkipping line 2756: expected 1 fields, saw 2\\nSkipping line 2757: expected 1 fields, saw 2\\nSkipping line 2758: expected 1 fields, saw 2\\nSkipping line 2759: expected 1 fields, saw 2\\nSkipping line 2760: expected 1 fields, saw 2\\nSkipping line 2761: expected 1 fields, saw 2\\nSkipping line 2762: expected 1 fields, saw 2\\nSkipping line 2763: expected 1 fields, saw 2\\nSkipping line 2764: expected 1 fields, saw 2\\nSkipping line 2765: expected 1 fields, saw 2\\nSkipping line 2766: expected 1 fields, saw 2\\nSkipping line 2767: expected 1 fields, saw 2\\nSkipping line 2768: expected 1 fields, saw 2\\nSkipping line 2769: expected 1 fields, saw 2\\nSkipping line 2770: expected 1 fields, saw 2\\nSkipping line 2771: expected 1 fields, saw 2\\nSkipping line 2772: expected 1 fields, saw 2\\nSkipping line 2773: expected 1 fields, saw 2\\nSkipping line 2774: expected 1 fields, saw 2\\nSkipping line 2775: expected 1 fields, saw 2\\nSkipping line 2776: expected 1 fields, saw 2\\nSkipping line 2777: expected 1 fields, saw 2\\nSkipping line 2778: expected 1 fields, saw 2\\nSkipping line 2779: expected 1 fields, saw 2\\nSkipping line 2780: expected 1 fields, saw 2\\nSkipping line 2781: expected 1 fields, saw 2\\nSkipping line 2782: expected 1 fields, saw 2\\nSkipping line 2783: expected 1 fields, saw 2\\nSkipping line 2784: expected 1 fields, saw 2\\nSkipping line 2785: expected 1 fields, saw 2\\nSkipping line 2786: expected 1 fields, saw 2\\nSkipping line 2787: expected 1 fields, saw 2\\nSkipping line 2788: expected 1 fields, saw 2\\nSkipping line 2789: expected 1 fields, saw 2\\nSkipping line 2790: expected 1 fields, saw 2\\nSkipping line 2791: expected 1 fields, saw 2\\nSkipping line 2792: expected 1 fields, saw 2\\nSkipping line 2793: expected 1 fields, saw 2\\nSkipping line 2794: expected 1 fields, saw 2\\nSkipping line 2795: expected 1 fields, saw 2\\nSkipping line 2796: expected 1 fields, saw 2\\nSkipping line 2797: expected 1 fields, saw 2\\nSkipping line 2798: expected 1 fields, saw 2\\nSkipping line 2799: expected 1 fields, saw 2\\nSkipping line 2800: expected 1 fields, saw 2\\nSkipping line 2801: expected 1 fields, saw 2\\nSkipping line 2802: expected 1 fields, saw 2\\nSkipping line 2803: expected 1 fields, saw 2\\nSkipping line 2804: expected 1 fields, saw 2\\nSkipping line 2805: expected 1 fields, saw 2\\nSkipping line 2806: expected 1 fields, saw 2\\nSkipping line 2807: expected 1 fields, saw 2\\nSkipping line 2808: expected 1 fields, saw 2\\nSkipping line 2809: expected 1 fields, saw 2\\nSkipping line 2810: expected 1 fields, saw 2\\nSkipping line 2811: expected 1 fields, saw 2\\nSkipping line 2812: expected 1 fields, saw 2\\nSkipping line 2813: expected 1 fields, saw 2\\nSkipping line 2814: expected 1 fields, saw 2\\nSkipping line 2815: expected 1 fields, saw 2\\nSkipping line 2816: expected 1 fields, saw 2\\nSkipping line 2817: expected 1 fields, saw 2\\nSkipping line 2818: expected 1 fields, saw 2\\nSkipping line 2819: expected 1 fields, saw 2\\nSkipping line 2820: expected 1 fields, saw 2\\nSkipping line 2821: expected 1 fields, saw 2\\nSkipping line 2822: expected 1 fields, saw 2\\nSkipping line 2823: expected 1 fields, saw 2\\nSkipping line 2824: expected 1 fields, saw 2\\nSkipping line 2825: expected 1 fields, saw 2\\nSkipping line 2826: expected 1 fields, saw 2\\nSkipping line 2827: expected 1 fields, saw 2\\nSkipping line 2828: expected 1 fields, saw 2\\nSkipping line 2829: expected 1 fields, saw 2\\nSkipping line 2830: expected 1 fields, saw 2\\nSkipping line 2831: expected 1 fields, saw 2\\nSkipping line 2832: expected 1 fields, saw 2\\nSkipping line 2833: expected 1 fields, saw 2\\nSkipping line 2834: expected 1 fields, saw 2\\nSkipping line 2835: expected 1 fields, saw 2\\nSkipping line 2836: expected 1 fields, saw 2\\nSkipping line 2837: expected 1 fields, saw 2\\nSkipping line 2838: expected 1 fields, saw 2\\nSkipping line 2839: expected 1 fields, saw 2\\nSkipping line 2840: expected 1 fields, saw 2\\nSkipping line 2841: expected 1 fields, saw 2\\nSkipping line 2842: expected 1 fields, saw 2\\nSkipping line 2843: expected 1 fields, saw 2\\nSkipping line 2844: expected 1 fields, saw 2\\nSkipping line 2845: expected 1 fields, saw 2\\nSkipping line 2846: expected 1 fields, saw 2\\nSkipping line 2847: expected 1 fields, saw 2\\nSkipping line 2848: expected 1 fields, saw 2\\nSkipping line 2849: expected 1 fields, saw 2\\nSkipping line 2850: expected 1 fields, saw 2\\nSkipping line 2851: expected 1 fields, saw 2\\nSkipping line 2852: expected 1 fields, saw 2\\nSkipping line 2853: expected 1 fields, saw 2\\nSkipping line 2854: expected 1 fields, saw 2\\nSkipping line 2855: expected 1 fields, saw 2\\nSkipping line 2856: expected 1 fields, saw 2\\nSkipping line 2857: expected 1 fields, saw 2\\nSkipping line 2858: expected 1 fields, saw 2\\nSkipping line 2859: expected 1 fields, saw 2\\nSkipping line 2860: expected 1 fields, saw 2\\nSkipping line 2861: expected 1 fields, saw 2\\nSkipping line 2862: expected 1 fields, saw 2\\nSkipping line 2863: expected 1 fields, saw 2\\nSkipping line 2864: expected 1 fields, saw 2\\nSkipping line 2865: expected 1 fields, saw 2\\nSkipping line 2866: expected 1 fields, saw 2\\nSkipping line 2867: expected 1 fields, saw 2\\nSkipping line 2868: expected 1 fields, saw 2\\nSkipping line 2869: expected 1 fields, saw 2\\nSkipping line 2870: expected 1 fields, saw 2\\nSkipping line 2871: expected 1 fields, saw 2\\nSkipping line 2872: expected 1 fields, saw 2\\nSkipping line 2873: expected 1 fields, saw 2\\nSkipping line 2874: expected 1 fields, saw 2\\nSkipping line 2875: expected 1 fields, saw 2\\nSkipping line 2876: expected 1 fields, saw 2\\nSkipping line 2877: expected 1 fields, saw 2\\nSkipping line 2878: expected 1 fields, saw 2\\nSkipping line 2879: expected 1 fields, saw 2\\nSkipping line 2880: expected 1 fields, saw 2\\nSkipping line 2881: expected 1 fields, saw 2\\nSkipping line 2882: expected 1 fields, saw 2\\nSkipping line 2883: expected 1 fields, saw 2\\nSkipping line 2884: expected 1 fields, saw 2\\nSkipping line 2885: expected 1 fields, saw 2\\nSkipping line 2886: expected 1 fields, saw 2\\nSkipping line 2887: expected 1 fields, saw 2\\nSkipping line 2888: expected 1 fields, saw 2\\nSkipping line 2889: expected 1 fields, saw 2\\nSkipping line 2890: expected 1 fields, saw 2\\nSkipping line 2891: expected 1 fields, saw 2\\nSkipping line 2892: expected 1 fields, saw 2\\nSkipping line 2893: expected 1 fields, saw 2\\nSkipping line 2894: expected 1 fields, saw 2\\nSkipping line 2895: expected 1 fields, saw 2\\nSkipping line 2896: expected 1 fields, saw 2\\nSkipping line 2897: expected 1 fields, saw 2\\nSkipping line 2898: expected 1 fields, saw 2\\nSkipping line 2899: expected 1 fields, saw 2\\nSkipping line 2900: expected 1 fields, saw 2\\nSkipping line 2901: expected 1 fields, saw 2\\nSkipping line 2902: expected 1 fields, saw 2\\nSkipping line 2903: expected 1 fields, saw 2\\nSkipping line 2904: expected 1 fields, saw 2\\nSkipping line 2905: expected 1 fields, saw 2\\nSkipping line 2906: expected 1 fields, saw 2\\nSkipping line 2907: expected 1 fields, saw 2\\nSkipping line 2908: expected 1 fields, saw 2\\nSkipping line 2909: expected 1 fields, saw 2\\nSkipping line 2910: expected 1 fields, saw 2\\nSkipping line 2911: expected 1 fields, saw 2\\nSkipping line 2912: expected 1 fields, saw 2\\nSkipping line 2913: expected 1 fields, saw 2\\nSkipping line 2914: expected 1 fields, saw 2\\nSkipping line 2915: expected 1 fields, saw 2\\nSkipping line 2916: expected 1 fields, saw 2\\nSkipping line 2917: expected 1 fields, saw 2\\nSkipping line 2918: expected 1 fields, saw 2\\nSkipping line 2919: expected 1 fields, saw 2\\nSkipping line 2920: expected 1 fields, saw 2\\nSkipping line 2921: expected 1 fields, saw 2\\nSkipping line 2922: expected 1 fields, saw 2\\nSkipping line 2923: expected 1 fields, saw 2\\nSkipping line 2924: expected 1 fields, saw 2\\nSkipping line 2925: expected 1 fields, saw 2\\nSkipping line 2926: expected 1 fields, saw 2\\nSkipping line 2927: expected 1 fields, saw 2\\nSkipping line 2928: expected 1 fields, saw 2\\nSkipping line 2929: expected 1 fields, saw 2\\nSkipping line 2930: expected 1 fields, saw 2\\nSkipping line 2931: expected 1 fields, saw 2\\nSkipping line 2932: expected 1 fields, saw 2\\nSkipping line 2933: expected 1 fields, saw 2\\nSkipping line 2934: expected 1 fields, saw 2\\nSkipping line 2935: expected 1 fields, saw 2\\nSkipping line 2936: expected 1 fields, saw 2\\nSkipping line 2937: expected 1 fields, saw 2\\nSkipping line 2938: expected 1 fields, saw 2\\nSkipping line 2939: expected 1 fields, saw 2\\nSkipping line 2940: expected 1 fields, saw 2\\nSkipping line 2941: expected 1 fields, saw 2\\nSkipping line 2942: expected 1 fields, saw 2\\nSkipping line 2943: expected 1 fields, saw 2\\nSkipping line 2944: expected 1 fields, saw 2\\nSkipping line 2945: expected 1 fields, saw 2\\nSkipping line 2946: expected 1 fields, saw 2\\nSkipping line 2947: expected 1 fields, saw 2\\nSkipping line 2948: expected 1 fields, saw 2\\nSkipping line 2949: expected 1 fields, saw 2\\nSkipping line 2950: expected 1 fields, saw 2\\nSkipping line 2951: expected 1 fields, saw 2\\nSkipping line 2952: expected 1 fields, saw 2\\nSkipping line 2953: expected 1 fields, saw 2\\nSkipping line 2954: expected 1 fields, saw 2\\nSkipping line 2955: expected 1 fields, saw 2\\nSkipping line 2956: expected 1 fields, saw 2\\nSkipping line 2957: expected 1 fields, saw 2\\nSkipping line 2958: expected 1 fields, saw 2\\nSkipping line 2959: expected 1 fields, saw 2\\nSkipping line 2960: expected 1 fields, saw 2\\nSkipping line 2961: expected 1 fields, saw 2\\nSkipping line 2962: expected 1 fields, saw 2\\nSkipping line 2963: expected 1 fields, saw 2\\nSkipping line 2964: expected 1 fields, saw 2\\nSkipping line 2965: expected 1 fields, saw 2\\nSkipping line 2966: expected 1 fields, saw 2\\nSkipping line 2967: expected 1 fields, saw 2\\nSkipping line 2968: expected 1 fields, saw 2\\nSkipping line 2969: expected 1 fields, saw 2\\nSkipping line 2970: expected 1 fields, saw 2\\nSkipping line 2971: expected 1 fields, saw 2\\nSkipping line 2972: expected 1 fields, saw 2\\nSkipping line 2973: expected 1 fields, saw 2\\nSkipping line 2974: expected 1 fields, saw 2\\nSkipping line 2975: expected 1 fields, saw 2\\nSkipping line 2976: expected 1 fields, saw 2\\nSkipping line 2977: expected 1 fields, saw 2\\nSkipping line 2978: expected 1 fields, saw 2\\nSkipping line 2979: expected 1 fields, saw 2\\nSkipping line 2980: expected 1 fields, saw 2\\nSkipping line 2981: expected 1 fields, saw 2\\nSkipping line 2982: expected 1 fields, saw 2\\nSkipping line 2983: expected 1 fields, saw 2\\nSkipping line 2984: expected 1 fields, saw 2\\nSkipping line 2985: expected 1 fields, saw 2\\nSkipping line 2986: expected 1 fields, saw 2\\nSkipping line 2987: expected 1 fields, saw 2\\nSkipping line 2988: expected 1 fields, saw 2\\nSkipping line 2989: expected 1 fields, saw 2\\nSkipping line 2990: expected 1 fields, saw 2\\nSkipping line 2991: expected 1 fields, saw 2\\nSkipping line 2992: expected 1 fields, saw 2\\nSkipping line 2993: expected 1 fields, saw 2\\nSkipping line 2994: expected 1 fields, saw 2\\nSkipping line 2995: expected 1 fields, saw 2\\nSkipping line 2996: expected 1 fields, saw 2\\nSkipping line 2997: expected 1 fields, saw 2\\nSkipping line 2998: expected 1 fields, saw 2\\nSkipping line 2999: expected 1 fields, saw 2\\nSkipping line 3000: expected 1 fields, saw 2\\nSkipping line 3001: expected 1 fields, saw 2\\nSkipping line 3002: expected 1 fields, saw 2\\nSkipping line 3003: expected 1 fields, saw 2\\nSkipping line 3004: expected 1 fields, saw 2\\nSkipping line 3005: expected 1 fields, saw 2\\nSkipping line 3006: expected 1 fields, saw 2\\nSkipping line 3007: expected 1 fields, saw 2\\nSkipping line 3008: expected 1 fields, saw 2\\nSkipping line 3009: expected 1 fields, saw 2\\nSkipping line 3010: expected 1 fields, saw 2\\nSkipping line 3011: expected 1 fields, saw 2\\nSkipping line 3012: expected 1 fields, saw 2\\nSkipping line 3013: expected 1 fields, saw 2\\nSkipping line 3014: expected 1 fields, saw 2\\nSkipping line 3015: expected 1 fields, saw 2\\nSkipping line 3016: expected 1 fields, saw 2\\nSkipping line 3017: expected 1 fields, saw 2\\nSkipping line 3018: expected 1 fields, saw 2\\nSkipping line 3019: expected 1 fields, saw 2\\nSkipping line 3020: expected 1 fields, saw 2\\nSkipping line 3021: expected 1 fields, saw 2\\nSkipping line 3022: expected 1 fields, saw 2\\nSkipping line 3023: expected 1 fields, saw 2\\nSkipping line 3024: expected 1 fields, saw 2\\nSkipping line 3025: expected 1 fields, saw 2\\nSkipping line 3026: expected 1 fields, saw 2\\nSkipping line 3027: expected 1 fields, saw 2\\nSkipping line 3028: expected 1 fields, saw 2\\nSkipping line 3029: expected 1 fields, saw 2\\nSkipping line 3030: expected 1 fields, saw 2\\nSkipping line 3031: expected 1 fields, saw 2\\nSkipping line 3032: expected 1 fields, saw 2\\nSkipping line 3033: expected 1 fields, saw 2\\nSkipping line 3034: expected 1 fields, saw 2\\nSkipping line 3035: expected 1 fields, saw 2\\nSkipping line 3036: expected 1 fields, saw 2\\nSkipping line 3037: expected 1 fields, saw 2\\nSkipping line 3038: expected 1 fields, saw 2\\nSkipping line 3039: expected 1 fields, saw 2\\nSkipping line 3040: expected 1 fields, saw 2\\nSkipping line 3041: expected 1 fields, saw 2\\nSkipping line 3042: expected 1 fields, saw 2\\nSkipping line 3043: expected 1 fields, saw 2\\nSkipping line 3044: expected 1 fields, saw 2\\nSkipping line 3045: expected 1 fields, saw 2\\nSkipping line 3046: expected 1 fields, saw 2\\nSkipping line 3047: expected 1 fields, saw 2\\nSkipping line 3048: expected 1 fields, saw 2\\nSkipping line 3049: expected 1 fields, saw 2\\nSkipping line 3050: expected 1 fields, saw 2\\nSkipping line 3051: expected 1 fields, saw 2\\nSkipping line 3052: expected 1 fields, saw 2\\nSkipping line 3053: expected 1 fields, saw 2\\nSkipping line 3054: expected 1 fields, saw 2\\nSkipping line 3055: expected 1 fields, saw 2\\nSkipping line 3056: expected 1 fields, saw 2\\nSkipping line 3057: expected 1 fields, saw 2\\nSkipping line 3058: expected 1 fields, saw 2\\nSkipping line 3059: expected 1 fields, saw 2\\nSkipping line 3060: expected 1 fields, saw 2\\nSkipping line 3061: expected 1 fields, saw 2\\nSkipping line 3062: expected 1 fields, saw 2\\nSkipping line 3063: expected 1 fields, saw 2\\nSkipping line 3064: expected 1 fields, saw 2\\nSkipping line 3065: expected 1 fields, saw 2\\nSkipping line 3066: expected 1 fields, saw 2\\nSkipping line 3067: expected 1 fields, saw 2\\nSkipping line 3068: expected 1 fields, saw 2\\nSkipping line 3069: expected 1 fields, saw 2\\nSkipping line 3070: expected 1 fields, saw 2\\nSkipping line 3071: expected 1 fields, saw 2\\nSkipping line 3072: expected 1 fields, saw 2\\nSkipping line 3073: expected 1 fields, saw 2\\nSkipping line 3074: expected 1 fields, saw 2\\nSkipping line 3075: expected 1 fields, saw 2\\nSkipping line 3076: expected 1 fields, saw 2\\nSkipping line 3077: expected 1 fields, saw 2\\nSkipping line 3078: expected 1 fields, saw 2\\nSkipping line 3079: expected 1 fields, saw 2\\nSkipping line 3080: expected 1 fields, saw 2\\nSkipping line 3081: expected 1 fields, saw 2\\nSkipping line 3082: expected 1 fields, saw 2\\nSkipping line 3083: expected 1 fields, saw 2\\nSkipping line 3084: expected 1 fields, saw 2\\nSkipping line 3085: expected 1 fields, saw 2\\nSkipping line 3086: expected 1 fields, saw 2\\nSkipping line 3087: expected 1 fields, saw 2\\nSkipping line 3088: expected 1 fields, saw 2\\nSkipping line 3089: expected 1 fields, saw 2\\nSkipping line 3090: expected 1 fields, saw 2\\nSkipping line 3091: expected 1 fields, saw 2\\nSkipping line 3092: expected 1 fields, saw 2\\nSkipping line 3093: expected 1 fields, saw 2\\nSkipping line 3094: expected 1 fields, saw 2\\nSkipping line 3095: expected 1 fields, saw 2\\nSkipping line 3096: expected 1 fields, saw 2\\nSkipping line 3097: expected 1 fields, saw 2\\nSkipping line 3098: expected 1 fields, saw 2\\nSkipping line 3099: expected 1 fields, saw 2\\nSkipping line 3100: expected 1 fields, saw 2\\nSkipping line 3101: expected 1 fields, saw 2\\nSkipping line 3102: expected 1 fields, saw 2\\nSkipping line 3103: expected 1 fields, saw 2\\nSkipping line 3104: expected 1 fields, saw 2\\nSkipping line 3105: expected 1 fields, saw 2\\nSkipping line 3106: expected 1 fields, saw 2\\nSkipping line 3107: expected 1 fields, saw 2\\nSkipping line 3108: expected 1 fields, saw 2\\nSkipping line 3109: expected 1 fields, saw 2\\nSkipping line 3110: expected 1 fields, saw 2\\nSkipping line 3111: expected 1 fields, saw 2\\nSkipping line 3112: expected 1 fields, saw 2\\nSkipping line 3113: expected 1 fields, saw 2\\nSkipping line 3114: expected 1 fields, saw 2\\nSkipping line 3115: expected 1 fields, saw 2\\nSkipping line 3116: expected 1 fields, saw 2\\nSkipping line 3117: expected 1 fields, saw 2\\nSkipping line 3118: expected 1 fields, saw 2\\nSkipping line 3119: expected 1 fields, saw 2\\nSkipping line 3120: expected 1 fields, saw 2\\nSkipping line 3121: expected 1 fields, saw 2\\nSkipping line 3122: expected 1 fields, saw 2\\nSkipping line 3123: expected 1 fields, saw 2\\nSkipping line 3124: expected 1 fields, saw 2\\nSkipping line 3125: expected 1 fields, saw 2\\nSkipping line 3126: expected 1 fields, saw 2\\nSkipping line 3127: expected 1 fields, saw 2\\nSkipping line 3128: expected 1 fields, saw 2\\nSkipping line 3129: expected 1 fields, saw 2\\nSkipping line 3130: expected 1 fields, saw 2\\nSkipping line 3131: expected 1 fields, saw 2\\nSkipping line 3132: expected 1 fields, saw 2\\nSkipping line 3133: expected 1 fields, saw 2\\nSkipping line 3134: expected 1 fields, saw 2\\nSkipping line 3135: expected 1 fields, saw 2\\nSkipping line 3136: expected 1 fields, saw 2\\nSkipping line 3137: expected 1 fields, saw 2\\nSkipping line 3138: expected 1 fields, saw 2\\nSkipping line 3139: expected 1 fields, saw 2\\nSkipping line 3140: expected 1 fields, saw 2\\nSkipping line 3141: expected 1 fields, saw 2\\nSkipping line 3142: expected 1 fields, saw 2\\nSkipping line 3143: expected 1 fields, saw 2\\nSkipping line 3144: expected 1 fields, saw 2\\nSkipping line 3145: expected 1 fields, saw 2\\nSkipping line 3146: expected 1 fields, saw 2\\nSkipping line 3147: expected 1 fields, saw 2\\nSkipping line 3148: expected 1 fields, saw 2\\nSkipping line 3149: expected 1 fields, saw 2\\nSkipping line 3150: expected 1 fields, saw 2\\nSkipping line 3151: expected 1 fields, saw 2\\nSkipping line 3152: expected 1 fields, saw 2\\nSkipping line 3153: expected 1 fields, saw 2\\nSkipping line 3154: expected 1 fields, saw 2\\nSkipping line 3155: expected 1 fields, saw 2\\nSkipping line 3156: expected 1 fields, saw 2\\nSkipping line 3157: expected 1 fields, saw 2\\nSkipping line 3158: expected 1 fields, saw 2\\nSkipping line 3159: expected 1 fields, saw 2\\nSkipping line 3160: expected 1 fields, saw 2\\nSkipping line 3161: expected 1 fields, saw 2\\nSkipping line 3162: expected 1 fields, saw 2\\nSkipping line 3163: expected 1 fields, saw 2\\nSkipping line 3164: expected 1 fields, saw 2\\nSkipping line 3165: expected 1 fields, saw 2\\nSkipping line 3166: expected 1 fields, saw 2\\nSkipping line 3167: expected 1 fields, saw 2\\nSkipping line 3168: expected 1 fields, saw 2\\nSkipping line 3169: expected 1 fields, saw 2\\nSkipping line 3170: expected 1 fields, saw 2\\nSkipping line 3171: expected 1 fields, saw 2\\nSkipping line 3172: expected 1 fields, saw 2\\nSkipping line 3173: expected 1 fields, saw 2\\nSkipping line 3174: expected 1 fields, saw 2\\nSkipping line 3175: expected 1 fields, saw 2\\nSkipping line 3176: expected 1 fields, saw 2\\nSkipping line 3177: expected 1 fields, saw 2\\nSkipping line 3178: expected 1 fields, saw 2\\nSkipping line 3179: expected 1 fields, saw 2\\nSkipping line 3180: expected 1 fields, saw 2\\nSkipping line 3181: expected 1 fields, saw 2\\nSkipping line 3182: expected 1 fields, saw 2\\nSkipping line 3183: expected 1 fields, saw 2\\nSkipping line 3184: expected 1 fields, saw 2\\nSkipping line 3185: expected 1 fields, saw 2\\nSkipping line 3186: expected 1 fields, saw 2\\nSkipping line 3187: expected 1 fields, saw 2\\nSkipping line 3188: expected 1 fields, saw 2\\nSkipping line 3189: expected 1 fields, saw 2\\nSkipping line 3190: expected 1 fields, saw 2\\nSkipping line 3191: expected 1 fields, saw 2\\nSkipping line 3192: expected 1 fields, saw 2\\nSkipping line 3193: expected 1 fields, saw 2\\nSkipping line 3194: expected 1 fields, saw 2\\nSkipping line 3195: expected 1 fields, saw 2\\nSkipping line 3196: expected 1 fields, saw 2\\nSkipping line 3197: expected 1 fields, saw 2\\nSkipping line 3198: expected 1 fields, saw 2\\nSkipping line 3199: expected 1 fields, saw 2\\nSkipping line 3200: expected 1 fields, saw 2\\nSkipping line 3201: expected 1 fields, saw 2\\nSkipping line 3202: expected 1 fields, saw 2\\nSkipping line 3203: expected 1 fields, saw 2\\nSkipping line 3204: expected 1 fields, saw 2\\nSkipping line 3205: expected 1 fields, saw 2\\nSkipping line 3206: expected 1 fields, saw 2\\nSkipping line 3207: expected 1 fields, saw 2\\nSkipping line 3208: expected 1 fields, saw 2\\nSkipping line 3209: expected 1 fields, saw 2\\nSkipping line 3210: expected 1 fields, saw 2\\nSkipping line 3211: expected 1 fields, saw 2\\nSkipping line 3212: expected 1 fields, saw 2\\nSkipping line 3213: expected 1 fields, saw 2\\nSkipping line 3214: expected 1 fields, saw 2\\nSkipping line 3215: expected 1 fields, saw 2\\nSkipping line 3216: expected 1 fields, saw 2\\nSkipping line 3217: expected 1 fields, saw 2\\nSkipping line 3218: expected 1 fields, saw 2\\nSkipping line 3219: expected 1 fields, saw 2\\nSkipping line 3220: expected 1 fields, saw 2\\nSkipping line 3221: expected 1 fields, saw 2\\nSkipping line 3222: expected 1 fields, saw 2\\nSkipping line 3223: expected 1 fields, saw 2\\nSkipping line 3224: expected 1 fields, saw 2\\nSkipping line 3225: expected 1 fields, saw 2\\nSkipping line 3226: expected 1 fields, saw 2\\nSkipping line 3227: expected 1 fields, saw 2\\nSkipping line 3228: expected 1 fields, saw 2\\nSkipping line 3229: expected 1 fields, saw 2\\nSkipping line 3230: expected 1 fields, saw 2\\nSkipping line 3231: expected 1 fields, saw 2\\nSkipping line 3232: expected 1 fields, saw 2\\nSkipping line 3233: expected 1 fields, saw 2\\nSkipping line 3234: expected 1 fields, saw 2\\nSkipping line 3235: expected 1 fields, saw 2\\nSkipping line 3236: expected 1 fields, saw 2\\nSkipping line 3237: expected 1 fields, saw 2\\nSkipping line 3238: expected 1 fields, saw 2\\nSkipping line 3239: expected 1 fields, saw 2\\nSkipping line 3240: expected 1 fields, saw 2\\nSkipping line 3241: expected 1 fields, saw 2\\nSkipping line 3242: expected 1 fields, saw 2\\nSkipping line 3243: expected 1 fields, saw 2\\nSkipping line 3244: expected 1 fields, saw 2\\nSkipping line 3245: expected 1 fields, saw 2\\nSkipping line 3246: expected 1 fields, saw 2\\nSkipping line 3247: expected 1 fields, saw 2\\nSkipping line 3248: expected 1 fields, saw 2\\nSkipping line 3249: expected 1 fields, saw 2\\nSkipping line 3250: expected 1 fields, saw 2\\nSkipping line 3251: expected 1 fields, saw 2\\nSkipping line 3252: expected 1 fields, saw 2\\nSkipping line 3253: expected 1 fields, saw 2\\nSkipping line 3254: expected 1 fields, saw 2\\nSkipping line 3255: expected 1 fields, saw 2\\nSkipping line 3256: expected 1 fields, saw 2\\nSkipping line 3257: expected 1 fields, saw 2\\nSkipping line 3258: expected 1 fields, saw 2\\nSkipping line 3259: expected 1 fields, saw 2\\nSkipping line 3260: expected 1 fields, saw 2\\nSkipping line 3261: expected 1 fields, saw 2\\nSkipping line 3262: expected 1 fields, saw 2\\nSkipping line 3263: expected 1 fields, saw 2\\nSkipping line 3264: expected 1 fields, saw 2\\nSkipping line 3265: expected 1 fields, saw 2\\nSkipping line 3266: expected 1 fields, saw 2\\nSkipping line 3267: expected 1 fields, saw 2\\nSkipping line 3268: expected 1 fields, saw 2\\nSkipping line 3269: expected 1 fields, saw 2\\nSkipping line 3270: expected 1 fields, saw 2\\nSkipping line 3271: expected 1 fields, saw 2\\nSkipping line 3272: expected 1 fields, saw 2\\nSkipping line 3273: expected 1 fields, saw 2\\nSkipping line 3274: expected 1 fields, saw 2\\nSkipping line 3275: expected 1 fields, saw 2\\nSkipping line 3276: expected 1 fields, saw 2\\nSkipping line 3277: expected 1 fields, saw 2\\nSkipping line 3278: expected 1 fields, saw 2\\nSkipping line 3279: expected 1 fields, saw 2\\nSkipping line 3280: expected 1 fields, saw 2\\nSkipping line 3281: expected 1 fields, saw 2\\nSkipping line 3282: expected 1 fields, saw 2\\nSkipping line 3283: expected 1 fields, saw 2\\nSkipping line 3284: expected 1 fields, saw 2\\nSkipping line 3285: expected 1 fields, saw 2\\nSkipping line 3286: expected 1 fields, saw 2\\nSkipping line 3287: expected 1 fields, saw 2\\nSkipping line 3288: expected 1 fields, saw 2\\nSkipping line 3289: expected 1 fields, saw 2\\nSkipping line 3290: expected 1 fields, saw 2\\nSkipping line 3291: expected 1 fields, saw 2\\nSkipping line 3292: expected 1 fields, saw 2\\nSkipping line 3293: expected 1 fields, saw 2\\nSkipping line 3294: expected 1 fields, saw 2\\nSkipping line 3295: expected 1 fields, saw 2\\nSkipping line 3296: expected 1 fields, saw 2\\nSkipping line 3297: expected 1 fields, saw 2\\nSkipping line 3298: expected 1 fields, saw 2\\nSkipping line 3299: expected 1 fields, saw 2\\nSkipping line 3300: expected 1 fields, saw 2\\nSkipping line 3301: expected 1 fields, saw 2\\nSkipping line 3302: expected 1 fields, saw 2\\nSkipping line 3303: expected 1 fields, saw 2\\nSkipping line 3304: expected 1 fields, saw 2\\nSkipping line 3305: expected 1 fields, saw 2\\nSkipping line 3306: expected 1 fields, saw 2\\nSkipping line 3307: expected 1 fields, saw 2\\nSkipping line 3308: expected 1 fields, saw 2\\nSkipping line 3309: expected 1 fields, saw 2\\nSkipping line 3310: expected 1 fields, saw 2\\nSkipping line 3311: expected 1 fields, saw 2\\nSkipping line 3312: expected 1 fields, saw 2\\nSkipping line 3313: expected 1 fields, saw 2\\nSkipping line 3314: expected 1 fields, saw 2\\nSkipping line 3315: expected 1 fields, saw 2\\nSkipping line 3316: expected 1 fields, saw 2\\nSkipping line 3317: expected 1 fields, saw 2\\nSkipping line 3318: expected 1 fields, saw 2\\nSkipping line 3319: expected 1 fields, saw 2\\nSkipping line 3320: expected 1 fields, saw 2\\nSkipping line 3321: expected 1 fields, saw 2\\nSkipping line 3322: expected 1 fields, saw 2\\nSkipping line 3323: expected 1 fields, saw 2\\nSkipping line 3324: expected 1 fields, saw 2\\nSkipping line 3325: expected 1 fields, saw 2\\nSkipping line 3326: expected 1 fields, saw 2\\nSkipping line 3327: expected 1 fields, saw 2\\nSkipping line 3328: expected 1 fields, saw 2\\nSkipping line 3329: expected 1 fields, saw 2\\nSkipping line 3330: expected 1 fields, saw 2\\nSkipping line 3331: expected 1 fields, saw 2\\nSkipping line 3332: expected 1 fields, saw 2\\nSkipping line 3333: expected 1 fields, saw 2\\nSkipping line 3334: expected 1 fields, saw 2\\nSkipping line 3335: expected 1 fields, saw 2\\nSkipping line 3336: expected 1 fields, saw 2\\nSkipping line 3337: expected 1 fields, saw 2\\nSkipping line 3338: expected 1 fields, saw 2\\nSkipping line 3339: expected 1 fields, saw 2\\nSkipping line 3340: expected 1 fields, saw 2\\nSkipping line 3341: expected 1 fields, saw 2\\nSkipping line 3342: expected 1 fields, saw 2\\nSkipping line 3343: expected 1 fields, saw 2\\nSkipping line 3344: expected 1 fields, saw 2\\nSkipping line 3345: expected 1 fields, saw 2\\nSkipping line 3346: expected 1 fields, saw 2\\nSkipping line 3347: expected 1 fields, saw 2\\nSkipping line 3348: expected 1 fields, saw 2\\nSkipping line 3349: expected 1 fields, saw 2\\nSkipping line 3350: expected 1 fields, saw 2\\nSkipping line 3351: expected 1 fields, saw 2\\nSkipping line 3352: expected 1 fields, saw 2\\nSkipping line 3353: expected 1 fields, saw 2\\nSkipping line 3354: expected 1 fields, saw 2\\nSkipping line 3355: expected 1 fields, saw 2\\nSkipping line 3356: expected 1 fields, saw 2\\nSkipping line 3357: expected 1 fields, saw 2\\nSkipping line 3358: expected 1 fields, saw 2\\nSkipping line 3359: expected 1 fields, saw 2\\nSkipping line 3360: expected 1 fields, saw 2\\nSkipping line 3361: expected 1 fields, saw 2\\nSkipping line 3362: expected 1 fields, saw 2\\nSkipping line 3363: expected 1 fields, saw 2\\nSkipping line 3364: expected 1 fields, saw 2\\nSkipping line 3365: expected 1 fields, saw 2\\nSkipping line 3366: expected 1 fields, saw 2\\nSkipping line 3367: expected 1 fields, saw 2\\nSkipping line 3368: expected 1 fields, saw 2\\nSkipping line 3369: expected 1 fields, saw 2\\nSkipping line 3370: expected 1 fields, saw 2\\nSkipping line 3371: expected 1 fields, saw 2\\nSkipping line 3372: expected 1 fields, saw 2\\nSkipping line 3373: expected 1 fields, saw 2\\nSkipping line 3374: expected 1 fields, saw 2\\nSkipping line 3375: expected 1 fields, saw 2\\nSkipping line 3376: expected 1 fields, saw 2\\nSkipping line 3377: expected 1 fields, saw 2\\nSkipping line 3378: expected 1 fields, saw 2\\nSkipping line 3379: expected 1 fields, saw 2\\nSkipping line 3380: expected 1 fields, saw 2\\nSkipping line 3381: expected 1 fields, saw 2\\nSkipping line 3382: expected 1 fields, saw 2\\nSkipping line 3383: expected 1 fields, saw 2\\nSkipping line 3384: expected 1 fields, saw 2\\nSkipping line 3385: expected 1 fields, saw 2\\nSkipping line 3386: expected 1 fields, saw 2\\nSkipping line 3387: expected 1 fields, saw 2\\nSkipping line 3388: expected 1 fields, saw 2\\nSkipping line 3389: expected 1 fields, saw 2\\nSkipping line 3390: expected 1 fields, saw 2\\nSkipping line 3391: expected 1 fields, saw 2\\nSkipping line 3392: expected 1 fields, saw 2\\nSkipping line 3393: expected 1 fields, saw 2\\nSkipping line 3394: expected 1 fields, saw 2\\nSkipping line 3395: expected 1 fields, saw 2\\nSkipping line 3396: expected 1 fields, saw 2\\nSkipping line 3397: expected 1 fields, saw 2\\nSkipping line 3398: expected 1 fields, saw 2\\nSkipping line 3399: expected 1 fields, saw 2\\nSkipping line 3400: expected 1 fields, saw 2\\nSkipping line 3401: expected 1 fields, saw 2\\nSkipping line 3402: expected 1 fields, saw 2\\n'\n" + ] + }, + { + "data": { + "text/html": [ + "
\n", + "\n", + "\n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + "
0Atmospheric CO2 concentrations (ppm) derived ...
1at Mauna Loa, Observatory, Hawaii: Latitude 1...
2...
3Source: R. F. Keeling, S. J. Walker, S. C. Pi...
4Scripps CO2 Program ( http://scrippsco2.ucsd....
5Scripps Institution of Oceanography (SIO) ...
6University of California ...
7La Jolla, California USA 92093-0244 ...
8...
9Status of data and correspondence: ...
10...
11These data are subject to revision based on r...
12about the data should be directed to Dr. Ralp...
13(sjwalker@ucsd.edu) and Stephen Piper (scpipe...
14...
15Baseline data in this file through 07-Jan-202...
16...
17----------------------------------------------...
18...
19Please cite as: ...
20...
21C. D. Keeling, S. C. Piper, R. B. Bacastow, M...
22H. A. Meijer, Exchanges of atmospheric CO2 an...
23oceans from 1978 to 2000. I. Global aspects,...
24Institution of Oceanography, San Diego, 88 pa...
25...
26If it is necessary to cite a peer-reviewed ar...
27...
28C. D. Keeling, S. C. Piper, R. B. Bacastow, M...
29H. A. Meijer, Atmospheric CO2 and 13CO2 excha...
30oceans from 1978 to 2000: observations and ca...
31editors, Ehleringer, J.R., T. E. Cerling, M. ...
32New York, 2005. ...
33...
34----------------------------------------------...
35...
36...
37The data file below contains 2 columns indica...
38concentrations in micro-mol CO2 per mole (ppm...
39SIO manometric mole fraction scale. These we...
40adjusted to 12:00 hours at middle day of each...
41indicated by the date in the first column. ...
\n", + "
" + ], + "text/plain": [ + " -------------------------------------------------------------------------------------------\n", + "0 Atmospheric CO2 concentrations (ppm) derived ... \n", + "1 at Mauna Loa, Observatory, Hawaii: Latitude 1... \n", + "2 ... \n", + "3 Source: R. F. Keeling, S. J. Walker, S. C. Pi... \n", + "4 Scripps CO2 Program ( http://scrippsco2.ucsd.... \n", + "5 Scripps Institution of Oceanography (SIO) ... \n", + "6 University of California ... \n", + "7 La Jolla, California USA 92093-0244 ... \n", + "8 ... \n", + "9 Status of data and correspondence: ... \n", + "10 ... \n", + "11 These data are subject to revision based on r... \n", + "12 about the data should be directed to Dr. Ralp... \n", + "13 (sjwalker@ucsd.edu) and Stephen Piper (scpipe... \n", + "14 ... \n", + "15 Baseline data in this file through 07-Jan-202... \n", + "16 ... \n", + "17 ----------------------------------------------... \n", + "18 ... \n", + "19 Please cite as: ... \n", + "20 ... \n", + "21 C. D. Keeling, S. C. Piper, R. B. Bacastow, M... \n", + "22 H. A. Meijer, Exchanges of atmospheric CO2 an... \n", + "23 oceans from 1978 to 2000. I. Global aspects,... \n", + "24 Institution of Oceanography, San Diego, 88 pa... \n", + "25 ... \n", + "26 If it is necessary to cite a peer-reviewed ar... \n", + "27 ... \n", + "28 C. D. Keeling, S. C. Piper, R. B. Bacastow, M... \n", + "29 H. A. Meijer, Atmospheric CO2 and 13CO2 excha... \n", + "30 oceans from 1978 to 2000: observations and ca... \n", + "31 editors, Ehleringer, J.R., T. E. Cerling, M. ... \n", + "32 New York, 2005. ... \n", + "33 ... \n", + "34 ----------------------------------------------... \n", + "35 ... \n", + "36 ... \n", + "37 The data file below contains 2 columns indica... \n", + "38 concentrations in micro-mol CO2 per mole (ppm... \n", + "39 SIO manometric mole fraction scale. These we... \n", + "40 adjusted to 12:00 hours at middle day of each... \n", + "41 indicated by the date in the first column. ... " + ] + }, + "execution_count": 15, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "raw_data = pd.read_csv(data_file, error_bad_lines=False)\n", + "raw_data" + ] }, { "cell_type": "markdown", @@ -89,7 +378,7 @@ }, { "cell_type": "code", - "execution_count": 21, + "execution_count": 8, "metadata": {}, "outputs": [], "source": [ @@ -98,7 +387,7 @@ }, { "cell_type": "code", - "execution_count": 34, + "execution_count": 9, "metadata": {}, "outputs": [], "source": [ @@ -112,7 +401,7 @@ }, { "cell_type": "code", - "execution_count": 35, + "execution_count": 10, "metadata": {}, "outputs": [ { @@ -122,7 +411,7 @@ "traceback": [ "\u001b[0;31m---------------------------------------------------------------------------\u001b[0m", "\u001b[0;31mParserError\u001b[0m Traceback (most recent call last)", - "\u001b[0;32m\u001b[0m in \u001b[0;36m\u001b[0;34m\u001b[0m\n\u001b[0;32m----> 1\u001b[0;31m \u001b[0mraw_data\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mpd\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread_csv\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mdata_file_campus\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mskiprows\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;36m1\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 2\u001b[0m \u001b[0mraw_data\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32m\u001b[0m in \u001b[0;36m\u001b[0;34m\u001b[0m\n\u001b[0;32m----> 1\u001b[0;31m \u001b[0mraw_data_campus\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mpd\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread_csv\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mdata_file_campus\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mskiprows\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;36m1\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 2\u001b[0m \u001b[0mraw_data_campus\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36mparser_f\u001b[0;34m(filepath_or_buffer, sep, delimiter, header, names, index_col, usecols, squeeze, prefix, mangle_dupe_cols, dtype, engine, converters, true_values, false_values, skipinitialspace, skiprows, nrows, na_values, keep_default_na, na_filter, verbose, skip_blank_lines, parse_dates, infer_datetime_format, keep_date_col, date_parser, dayfirst, iterator, chunksize, compression, thousands, decimal, lineterminator, quotechar, quoting, escapechar, comment, encoding, dialect, tupleize_cols, error_bad_lines, warn_bad_lines, skipfooter, skip_footer, doublequote, delim_whitespace, as_recarray, compact_ints, use_unsigned, low_memory, buffer_lines, memory_map, float_precision)\u001b[0m\n\u001b[1;32m 707\u001b[0m skip_blank_lines=skip_blank_lines)\n\u001b[1;32m 708\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 709\u001b[0;31m \u001b[0;32mreturn\u001b[0m \u001b[0m_read\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mfilepath_or_buffer\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mkwds\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 710\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 711\u001b[0m \u001b[0mparser_f\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m__name__\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mname\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36m_read\u001b[0;34m(filepath_or_buffer, kwds)\u001b[0m\n\u001b[1;32m 453\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 454\u001b[0m \u001b[0;32mtry\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 455\u001b[0;31m \u001b[0mdata\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mparser\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mnrows\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 456\u001b[0m \u001b[0;32mfinally\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 457\u001b[0m \u001b[0mparser\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mclose\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36mread\u001b[0;34m(self, nrows)\u001b[0m\n\u001b[1;32m 1067\u001b[0m \u001b[0;32mraise\u001b[0m \u001b[0mValueError\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m'skipfooter not supported for iteration'\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1068\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m-> 1069\u001b[0;31m \u001b[0mret\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_engine\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mnrows\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 1070\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1071\u001b[0m \u001b[0;32mif\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0moptions\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mget\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m'as_recarray'\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", @@ -137,13 +426,13 @@ } ], "source": [ - "raw_data = pd.read_csv(data_file_campus, skiprows=1)\n", - "raw_data" + "raw_data_campus = pd.read_csv(data_file_campus, skiprows=1)\n", + "raw_data_campus" ] }, { "cell_type": "code", - "execution_count": 26, + "execution_count": 11, "metadata": {}, "outputs": [], "source": [ @@ -152,21 +441,21 @@ }, { "cell_type": "code", - "execution_count": 29, + "execution_count": 12, "metadata": {}, "outputs": [], "source": [ - "data_file = \"latency_remote.csv\"\n", + "data_file_remote = \"latency_remote.csv\"\n", "\n", "import os\n", "import urllib.request\n", "if not os.path.exists(data_file):\n", - " urllib.request.urlretrieve(data_url, data_file)" + " urllib.request.urlretrieve(data_url_latency_remote, data_file_remote)" ] }, { "cell_type": "code", - "execution_count": 30, + "execution_count": 13, "metadata": {}, "outputs": [ { @@ -176,7 +465,7 @@ "traceback": [ "\u001b[0;31m---------------------------------------------------------------------------\u001b[0m", "\u001b[0;31mParserError\u001b[0m Traceback (most recent call last)", - "\u001b[0;32m\u001b[0m in \u001b[0;36m\u001b[0;34m\u001b[0m\n\u001b[0;32m----> 1\u001b[0;31m \u001b[0mraw_data\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mpd\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread_csv\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mdata_file\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mskiprows\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;36m1\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 2\u001b[0m \u001b[0mraw_data\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", + "\u001b[0;32m\u001b[0m in \u001b[0;36m\u001b[0;34m\u001b[0m\n\u001b[0;32m----> 1\u001b[0;31m \u001b[0mraw_data_remote\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mpd\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread_csv\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mdata_file_remote\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mskiprows\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;36m1\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 2\u001b[0m \u001b[0mraw_data_remote\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36mparser_f\u001b[0;34m(filepath_or_buffer, sep, delimiter, header, names, index_col, usecols, squeeze, prefix, mangle_dupe_cols, dtype, engine, converters, true_values, false_values, skipinitialspace, skiprows, nrows, na_values, keep_default_na, na_filter, verbose, skip_blank_lines, parse_dates, infer_datetime_format, keep_date_col, date_parser, dayfirst, iterator, chunksize, compression, thousands, decimal, lineterminator, quotechar, quoting, escapechar, comment, encoding, dialect, tupleize_cols, error_bad_lines, warn_bad_lines, skipfooter, skip_footer, doublequote, delim_whitespace, as_recarray, compact_ints, use_unsigned, low_memory, buffer_lines, memory_map, float_precision)\u001b[0m\n\u001b[1;32m 707\u001b[0m skip_blank_lines=skip_blank_lines)\n\u001b[1;32m 708\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 709\u001b[0;31m \u001b[0;32mreturn\u001b[0m \u001b[0m_read\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mfilepath_or_buffer\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mkwds\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 710\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 711\u001b[0m \u001b[0mparser_f\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m__name__\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mname\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36m_read\u001b[0;34m(filepath_or_buffer, kwds)\u001b[0m\n\u001b[1;32m 453\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 454\u001b[0m \u001b[0;32mtry\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 455\u001b[0;31m \u001b[0mdata\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mparser\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mnrows\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 456\u001b[0m \u001b[0;32mfinally\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 457\u001b[0m \u001b[0mparser\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mclose\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36mread\u001b[0;34m(self, nrows)\u001b[0m\n\u001b[1;32m 1067\u001b[0m \u001b[0;32mraise\u001b[0m \u001b[0mValueError\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m'skipfooter not supported for iteration'\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1068\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m-> 1069\u001b[0;31m \u001b[0mret\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_engine\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mnrows\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 1070\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1071\u001b[0m \u001b[0;32mif\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0moptions\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mget\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m'as_recarray'\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", @@ -191,8 +480,8 @@ } ], "source": [ - "raw_data = pd.read_csv(data_file, skiprows=1)\n", - "raw_data" + "raw_data_remote = pd.read_csv(data_file_remote, skiprows=1)\n", + "raw_data_remote" ] }, { @@ -207,7 +496,9 @@ "execution_count": null, "metadata": {}, "outputs": [], - "source": [] + "source": [ + "\n" + ] } ], "metadata": {
