result3
parent 1053dba4
...@@ -9,7 +9,7 @@ ...@@ -9,7 +9,7 @@
"execution_count": 95, "execution_count": 5,
"outputs": [], "outputs": [],
"source": [ "source": [
...@@ -22,7 +22,7 @@ ...@@ -22,7 +22,7 @@
"execution_count": 96, "execution_count": 6,
...@@ -32,7 +32,7 @@ ...@@ -32,7 +32,7 @@
"execution_count": 97, "execution_count": 7,
...@@ -47,7 +47,7 @@ ...@@ -47,7 +47,7 @@
"execution_count": 98, "execution_count": 8,
"outputs": [ "outputs": [
...@@ -73,7 +73,7 @@ ...@@ -73,7 +73,7 @@
"execution_count": 99, "execution_count": 9,
...@@ -82,7 +82,7 @@ ...@@ -82,7 +82,7 @@
"execution_count": 100, "execution_count": 10,
...@@ -112,7 +112,7 @@ ...@@ -112,7 +112,7 @@
"execution_count": 101, "execution_count": 11,
...@@ -142,7 +142,7 @@ ...@@ -142,7 +142,7 @@
"execution_count": 102, "execution_count": 12,
...@@ -152,7 +152,7 @@ ...@@ -152,7 +152,7 @@
"traceback": [ "traceback": [
"\u001b[0;31m---------------------------------------------------------------------------\u001b[0m", "\u001b[0;31m---------------------------------------------------------------------------\u001b[0m",
"\u001b[0;31mImportError\u001b[0m Traceback (most recent call last)", "\u001b[0;31mImportError\u001b[0m Traceback (most recent call last)",
"\u001b[0;32m<ipython-input-102-e53db971c966>\u001b[0m in \u001b[0;36m<module>\u001b[0;34m\u001b[0m\n\u001b[0;32m----> 1\u001b[0;31m \u001b[0;32mfrom\u001b[0m \u001b[0mstatsmodels\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mtsa\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mseasonal\u001b[0m \u001b[0;32mimport\u001b[0m \u001b[0mSTL\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 2\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 3\u001b[0m \u001b[0;31m# Décomposition de la série temporelle\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 4\u001b[0m \u001b[0mstl\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mSTL\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mdata\u001b[0m\u001b[0;34m[\u001b[0m\u001b[0;34m'CO2'\u001b[0m\u001b[0;34m]\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mseasonal\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;36m13\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 5\u001b[0m \u001b[0mres\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mstl\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mfit\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n", "\u001b[0;32m<ipython-input-12-e53db971c966>\u001b[0m in \u001b[0;36m<module>\u001b[0;34m\u001b[0m\n\u001b[0;32m----> 1\u001b[0;31m \u001b[0;32mfrom\u001b[0m \u001b[0mstatsmodels\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mtsa\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mseasonal\u001b[0m \u001b[0;32mimport\u001b[0m \u001b[0mSTL\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 2\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 3\u001b[0m \u001b[0;31m# Décomposition de la série temporelle\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 4\u001b[0m \u001b[0mstl\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mSTL\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mdata\u001b[0m\u001b[0;34m[\u001b[0m\u001b[0;34m'CO2'\u001b[0m\u001b[0;34m]\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mseasonal\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;36m13\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 5\u001b[0m \u001b[0mres\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mstl\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mfit\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
"\u001b[0;31mImportError\u001b[0m: cannot import name 'STL'" "\u001b[0;31mImportError\u001b[0m: cannot import name 'STL'"
...@@ -213,7 +213,7 @@ ...@@ -213,7 +213,7 @@
"execution_count": 68, "execution_count": 13,
...@@ -228,7 +228,7 @@ ...@@ -228,7 +228,7 @@
"execution_count": 70, "execution_count": 14,
...@@ -258,26 +258,26 @@ ...@@ -258,26 +258,26 @@
"execution_count": 81, "execution_count": 15,
"name": "stdout", "name": "stdout",
"output_type": "stream", "output_type": "stream",
"text": [ "text": [
" date size bytes from url \\\n", " 0 1 2 3 4 \\\n",
"0 [1421771203.082701] 1257 bytes from stackoverflow.com \n", "0 [1421771203.082701] 1257 bytes from stackoverflow.com \n",
"1 [1421771203.408254] 454 bytes from stackoverflow.com \n", "1 [1421771203.408254] 454 bytes from stackoverflow.com \n",
"2 [1421771203.739730] 775 bytes from stackoverflow.com \n", "2 [1421771203.739730] 775 bytes from stackoverflow.com \n",
"3 [1421771204.056630] 1334 bytes from stackoverflow.com \n", "3 [1421771204.056630] 1334 bytes from stackoverflow.com \n",
"4 [1421771204.372224] 83 bytes from stackoverflow.com \n", "4 [1421771204.372224] 83 bytes from stackoverflow.com \n",
"\n", "\n",
" ip icmp ttl time ms \n", " 5 6 7 8 9 \n",
"0 (198.252.206.140): icmp_seq=1 ttl=50 NaN ms \n", "0 (198.252.206.140): icmp_seq=1 ttl=50 time=120 ms \n",
"1 (198.252.206.140): icmp_seq=1 ttl=50 NaN ms \n", "1 (198.252.206.140): icmp_seq=1 ttl=50 time=120 ms \n",
"2 (198.252.206.140): icmp_seq=1 ttl=50 NaN ms \n", "2 (198.252.206.140): icmp_seq=1 ttl=50 time=126 ms \n",
"3 (198.252.206.140): icmp_seq=1 ttl=50 NaN ms \n", "3 (198.252.206.140): icmp_seq=1 ttl=50 time=112 ms \n",
"4 (198.252.206.140): icmp_seq=1 ttl=50 NaN ms \n" "4 (198.252.206.140): icmp_seq=1 ttl=50 time=111 ms \n"
...@@ -288,25 +288,9 @@ ...@@ -288,25 +288,9 @@
"execution_count": 83, "execution_count": 16,
"outputs": [ "outputs": [],
"ename": "AttributeError",
"evalue": "Can only use .str accessor with string values, which use np.object_ dtype in pandas",
"output_type": "error",
"traceback": [
"\u001b[0;31mAttributeError\u001b[0m Traceback (most recent call last)",
"\u001b[0;32m<ipython-input-83-7ddb759974fe>\u001b[0m in \u001b[0;36m<module>\u001b[0;34m\u001b[0m\n\u001b[1;32m 10\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 11\u001b[0m \u001b[0;31m# Procesar los datos de ping para liglab2 y stackoverflow\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m---> 12\u001b[0;31m \u001b[0mdf_liglab2\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mprocess_ping_data\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mdf_liglab2\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 13\u001b[0m \u001b[0mdf_stackoverflow\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mprocess_ping_data\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mdf_stackoverflow\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
"\u001b[0;32m<ipython-input-83-7ddb759974fe>\u001b[0m in \u001b[0;36mprocess_ping_data\u001b[0;34m(df)\u001b[0m\n\u001b[1;32m 6\u001b[0m \u001b[0mdf\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mdropna\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0minplace\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;32mTrue\u001b[0m\u001b[0;34m)\u001b[0m \u001b[0;31m# Eliminar filas incompletas\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 7\u001b[0m \u001b[0mdf\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mcolumns\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0;34m[\u001b[0m\u001b[0;34m\"date\"\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0;34m\"size\"\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0;34m\"bytes\"\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0;34m\"from\"\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0;34m\"url\"\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0;34m\"ip\"\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0;34m\"icmp\"\u001b[0m\u001b[0;34m,\u001b[0m\u001b[0;34m\"ttl\"\u001b[0m\u001b[0;34m,\u001b[0m\u001b[0;34m\"time\"\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0;34m\"ms\"\u001b[0m\u001b[0;34m]\u001b[0m \u001b[0;31m# Nombrar las columnas\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m----> 8\u001b[0;31m \u001b[0mdf\u001b[0m\u001b[0;34m[\u001b[0m\u001b[0;34m\"time\"\u001b[0m\u001b[0;34m]\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mdf\u001b[0m\u001b[0;34m[\u001b[0m\u001b[0;34m\"time\"\u001b[0m\u001b[0;34m]\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mstr\u001b[0m\u001b[0;34m[\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m-\u001b[0m\u001b[0;36m3\u001b[0m\u001b[0;34m]\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mastype\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mfloat\u001b[0m\u001b[0;34m)\u001b[0m \u001b[0;31m# Convertir el tiempo a float\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 9\u001b[0m \u001b[0;32mreturn\u001b[0m \u001b[0mdf\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 10\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n",
"\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/core/generic.py\u001b[0m in \u001b[0;36m__getattr__\u001b[0;34m(self, name)\u001b[0m\n\u001b[1;32m 3608\u001b[0m if (name in self._internal_names_set or name in self._metadata or\n\u001b[1;32m 3609\u001b[0m name in self._accessors):\n\u001b[0;32m-> 3610\u001b[0;31m \u001b[0;32mreturn\u001b[0m \u001b[0mobject\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m__getattribute__\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mself\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mname\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 3611\u001b[0m \u001b[0;32melse\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 3612\u001b[0m \u001b[0;32mif\u001b[0m \u001b[0mname\u001b[0m \u001b[0;32min\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_info_axis\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
"\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/core/accessor.py\u001b[0m in \u001b[0;36m__get__\u001b[0;34m(self, instance, owner)\u001b[0m\n\u001b[1;32m 52\u001b[0m \u001b[0;31m# this ensures that Series.str.<method> is well defined\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 53\u001b[0m \u001b[0;32mreturn\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0maccessor_cls\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m---> 54\u001b[0;31m \u001b[0;32mreturn\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mconstruct_accessor\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0minstance\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 55\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 56\u001b[0m \u001b[0;32mdef\u001b[0m \u001b[0m__set__\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mself\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0minstance\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mvalue\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
"\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/core/strings.py\u001b[0m in \u001b[0;36m_make_accessor\u001b[0;34m(cls, data)\u001b[0m\n\u001b[1;32m 1908\u001b[0m \u001b[0;31m# (instead of test for object dtype), but that isn't practical for\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1909\u001b[0m \u001b[0;31m# performance reasons until we have a str dtype (GH 9343)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m-> 1910\u001b[0;31m raise AttributeError(\"Can only use .str accessor with string \"\n\u001b[0m\u001b[1;32m 1911\u001b[0m \u001b[0;34m\"values, which use np.object_ dtype in \"\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1912\u001b[0m \"pandas\")\n",
"\u001b[0;31mAttributeError\u001b[0m: Can only use .str accessor with string values, which use np.object_ dtype in pandas"
"import numpy as np\n", "import numpy as np\n",
"\n", "\n",
...@@ -314,7 +298,9 @@ ...@@ -314,7 +298,9 @@
"def process_ping_data(df):\n", "def process_ping_data(df):\n",
" df.dropna(inplace=True) # Eliminar filas incompletas\n", " df.dropna(inplace=True) # Eliminar filas incompletas\n",
" df.columns = [\"date\", \"size\", \"bytes\", \"from\", \"url\", \"ip\", \"icmp\",\"ttl\",\"time\", \"ms\"] # Nombrar las columnas\n", " df.columns = [\"date\", \"size\", \"bytes\", \"from\", \"url\", \"ip\", \"icmp\",\"ttl\",\"time\", \"ms\"] # Nombrar las columnas\n",
" df[\"time\"] = df[\"time\"].str[:-3].astype(float) # Convertir el tiempo a float\n", " df[\"time\"] = df[\"time\"].str[5:].astype(float) # Convertir el tiempo a float\n",
" df[\"date\"] = df[\"date\"].str[1:18]\n",
" df[\"date\"] = pd.to_datetime(df[\"date\"], unit='s')\n",
" return df\n", " return df\n",
"\n", "\n",
"# Procesar los datos de ping para liglab2 y stackoverflow\n", "# Procesar los datos de ping para liglab2 y stackoverflow\n",
...@@ -324,50 +310,995 @@ ...@@ -324,50 +310,995 @@
"execution_count": 72, "execution_count": 17,
"ename": "KeyError",
"evalue": "'timestamp'",
"traceback": [
"\u001b[0;31mTypeError\u001b[0m Traceback (most recent call last)",
"\u001b[0;32mpandas/_libs/index.pyx\u001b[0m in \u001b[0;36mpandas._libs.index.IndexEngine.get_loc\u001b[0;34m()\u001b[0m\n",
"\u001b[0;32mpandas/_libs/hashtable_class_helper.pxi\u001b[0m in \u001b[0;36mpandas._libs.hashtable.Int64HashTable.get_item\u001b[0;34m()\u001b[0m\n",
"\u001b[0;31mTypeError\u001b[0m: an integer is required",
"\nDuring handling of the above exception, another exception occurred:\n",
"\u001b[0;31mKeyError\u001b[0m Traceback (most recent call last)",
"\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/core/indexes/base.py\u001b[0m in \u001b[0;36mget_loc\u001b[0;34m(self, key, method, tolerance)\u001b[0m\n\u001b[1;32m 2524\u001b[0m \u001b[0;32mtry\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m-> 2525\u001b[0;31m \u001b[0;32mreturn\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_engine\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mget_loc\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mkey\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 2526\u001b[0m \u001b[0;32mexcept\u001b[0m \u001b[0mKeyError\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
"\u001b[0;31mKeyError\u001b[0m: 'timestamp'",
"\u001b[0;32m<ipython-input-72-8b781e47d17b>\u001b[0m in \u001b[0;36m<module>\u001b[0;34m\u001b[0m\n\u001b[1;32m 3\u001b[0m \u001b[0;31m# Gráfico del tiempo de transmisión a lo largo del tiempo\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 4\u001b[0m \u001b[0mplt\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mfigure\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mfigsize\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;36m10\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0;36m6\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m----> 5\u001b[0;31m \u001b[0mplt\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mplot\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mdf_liglab2\u001b[0m\u001b[0;34m[\u001b[0m\u001b[0;34m\"timestamp\"\u001b[0m\u001b[0;34m]\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mdf_liglab2\u001b[0m\u001b[0;34m[\u001b[0m\u001b[0;34m\"time\"\u001b[0m\u001b[0;34m]\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mlabel\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;34m\"liglab2\"\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 6\u001b[0m \u001b[0mplt\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mxlabel\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m\"Tiempo\"\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 7\u001b[0m \u001b[0mplt\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mylabel\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m\"Tiempo de transmisión (ms)\"\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
"\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/core/frame.py\u001b[0m in \u001b[0;36m__getitem__\u001b[0;34m(self, key)\u001b[0m\n\u001b[1;32m 2137\u001b[0m \u001b[0;32mreturn\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_getitem_multilevel\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mkey\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 2138\u001b[0m \u001b[0;32melse\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m-> 2139\u001b[0;31m \u001b[0;32mreturn\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_getitem_column\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mkey\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 2140\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 2141\u001b[0m \u001b[0;32mdef\u001b[0m \u001b[0m_getitem_column\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mself\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mkey\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
"\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/core/frame.py\u001b[0m in \u001b[0;36m_getitem_column\u001b[0;34m(self, key)\u001b[0m\n\u001b[1;32m 2144\u001b[0m \u001b[0;31m# get column\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 2145\u001b[0m \u001b[0;32mif\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mcolumns\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mis_unique\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m-> 2146\u001b[0;31m \u001b[0;32mreturn\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_get_item_cache\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mkey\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 2147\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 2148\u001b[0m \u001b[0;31m# duplicate columns & possible reduce dimensionality\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
"\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/core/generic.py\u001b[0m in \u001b[0;36m_get_item_cache\u001b[0;34m(self, item)\u001b[0m\n\u001b[1;32m 1840\u001b[0m \u001b[0mres\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mcache\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mget\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mitem\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1841\u001b[0m \u001b[0;32mif\u001b[0m \u001b[0mres\u001b[0m \u001b[0;32mis\u001b[0m \u001b[0;32mNone\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m-> 1842\u001b[0;31m \u001b[0mvalues\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_data\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mget\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mitem\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 1843\u001b[0m \u001b[0mres\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_box_item_values\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mitem\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mvalues\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1844\u001b[0m \u001b[0mcache\u001b[0m\u001b[0;34m[\u001b[0m\u001b[0mitem\u001b[0m\u001b[0;34m]\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mres\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
"\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/core/internals.py\u001b[0m in \u001b[0;36mget\u001b[0;34m(self, item, fastpath)\u001b[0m\n\u001b[1;32m 3841\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 3842\u001b[0m \u001b[0;32mif\u001b[0m \u001b[0;32mnot\u001b[0m \u001b[0misna\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mitem\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m-> 3843\u001b[0;31m \u001b[0mloc\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mitems\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mget_loc\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mitem\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 3844\u001b[0m \u001b[0;32melse\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 3845\u001b[0m \u001b[0mindexer\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mnp\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0marange\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mlen\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mitems\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m[\u001b[0m\u001b[0misna\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mitems\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m]\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
"\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/core/indexes/base.py\u001b[0m in \u001b[0;36mget_loc\u001b[0;34m(self, key, method, tolerance)\u001b[0m\n\u001b[1;32m 2525\u001b[0m \u001b[0;32mreturn\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_engine\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mget_loc\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mkey\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 2526\u001b[0m \u001b[0;32mexcept\u001b[0m \u001b[0mKeyError\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m-> 2527\u001b[0;31m \u001b[0;32mreturn\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_engine\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mget_loc\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_maybe_cast_indexer\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mkey\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 2528\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 2529\u001b[0m \u001b[0mindexer\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mget_indexer\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m[\u001b[0m\u001b[0mkey\u001b[0m\u001b[0;34m]\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mmethod\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0mmethod\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mtolerance\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0mtolerance\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
"data": { "data": {
"text/html": [
"<div>\n",
"<style scoped>\n",
" vertical-align: middle;\n",
" }\n",
" vertical-align: top;\n",
" }\n",
" .dataframe thead th {\n",
" text-align: right;\n",
" }\n",
"</style>\n",
" <thead>\n",
" <th></th>\n",
" <th>date</th>\n",
" <th>size</th>\n",
" <th>bytes</th>\n",
" <th>from</th>\n",
" <th>url</th>\n",
" <th>ip</th>\n",
" <th>icmp</th>\n",
" <th>ttl</th>\n",
" <th>time</th>\n",
" <th>ms</th>\n",
" </tr>\n",
" </thead>\n",
" <tbody>\n",
" <tr>\n",
" <th>0</th>\n",
" <td>2015-01-20 16:26:43.082701</td>\n",
" <td>1257</td>\n",
" <td>bytes</td>\n",
" <td>from</td>\n",
" <td>stackoverflow.com</td>\n",
" <td>(198.252.206.140):</td>\n",
" <td>icmp_seq=1</td>\n",
" <td>ttl=50</td>\n",
" <td>120.0</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>1</th>\n",
" <td>2015-01-20 16:26:43.408254</td>\n",
" <td>454</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>2</th>\n",
" <td>2015-01-20 16:26:43.739730</td>\n",
" <td>775</td>\n",
" <td>from</td>\n",
" <td>126.0</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>3</th>\n",
" <td>2015-01-20 16:26:44.056630</td>\n",
" <td>1334</td>\n",
" <td>from</td>\n",
" <td>112.0</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>4</th>\n",
" <td>2015-01-20 16:26:44.372224</td>\n",
" <td>83</td>\n",
" <td>from</td>\n",
" <td>111.0</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>5</th>\n",
" <td>2015-01-20 16:26:44.688367</td>\n",
" <td>694</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6</th>\n",
" <td>2015-01-20 16:26:45.005514</td>\n",
" <td>1577</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>7</th>\n",
" <td>2015-01-20 16:26:45.321112</td>\n",
" <td>632</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>8</th>\n",
" <td>2015-01-20 16:26:45.637464</td>\n",
" <td>405</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>9</th>\n",
" <td>2015-01-20 16:26:45.953472</td>\n",
" <td>1419</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>10</th>\n",
" <td>2015-01-20 16:26:46.269163</td>\n",
" <td>329</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>11</th>\n",
" <td>2015-01-20 16:26:46.585098</td>\n",
" <td>868</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>12</th>\n",
" <td>2015-01-20 16:26:46.901972</td>\n",
" <td>1714</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>13</th>\n",
" <td>2015-01-20 16:26:47.217863</td>\n",
" <td>1053</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>14</th>\n",
" <td>2015-01-20 16:26:47.533900</td>\n",
" <td>349</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>15</th>\n",
" <td>2015-01-20 16:26:47.851148</td>\n",
" <td>1598</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>16</th>\n",
" <td>2015-01-20 16:26:48.166794</td>\n",
" <td>1412</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>17</th>\n",
" <td>2015-01-20 16:26:48.482159</td>\n",
" <td>167</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>18</th>\n",
" <td>2015-01-20 16:26:48.798155</td>\n",
" <td>60</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>19</th>\n",
" <td>2015-01-20 16:26:49.114480</td>\n",
" <td>1038</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>20</th>\n",
" <td>2015-01-20 16:26:49.430586</td>\n",
" <td>949</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>21</th>\n",
" <td>2015-01-20 16:26:49.746729</td>\n",
" <td>279</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>22</th>\n",
" <td>2015-01-20 16:26:50.062322</td>\n",
" <td>757</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>23</th>\n",
" <td>2015-01-20 16:26:50.378113</td>\n",
" <td>1355</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>24</th>\n",
" <td>2015-01-20 16:26:50.694015</td>\n",
" <td>1151</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>25</th>\n",
" <td>2015-01-20 16:26:51.009670</td>\n",
" <td>237</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>26</th>\n",
" <td>2015-01-20 16:26:51.324856</td>\n",
" <td>1221</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>27</th>\n",
" <td>2015-01-20 16:26:51.640544</td>\n",
" <td>1063</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>28</th>\n",
" <td>2015-01-20 16:26:51.956109</td>\n",
" <td>445</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>29</th>\n",
" <td>2015-01-20 16:26:52.272504</td>\n",
" <td>1619</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>...</th>\n",
" <td>...</td>\n",
" <td>...</td>\n",
" <td>...</td>\n",
" <td>...</td>\n",
" <td>...</td>\n",
" <td>...</td>\n",
" <td>...</td>\n",
" <td>...</td>\n",
" <td>...</td>\n",
" <td>...</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6857</th>\n",
" <td>2015-01-20 17:04:11.530711</td>\n",
" <td>234</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6858</th>\n",
" <td>2015-01-20 17:04:11.847515</td>\n",
" <td>231</td>\n",
" <td>from</td>\n",
" <td>110.0</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6859</th>\n",
" <td>2015-01-20 17:04:12.163837</td>\n",
" <td>1495</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6860</th>\n",
" <td>2015-01-20 17:04:12.479834</td>\n",
" <td>1313</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6861</th>\n",
" <td>2015-01-20 17:04:12.795239</td>\n",
" <td>182</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6862</th>\n",
" <td>2015-01-20 17:04:13.111570</td>\n",
" <td>2000</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6863</th>\n",
" <td>2015-01-20 17:04:13.427110</td>\n",
" <td>1396</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6864</th>\n",
" <td>2015-01-20 17:04:13.742351</td>\n",
" <td>515</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6865</th>\n",
" <td>2015-01-20 17:04:14.058100</td>\n",
" <td>590</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6866</th>\n",
" <td>2015-01-20 17:04:14.373566</td>\n",
" <td>229</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6867</th>\n",
" <td>2015-01-20 17:04:14.689196</td>\n",
" <td>806</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6868</th>\n",
" <td>2015-01-20 17:04:15.007766</td>\n",
" <td>422</td>\n",
" <td>from</td>\n",
" <td>113.0</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6869</th>\n",
" <td>2015-01-20 17:04:15.324571</td>\n",
" <td>1939</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6870</th>\n",
" <td>2015-01-20 17:04:15.639814</td>\n",
" <td>365</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6871</th>\n",
" <td>2015-01-20 17:04:15.954957</td>\n",
" <td>502</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6872</th>\n",
" <td>2015-01-20 17:04:16.272951</td>\n",
" <td>1738</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6873</th>\n",
" <td>2015-01-20 17:04:16.591915</td>\n",
" <td>1148</td>\n",
" <td>from</td>\n",
" <td>114.0</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6874</th>\n",
" <td>2015-01-20 17:04:16.915868</td>\n",
" <td>294</td>\n",
" <td>from</td>\n",
" <td>119.0</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6875</th>\n",
" <td>2015-01-20 17:04:17.231617</td>\n",
" <td>1534</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6876</th>\n",
" <td>2015-01-20 17:04:17.546404</td>\n",
" <td>1103</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6877</th>\n",
" <td>2015-01-20 17:04:17.861499</td>\n",
" <td>1121</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6878</th>\n",
" <td>2015-01-20 17:04:18.177030</td>\n",
" <td>1219</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6879</th>\n",
" <td>2015-01-20 17:04:18.493444</td>\n",
" <td>1880</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6880</th>\n",
" <td>2015-01-20 17:04:18.808864</td>\n",
" <td>986</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6881</th>\n",
" <td>2015-01-20 17:04:19.124524</td>\n",
" <td>357</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6882</th>\n",
" <td>2015-01-20 17:04:19.440517</td>\n",
" <td>1696</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6883</th>\n",
" <td>2015-01-20 17:04:19.756250</td>\n",
" <td>561</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6884</th>\n",
" <td>2015-01-20 17:04:20.071820</td>\n",
" <td>773</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6885</th>\n",
" <td>2015-01-20 17:04:20.387385</td>\n",
" <td>1009</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6886</th>\n",
" <td>2015-01-20 17:04:20.704382</td>\n",
" <td>1948</td>\n",
" <td>from</td>\n",
" <td>ms</td>\n",
" </tr>\n",
" </tbody>\n",
"</table>\n",
"<p>6824 rows × 10 columns</p>\n",
"</div>"
"text/plain": [ "text/plain": [
"<Figure size 720x432 with 0 Axes>" " date size bytes from url \\\n",
"0 2015-01-20 16:26:43.082701 1257 bytes from stackoverflow.com \n",
"1 2015-01-20 16:26:43.408254 454 bytes from stackoverflow.com \n",
"2 2015-01-20 16:26:43.739730 775 bytes from stackoverflow.com \n",
"3 2015-01-20 16:26:44.056630 1334 bytes from stackoverflow.com \n",
"4 2015-01-20 16:26:44.372224 83 bytes from stackoverflow.com \n",
"5 2015-01-20 16:26:44.688367 694 bytes from stackoverflow.com \n",
"6 2015-01-20 16:26:45.005514 1577 bytes from stackoverflow.com \n",
"7 2015-01-20 16:26:45.321112 632 bytes from stackoverflow.com \n",
"8 2015-01-20 16:26:45.637464 405 bytes from stackoverflow.com \n",
"9 2015-01-20 16:26:45.953472 1419 bytes from stackoverflow.com \n",
"10 2015-01-20 16:26:46.269163 329 bytes from stackoverflow.com \n",
"11 2015-01-20 16:26:46.585098 868 bytes from stackoverflow.com \n",
"12 2015-01-20 16:26:46.901972 1714 bytes from stackoverflow.com \n",
"13 2015-01-20 16:26:47.217863 1053 bytes from stackoverflow.com \n",
"14 2015-01-20 16:26:47.533900 349 bytes from stackoverflow.com \n",
"15 2015-01-20 16:26:47.851148 1598 bytes from stackoverflow.com \n",
"16 2015-01-20 16:26:48.166794 1412 bytes from stackoverflow.com \n",
"17 2015-01-20 16:26:48.482159 167 bytes from stackoverflow.com \n",
"18 2015-01-20 16:26:48.798155 60 bytes from stackoverflow.com \n",
"19 2015-01-20 16:26:49.114480 1038 bytes from stackoverflow.com \n",
"20 2015-01-20 16:26:49.430586 949 bytes from stackoverflow.com \n",
"21 2015-01-20 16:26:49.746729 279 bytes from stackoverflow.com \n",
"22 2015-01-20 16:26:50.062322 757 bytes from stackoverflow.com \n",
"23 2015-01-20 16:26:50.378113 1355 bytes from stackoverflow.com \n",
"24 2015-01-20 16:26:50.694015 1151 bytes from stackoverflow.com \n",
"25 2015-01-20 16:26:51.009670 237 bytes from stackoverflow.com \n",
"26 2015-01-20 16:26:51.324856 1221 bytes from stackoverflow.com \n",
"27 2015-01-20 16:26:51.640544 1063 bytes from stackoverflow.com \n",
"28 2015-01-20 16:26:51.956109 445 bytes from stackoverflow.com \n",
"29 2015-01-20 16:26:52.272504 1619 bytes from stackoverflow.com \n",
"... ... ... ... ... ... \n",
"6857 2015-01-20 17:04:11.530711 234 bytes from stackoverflow.com \n",
"6858 2015-01-20 17:04:11.847515 231 bytes from stackoverflow.com \n",
"6859 2015-01-20 17:04:12.163837 1495 bytes from stackoverflow.com \n",
"6860 2015-01-20 17:04:12.479834 1313 bytes from stackoverflow.com \n",
"6861 2015-01-20 17:04:12.795239 182 bytes from stackoverflow.com \n",
"6862 2015-01-20 17:04:13.111570 2000 bytes from stackoverflow.com \n",
"6863 2015-01-20 17:04:13.427110 1396 bytes from stackoverflow.com \n",
"6864 2015-01-20 17:04:13.742351 515 bytes from stackoverflow.com \n",
"6865 2015-01-20 17:04:14.058100 590 bytes from stackoverflow.com \n",
"6866 2015-01-20 17:04:14.373566 229 bytes from stackoverflow.com \n",
"6867 2015-01-20 17:04:14.689196 806 bytes from stackoverflow.com \n",
"6868 2015-01-20 17:04:15.007766 422 bytes from stackoverflow.com \n",
"6869 2015-01-20 17:04:15.324571 1939 bytes from stackoverflow.com \n",
"6870 2015-01-20 17:04:15.639814 365 bytes from stackoverflow.com \n",
"6871 2015-01-20 17:04:15.954957 502 bytes from stackoverflow.com \n",
"6872 2015-01-20 17:04:16.272951 1738 bytes from stackoverflow.com \n",
"6873 2015-01-20 17:04:16.591915 1148 bytes from stackoverflow.com \n",
"6874 2015-01-20 17:04:16.915868 294 bytes from stackoverflow.com \n",
"6875 2015-01-20 17:04:17.231617 1534 bytes from stackoverflow.com \n",
"6876 2015-01-20 17:04:17.546404 1103 bytes from stackoverflow.com \n",
"6877 2015-01-20 17:04:17.861499 1121 bytes from stackoverflow.com \n",
"6878 2015-01-20 17:04:18.177030 1219 bytes from stackoverflow.com \n",
"6879 2015-01-20 17:04:18.493444 1880 bytes from stackoverflow.com \n",
"6880 2015-01-20 17:04:18.808864 986 bytes from stackoverflow.com \n",
"6881 2015-01-20 17:04:19.124524 357 bytes from stackoverflow.com \n",
"6882 2015-01-20 17:04:19.440517 1696 bytes from stackoverflow.com \n",
"6883 2015-01-20 17:04:19.756250 561 bytes from stackoverflow.com \n",
"6884 2015-01-20 17:04:20.071820 773 bytes from stackoverflow.com \n",
"6885 2015-01-20 17:04:20.387385 1009 bytes from stackoverflow.com \n",
"6886 2015-01-20 17:04:20.704382 1948 bytes from stackoverflow.com \n",
"0 (198.252.206.140): icmp_seq=1 ttl=50 120.0 ms \n",
"1 (198.252.206.140): icmp_seq=1 ttl=50 120.0 ms \n",
"2 (198.252.206.140): icmp_seq=1 ttl=50 126.0 ms \n",
"3 (198.252.206.140): icmp_seq=1 ttl=50 112.0 ms \n",
"4 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"5 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"6 (198.252.206.140): icmp_seq=1 ttl=50 112.0 ms \n",
"7 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"8 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"9 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"10 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"11 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"12 (198.252.206.140): icmp_seq=1 ttl=50 112.0 ms \n",
"13 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"14 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"15 (198.252.206.140): icmp_seq=1 ttl=50 112.0 ms \n",
"16 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"17 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"18 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"19 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"20 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"21 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"22 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"23 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"24 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"25 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"26 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"27 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"28 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"29 (198.252.206.140): icmp_seq=1 ttl=50 112.0 ms \n",
"... ... ... ... ... .. \n",
"6857 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"6858 (198.252.206.140): icmp_seq=1 ttl=50 110.0 ms \n",
"6859 (198.252.206.140): icmp_seq=1 ttl=50 112.0 ms \n",
"6860 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"6861 (198.252.206.140): icmp_seq=1 ttl=50 110.0 ms \n",
"6862 (198.252.206.140): icmp_seq=1 ttl=50 112.0 ms \n",
"6863 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"6864 (198.252.206.140): icmp_seq=1 ttl=50 110.0 ms \n",
"6865 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"6866 (198.252.206.140): icmp_seq=1 ttl=50 110.0 ms \n",
"6867 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"6868 (198.252.206.140): icmp_seq=1 ttl=50 113.0 ms \n",
"6869 (198.252.206.140): icmp_seq=1 ttl=50 112.0 ms \n",
"6870 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"6871 (198.252.206.140): icmp_seq=1 ttl=50 110.0 ms \n",
"6872 (198.252.206.140): icmp_seq=1 ttl=50 113.0 ms \n",
"6873 (198.252.206.140): icmp_seq=1 ttl=50 114.0 ms \n",
"6874 (198.252.206.140): icmp_seq=1 ttl=50 119.0 ms \n",
"6875 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"6876 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"6877 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"6878 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"6879 (198.252.206.140): icmp_seq=1 ttl=50 112.0 ms \n",
"6880 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"6881 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"6882 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"6883 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"6884 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"6885 (198.252.206.140): icmp_seq=1 ttl=50 111.0 ms \n",
"6886 (198.252.206.140): icmp_seq=1 ttl=50 112.0 ms \n",
"[6824 rows x 10 columns]"
"df_stackoverflow"
"execution_count": 18,
"image/png": "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\n",
"<Figure size 720x432 with 1 Axes>"
"output_type": "display_data" "output_type": "display_data"
...@@ -376,7 +1307,7 @@ ...@@ -376,7 +1307,7 @@
"\n", "\n",
"# Gráfico del tiempo de transmisión a lo largo del tiempo\n", "# Gráfico del tiempo de transmisión a lo largo del tiempo\n",
"plt.figure(figsize=(10, 6))\n", "plt.figure(figsize=(10, 6))\n",
"plt.plot(df_liglab2[\"timestamp\"], df_liglab2[\"time\"], label=\"liglab2\")\n", "plt.plot(df_liglab2[\"date\"], df_liglab2[\"time\"], label=\"liglab2\")\n",
"plt.xlabel(\"Tiempo\")\n", "plt.xlabel(\"Tiempo\")\n",
"plt.ylabel(\"Tiempo de transmisión (ms)\")\n", "plt.ylabel(\"Tiempo de transmisión (ms)\")\n",
"plt.title(\"Evolución del tiempo de transmisión (liglab2)\")\n", "plt.title(\"Evolución del tiempo de transmisión (liglab2)\")\n",
