Commit 1f8cc71b authored by f8dc60cab5180566667b00ce62a51ae7's avatar f8dc60cab5180566667b00ce62a51ae7
parents e1978dd4 9d04bca5
# MOOC Reproducible Research: my logbook # MOOC Reproducible Research: my logbook
# Mission 1
## Module 1: Cahier de notes, cahier de laboratoire ## Module 1: Cahier de notes, cahier de laboratoire
I have started this module on June 5. I have started this module on June 5.
...@@ -45,7 +47,7 @@ and completed several quizzes relsted to th each thematique of this Module. ...@@ -45,7 +47,7 @@ and completed several quizzes relsted to th each thematique of this Module.
- How to use GitLab history - How to use GitLab history
- beginnig of the work with Jupyter notebook and commited it - beginnig of the work with Jupyter notebook and commited it
# Mission 2 - Module 2. # Mission 3 - Module 2.
## Excercice 02 (1st part) ## Excercice 02 (1st part)
...@@ -90,3 +92,30 @@ Prior to the launch, a teleconference was held to assess the risk of taking off ...@@ -90,3 +92,30 @@ Prior to the launch, a teleconference was held to assess the risk of taking off
2. **Key data points were excluded** from the analysis. 2. **Key data points were excluded** from the analysis.
3. **the uncertainity of the logistic regression estimates was not taken into accounts**, leading to overconfidence in the predictions. 3. **the uncertainity of the logistic regression estimates was not taken into accounts**, leading to overconfidence in the predictions.
# Mission 4 - Module 3
## Exercise 03 (1st part)
In this task, the following steps were perfomed:
- The small part of code was implemented and modified to check whether the local CSV file already exists.
- If the file does not exist, it is downloaded from the Réseau Sentinelles server and saved localy.
- If the file is present, the local copy was used instead of re-downloading the data.
- Necessary comments were added in the code to explain the logic and purpose of each step:
- Firstly, check if the local CSV file already exists.
- Secondly, if the file does not exist, download it from the official URL and save it locally.
- Thirdly,this ensures that the analysis uses a consistent local copy and avoids repeated downloads.
**A comparative analysis with the reference solution confirmed the implementation was correct.**
## Exercise 03 (2nd part)
The objective of this tast is to analyze the incidence of chickenpox using a new dataset. It is necessary to identify the strongest and weakest epidemic years using the incidence data.
For this aim, I perfomed the following step:
- Loaded the dataset from the Website Sentinelles
- Converted weekly data to dates and grouped it by epidemiological year (from September 1 to August 31)
- Calculated the total incidence per epidemiological year
