Update exercice_en.Rmd
parent 3143a288
title: "Doing a simple calculation on your own" title: "Data visualization"
author: "Gkiouzepi Eleni" author: "Gkiouzepi Eleni"
date: "24/7/2021" date: "24/7/2021"
...@@ -9,41 +9,23 @@ output: html_document ...@@ -9,41 +9,23 @@ output: html_document
## Data set: ## Data set:
```{r} ```{r}
x <- c(14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0) x <- c(14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0)
## Exercice 02-2 ## Sequence Plot
### 1. What is the average ?
```{r} ```{r}
round(mean(x), digits=2) plot(x, type="l", col="blue", xlim = c(0,100), ylim=c(0,25), xaxs = "i", yaxs = "i", xlab="",ylab="", tck = 0.02)
grid(nx = 5, ny = 5, col = "lightgray", lty = "dotted",
lwd = par("lwd"), equilogs = TRUE)
### 2. What is the minimum ? ## Histogram
```{r} ```{r}
round(min(x), digits=2) hist(x, breaks=seq(min(x),max(x),l=11), col="blue", xlim = c(0,25), ylim=c(0,25), xaxs = "i", yaxs = "i",main="", xlab="",ylab="", tck = 0.02)
### 3. What is the maximum ?
round(max(x), digits=2)
### 4. What is the median ?
round(median(x), digits=2)
### 5. What is the standard deviation ?
round(sd(x), digits=2)
