diff --git a/module4/ressources/resources.org b/module4/ressources/resources.org new file mode 100644 index 0000000000000000000000000000000000000000..1c2ba5925b0bbe1f611b125f763a10e15e57ed40 --- /dev/null +++ b/module4/ressources/resources.org @@ -0,0 +1,194 @@ +# -*- mode: org -*- +#+TITLE: +#+AUTHOR: Arnaud Legrand +#+DATE: June, 2018 +#+STARTUP: overview indent +#+OPTIONS: num:nil toc:t +#+PROPERTY: header-args :eval never-export + +* Getting information about Python(3) libraries +** Getting the list of installed packages and their version +https://stackoverflow.com/questions/20180543/how-to-check-version-of-python-modules +#+begin_src shell :results output :exports both +pip3 freeze +#+end_src + +#+RESULTS: +#+begin_example +asn1crypto==0.24.0 +attrs==17.4.0 +bcrypt==3.1.4 +beautifulsoup4==4.6.0 +bleach==2.1.3 +... +pandas==0.22.0 +pandocfilters==1.4.2 +paramiko==2.4.0 +patsy==0.5.0 +pexpect==4.2.1 +... +traitlets==4.3.2 +tzlocal==1.5.1 +urllib3==1.22 +wcwidth==0.1.7 +webencodings==0.5 +#+end_example + +#+begin_src shell :results output :exports both +pip3 show pandas +echo " " +pip3 show statsmodels +#+end_src + +#+RESULTS: +#+begin_example +Name: pandas +Version: 0.22.0 +Summary: Powerful data structures for data analysis, time series,and statistics +Home-page: http://pandas.pydata.org +Author: None +Author-email: None +License: BSD +Location: /usr/lib/python3/dist-packages +Requires: + +Name: statsmodels +Version: 0.9.0 +Summary: Statistical computations and models for Python +Home-page: http://www.statsmodels.org/ +Author: None +Author-email: None +License: BSD License +Location: /home/alegrand/.local/lib/python3.6/site-packages +Requires: patsy, pandas +#+end_example + +#+begin_src python :results output :exports both + +#+end_src + +** How to list imported modules? +Inspiring from [[https://stackoverflow.com/questions/4858100/how-to-list-imported-modules][StackOverflow]], here is a simple function that lists +loaded package (that have a =__version__= attribute, which is +unfortunately not completely standard). + +#+begin_src python :results output :exports both +def print_imported_modules(): + import sys + for name,val in sys.modules.items(): + if(hasattr(val, '__version__')): + print(val.__name__, val.__version__) + +print("**** Package list in the beginning ****"); +print_imported_modules() +print("**** Package list after loading pandas ****"); +import pandas +print_imported_modules() + +#+end_src + +#+RESULTS: +#+begin_example +,**** Package list in the beginning **** +,**** Package list after loading pandas **** +pandas 0.22.0 +numpy 1.14.5 +numpy.lib 1.14.5 +numpy.core 1.14.5 +numpy.core.multiarray 3.1 +numpy.core.umath b'0.4.0' +re 2.2.1 +ctypes 1.1.0 +_ctypes 1.1.0 +logging 0.5.1.2 +argparse 1.1 +zlib 1.0 +numpy.linalg._umath_linalg b'0.1.5' +decimal 1.70 +decimal 1.70 +pytz 2018.5 +dateutil 2.7.3 +distutils 3.6.5rc1 +platform 1.0.8 +ipaddress 1.0 +six 1.11.0 +json 2.0.9 +csv 1.0 +_csv 1.0 +urllib.request 3.6 +matplotlib 2.1.1 +pyparsing 2.2.0 +cycler 0.10.0 +_libjson 1.33 +#+end_example + +** Setting up an environment with pip +The easiest way to go is as follows: +#+begin_src shell :results output :exports both +pip3 freeze > requirements.txt # to obtain the list of packages with their version +pip3 install -r requirements.txt # to install the previous list of packages, possibly on an other machine +#+end_src + +If you want to have several installed python environments, you may +want to use [[https://docs.pipenv.org/][Pipenv]]. I doubt it allows to track correctly FORTRAN or C +dynamic libraries that are wrapped by Python. +* Getting information about R libraries +The best way seems to be to rely on the =devtools= package. + +#+begin_src R :results output :session *R* :exports both +sessionInfo() +devtools::session_info() +#+end_src + +#+RESULTS: +#+begin_example +R version 3.5.1 (2018-07-02) +Platform: x86_64-pc-linux-gnu (64-bit) +Running under: Debian GNU/Linux buster/sid + +Matrix products: default +BLAS: /usr/lib/x86_64-linux-gnu/blas/libblas.so.3.8.0 +LAPACK: /usr/lib/x86_64-linux-gnu/lapack/liblapack.so.3.8.0 + +locale: + [1] LC_CTYPE=fr_FR.UTF-8 LC_NUMERIC=C + [3] LC_TIME=fr_FR.UTF-8 LC_COLLATE=fr_FR.UTF-8 + [5] LC_MONETARY=fr_FR.UTF-8 LC_MESSAGES=fr_FR.UTF-8 + [7] LC_PAPER=fr_FR.UTF-8 LC_NAME=C + [9] LC_ADDRESS=C LC_TELEPHONE=C +[11] LC_MEASUREMENT=fr_FR.UTF-8 LC_IDENTIFICATION=C + +attached base packages: +[1] stats graphics grDevices utils datasets methods base + +loaded via a namespace (and not attached): +[1] compiler_3.5.1 +Session info ------------------------------------------------------------------ + setting value + version R version 3.5.1 (2018-07-02) + system x86_64, linux-gnu + ui X11 + language (EN) + collate fr_FR.UTF-8 + tz Europe/Paris + date 2018-08-01 + +Packages ---------------------------------------------------------------------- + package * version date source + base * 3.5.1 2018-07-02 local + compiler 3.5.1 2018-07-02 local + datasets * 3.5.1 2018-07-02 local + devtools 1.13.6 2018-06-27 CRAN (R 3.5.1) + digest 0.6.15 2018-01-28 CRAN (R 3.5.0) + graphics * 3.5.1 2018-07-02 local + grDevices * 3.5.1 2018-07-02 local + memoise 1.1.0 2017-04-21 CRAN (R 3.5.1) + methods * 3.5.1 2018-07-02 local + stats * 3.5.1 2018-07-02 local + utils * 3.5.1 2018-07-02 local + withr 2.1.2 2018-03-15 CRAN (R 3.5.0) +#+end_example + +Some actually advocate that [[https://github.com/ropensci/rrrpkg][writing a reproducible research compendium +can be done by writing an R package]]. Those of you willing to have a +clean R dependency management should thus have a look at [[https://rstudio.github.io/packrat/][Packrat]].
