diff --git a/module2/ressources/jupyter_fr.org b/module2/ressources/jupyter_fr.org index fe3ee074bca643de2ca87def7203bb88d46753ce..065c75bbf1dc40ea80e27865ef2316b126c7b1c8 100644 --- a/module2/ressources/jupyter_fr.org +++ b/module2/ressources/jupyter_fr.org @@ -1,118 +1,152 @@ # -*- mode: org -*- -#+TITLE: FIXME Jupyter : tips and tricks, Installing and configuring +#+TITLE: Jupyter : Trucs et astuces, installation et configuration #+AUTHOR: Arnaud Legrand, Benoit Rospars, Konrad Hinsen #+DATE: June, 2018 #+STARTUP: overview indent #+OPTIONS: num:nil toc:t #+PROPERTY: header-args :eval never-export -* Table of Contents :TOC: -- [[#1-jupyter-tips-and-tricks][1 Jupyter tips and tricks]] - - [[#11-creating-or-importing-a-notebook][1.1 Creating or importing a notebook]] - - [[#12-running-r-and-python-in-the-same-notebook][1.2 Running R and Python in the same notebook]] - - [[#13-other-languages][1.3 Other languages]] -- [[#2-installing-and-configuring-jupyter-on-your-computer][2 Installing and configuring Jupyter on your computer]] - - [[#21-installing-jupyter][2.1 Installing Jupyter]] - - [[#22-making-sure-jupyter-allows-you-to-use-r][2.2 Making sure Jupyter allows you to use R]] - - [[#23-additional-tips][2.3 Additional tips]] - -* 1 Jupyter tips and tricks -The following [[https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/][webpage]] lists several Jupyter tricks (in particular, it -illustrates many =IPython magic= commands) that should improve your -efficiency (note that this blog post is about two years old so some of -the tricks may have been integrated in the default behavior of Jupyter -now). -** 1.1 Creating or importing a notebook -Using the Jupyter environment we deployed for this MOOC will allow to -easily access any file from your default GitLab project. There are -situations however where you may want to play with other notebooks. -- Adding a brand new notebook in a given directory :: Simply follow - the following steps: - 1. From the menu: =File -> Open=. You're now in the Jupyter file manager. - 2. Navigate to the directory where you want your notebook to be created. - 3. Then from the top right button: =New -> Notebook: Python 3=. - 4. Give your notebook a name from the menu: =File -> Rename=. - - N.B.: If you create a file by doing ~File -> New Notebook -> - Python 3~, the new notebook will be created in the current - directory. Moving it afterward is possible but a bit cumbersome - (you'll have to go through the Jupyter file manager by following - the menu =File -> Open=, then select it, =Shut= it =down=, and =Move= - and/or =Rename=). -- Importing an already existing notebook :: If your notebook is - already in your GitLab project, then simply synchronize by using - the =Git pull= button and use the =File -> Open= menu. Otherwise, - imagine, you want to import the [[https://app-learninglab.inria.fr/gitlab/moocrr-session1/moocrr-reproducibility-study/blob/master/src/Python3/challenger.ipynb][following notebook]] from someone - else's repository to re-execute it. - 1. Download the file on your computer. E.g., for this [[https://app-learninglab.inria.fr/gitlab/moocrr-session1/moocrr-reproducibility-study/blob/master/src/Python3/challenger.ipynb][GitLab hosted - notebook]], click on =Open raw= (a small == within a document icon) - and save (=Ctrl-S= on most browsers) the content (a long Json text - file). - 2. Open the Jupyter file manager from the menu =File -> Open= and - navigate to the directory where you want to upload your notebook. - 3. Then from the top right button, =Upload= the previously downloaded - notebook and confirm the upload. - 4. Open the freshly uploaded notebook through the Jupyter file - manager. -** 1.2 Running R and Python in the same notebook -=rpy2= package allows to use both languages in the same notebook by: -1. Loading =rpy2=: +* Table des matières :TOC: +- [[#1-jupyter-trucs-et-astuces][1 Jupyter: Trucs et astuces]] + - [[#11-création-ou-import-dun-notebook][1.1 Création ou import d'un notebook]] + - [[#12-exécuter-du-code-r-et-du-code-python-dans-le-même-notebook][1.2 Exécuter du code R et du code Python dans le même notebook]] + - [[#13-autres-langages-que-python-et-r][1.3 Autres langages que Python et R]] +- [[#2-installation-et-configuration-de-jupyter-sur-votre-ordinateur][2 Installation et configuration de Jupyter sur votre ordinateur]] + - [[#21-installation-de-jupyter][2.1 Installation de Jupyter]] + - [[#22-sassurer-que-jupyter-vous-permet-dutiliser-r][2.2 S'assurer que Jupyter vous permet d'utiliser R]] + - [[#23-conseils-additionnels][2.3 Conseils additionnels]] + +* 1 Jupyter: Trucs et astuces +Cette [[https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/][page web]] (en anglais) recense un certain nombre d'astuces +relatives à l'utilisation de Jupyter (et en particulier des +illustrations des nombreuses commandes magiques =IPython magic=) et +susceptibles d'améliorer votre efficacité (notez bien que ce billet a +plus de deux ans que Jupyter évoluant très rapidement, certaines de +ces astuces ou de ces modules complémentaires font maintenant partie +du comportement par défaut des versions les plus récentes de Jupyter). +** 1.1 Création ou import d'un notebook +L'environnement Jupyter que nous avons déployé dans le cadre de ce +MOOC vous permettra d'accéder très simplement à tout fichier (et en +particulier les notebooks des différents exercices que nous avons +créés pour vous) de votre projet gitlab par défaut. Il y a néanmoins +des situations où vous pouvez vouloir utiliser d'autres notebooks que +ceux du MOOC. +- Créer un notebook tout neuf dans un répertoire donné :: + 1. À partir du menu: =File -> Open=. Ceci vous permet d'accéder au + gestionnaire de fichiers de Jupyter. + 2. Naviguez jusque dans le répertoire dans lequel vous souhaitez + créer votre notebook. + 3. Utilisez le bouton en haut à droite: =New -> Notebook: Python 3=. + 4. Donnez un nom à votre notebook à partir du menu: =File -> Rename=. + + N.B.: Si vous créez un notebook à partir du menu ~File -> New + Notebook -> Python 3~, il sera créé dans le répertoire courant. Le + déplacer après coup et un peu pénible. Il vous faudra aller dans + le gestionnaire de fichiers de Jupyter (menu =File -> Open=), + sélectionner le notebook, l'arrêter (=Shut =down=), puis le déplacer + (=Move=) et/ou le renommer (=Rename=). +- Importer un notebook déja existant :: Si le notebook qui vous + intéresse est déjà dans votre projet GitLab, il vous suffit de + synchroniser la copie de votre Jupyter à l'aide du bouton =Git + pull= et d'utiliser le menu =File -> Open=. Dans le cas contraire, + par exemple si souhaitez importer cet [[https://app-learninglab.inria.fr/gitlab/moocrr-session1/moocrr-reproducibility-study/blob/master/src/Python3/challenger.ipynb][autre notebook]] rédigé par + quelqu'un d'autre, procédez de la façon suivante: + 1. Télé-chargez le fichier sur votre répertoire. Pour ce [[https://app-learninglab.inria.fr/gitlab/moocrr-session1/moocrr-reproducibility-study/blob/master/src/Python3/challenger.ipynb][Notebook + hébergé sur un gitLab]], cliquez sur =Open raw= (l'icone avec + un petit == ) et sauvegardez (=Ctrl-S= sur la plupart des + navigateurs) son contenu (un long fichier texte au format JSON). + 2. Ouvrez le gestionnaire de fichiers de Jupyter via le menu =File -> + Open= et naviguez jusqu'au répertoire où vous souhaitez déposer + votre notebook. + 3. Utilisez le bouton en haut à droite =Upload= pour transférer le + document de votre ordinateur vers le serveur Jupyter et confirmez + l'upload. + 4. Vous pouvez maintenant ouvrir le notebook fraîchement récupéré + à l'aide du navigateur de fichiers de Jupyter et réexécuter le + code correspondant. +** 1.2 Exécuter du code R et du code Python dans le même notebook +C'était impossible avec les premières versions de Jupyter mais c'est +désormais très facile grâce à la bibliothèque python =rpy2=. Il vous +faut tout d'abord ouvrir un notebook python. +1. Chargez la bibliothèque =rpy2=. Le =%load_ext= est une commande magique + jupyter qui charge cette bibliothèque et vous donne accès à de + nouvelles commandes magiques. #+begin_src python :results output :exports both %load_ext rpy2.ipython #+end_src -2. Using the =%R= Ipython magic: +2. Utilisez la (nouvellement activée) commande magique =%R=: #+begin_src python :results output :exports both %%R summary(cars) #+end_src - Python objects can then even be passed to R as follows (assuming =df= - is a pandas dataframe): + Les objets Python peuvent même être passé à R de la façon suivante + (ici, on suppose que =df= est une dataframe pandas): #+begin_src python :results output :exports both %%R -i df plot(df) #+end_src -Note that this =%%R= notation indicates that R should be used for the whole cell but -an other possibility is to use =%R= to have a single line of R within a -python cell. -** 1.3 Other languages -Jupyter is not limited to Pytyhon and R. Many other languages are available: -[[https://github.com/jupyter/jupyter/wiki/Jupyter-kernels][https://github.com/jupyter/jupyter/wiki/Jupyter-kernels]], including -non-free languages like SAS, Mathematica, Matlab... Note that the maturity of these kernels differs widely. - -None of these other languages have been deployed in the context of our -MOOC but you may want to read the next sections to learn how -to set up your own Jupyter on your computer and benefit from these extensions. - -Since the question was asked several times, if you really need to stay -with SAS, you should know that SAS can be used within Jupyter using -either the [[https://sassoftware.github.io/sas_kernel/][Python SASKernel]] or the [[https://sassoftware.github.io/saspy/][Python SASPy]] package (step by step -explanations about this are given [[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/documents/tuto_jupyter_windows/tuto_jupyter_windows.md][here]]). - -Since proprietary software such as SAS cannot easily be inspected, we discourage its use as it hinders reproducibility by -essence. But perfection does not exist anyway and using Jupyter -literate programming approach allied with systematic control version -and environment control will certainly help anyway. - -* 2 Installing and configuring Jupyter on your computer -In this section, we explain how to set up a Jupyter environment on -your own computer similar to the one deployed for this MOOC. - -Note that Jupyter notebooks are only a small part of the picture and -that Jupyter is now part of a bigger project: [[https://blog.jupyter.org/jupyterlab-is-ready-for-users-5a6f039b8906][JupyterLab]], which allows -you to mix various components (including notebooks) in your -browser. In the context of this MOOC, our time frame was too short to -benefit from JupyterLab which was still under active development. You may, however, prefer JupyterLab when doing an installation on your own computer. - -** 2.1 Installing Jupyter -Follow these instructions if you wish to have a Jupyter environment on -your own computer similar to the one we set up for this MOOC. - -First, download and install the [[https://conda.io/miniconda.html][latest version of Miniconda]]. We use -Miniconda version =4.5.4= and Python version =3.6= on our server. - -Miniconda is a light version of Anaconda, which includes Python, the Jupyter Notebook, and other commonly used packages for scientific computing and data science. - -Then download the [[https://gist.github.com/brospars/4671d9013f0d99e1c961482dab533c57][mooc_rr environment file]] and create the environment using conda: +Cette notation =%%R= indique à Python et à Jupyter et que le langage R +doit être utilisé pour évaluer l'ensemble de la cellule. En interne, +python (=rpy2=) maintient une session R, lui passe le code de la cellule +et récupère le résultat. Jupyter fait alors le nécessaire pour +l'afficher correctement. Il est également possible d'utiliser =%R= pour +avoir une seule ligne de R au sein d'une cellule python. +** 1.3 Autres langages que Python et R +Jupyter tire son nom des langages Julia, Python, et R. Il ne se limite +donc pas aux langages Python et R. De nombreux autres langages de +programmation sont disponibles: +[[https://github.com/jupyter/jupyter/wiki/Jupyter-kernels][https://github.com/jupyter/jupyter/wiki/Jupyter-kernels]], et en +particulier des langages non libres comme SAS, Mathematica, +Matlab... Notez que la maturité de ces noyaux est très variables. + +Nous n'avons déployé aucun de ces autres langages dans le cadre du +MOOC mais nous vous invitons à lire les sections suivantes pour +apprendre à déployer votre propre instance de jupyter et activer +certaines de ses extensions. + +Puisque la question est posée de façon récurrente, si vous avez besoin +d'utiliser le langage SAS plutôt que le langage R, il y a deux façons +d'utiliser SAS avec Jupyter: soit avec le noyau [[https://sassoftware.github.io/sas_kernel/][Python SASKernel]], soit +avec la bibliothèque [[https://sassoftware.github.io/saspy/][Python SASPy]] (des explications détaillés sont +données [[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/documents/tuto_jupyter_windows/tuto_jupyter_windows.md][ici]]). + +Malgré la qualité et la stabilité de ce langage, SAS n'en reste pas +moins un langage propriétaire, ce qui rend l'inspection de ses +procédures très difficile et limite la réutilisation des procédures +produites par d'autres chercheurs. Nous le déconseillons donc dans un +objectif de recherche reproductible mais il faut aussi savoir ne pas +être dogmatique. La perfection n'existe pas ;) et, même en utilisant +SAS, l'utilisation de la programmation lettrée de Jupyter et d'un +contrôle de version (avec gitlab) et d'environnement (avec docker par +exemple) se révélera très certainement précieux. +* 2 Installation et configuration de Jupyter sur votre ordinateur +Dans cette section, nous expliquons comment installer, sur votre +ordinateur, un environnement Jupyter similaire à celui que nous avons +déployé pour ce MOOC. + +Notez que les notebooks Jupyter ne constituent qu'une petite partie de +l'écosystème et que Jupyter fait maintenant partie d'un projet plus +large, [[https://blog.jupyter.org/jupyterlab-is-ready-for-users-5a6f039b8906][JupyterLab]], qui permet d'assembler différents composants (dont +les notebooks) dans votre navigateur. Dans le cadre de ce MOOC, nous +avons manqué de temps pour bénéficier de tout JupyterLab qui était +toujours en développement actif. À l'heure actuelle, vous pouvez +cependant avoir intérêt à installer tout JupyterLab sur votre ordinateur. + +** 2.1 Installation de Jupyter +Ces instructions permettent d'obtenir sur votre ordinateur un +environnement Jupyter similaire à celui que nous avons déployé dans le +cadre du MOOC. + +Téléchargez et installez la [[https://conda.io/miniconda.html][dernière version de Miniconda]]. Sur notre +serveur, nous utilisons la version =4.5.4= de Miniconda et la version +=3.6= de Python. + +Miniconda est une version légère d'Anaconda, une suite logicielle +incluant Python, Jupyter, R ainsi que les bibliothèques les plus +couramment utilisées en calcul scientifique et en science des données. + +Téléchargez ensuite le [[https://gist.github.com/brospars/4671d9013f0d99e1c961482dab533c57][fichier d'environnement =mooc_rr= ]] et déployez +votre environnement à l'aide de conda: #+begin_src shell :results output :exports both conda env create -f environment.yml @@ -125,95 +159,105 @@ source activate mooc_rr # Linux, MacOS and Windows: launch the notebook jupyter notebook #+end_src -** 2.2 Making sure Jupyter allows you to use R -The environment described in the last section should include R, but if -you proceeded otherwise and only have Python available in Jupyter, you -may want to read the following section. -*** • Installing [[https://github.com/IRkernel/IRkernel][IRKernel]] (R package) -Do the following in R console: - -Install the =devtools= package: - -#+begin_src R :results output :session *R* :exports both -install.packages('devtools',dep=TRUE) -#+end_src - -Define a proxy if needed: - -#+begin_src R :results output :session *R* :exports both -library(httr) -set_config(use_proxy(url="proxy", port=80, username="username", password="password")) -#+end_src - -Install the =IRkernel= package: - -#+begin_src R :results output :session *R* :exports both -devtools::install_github('IRkernel/IRkernel') -IRkernel::installspec() # to register the kernel in the current R installation -#+end_src - -*** • Installing rpy2 (Python package) -On Linux, the rpy2 package is available in standard distributions +** 2.2 S'assurer que Jupyter vous permet d'utiliser R +Si vous avez installé l'environnement de la façon décrite dans la +section précédente, vous devriez déjà avoir R à votre disposition et +vous n'avez donc rien à faire. Mais si vous avez procédé différemment +et n'avez que Python et Jupyter à votre disposition, il vous faudra +certainement suivre les étapes suivantes +*** • Installation de [[https://github.com/IRkernel/IRkernel][IRKernel]] (R package) +IRKernel vous permettra de faire des notebooks utilisant le langage R +plutôt que le langage Python. Nous supposons ici que R est déjà +installé et fonctionnel sur votre ordinateur. Dans une console R: +- Installer la bibliothèque =devtools=: + #+begin_src R :results output :session *R* :exports both + install.packages('devtools',dep=TRUE) + #+end_src +- Définissez un proxy si nécessaire (c'est important si votre + ordinateur est connecté à une entreprise qui limite l'accès à + Internet): + #+begin_src R :results output :session *R* :exports both + library(httr) + set_config(use_proxy(url="proxy", port=80, username="username", password="password")) + #+end_src +- Installez la bibliothèque =IRkernel=: + #+begin_src R :results output :session *R* :exports both + devtools::install_github('IRkernel/IRkernel') + IRkernel::installspec() # to register the kernel in the current R installation + #+end_src +*** • Installation de rpy2 (Python package) +La bibliothèque =rpy2= permet à Python d'appeler R et donc de mélanger +les deux langages dans le même notebook. Cette bibliothèque est en +général disponible sur les distributions récentes. Par exemple sous +debian ou ubuntu: #+begin_src shell :results output :exports both sudo apt-get install python3-rpy2 python3-tzlocal #+end_src -An alternative (not really recommended if the first one is available) -consists in going through the python package manager with +Si vous ne disposez pas d'une distribution linux récente, il est +possible (mais non recommandé) d'utiliser le gestionnaire de paquets +de python: #+begin_src python :results output :exports both pip3 install rpy2 #+end_src *Windows* -Download the =rpy2= [[https://www.lfd.uci.edu/~gohlke/pythonlibs/#rpy2][binary file]] by choosing the right operating system. +Téléchargez le [[https://www.lfd.uci.edu/~gohlke/pythonlibs/#rpy2][fichier binaire]] =rpy2= en choisissant le bon système +d'exploitation. -Open a DOS console and type the following command: +Ouvrez une console DOS et tapez les commandes suivantes: #+begin_src shell :results output :exports both python -m pip install rpy2‑2.9.4‑cp37‑cp37m‑win_amd64.whl # adapt filename #+end_src -Install also =tzlocal=: +Installez également =tzlocal=: #+begin_src shell :results output :exports both python -m pip install tzlocal #+end_src -** 2.3 Additional tips -*** • Exporting a notebook -Here is what we had to install on a recent Debian computer to make sure -the notebook export via LaTeX works: +** 2.3 Conseils additionnels +*** • Exporter un notebook +Jupyter évolue rapidement et ces informations peuvent vite devenir +obsolète mais voici ce qu'il peut être utile d'installer sur une +debian récente pour que l'export des notebooks via LaTeX soit +fonctionnel: #+begin_src shell :results output :exports both sudo apt-get install texlive-xetex wkhtmltopdf #+end_src -Obviously, you can convert to html or pdf using the using the =File > Download as > HTML= (or =PDF=) menu option. This can also be done from -the command line with the following command: - +L'export vers HTML ou PDF peut se faire dans Jupyter via le menu =File +> Download as > HTML= (ou =PDF=). Il peut également être fait en ligne de +commande de la façon suivante: #+begin_src sh :results output :exports both ipython3 nbconvert --to pdf Untitled.ipynb #+end_src -If you want to use a specific style, then the =nbconvert= exporter -should be customized. This is discussed and demoed [[http://markus-beuckelmann.de/blog/customizing-nbconvert-pdf.html][here]]. We encourage -you to simply read the [[https://nbconvert.readthedocs.io/en/latest/][doc of nbconvert]]. +Pour utiliser un style spécifique, il suffit de personnaliser +l'exporter =nbconvert=. Cette personnalisation est présentée [[http://markus-beuckelmann.de/blog/customizing-nbconvert-pdf.html][ici]] mais +nous vous encourageons à simplement lire la [[https://nbconvert.readthedocs.io/en/latest/][documentation de +nbconvert]]. -Instead of going directly through LaTeX and playing too much with the -=nbconvert= exporter, an other option consists in exporting to Markdown -and playing with [[https://pandoc.org/][pandoc]]. Both approaches work, it's rather a matter of -taste. +Plutôt que de bidouiller trop =nbconvert=, il est aussi possible +d'exporter en Markdown et d'utiliser [[https://pandoc.org/][pandoc]] qui est très flexible. Les +deux approches sont possibles, c'est une question de goût. *Windows* -Download and install MiKTeX from the [[https://miktex.org/download][MiKTeX webpage]] by choosing the -right operating system. You will be prompted to install some specific -packages when exporting to pdf. +Nous vous conseillons de télécharger et d'installer la distribution +MiKTeX à partir du [[https://miktex.org/download][site web de MiKTeX]] en choisissant le bon système +d'exploitation. Lors de votre premier export vers pdf, il vous sera +certainement demandé d'installer des packages LaTeX spécifiques. -*** • Improving notebook readability -Here are a few extensions that can ease your life: -- [[https://stackoverflow.com/questions/33159518/collapse-cell-in-jupyter-notebook][Code folding]] to improve readability when browsing the notebook. +*** • Améliorer la lisibilité d'un notebook +Lorsque les notebooks s'allongent, ils deviennent vite difficile à +lire. Voici quelques extensions qui peuvent vous faciliter un peu la +vie: +- Il est possible [[https://stackoverflow.com/questions/33159518/collapse-cell-in-jupyter-notebook][plier/déplier votre code]]: #+begin_src shell :results output :exports both pip3 install jupyter_contrib_nbextensions # jupyter contrib nbextension install --user # not done yet #+end_src -- [[https://github.com/kirbs-/hide_code][Hiding code]] to improve readability when exporting. +- Il est aussi possible de [[https://github.com/kirbs-/hide_code][contrôler la visibilité des cellules]], ce + qui peut être très utile si on exporte le notebook: #+begin_src sh :results output :exports both sudo pip3 install hide_code sudo jupyter-nbextension install --py hide_code @@ -221,23 +265,31 @@ Here are a few extensions that can ease your life: jupyter-serverextension enable --py hide_code #+end_src -*** • Interacting with GitLab and GitHub -To ease your experience, we added pull/push buttons that allow -you to commit and sync with GitLab. This development was specific to -the MOOC but inspired from a previous [[https://github.com/Lab41/sunny-side-up][proof of concept]]. We have -recently discovered that someone else developed about at the same time -a [[https://github.com/sat28/githubcommit][rather generic version of this Jupyter plugin]]. Otherwise, remember -that it is very easy to insert a shell cell in Jupyter in which you -can easily issue git commands. This is how we work most of the time. - -This being said, you may have noticed that Jupyter keeps a perfect -track of the sequence in which cells have been run by updating the -"output index". This is a very good property from the reproducibility -point of view but depending on your usage, you may find it a bit -painful when committing. Some people have thus developed [[https://gist.github.com/pbugnion/ea2797393033b54674af][specific git -hooks]] to ignore these numbers when committing Jupyter notebooks. There -is a long an interesting discussion about various options on -[[https://stackoverflow.com/questions/18734739/using-ipython-notebooks-under-version-control][StackOverflow]]. - -For those who use [[https://blog.jupyter.org/jupyterlab-is-ready-for-users-5a6f039b8906][JupyterLab]] rather than the plain Jupyter, a specific [[https://github.com/jupyterlab/jupyterlab-git][JupyterLab git plugin]] has been developed to offer a nice version control experience. +*** • Interaction avec GitLab et GitHub +Pour rendre vous simplifier la vie, nous avons rajouté des boutons +=pull/push= dans Jupyter qui vous permettent de synchroniser vos +modifications avec GitLab. Ce développement spécifique pour ce MOOC +s'est inspiré d'une [[https://github.com/Lab41/sunny-side-up][preuve de concept]] précédente mais est vraiment /ad +hoc/. Indépendemment et à peu près au même moment, une autre personne a +développé un [[https://github.com/sat28/githubcommit][Plugin Jupyter assez générique permettant de se +synchroniser avec Gitlab ou Github]]. Si cette fonctionnalité vous +intéresse, c'est donc une piste intéressante à explorer. Sinon, +souvenez vous qu'il est très simple d'insérer une cellule shell dans +Jupyter et dans laquelle vous pouvez facilement insérer des commandes +git. C'est la façon dont nous travaillons en pratique la majorité du +temps. + +Ceci étant dit, vous avez certainement remarqué que Jupyter conserve +une trace parfaite de l'ordre dans lequel les cellules ont été +exécutées en incrémentant leur "indice". C'est une très bonne +propriété d'un point de vue reproductibilité mais il se peut, selon +votre usage, que cela s'avère peu pratique du point de vue du suivi de +version. Certaines personnes ont donc développé des [[https://gist.github.com/pbugnion/ea2797393033b54674af][git hooks +spécifiques]] permettant d'ignorer ces numéros lorsque l'on committe des +notebooks Jupyter. Il y au une longue discussion à ce sujet sur +[[https://stackoverflow.com/questions/18734739/using-ipython-notebooks-under-version-control][StackOverflow]] qui détaille différentes options. + +Enfin, pour ceux qui utilisent [[https://blog.jupyter.org/jupyterlab-is-ready-for-users-5a6f039b8906][JupyterLab]] plutôt que le Jupyter de +base, un [[https://github.com/jupyterlab/jupyterlab-git][plugin git pour JupyterLab]] a été développé et offre des +fonctionnalités de suivi de version dignes d'un IDE classique.
