diff --git a/module2/ressources/MergeRequestM2Exo5.org b/module2/ressources/MergeRequestM2Exo5.org new file mode 100644 index 0000000000000000000000000000000000000000..3d6c8e3374fe92dbef3a6a7758616811d3179d4b --- /dev/null +++ b/module2/ressources/MergeRequestM2Exo5.org @@ -0,0 +1,44 @@ +# -*- mode: org -*- +#+TITLE: Perform a Merge/Request in Gitlab to update your mooc-rr repository +#+AUTHOR: Laurence Farhi +#+DATE: April, 2019 +#+STARTUP: overview indent +#+OPTIONS: num:nil toc:t +#+PROPERTY: header-args :eval never-export + + +This document explains how to retrieve from your GitLab repository the resource changes required for the exercise5 of Module 2. +To do this, we ask you to validate a Merge request with all the modifications made by Konrad, following the procedure below. + +Go to your Gitlab workspace, from the page [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/5571950188c946e790f06d4bc90fb5f6]["Your Gitlab space"]] + +Follow the instructions below. + +[[file:MergeRequest_images/MergeRequest1.png]] + +You can see that there is a request for Merge pending. + +[[file:MergeRequest_images/MergeRequest2.png]] + +Select the Merge request. + +[[file:MergeRequest_images/MergeRequest3.png]] + +If you have meanwhile modified one of the files, Gitlab will warn you that there is a conflict (grey button with "!'') and will propose you to do the merge manually. Let you be guided... + +If you go to mooc-rr/module2/exo5, you should see that 4 files have been modified. + +[[file:MergeRequest_images/MergeRequest4.png]] + +Then, if you follow the Jupyter path, you must also apply the changes in your Jupyter space. + +To do this, go to your Jupyter space, from [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/5310b948b605466d95b47e0676cf1069]["exercice 5 of Module 2"]] + (bouton "Read the analysis"). + +Make a "Git pull" to update your Jupiter space. + + [[file:MergeRequest_images/MergeRequest5.png]] + +When you read the notebook again (reload it), you should see the following change: + + [[file:MergeRequest_images/MergeRequest6.png]] diff --git a/module2/ressources/MergeRequestM2Exo5_fr.org b/module2/ressources/MergeRequestM2Exo5_fr.org index 574797cc401b2bd91ad556e85e76c9b5c9b01928..eec2ce23b018c1ef411510dbb604b9305b17bd57 100644 --- a/module2/ressources/MergeRequestM2Exo5_fr.org +++ b/module2/ressources/MergeRequestM2Exo5_fr.org @@ -36,6 +36,7 @@ Pour cela, rendez-vous sur votre espace Jupyter, depuis [[https://www.fun-mooc.f (bouton "Lire l'analyse"). Faites un "Git pull" pour mettre à jour votre espace Jupiter. + [[file:MergeRequest_images/MergeRequest5.png]] Quand vous lisez à nouveau le notebook (quittez la page et rechargez), vous devez voir la modification suivante :
