diff --git a/module2/ressources/emacs_orgmode.org b/module2/ressources/emacs_orgmode.org index 8d03f5a750e88e82dd782ce71e73b52f61b87685..28c763190b0dd3bb81133f7daa1c0b057b3953e3 100644 --- a/module2/ressources/emacs_orgmode.org +++ b/module2/ressources/emacs_orgmode.org @@ -19,7 +19,7 @@ The next section provides information on how to install emacs. * Installing emacs, org-mode, ess, and auctex. ** Linux (Debian, Ubuntu) -We provide here only instructions for debian-based distributions. Feel +We provide here only instructions for Debian-based distributions. Feel free to contribute to this document to provide up-to-date information for other distributions (e.g.n redhat, fedora). @@ -97,28 +97,21 @@ versions: - Emacs 26.1 - Org-mode 9.1.13 - ESS 17.11 -To have code pretty printing when exporting to html, it appears like -you should install the =htmlize= package, which is done by opening emacs -and typing the following command: -#+BEGIN_EXAMPLE -M-x package-install RET htmlize RET # where M-x means pressing the "Esc" key then the "x" key -#+END_EXAMPLE *** Directory naming conventions -In all the following instructions, it is common to refer to your home +In the following instructions, we refer to your home directory through the (UNIX) =~/= notation. On Windows, your home directory should be something like =C:\Users\yourname=. Therefore, whenever we mention the =~/org/= (resp. the =~/.emacs.d/=) directory this means we are referring to =C:\Users\yourname\org= (resp. =C:\Users\yourname\.emacs.d\=). *** Making R and Python available to the console -When running a command, windows will look for the command in the +When running a command, Windows will look for the command in the directories indicated in the =PATH= environment variable. If none of these directories contains the command, Windows will stop and indicate -the command does not exist. To make sure R (, which may be in -something like =C:/Program Files/R/R-3.5.1/bin/x64/=) and Python (, -which may be in something like =C:/Program Files/Python/Python37/=) can -easily be run from emacs, you should thus configure the =PATH= variable +the command does not exist. To make sure R (which may be in +something like =C:/Program Files/R/R-3.5.1/bin/x64/=) and Python (which may be in something like =C:/Program Files/Python/Python37/=) can +easily be run from Emacs, you should thus configure the =PATH= variable accordingly. This requires to go through the "Environment Variable" editor as @@ -142,6 +135,14 @@ matplotlib.matplotlib_fname() Open the =matplotlibrc= file and add a =#= at the beginning of the line starting with =backend=, which amounts to use the default =Agg= value. +** All platforms: pretty code in HTML export +To have code pretty printing when exporting to HTML, you should +install the =htmlize= package, which is done by opening emacs and +typing the following command: +#+BEGIN_EXAMPLE +M-x package-install RET htmlize RET # where M-x means pressing the "Esc" key then the "x" key +#+END_EXAMPLE + * A simple "/reproducible research/" emacs configuration This section is illustrated in a [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4][video tutorial]] (/"Mise en place Emacs/Orgmode"/ in French). Watching it before following the @@ -157,10 +158,10 @@ minimalist one that is rather "/reproducible research/" oriented by adding a few org-mode specific configurations. ** Step 0: Backup and download our configuration -The procedure we propose will wipe your already existing custom emacs -configuration if you already have one. *You should thus beforehand make -a backup of =~/.emacs= and of =~/.emacs.d/init.el=* (if these file -exists). +The procedure we propose will wipe your already existing custom Emacs +configuration if you have one. *You should thus beforehand make +a backup of =~/.emacs= and of =~/.emacs.d/init.el=* (if these files +exist). #+begin_src shell :results output :exports none export FILE_LIST="rr_org/init.el rr_org/journal.org" @@ -187,7 +188,7 @@ mkdir -p ~/org/ Then copy =rr_org/journal.org= file in your =~/org/= directory. This file will be your laboratory notebook and all the notes you will capture with =C-c c= will go automatically go in this file. The first -entry of this notebook is populated with [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org][many emacs shortcuts]] that you +entry of this notebook is populated with [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org][many Emacs shortcuts]] that you should give a try. ** Step 2: Set up Emacs configuration Copy =rr_org/init.el= in your =~/.emacs.d/= directory. @@ -231,10 +232,10 @@ is demonstrated in the [[https://app-learninglab.inria.fr/gitlab/learning-lab/mo ** Step 5: Open and play with your journal: In step 1, you were told to create an journal in =~org/journal.org=. First you probably want to make sure this file is -backed up in a revision control system like git. We leave it up to you +stored in a version control system like git. We leave it up to you to set this up but if you have any trouble, feel free to ask on the FUN forums. -* A stub of replicable article +* A stub of a replicable article This section is illustrated in a [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4][video tutorial]] (/"Écrire un article réplicable avec Emacs/Orgmode"/ in French). Watching it before following the instructions given in this section may help. @@ -262,7 +263,7 @@ tar zxf replicable_article.tgz; cd replicable_article; make ; evince article.pdf *Possible issues*: - If the =make= command fails (especially on Mac), it may be because - emacs or something else is not correctly installed. In that case, + Emacs or something else is not correctly installed. In that case, open the article directly with the following command: #+begin_src sh :results output :exports both emacs -q --eval "(setq enable-local-eval t)" --eval "(setq enable-local-variables t)" article.org @@ -282,16 +283,16 @@ If you remove the =# = in the beginning of the line, it will not be a comment anymore and will indicate org-mode to stop evaluating every chunk of code when exporting. -* Emacs Tips and tricks +* Emacs tips and tricks ** Cheat-sheets -Learning emacs and org-mode can be difficult as there is an inordinate +Learning Emacs and Org-Mode can be difficult as there is an inordinate amount of shortcuts. Many people have thus come up with cheat-sheats. Here is a selection in case it helps: *** Emacs -- [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org][Common and step-by-step emacs shortcuts for our /reproducible research/ configuration]] +- [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org][Common and step-by-step Emacs shortcuts for our /reproducible research/ configuration]] - [[https://www.gnu.org/software/emacs/refcards/pdf/refcard.pdf][The official GNU emacs refcard]] -- Two graphical cheat-sheats by Sacha Hua on [[http://sachachua.com/blog/wp-content/uploads/2013/05/How-to-Learn-Emacs-v2-Large.png][how to learn emacs]] and on - [[http://sachachua.com/blog/wp-content/uploads/2013/08/20130830-Emacs-Newbie-How-to-Learn-Emacs-Keyboard-Shortcuts.png][how to learn emacs shortcuts]]. +- Two graphical cheat-sheats by Sacha Chua on [[http://sachachua.com/blog/wp-content/uploads/2013/05/How-to-Learn-Emacs-v2-Large.png][how to learn Emacs]] and on + [[http://sachachua.com/blog/wp-content/uploads/2013/08/20130830-Emacs-Newbie-How-to-Learn-Emacs-Keyboard-Shortcuts.png][how to learn Emacs shortcuts]]. *** Org-mode - [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org][Common and step-by-step org-mode shortcuts for our /reproducible research/ configuration]] - [[https://orgmode.org/worg/orgcard.html][The official org-mode refcard]] @@ -306,12 +307,12 @@ have smart completion in emacs for the most common languages. If you feel this is needed, you should follow the instructions from the official Web page: http://company-mode.github.io/ *** Magit -[[https://magit.vc/][Magit]] is an emacs interface for Git. Its usage is briefly illustrated +[[https://magit.vc/][Magit]] is an Emacs interface for Git. Its usage is briefly illustrated in the context of this MOOC in a [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4][video tutorial]] (/"Utilisation Emacs/git"/ in French). It is very powerful and we use it on a daily basis but you should -definitely understand what git does behind the scene beforehand. If +definitely understand what git does behind the scenes beforehand. If you feel this would be useful for you, you should follow [[https://magit.vc/screenshots/][this visual walk-through]] or [[https://www.emacswiki.org/emacs/Magit][this really short "crash course"]]. If you installed the previous "/reproducible research/" emacs configuration, you can easily
