Learning Lab
0893b72e
0893b72e
modif du titre de la doc sur Jupiter + génération du .md
ee77013c
3
3 changed files
433 additions
143 deletions
+433
-143
emacs_orgmode.md
module2/ressources/emacs_orgmode.md
+127
-142
jupyter.md
module2/ressources/jupyter.md
+305
jupyter.org
module2/ressources/jupyter.org
+1
-1
0893b72e
@@ -3,51 +3,49 @@ configuration* and *A stub of replicable article* explain how to set up
emacs/org-mode for this MOOC. These are very important sections in the
context of this MOOC.
These sections are illustrated in two out of the
three video tutorials of this
sequence](https://www.fun-mooc.fr/courses/course-v1:inria+41016+session0
1bis
/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4),
2
which you really should follow carefully
Otherwise, you may
have trouble doing the exercises later on
. Likewise, I strongly
encourage you to watch the
"emacs and git" video tutorial available at
the same
place](https://www.fun-mooc.fr/courses/course-v1:inria+41016+session0
1bis
/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4).
2
The next section provides information on how to install emacs.
emacs.
Table of Contents
# Table of Contents <span class="tag" data-tag-name="TOC"><span class="smallcaps">TOC</span></span>
Installing emacs, org-mode, ess, and
auctex.](#installing-emacs-org-mode-ess-and-auctex)
Linux (Debian, Ubuntu)
#linux-debian-ubuntu
macOS
#macos
Windows
#windows
All platforms: pretty code in HTML
macOS
#macos
Windows
#windows
export](#all-platforms-pretty-code-in-html-export)
A simple "
*reproducible research*
" emacs configuration
A simple "
](#a-simple-reproducible-research-emacs-configuration-)
Step 0: Backup and download our
configuration](#step-0-backup-and-download-our-configuration)
Step 1: Prepare your journal
#step-1-prepare-your-journal
Step 2: Set up Emacs
configuration](#step-2-set-up-emacs-configuration)
Step 3: Adapt the configuration to your specific needs if
required](#step-3-adapt-the-configuration-to-your-specific-needs-if-required)
Step 4: Check whether the installation is working or
not](#step-4-check-whether-the-installation-is-working-or-not)
Step 5: Open and play with your
journal:](#step-5-open-and-play-with-your-journal)
A stub of a replicable article
#a-stub-of-a-replicable-article
Emacs tips and tricks
#emacs-tips-and-tricks
Cheat-sheets
#cheat-sheets
Video tutorials
#video-tutorials
Additional useful emacs
Cheat-sheets
#cheat-sheets
Video tutorials
#video-tutorials
packages](#additional-useful-emacs-packages)
Other resources
#other-resources
Other resources
#other-resources
Installing emacs, org-mode, ess, and auctex.
# Installing emacs, org-mode, ess, and auctex.
## Linux (Debian, Ubuntu)
We provide here only instructions for Debian-based distributions. Feel
free to contribute to this document to provide up-to-date information
@@ -56,63 +54,63 @@ for other distributions (e.g.n redhat, fedora).
Today, the stable versions of the most common distributions provide
recent enough versions of emacs and org-mode:
Debian (stretch) ships with
emacs
25.
1](https://packages.debian.org/stretch/emacs25) and
org-mode
9.
0.3](https://packages.debian.org/stretch/org-mode)
Ubuntu (bionic 18.04) ships with
emacs
25.
2](https://packages.ubuntu.com/bionic/emacs25) and
org-mode
9.
1.6](https://packages.ubuntu.com/bionic/org-mode)
Ubuntu (artful 17.04) ships with
emacs
25.
2](https://packages.ubuntu.com/artful/emacs25) and
org-mode
9.
0.9](https://packages.ubuntu.com/artful/org-mode)
emacs 25.1
org-mode
9.0.3
emacs 25.2
org-mode
9.1.6
emacs 25.2
org-mode
9.0.9
If your distribution is older than this, well, it may be a good time for
upgrading
upgrading
Simply run (as root):
{.bash .rundoc-block rundoc-language="sh" rundoc-results="output" rundoc-exports="both"}
bash
apt-get update
apt-get
install
emacs25 org-mode ess r-base auctex
Then make sure you have a sufficiently recent version of emacs.
bash
emacs
--version
2>&1 |
head
-n
{.example}
example
GNU Emacs 25.2.2
Likewise, you'll want to check you have a recent version of org-mode:
bash
emacs
-batch
--funcall
"org-version"
2>&1 |
grep
version
{.example}
example
Org mode version 9.1.11 (9.1.11-dist @ /usr/share/emacs/25.2/site-lisp/elpa/org-9.1.11/)
The version numbers you get will depend on the distribution you are
running.
**You really want to make sure you do not rely on org-mode 8**
which is now deprecated.
running.
<span
class=
"underline"
rely on org-mode 8
</span>
macOS
## macOS
**Note:**
macOS comes with a prehistoric command-line-only version of
Emacs located at
`/usr/bin/emacs`
. It's best to forget about it.
**Option 1**
: Install the
`.dmg`
file from
Vincent
**Option 1**
: Install the
`.dmg`
file from
Vincent
Goulet](http://vgoulet.act.ulaval.ca/):
<https://vigou3.gitlab.io/emacs-modified-macos/>
It ships with recent versions:
Emacs 26.1
Org-mode 9.1.13
ESS 17.11
. It ships with
recent versions:
Emacs 26.1
Org-mode 9.1.13
ESS 17.11
If you install this version of Emacs, or in fact any other version
of Emacs distributed as a clickable application in a
`.dmg`
file,
you must type the full path to the executable if you want to run
@@ -120,10 +118,10 @@ Emacs located at `/usr/bin/emacs`. It's best to forget about it.
at
`/Applications/Emacs.app`
, then the executable is at
`/Applications/Emacs.app/Contents/MacOS/Emacs`
**Option 2**
: If you use
Homebrew
https://docs.brew.sh/
, do the
**Option 2**
: If you use
Homebrew
, do the
following:
bash
brew update
brew
install
emacs
--with-cocoa
brew linkapps emacs
@@ -133,31 +131,30 @@ Emacs located at `/usr/bin/emacs`. It's best to forget about it.
brew tap brewsci/science
brew
install
ess
This provides an
emacs
command
for
use from the
command
line, plus
a clickable application at
Cellar/emacs/26.1_1/Emacs.app
inside
your Homebrew directory. If you installed Homebrew at the default
location
/usr/local
then
this is
/usr/local/Cellar/emacs/26.1_1/Emacs.app
If you installed
Homebrew on an account with administrator privileges, you can add
bash
brew linkapps emacs
in
order to make Emacs accessible directly from
/Applications
Windows
## Windows
Install the
.exe
file from
Vincent
Goulet]
<https://vigou3.gitlab.io/emacs-modified-windows/>
versions:
<https://vigou3.gitlab.io/emacs-modified-windows/>. It ships with recent
versions:
Emacs 26.1
Org-mode 9.1.13
ESS 17.11
Emacs 26.1
Org-mode 9.1.13
ESS 17.11
### Directory naming conventions
@@ -185,7 +182,7 @@ explained
Open an DOS console and
type
the following
command
{.shell .rundoc-block rundoc-language="shell" rundoc-results="output" rundoc-exports="both"}
shell
python -m pip install -U matplotlib
@@ -195,7 +192,7 @@ Then you will want to deactivate interactive plots in matplotlib. To
this end, you first need to know where the matplotlib configuration is
located. Open a python console the type the following code:
{.python .rundoc-block rundoc-language="python" rundoc-results="output" rundoc-exports="both"}
python
import matplotlib
matplotlib.matplotlib_fname()
@@ -205,23 +202,22 @@ matplotlib.matplotlib_fname()
Open the `matplotlibrc` file and modify the line starting with `backend`
to make it `backend : Agg`.
All platforms: pretty code in HTML export
## All platforms: pretty code in HTML export
To have code pretty printing when exporting to HTML, you should install
the `htmlize` package, which is done by opening emacs and typing the
following command:
following
command:
{.example}
example
M-x package-install RET htmlize RET # where M-x means pressing the "Esc" key then the "x" key
A simple "*reproducible research*" emacs configuration
# A simple "*reproducible research*" emacs configuration
This section is illustrated in a [video
tutorial](https://www.fun-mooc.fr/courses/course-v1:inria+41016+session0
1bis
/"Mise en place Emacs/Orgmode"/
in French). Watching it before
2
*"Mise en place Emacs/Orgmode"*
following the instructions given in this section may help.
Emacs comes with very basic default configuration and it appears like
@@ -235,8 +231,7 @@ references). In the context of this MOOC, we propose you a relatively
minimalist one that is rather "*reproducible research*" oriented by
adding a few org-mode specific configurations.
Step 0: Backup and download our configuration
## Step 0: Backup and download our configuration
The procedure we propose will wipe your already existing custom Emacs
configuration if you have one. **You should thus beforehand make a
@@ -244,11 +239,11 @@ backup** of `~/.emacs` and of `~/.emacs.d/init.el` (if these files
exist).
Then download [this
archive](https://
app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/raw/master/module2/
ressources/rr_org_archive.tgz)
archive](https://
gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-
and uncompress it. It contains the following files and we will refer to
them in the following:
{.example}
example
rr_org/init.el
rr_org/journal.org
@@ -256,12 +251,11 @@ rr_org/journal.org
Alternatively, [the files you are looking for are available
here](rr_org/).
## Step 1: Prepare your journal
Create an `org/` directory in the top of your home:
bash
mkdir -p ~/org/
@@ -269,11 +263,10 @@ Then copy `rr_org/journal.org` file in your `~/org/` directory. This
file will be your laboratory notebook and all the notes you will capture
with `C-c c` will go automatically go in this file. The first entry of
this notebook is populated with [many Emacs
shortcuts](https://
/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org)
shortcuts](https://
that you should give a try.
Step 2: Set up Emacs configuration
## Step 2: Set up Emacs configuration
Copy `rr_org/init.el` in your `~/.emacs.d/` directory.
@@ -281,8 +274,7 @@ Alternatively, if you do not want to mess with your already existing
emacs configuration, you may launch emacs with this specific
configuration with the following command: `emacs -q -l rr_org/init.el`.
Step 3: Adapt the configuration to your specific needs if required
## Step 3: Adapt the configuration to your specific needs if required
There are two situations in which it might be necessary to modify
`init.el`:
@@ -291,22 +283,20 @@ There are two situations in which it might be necessary to modify
sites (HTTP(S) protocol).
2. You have multiple installations of Python or R on your computer, or
they are in unusual places and not fully configured. If you can run
- "python3" and "R" under Linux and macOS
- "Python" and "R" under Windows
in a terminal without getting an error message, then you should not
have to do anything.
If you do have to modify `init.el`, check the comments at the beginning
of the file for instructions.
Step 4: Check whether the installation is working or not
## Step 4: Check whether the installation is working or not
Open a new instance of Emacs and open a `foo.org` file. Copy the
following lines in this file:
{.example}
example
#+begin_src shell :session foo :results output :exports both
ls -la # or dir under windows
@@ -323,22 +313,20 @@ In the video, we already have demonstrated the main features and
shortcuts of emacs/org-mode that will help you maintain a document and
benefit from literate programming. The list of features and shortcuts is
demonstrated in the [first entry of your
labbook](https://
/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org).
labbook](https://
Step 5: Open and play with your journal:
## Step 5: Open and play with your journal:
In step 1, you were told to create an journal in `~org/journal.org`.
First you probably want to make sure this file is stored in a version
control system like git. We leave it up to you to set this up but if you
have any trouble, feel free to ask on the FUN forums.
# A stub of a replicable article
1bis
/"Écrire un article réplicable avec Emacs/Orgmode"/
in French).
2
*"Écrire un article réplicable avec Emacs/Orgmode"*
in French).
Watching it before following the instructions given in this section may
help.
@@ -348,42 +336,45 @@ not be able to generate this document. When being compiled, the article
downloads the corresponding LaTeX packages so you also need to have a
working `wget` command (alternatively, it uses `curl`). Once downloaded,
you may still read the source
[article.org](https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.org)
<https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.org>
and understand how it works though.
Download the following
[archive](https://
ressources/replicable_article.tgz),
[archive](https://
uncompress it and simply `make` to generate the article. You should then
be able to open the [resulting
article](https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.pdf).
This is summarized in the following command:
article](https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.pdf).
command:
wget --no-check-certificate -O replicable_article.tgz https://
bash
tar zxf replicable_article.tgz; cd replicable_article; make ; evince article.pdf
**Possible issues**:
If the `
make
` command fails (especially on Mac), it may be because
If the `make` command fails (especially on Mac), it may be because
Emacs or something else is not correctly installed. In that case,
open the article directly with the following command:
``` {.bash .rundoc-block rundoc-language="sh" rundoc-results="output" rundoc-exports="both"}
command:
``` bash
emacs -q --eval "(setq enable-local-eval t)" --eval "(setq enable-local-variables t)" article.org
and export it to pdf with the following shortcut: `C-c C-e l o`
- If it still doesn't work and emacs complains about not finding ESS,
it may be because you installed ESS in your home instead of
system-wide. In that case, try to remove the `-q` in the previous
command line to load your personal emacs configuration.
Finally, when you'll be tired of always re-executing all the source code
when exporting, just look for the following line in
/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.org):
{.example}
example
@@ -391,11 +382,9 @@ If you remove the `# ` in the beginning of the line, it will not be a
comment anymore and will indicate org-mode to stop evaluating every
chunk of code when exporting.
# Emacs tips and tricks
Cheat-sheets
## Cheat-sheets
Learning Emacs and Org-Mode can be difficult as there is an inordinate
amount of shortcuts. Many people have thus come up with cheat-sheats.
@@ -403,37 +392,35 @@ Here is a selection in case it helps:
### Emacs
[Common and step-by-step Emacs shortcuts for our *reproducible
reproducible
research
configuration](https://
[The official GNU emacs
refcard](https://www.gnu.org/software/emacs/refcards/pdf/refcard.pdf)
- Two graphical cheat-sheats by Sacha Chua o
n
and on
Two graphical cheat-sheats by Sacha Chua on
how to lear
n
Emacs
](http://sachachua.com/blog/wp-content/uploads/2013/05/How-to-Learn-Emacs-v2-Large.png)
and on
how to learn Emacs
shortcuts
](http://sachachua.com/blog/wp-content/uploads/2013/08/20130830-Emacs-Newbie-How-to-Learn-Emacs-Keyboard-Shortcuts.png).
### Org-mode
[Common and step-by-step org-mode shortcuts for our *reproducible
reproducible
research
[The official org-mode
refcard](https://orgmode.org/worg/orgcard.html)
[The official description of the org-mode
syntax](https://orgmode.org/worg/dev/org-syntax.html) and a
relatively concise description of the org-mode
syntax](https://gist.github.com/hoeltgman/3825415).
Video tutorials
## Video tutorials
For those of you who prefer video explanations, here is a
Youtube
channel with many step by step emacs
tutorials](https://www.youtube.com/playlist?list=PL9KxKa8NpFxIcNQa9js7dQQIHc81b0-Xg).
Additional useful emacs packages
## Additional useful emacs packages
### Company-mode
@@ -441,13 +428,13 @@ Additional useful emacs packages
framework for Emacs. It allows to have smart completion in emacs for the
most common languages. If you feel this is needed, you should follow the
instructions from the official Web page:
[<http://company-mode.github.io/>](http://company-mode.github.io/)
### Magit
Magit
https://magit.vc/
is an Emacs interface for Git. Its usage is
briefly illustrated in the context of this MOOC in a
video
1bis
2
*Utilisation Emacs/git*
" in French).
It is very powerful and we use it on a daily basis but you should
@@ -458,10 +445,8 @@ walk-through](https://magit.vc/screenshots/) or [this really short
the previous "
" emacs configuration, you can
easily invoke magit by using
`C-x g`
Other resources
## Other resources
The compact Org-mode Guide
https://orgmode.org/orgguide.pdf
Many examples illustrating the use of different languages in
org-mode](https://github.com/dfeich/org-babel-examples)
0893b72e
# 1\. Jupyter tips and tricks
The following
webpage
https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/
lists several Jupyter tricks (in particular, it illustrates many
`IPython magic`
commands) that should improve your efficiency (note that
this blog post is about two years old so some of the tricks may have
been integrated in the default behavior of Jupyter now).
## Creating or importing a notebook
Using the Jupyter environment we deployed for this MOOC will allow to
easily access any file from your default GitLab project. There are
situations however where you may want to play with other notebooks.
Adding a brand new notebook in a given directory
Simply follow the following steps:
1.
From the menu:
`File -> Open`
. You're now in the Jupyter file
manager.
2.
Navigate to the directory where you want your notebook to be
created.
3.
Then from the top right button:
`New -> Notebook: Python 3`
4.
Give your notebook a name from the menu:
`File -> Rename`
N.B.: If you create a file by doing
`File -> New Notebook ->
Python 3`
, the new notebook will be created in the current
directory. Moving it afterward is possible but a bit cumbersome
(you'll have to go through the Jupyter file manager by following
the menu
`File -> Open`
, then select it,
`Shut`
it
`down`
, and
`Move`
and/or
`Rename`
Importing an already existing notebook
If your notebook is already in your GitLab project, then simply
synchronize by using the
`Git pull`
button and use the
`File ->
Open`
menu. Otherwise, imagine, you want to import the
following
notebook](https://app-learninglab.inria.fr/gitlab/moocrr-session1/moocrr-reproducibility-study/blob/master/src/Python3/challenger.ipynb)
from someone else's repository to re-execute it.
1.
Download the file on your computer. E.g., for this
GitLab
hosted
notebook](https://app-learninglab.inria.fr/gitlab/moocrr-session1/moocrr-reproducibility-study/blob/master/src/Python3/challenger.ipynb),
click on
`Open raw`
(a small
within a document icon) and
save (
`Ctrl-S`
on most browsers) the content (a long Json text
file).
2.
Open the Jupyter file manager from the menu
`File -> Open`
navigate to the directory where you want to upload your
notebook.
3.
Then from the top right button,
`Upload`
the previously
downloaded notebook and confirm the upload.
4.
Open the freshly uploaded notebook through the Jupyter file
manager.
## Running R and Python in the same notebook
`rpy2`
package allows to use both languages in the same notebook by:
1.
Loading
`rpy2`
python
load_ext
rpy2
ipython
2.
Using
the
`%R`
Ipython
magic
python
R
summary
cars
Python
objects
can
then
even
be
passed
to
R
as
follows
assuming
`df`
is
a
pandas
dataframe
python
R
i
df
plot
df
Note
that
this
`%%R`
notation
indicates
that
R
should
be
used
for
the
whole
cell
but
an
other
possibility
is
to
use
`%R`
to
have
a
single
line
of
R
within
a
python
cell
## Other languages
Jupyter
is
not
limited
to
Pytyhon
R
Many
other
languages
are
available
https
github
com
jupyter
jupyter
wiki
Jupyter
kernels
including
non
free
languages
like
SAS
Mathematica
Matlab
Note
that
the
maturity
of
these
kernels
differs
widely
None
of
these
other
languages
have
been
deployed
in
the
context
of
our
MOOC
but
you
may
want
to
read
the
next
sections
to
learn
how
to
set
up
your
own
Jupyter
on
your
computer
benefit
from
these
extensions
Since
the
question
was
asked
several
times
if
you
really
need
to
stay
SAS
you
should
know
that
SAS
can
be
used
within
Jupyter
using
either
the
Python
SASKernel
https
sassoftware
github
io
sas_kernel
the
Python
SASPy
https
sassoftware
github
io
saspy
package
step
step
explanations
about
this
are
given
here
https
gitlab
inria
fr
learninglab
mooc
rr
mooc
rr
blob
master
tuto_jupyter_windows
md
Since
proprietary
software
such
as
SAS
cannot
easily
be
inspected
we
discourage
its
use
as
it
hinders
reproducibility
essence
But
perfection
does
not
exist
anyway
using
Jupyter
literate
programming
approach
allied
systematic
control
version
environment
control
will
certainly
help
anyway
# 2\. Installing and configuring Jupyter on your computer
In
this
section
we
explain
how
to
set
up
a
Jupyter
environment
on
your
own
computer
similar
to
the
one
deployed
for
this
MOOC
Note
that
Jupyter
notebooks
are
only
a
small
part
of
the
that
Jupyter
is
now
part
of
a
bigger
project
JupyterLab
https
blog
jupyter
org
jupyterlab
is
ready
for
users
5
a6f039b8906
which
allows
you
to
mix
various
components
including
notebooks
in
your
browser
In
the
context
of
this
MOOC
our
time
frame
was
too
short
to
benefit
from
JupyterLab
which
was
still
under
active
development
You
may
however
prefer
JupyterLab
when
doing
an
installation
on
your
own
computer
## 2.1 Installing Jupyter
Follow
these
instructions
if
you
wish
to
have
a
Jupyter
environment
on
your
own
computer
similar
to
the
one
we
set
up
for
this
MOOC
First
download
install
the
latest
version
of
Miniconda
https
conda
io
miniconda
html
We
use
Miniconda
version
`4.5.4`
Python
version
`3.6`
on
our
server
Miniconda
is
a
light
version
of
Anaconda
which
includes
Python
the
Jupyter
Notebook
other
commonly
used
packages
for
scientific
computing
science
Then
download
the
mooc
sub
rr
sub
environment
file
https
gist
github
com
brospars
4671
d9013f0d99e1c961482dab533c57
create
the
environment
using
conda
shell
conda env create -f environment.yml
# Windows activate the environment
activate mooc_rr
# Linux and MacOS activate the environment
source activate mooc_rr
# Linux, MacOS and Windows: launch the notebook
jupyter notebook
## 2.2 Making sure Jupyter allows you to use R
The environment described in the last section should include R, but if
you proceeded otherwise and only have Python available in Jupyter, you
may want to read the following
section.
### • Installing [IRKernel](https://github.com/IRkernel/IRkernel) (R package)
Do the following in R console:
Install the `devtools` package:
r
install.packages('devtools',dep=TRUE)
Define a proxy if needed:
r
library(httr)
set_config(use_proxy(url="proxy", port=80, username="username", password="password"))
Install the `IRkernel` package:
r
devtools::install_github('IRkernel/IRkernel')
IRkernel::installspec() # to register the kernel in the current R installation
### • Installing rpy2 (Python package)
On Linux, the rpy2 package is available in standard distributions
shell
sudo apt-get install python3-rpy2 python3-tzlocal
An alternative (not really recommended if the first one is available)
consists in going through the python package manager with
python
pip3 install rpy2
**Windows**
Download the `rpy2` [binary
file](https://www.lfd.uci.edu/~gohlke/pythonlibs/#rpy2) by choosing the
right operating system.
Open a DOS console and type the following
command:
shell
python -m pip install rpy2‑2.9.4‑cp37‑cp37m‑win_amd64.whl # adapt filename
Install also `tzlocal`:
shell
python -m pip install tzlocal
## 2.3 Additional tips
### • Exporting a notebook
Here is what we had to install on a recent Debian computer to make sure
the notebook export via LaTeX works:
shell
sudo apt-get install texlive-xetex wkhtmltopdf
Obviously, you can convert to html or pdf using the using the `File >
Download as > HTML` (or `PDF`) menu option. This can also be done from
the command line with the following command:
bash
ipython3 nbconvert --to pdf Untitled.ipynb
If you want to use a specific style, then the `nbconvert` exporter
should be customized. This is discussed and demoed
[here](http://markus-beuckelmann.de/blog/customizing-nbconvert-pdf.html).
We encourage you to simply read the [doc of
nbconvert](https://nbconvert.readthedocs.io/en/latest/).
Instead of going directly through LaTeX and playing too much with the
`nbconvert` exporter, an other option consists in exporting to Markdown
and playing with [pandoc](https://pandoc.org/). Both approaches work,
it's rather a matter of taste.
**Windows**
Download and install MiKTeX from the [MiKTeX
webpage](https://miktex.org/download) by choosing the right operating
system. You will be prompted to install some specific packages when
exporting to pdf.
### • Improving notebook readability
Here are a few extensions that can ease your life:
- [Code
folding](https://stackoverflow.com/questions/33159518/collapse-cell-in-jupyter-notebook)
to improve readability when browsing the notebook.
shell
pip3 install jupyter_contrib_nbextensions
# jupyter contrib nbextension install --user # not done yet
- [Hiding code](https://github.com/kirbs-/hide_code) to improve
readability when exporting.
bash
sudo pip3 install hide_code
sudo jupyter-nbextension install --py hide_code
jupyter-nbextension enable --py hide_code
jupyter-serverextension enable --py hide_code
### • Interacting with GitLab and GitHub
To ease your experience, we added pull/push buttons that allow you to
commit and sync with GitLab. This development was specific to the MOOC
but inspired from a previous
proof of
concept](https://github.com/Lab41/sunny-side-up). We have recently
discovered that someone else developed about at the same time a
rather
generic version of this Jupyter
plugin](https://github.com/sat28/githubcommit). Otherwise, remember that
it is very easy to insert a shell cell in Jupyter in which you can
easily issue git commands. This is how we work most of the time.
This being said, you may have noticed that Jupyter keeps a perfect track
of the sequence in which cells have been run by updating the "output
index". This is a very good property from the reproducibility point of
view but depending on your usage, you may find it a bit painful when
committing. Some people have thus developed
specific git
hooks](https://gist.github.com/pbugnion/ea2797393033b54674af) to ignore
these numbers when committing Jupyter notebooks. There is a long an
interesting discussion about various options on
StackOverflow
https://stackoverflow.com/questions/18734739/using-ipython-notebooks-under-version-control
For those who use
JupyterLab
https://blog.jupyter.org/jupyterlab-is-ready-for-users-5a6f039b8906
rather than the plain Jupyter, a specific
JupyterLab git
plugin](https://github.com/jupyterlab/jupyterlab-git) has been developed
to offer a nice version control experience.
0893b72e
# -*- mode: org -*-
#+TITLE: Jupyter
#+TITLE: Jupyter
: tips and tricks, Installing and configuring
#+AUTHOR: Arnaud Legrand, Benoit Rospars, Konrad Hinsen
#+DATE: June, 2018
#+STARTUP: overview indent
