From 0f2c2ca1a7e44d9aff2b235a32d4373c9518775b Mon Sep 17 00:00:00 2001 From: FARHI Laurence Date: Wed, 3 Apr 2019 18:11:10 +0200 Subject: [PATCH] Erreur dans les liens --- module2/ressources/jupyter.org | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-) diff --git a/module2/ressources/jupyter.org b/module2/ressources/jupyter.org index 07fed2e..b667038 100644 --- a/module2/ressources/jupyter.org +++ b/module2/ressources/jupyter.org @@ -352,10 +352,10 @@ the MOOC but inspired from a previous [[https://github.com/Lab41/sunny-side-up][ recently discovered that someone else developed about at the same time a [[https://github.com/sat28/githubcommit][rather generic version of this Jupyter plugin]]. Otherwise, remember that it is very easy to insert a shell cell in Jupyter in which you -can easily issue git commands. This is how we work most of the time. If you choose this solution, *we strongly advise that you -follow [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/d132a854b0464ad29085cedaded23136][our tutorial on using git from RStudio]]* (/"RStudio et Gitlab"/ -). Before proceeding, make sure you also have followed the -*[[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/7508aece244548349424dfd61ee3ba85]["git/GitLab configuration" tutorial]]*. +can easily issue git commands. This is how we work most of the time. If you choose this solution, you will have to configure Git on your +computer. To do this, you can follow the video +[[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/7508aece244548349424dfd61ee3ba85][Configure git for Gitlab]] and read the document +[[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/module2/ressources/gitlab.org][Git and GitLab]]. This being said, you may have noticed that Jupyter keeps a perfect track of the sequence in which cells have been run by updating the -- 2.18.1
