From 16cd34ce4eae5cd1fd66679591804eb1e0175cdf Mon Sep 17 00:00:00 2001 From: Arnaud Legrand Date: Tue, 24 Jul 2018 11:05:36 +0200 Subject: [PATCH] Auto-generated files --- module2/ressources/emacs_orgmode.html | 173 +++++++++---------- module2/ressources/gitlab.html | 233 ++++++++++++++++++++++++++ module2/ressources/jupyter.html | 104 ++++++------ module2/ressources/rstudio.html | 174 +++---------------- 4 files changed, 400 insertions(+), 284 deletions(-) create mode 100644 module2/ressources/gitlab.html diff --git a/module2/ressources/emacs_orgmode.html b/module2/ressources/emacs_orgmode.html index 3e7b3fc..3c0fb64 100644 --- a/module2/ressources/emacs_orgmode.html +++ b/module2/ressources/emacs_orgmode.html @@ -4,43 +4,43 @@
Table of Contents
@@ -53,17 +53,22 @@ set up org-mode for this MOOC. You really should follow them carefully or you may have trouble doing the exercices later on.
Installing emacs, org-mode, ess, and auctex.
+The next sections provide information on how to install emacs. Before +proceeding, make sure you have read the "Git and GitLab" instructions. +
OS-specific installation procedure
Linux (Debian, Ubuntu)
We provide here only instructions for debian-based distributions. Feel free to contribute to this document to provide up-to-date information @@ -125,9 +130,9 @@ which is now deprecated.
Mac OS X
Mac OS X
  • Option 1: Install the .dmg file from Vincent Goulet: @@ -160,9 +165,9 @@ brew install wget
Windows
Windows
Install the .exe file from Vincent Goulet: https://vigou3.github.io/emacs-modified-windows/. It ships with recent @@ -176,9 +181,9 @@ versions:
TODO A simple "reproducible research" emacs configuration
There will be a mini video illustrating these steps at some point @@ -197,9 +202,9 @@ adding a few org-mode specific configurations.
Step 0: Backup and download our configuration
The procedure we propose will wipe your already existing custom emacs configuration if you already have one. You should thus beforehand make @@ -220,9 +225,9 @@ rr_org/journal.org
Step 1: Prepare your journal
Create an org/ directory in the top of your home:
@@ -239,9 +244,9 @@ should give a try.
Step 2: Set up Emacs configuration
Copy rr_org/init.el in your ~/.emacs.d/ directory.
@@ -253,9 +258,9 @@ configuration with the following command: emacs -q -l rr_org/init.el
Step 3: Check whether the installation is working or not
Open a new instance of Emacs and open a foo.org file. Copy the following lines in this file: @@ -286,9 +291,9 @@ is demonstrated in the -
Step 4: Open and play with your journal:
In step 1, you were told to create an journal in ~org/journal.org. First you probably want to make sure this file is @@ -299,9 +304,9 @@ forums.
TODO A stub of replicable article
There will be a mini video illustrating these steps at some point @@ -368,22 +373,22 @@ chunk of code when exporting.
Emacs Tips and tricks
Cheat-sheets
Cheat-sheets
Learning emacs and org-mode can be difficult as there is an inordinate amount of shortcuts. Many people have thus come up with cheat-sheats. Here is a selection in case it helps:
Emacs
Org-mode
Org-mode
Video tutorials
Video tutorials
For those of you who prefer video explanations, here is a Youtube channel with many step by step emacs tutorials.
Additional useful emacs packages
Company-mode
Company-mode
Company-mode is a text completion framework for Emacs. It allows to have smart completion in emacs for the most common languages. If you @@ -427,9 +432,9 @@ official webpage: http://company-mode.g
Magit
Magit
Magit is an emacs interface for Git. It is very powerfull and we use it on a daily basis but you should definitely understand what git does @@ -440,9 +445,9 @@ you should follow the instructions from here:
Other resources
Other resources
  • The compact Org-mode Guide
  • Many examples illustrating the use of different languages in org-mode
  • diff --git a/module2/ressources/gitlab.html b/module2/ressources/gitlab.html new file mode 100644 index 0000000..4d05a98 --- /dev/null +++ b/module2/ressources/gitlab.html @@ -0,0 +1,233 @@ +
    Git and GitLab
    +So far, you only used git via the web interface from the GitLab we +deployed for the MOOC. +
    +If you access this link from the FUN platform, you do not have to +authenticate and you can readily read and modify all your files. This +is very convenient but in most cases, you will want to have your own +local copy of the repository and you will have to synchronize your +local copy with the remote GitLab one. To propagate your +modifications, you will obviously have to authenticate yourself on +GitLab. This document describes the software you need to have +installed on your machine and how to handle authentification. Please +read these instructions carefully. +
    Installing Git
    Linux (debian, ubuntu)
    +We provide here only instructions for debian-based distributions. Feel +free to contribute to this document to provide up-to-date information +for other distributions (e.g., redhat, fedora). +
    +Run (as root): +
    apt-get update ; apt-get install git
    Mac OSX and Windows
    Authenticating on GitLab
    +There are two ways of authenticating and synchronizing your local +repository with GitLab: through HTTPS or through SSH. The first one +does not require any particular software installation on your machine +so this is what I recommend for this MOOC. Yet, I also describe the +second one as it is the one I prefer (once it is well configured, it +never asks me for any password anymore and I don't have to remember +anything). +
    Option 1: HTTPS
    Configuring your GitLab password
    +In this video, I explain how to change your password on our GitLab. +
    +Youtube Video +
    Making sure git remembers your password
    +My GitLab id is 3211ac4f2fb71deaeff9252764c368e7. Say I've configured +my password to be tototutu (what a weak password…) and I want to +clone my mooc-rr repository. If you clone your repos by simply pasting +the GitLab url (e.g., with the following command line) you will be +prompted for your login and your password every time you want to +propagate your local modifications. +
    git clone https://app-learninglab.inria.fr/gitlab/3211ac4f2fb71deaeff9252764c368e7/mooc-rr
    +This can be quite painful, which is why you can also provide them once +and for all when cloning, as follows: +
    git clone https://3211ac4f2fb71deaeff9252764c368e7:tototutu@app-learninglab.inria.fr/gitlab/3211ac4f2fb71deaeff9252764c368e7/mooc-rr
    +This is very convenient but there is one drawback to understand. This +means your password is stored, unencrypted on your hard drive. If +anyone ever gets an access to your machine, he will gain access rights +to all your repos, which can be problematic. This is why the really +good way to do this is to follow these instructions: +
    git config --global credential.helper cache                  # remember my password
    +git config --global credential.helper "cache --timeout=3600" # for one hour at most
    +With this setup, you will be prompted for your password but it will be +cached in memory and they will not be asked again before an hour. +
    Option 2: SSH
    +My prefered (although more technical) solution is to install SSH, to +create a pair or private/public keys, and to upload your SSH public +key on GitLab. This section provides with information on how to do +this. +
    Installing SSH
    • Linux (debian, ubuntu)
      +Run (as root): +
      apt-get update ; apt-get install openssh-client
    • Mac OSX
      +You do not have anything to do as it is installed by default. +
    • Windows
      +You should install the Putty client. Once it is installed, look for +the section on generating an SSH key. +
    Setting up SSH on Framagit
    +Here are all the official explanations on how to set up your SSH key +on GitLab. Alternatively, you may also want to have a look at this +video: +
    diff --git a/module2/ressources/jupyter.html b/module2/ressources/jupyter.html index b47162e..17bbf92 100644 --- a/module2/ressources/jupyter.html +++ b/module2/ressources/jupyter.html @@ -4,34 +4,34 @@
    Table of Contents
Additional Jupyter resources or tricks
Tips and tricks
Tips and tricks
The following webpage lists several Jupyter tricks (in particular, it illustrates many Ipython magic commands) that should improve your @@ -41,17 +41,23 @@ now).
Running R and Python in the same notebook
The best solution to this is to install rpy2. On my machine, I have -installed the python3-rpy2 debian package with apt-get install. An -other alternative consists in going through the python package manager -with +installed the python3-rpy2 debian package with apt-get install. E.g.,
pip install rpy2
sudo apt-get install python3-rpy2 python3-tzlocal
+An other (not really recommanded) alternative consists in going +through the python package manager with +
pip3 install rpy2
@@ -85,9 +91,9 @@ plot(df)
Exporting a notebook
Obviously, you can convert to html or pdf using the using the File > Download as > HTML (or PDF) menu option. This can also be done from @@ -114,13 +120,13 @@ taste.
Installing Jupyter on your own machine
Installing jupyter
Installing jupyter
Here is what you should install:
@@ -151,15 +157,15 @@ The ipython notebook can then be run with the following command:
Using R
Using R
If you want to use the R kernel in jupyter, follow these instructions.
-Alternatively, you can install rpy2 (see the Running R and Python in +Alternatively, you can install rpy2 (see the Running R and Python in the same notebook section).
@@ -168,9 +174,9 @@ the same notebook section).
Exporting your notebooks with latex
Here is what I had to install on my recent debian machine to make sure the notebook export via latex works: @@ -182,9 +188,9 @@ sudo apt-get install texlive-xetex
Interacting with gitlab
Here is our jupyter extension that allows to git push/pull from the notebooks: @@ -196,9 +202,9 @@ jupyter nbextension enable nb-git
Interesting extensions to improve notebook readability
Here are two interesting extensions that can improve readability:
@@ -225,9 +231,9 @@ jupyter-serverextension enable --py hide_code
Installing JupyterHub   Benoit
Benoit may give a few hints on this. diff --git a/module2/ressources/rstudio.html b/module2/ressources/rstudio.html index 5dc3d80..618c528 100644 --- a/module2/ressources/rstudio.html +++ b/module2/ressources/rstudio.html @@ -4,33 +4,15 @@
Table of Contents
@@ -45,9 +27,8 @@ may want to watch this video:
-The next sections provide information on how to install Rstudio, Git -(to interact with GitLab), and SSH (to avoid typing your password -every time you synchronize with GitLab). +The next sections provide information on how to install Rstudio. Before +proceeding, make sure you have read the "Git and GitLab" instructions.
@@ -58,7 +39,7 @@ on:
Installing Rstudio
Installing Rstudio
We provide here only instructions for debian-based distributions. Feel free to contribute to this document to provide up-to-date information @@ -103,9 +84,9 @@ for upgrading…
Installing R
Installing R
Beforehand, you need to install the R language and convenient packages by running (as root): @@ -138,9 +119,9 @@ to run (as root):
Installing rstudio
Installing rstudio
Rstudio is unfortunately not packaged within debian so the easiest is to download the corresponding debian package on the Rstudio webpage @@ -158,9 +139,9 @@ sudo apt-get update ; sudo apt-get -f install -
Mac OSX and Windows
Mac OSX and Windows
Some instructions on installing R and knitr must be missing. This @@ -184,113 +165,4 @@ install.packages("ggplot2")
Installing Git
-We provide here only instructions for debian-based distributions. Feel -free to contribute to this document to provide up-to-date information -for other distributions (e.g., redhat, fedora). -
-Run (as root): -
Mac OSX and Windows
Setting up SSH
-There are two ways of synchronizing your local repository with GitLab: -through HTTPS or through SSH. The first one does not require any -particular configuration but you will be regularly prompted for your -GitLab password, which can be quite tedious. To avoid this, the best -solution is to set install SSH, to create a pair or private/public -keys, and to upload your SSH public key on GitLab. This section -provides with information on how to do this. -
Installation
-Run (as root): -
Mac OSX
-You do not have anything to do as it is installed by default. -
Windows
-You should install the Putty client. Once it is installed, look for -the section on generating an SSH key. -
-Here are all the official explanations on how to set up your SSH key -on GitLab. Alternatively, you may also want to have a look at this -video: -
-- 2.18.1
