diff --git a/module2/ressources/jupyter.html b/module2/ressources/jupyter.html index 17bbf92dc51bfed31c604172eb4c252038745051..5652d8e063a24797a70ced3b5786f11b60e33023 100644 --- a/module2/ressources/jupyter.html +++ b/module2/ressources/jupyter.html @@ -4,34 +4,34 @@
Table of Contents
Additional Jupyter resources or tricks
Tips and tricks
Tips and tricks
The following webpage lists several Jupyter tricks (in particular, it illustrates many Ipython magic commands) that should improve your @@ -41,9 +41,9 @@ now).
Running R and Python in the same notebook
The best solution to this is to install rpy2. On my machine, I have installed the python3-rpy2 debian package with apt-get install. E.g., @@ -91,9 +91,9 @@ plot(df)
Exporting a notebook
Obviously, you can convert to html or pdf using the using the File > Download as > HTML (or PDF) menu option. This can also be done from @@ -120,13 +120,13 @@ taste.
Installing Jupyter on your own machine
Installing jupyter
Installing jupyter
Here is what you should install:
@@ -157,15 +157,15 @@ The ipython notebook can then be run with the following command:
Using R
Using R
If you want to use the R kernel in jupyter, follow these instructions.
-Alternatively, you can install rpy2 (see the Running R and Python in +Alternatively, you can install rpy2 (see the Running R and Python in the same notebook section).
@@ -174,9 +174,9 @@ the same notebook section).
Exporting your notebooks with latex
Here is what I had to install on my recent debian machine to make sure the notebook export via latex works: @@ -188,9 +188,9 @@ sudo apt-get install texlive-xetex
Interacting with gitlab
Interacting with GitLab
Here is our jupyter extension that allows to git push/pull from the notebooks: @@ -202,9 +202,9 @@ jupyter nbextension enable nb-git
Interesting extensions to improve notebook readability
Here are two interesting extensions that can improve readability:
@@ -231,9 +231,9 @@ jupyter-serverextension enable --py hide_code
Installing JupyterHub   Benoit
Benoit may give a few hints on this. diff --git a/module2/ressources/jupyter.org b/module2/ressources/jupyter.org index f165c473529d1e2503e4a809c3cdb6633c517b0f..24115e600f3cf62868887bd2e3447eca3b698dd4 100644 --- a/module2/ressources/jupyter.org +++ b/module2/ressources/jupyter.org @@ -91,7 +91,7 @@ the notebook export via latex works: sudo apt-get install wkhtmltopdf sudo apt-get install texlive-xetex #+end_src -** Interacting with gitlab +** Interacting with GitLab Here is our [[https://github.com/brospars/nb-git][jupyter extension that allows to git push/pull from the notebooks]]: #+begin_src shell :results output :exports both
