diff --git a/module2/ressources/jupyter.org b/module2/ressources/jupyter.org index 24115e600f3cf62868887bd2e3447eca3b698dd4..f244ec7ad815ffd30ac937198463685798c30382 100644 --- a/module2/ressources/jupyter.org +++ b/module2/ressources/jupyter.org @@ -59,31 +59,24 @@ and playing with [[https://pandoc.org/][pandoc]]. Both approaches work, it's rat taste. * Installing Jupyter on your own machine ** Installing jupyter -Here is what you should install: -#+begin_src shell :results output :exports both -sudo apt-get install jupyter-notebook python3-pip python3-matplotlib python3-numpy -#+end_src +Follow these instructions if you wish to have a similar Jupyter environment on you own machine. + +First, download and install [[https://www.anaconda.com/download/][Anaconda latest version]]. We use Anaconda version =4.5.4= on our server .\\ +Anaconda includes Python, the Jupyter Notebook, and other commonly used packages for scientific computing and data science. -On my machine, I got the version 5.4.1: +Then download the [[https://gist.github.com/brospars/4671d9013f0d99e1c961482dab533c57][mooc_rr environment file]] and create it using conda: #+begin_src shell :results output :exports both -jupyter-notebook --version -#+end_src +conda env create -f environment.yml -#+RESULTS: -: 5.4.1 +# Windows activate the environment +activate mooc_rr -The ipython notebook can then be run with the following command: -#+begin_src shell :results output :exports both -jupyter-notebook -#+end_src -** Using R -If you want to use the R kernel in jupyter, follow [[https://github.com/IRkernel/IRkernel#installation][these instructions]]. +# Linux and MacOS activate the environment +source activate mooc_rr -Alternatively, you can install =rpy2= (see the [[*Running R and Python in the same notebook][Running R and Python in -the same notebook]] section). -#+begin_src shell :results output :exports both -sudo apt-get python3-rpy2 +jupyter notebook #+end_src + ** Exporting your notebooks with latex Here is what I had to install on my recent debian machine to make sure the notebook export via latex works: @@ -91,13 +84,7 @@ the notebook export via latex works: sudo apt-get install wkhtmltopdf sudo apt-get install texlive-xetex #+end_src -** Interacting with GitLab -Here is our [[https://github.com/brospars/nb-git][jupyter extension that allows to git push/pull from the -notebooks]]: -#+begin_src shell :results output :exports both -jupyter nbextension install https://raw.githubusercontent.com/brospars/nb-git/master/nb-git.js -jupyter nbextension enable nb-git -#+end_src + ** Interesting extensions to improve notebook readability Here are two interesting extensions that can improve readability: - [[https://stackoverflow.com/questions/33159518/collapse-cell-in-jupyter-notebook][Code folding]] @@ -112,7 +99,3 @@ Here are two interesting extensions that can improve readability: jupyter-nbextension enable --py hide_code jupyter-serverextension enable --py hide_code #+end_src -* Installing JupyterHub :Benoit: -#+BEGIN_QUOTE -Benoit may give a few hints on this. -#+END_QUOTE
