From 1d2522adbd1a6366213deb2c790ff639ced967f4 Mon Sep 17 00:00:00 2001 From: Laurence Farhi Date: Tue, 4 Feb 2020 17:19:21 +0100 Subject: [PATCH] suppression Toc inutile --- module1/ressources/version_control_other.org | 6 +----- module1/ressources/version_control_other_fr.org | 6 +----- 2 files changed, 2 insertions(+), 10 deletions(-) diff --git a/module1/ressources/version_control_other.org b/module1/ressources/version_control_other.org index 0facf5e..ad4c411 100644 --- a/module1/ressources/version_control_other.org +++ b/module1/ressources/version_control_other.org @@ -3,7 +3,7 @@ #+OPTIONS: d:(not "LOGBOOK") date:t e:t email:nil f:t inline:t num:t #+OPTIONS: p:nil pri:nil prop:nil stat:t tags:t tasks:t tex:t #+OPTIONS: timestamp:t title:t toc:t todo:t |:t -#+TITLE: Notes (and codes) that are archived but can evolve with version control systems +#+TITLE: Version control with LibreOffice or DokuWiki #+AUTHOR: Christophe Pouzat #+EMAIL: christophe.pouzat@parisdescartes.fr #+LANGUAGE: en @@ -12,10 +12,6 @@ #+CREATOR: Emacs 26.1 (Org mode 9.1.9) #+STARTUP: indent -* Table of contents :TOC: -- [[#version-control-with-libreoffice-or-dokuwiki][Version control with LibreOffice or DokuWiki]] - -* Version control with LibreOffice or DokuWiki Modification tracking in files generated and managed by =LibreOffice= is briefly described on the [[https://help.libreoffice.org/Common/Recording_Changes][wiki page]] of this software. A [[https://help.libreoffice.org/Common/Navigating_Changes][table of contents]] of the pages dedicated to this subject is available. For DoKuWiki, the best is to check the [[https://www.dokuwiki.org/start?id=dokuwiki][wiki]]. diff --git a/module1/ressources/version_control_other_fr.org b/module1/ressources/version_control_other_fr.org index e38e0ba..6148190 100644 --- a/module1/ressources/version_control_other_fr.org +++ b/module1/ressources/version_control_other_fr.org @@ -3,7 +3,7 @@ #+OPTIONS: d:(not "LOGBOOK") date:t e:t email:nil f:t inline:t num:t #+OPTIONS: p:nil pri:nil prop:nil stat:t tags:t tasks:t tex:t #+OPTIONS: timestamp:t title:t toc:t todo:t |:t -#+TITLE: Pérénité et évolutivité avec la gestion de version +#+TITLE: Gestion de version dans LibreOffice ou dans DokuWiki #+DATE: <2019-03-26 mar.> #+AUTHOR: Christophe Pouzat #+EMAIL: christophe.pouzat@parisdescartes.fr @@ -13,10 +13,6 @@ #+CREATOR: Emacs 26.1 (Org mode 9.1.9) #+STARTUP: indent -* Table des matières :TOC: -- [[#gestion-de-version-dans-libreoffice-ou-dans-dokuwiki][Gestion de version dans LibreOffice ou dans DokuWiki]] - -* Gestion de version dans LibreOffice ou dans DokuWiki L'enregistrement des modifications des fichiers générés et gérés par =LibreOffice= est succinctement décrite sur la [[https://help.libreoffice.org/Common/Recording_Changes/fr][page du Wiki]] de ce logiciel. Une espèce de [[https://help.libreoffice.org/Common/Navigating_Changes/fr][sommaire]] des pages concernant la gestion des modifications est également disponible. Le livre [[https://framabook.org/libreoffice-cest-style/][LibreOffice, c’est stylé !]] téléchargeable gratuitement (et légalement) ne semble pas aborder la question. Sa version source est disponible sur [[https://framagit.org/Framatophe/DWL/][framagit]]= (un autre serveur type GitLab) et est écrite en… =markdown= ! Pour DokuWiki, le plus simple est de consulter le [[https://www.dokuwiki.org/fr:dokuwiki][Wiki]] écrit, cette fois au moins !, en DokuWiki. -- 2.18.1
